TVS
Surface Mount – 600W > P6KE
Series
Description
The P6KE series is designed specifically
to protect sensitive electronic equipment
from voltage transients induced by lightning
and other transient voltage events.
Features
◆ 600W peak pulsepower capability at 10 x 1000μs waveform, repetition rate (duty cycle):
0.01%
◆ Glass Passivated chip junction
◆ For surface mounted applications to optimize board space
◆ Low profile package
◆ Built-in strain relief
◆ Low incremental surge resistance
◆ Excellent clamping capability
◆ Plastic package has UL flammability classification 94V-O
◆ Fast response time: typically less than 1.0ps from 0 Volts to BV min
◆ Typical IR less than 5uA above 22V
◆ High temperature soldering: 260°C/40 seconds at terminals
◆ IEC-61000-4-2 ESD 15KV(Air),8KV(Contact)
◆ ESD protection of data lines in accordance with IEC 61000-4-2(IEC801-2)
◆ EFT protection of data lines in accordance with IEC61000-4-4(IEC801-4)
Applications
TVS devices are ideal for the protection of I/O Interfaces, VCC bus and other
vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic
applications.
Maximum Ratings and Electrical Characteristics
(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
PPPM
600
W
Power Dissipation on infinite heat sink at
TA=50℃
PD
6.5
W
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave Unidirectional
only(Note 3)
IFSM
300
A
Maximum
Instantaneous
Forward
Voltage at 100A for Unidirectional only
VF
3.5V/5.0
V
TJ, TSTG
-55 to +
150
Typical Thermal Resistance Junction to
Lead
RuJL
15
℃/W
Ambient
RuJA
75
℃/W
Peak Pulse Power Dissipation at
TA=25℃
by
10x1000μs
waveform
(Fig.2)(Note 1) (Note 2)
Operating
Junction
Temperature Range
and
Storage
Notes:
1. Non-repetitive current pulse, per Fig.3and derated above TA=25℃ per Fig. 2.
2. Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional
device only, duty cycle=4 per minute maximum.
BI- POLAR
UNI-POLAR
VRWM
VBR
VBR
IT
IR
Ipp
Vc
(V)
MIN(V)
MAX(V)
(mA)
(µA)
(A)
(v)
P6KE6.8CA
P6KE6.8A
5.80
6.45
7.14
10
1000
57.14
10.5
P6KE7.5CA
P6KE7.5A
6.40
7.13
7.88
10
500
53.10
11.3
P6KE8.2CA
P6KE8.2A
7.02
7.79
8.61
10
200
49.59
12.1
P6KE9.1CA
P6KE9.1A
7.78
8.65
9.50
1
50
44.78
13.4
P6KE10CA
P6KE10A
8.55
9.50
10.50
1
10
41.38
14.5
P6KE11CA
P6KE11A
9.40
10.50
11.60
1
1
38.46
15.6
P6KE12CA
P6KE12A
10.20
11.40
12.60
1
1
35.93
16.7
P6KE13CA
P6KE13A
11.10
12.40
13.70
1
1
32.97
18.2
P6KE15CA
P6KE15A
12.80
14.30
15.80
1
1
28.30
21.2
P6KE16CA
P6KE16A
13.60
15.20
16.80
1
1
26.67
22.5
P6KE18CA
P6KE18A
15.30
17.10
18.90
1
1
23.81
25.2
P6KE20CA
P6KE20A
17.10
19.00
21.00
1
1
21.66
27.7
P6KE22CA
P6KE22A
18.80
20.90
23.10
1
1
19.61
30.6
P6KE24CA
P6KE24A
20.50
22.80
25.20
1
1
18.07
33.2
P6KE27CA
P6KE27A
23.10
25.70
28.40
1
1
16.00
37.5
P6KE30CA
P6KE30A
25.60
28.50
31.50
1
1
14.49
41.4
P6KE33CA
P6KE33A
28.20
31.40
34.70
1
1
13.13
45.7
P6KE36CA
P6KE36A
30.80
34.20
37.80
1
1
12.02
49.9
P6KE39CA
P6KE39A
33.30
37.10
41.00
1
1
11.13
53.9
P6KE43CA
P6KE43A
36.80
40.90
45.20
1
1
10.12
59.3
P6KE47CA
P6KE47A
40.20
44.70
49.40
1
1
9.26
64.8
P6KE51CA
P6KE51A
43.60
48.5
53.60
1
1
8.56
70.1
P6KE56CA
P6KE56A
47.80
53.20
58.80
1
1
7.79
77.0
P6KE62CA
P6KE62A
53.00
58.90
65.10
1
1
7.06
85.0
@Ipp
VOLTAGE
MAXIMUM
CLAMPING
CURRENT
PEAK PULSE
@VRWM
LEAKAGE
REVERSE
CURRENT
TEST
T
VBR(V)MAX.@I
VOLTAGE
BREAKDOWN
VOLTAGE
STAND-OFF
PART NUMBER
REVERSE
VRWM
VBR
VBR
IT
IR
Ipp
Vc
(V)
MIN(V)
MAX(V)
(mA)
(µA)
(A)
(v)
P6KE68CA
P6KE68A
58.10
64.60
71.40
1
1
6.52
92.0
P6KE75CA
P6KE75A
64.10
71.30
78.80
1
1
5.83
103.0
P6KE82CA
P6KE82A
70.10
77.90
86.10
1
1
5.31
113.0
P6KE91CA
P6KE91A
77.80
86.50
95.50
1
1
4.80
125.0
P6KE100CA
P6KE100A
84.00
95.00
105.00
1
1
4.38
137.0
P6KE110CA
P6KE110A
94.00
105.00
116.00
1
1
3.95
152.0
P6KE120CA
P6KE120A
102.00
114.00
126.00
1
1
3.95
152.0
P6KE130CA
P6KE130A
111.00
124.00
137.00
1
1
3.35
179.0
P6KE150CA
P6KE150A
128.00
143.00
158.00
1
1
2.90
207.0
P6KE160CA
P6KE160A
136.00
152.00
168.00
1
1
2.74
219.0
P6KE170CA
P6KE170A
145.00
162.00
179.00
1
1
2.56
234.0
P6KE180CA
P6KE180A
154.00
171.00
189.00
1
1
2.44
246.0
P6KE200CA
P6KE200A
171.00
190.00
210.00
1
1
2.19
274.0
P6KE220CA
P6KE220A
185.00
209.00
231.00
1
1
1.83
328.0
P6KE300CA
P6KE300A
256.00
285.00
315.00
1
1
1.45
414.0
P6KE350CA
P6KE350A
300.00
332.00
368.00
1
1
1.24
482.0
P6KE400CA
P6KE400A
342.00
380.00
420.00
1
1
1.09
548.0
P6KE440CA
P6KE440A
376.00
418.00
462.00
1
1
1.00
602.0
P6KE480CA
P6KE480A
408.00
456.00
504.00
1
1
0.91
658.0
P6KE520CA
P6KE520A
442.00
494.00
546.00
1
1
0.86
710.0
P6KE530CA
P6KE530A
450.00
503.50
556.5
1
1
0.83
725.0
P6KE540CA
P6KE540A
459.00
513.00
567.00
1
1
0.81
740.0
P6KE550CA
P6KE550A
467.00
522.5
577.50
1
1
0.79
760.0
Notes:
For bidirectional type having VRWM of 20 volts and less, the IR limit is double.
For parts without A (VBR is ± 10% and VC is 5% higher than A parts
@Ipp
VOLTAGE
CLAMPING
MAXIMUM
CURRENT
PULSE
PEAK
@VRWM
LEAKAGE
REVERSE
CURRENT
TEST
@IT
VBR(V)MAX.
N VOLTAGE
BREAKDOW
VOLTAGE
UNI-POLAR
STAND-OFF
BI- POLAR
REVERSE
PART NUMBER
I-V Curve Characteristics
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Figu re 3 - Pulse Waveform
Figure 4 - Typical Junction Capacitance
Figure 5 - Steady State Power Dissipation
Figure 6 - Maximum Non-Repetitive
Derating Curve
Forward Surge Current Uni-Directional Only
Part
Numbering
P6KE
(1)
XXX
(2)
System
C A
(3)
(4)
(1)
(2)
(3)
(4)
SERIES.
VR VOLTAGE.
BI-DIRECTIONAL.
5% VOLTAGE TOLERANCE.
Product Dimensions
A
D
C
D
B
DO-15
Dimension
Inches
Millimeters
NOTE
MIN
MAX
MIN
MAX
A
0.230
0.300
5.80
7.60
B
0.104
0.140
2.60
3.60
Φ
C
0.026
0.034
0.70
0.90
Φ
D
1.000
25.40
Summary of Packing Options
Package Type
Description
Packing
Industry
Quantity
Standard
2000PCS
EIA-481-D
DO-15
Embossed Carrier Reel Pack
很抱歉,暂时无法提供与“P6KE33A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35758
- 100+0.28781
- 300+0.25293
- 2000+0.22677
- 4000+0.20584
- 10000+0.19538
