UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509
www.brainboxes.com // sales@brainboxes.com
SW-508
Industrial 8 Port Ethernet Switch 10/100
8 Port Unmanaged Ethernet Switch DIN Mountable
• 8 Port 10/100 Mbs Ethernet Switch
• Redundant dual power inputs: +5V to
+30V DC
• Compact design with integral DIN
mount
• No software required - Simply plug in
and connect
• Industrial temperature range
+5 to +30 Volt Power Input
enables the device to be run
from a standard car battery ideal for in vehicle applications
GB AEOF 00031/11
Non conducting polyamide
casing with removable
numbered power terminal for
easy wiring
Integral DIN mount and slim
design provides Ethernet
connection to multiple devices
SW-508
No software needed: Simply plug in
any ethernet cable
-40ºC to +80ºC/-40ºF to +176ºF
temperature range
All Ethernet ports are Auto MDI/
MDIX supporting straight through or
crossover Ethernet cables
Non-conducting polyamide case
Multiple ports in a small space
Integral DIN mount with ground
Automatic detection of data
transmission speed: 10 or 100 MBps
2k Byte maximum packet size –
improves the efficiency of bulk data
transfer and system performance
Connectors
Screw Terminals
Wire Thickness
Power Supply
Power Consumption
Power Supply input
Isolation
Environmental
Operating Temperature
Storage Temperature
Ambient Relative Humidity
Magjack LED Information
Link/Activity LED
Ethernet
Ethernet Port
Protection
Housing
Power consumption is optimised
based on the status of the link
device
Dual redundant power input:
+5VDC to +30VDC
Easy Wire Removable screw terminal block
3.5mm pitch, #22 - #14, 0.5mm2-2.5mm2 pin power supply
0.150 inch, 3.81mm, 20 pins, 12+8 screw terminals, #26 - #16 AWG,
0.14mm2-1.3mm2
1.5 Watts Max : 300 mAmps@+5VDC/50mAmps@+30VDC
Unregulated +5V to +30Volts DC, reverse polarity protection
1500VRMS Magnetic isolation from Ethernet
5 to 95% (non-condensing)
Solid green
Flashing Green
Connection established
Data communication
8 x RJ45 jack, 10/100Mhz autosensing, crossover auto sensing (Auto
MDIX)
1,500 Volts magnetic isolation between ports
IP-20 rated non-conducting polyamide case
SW-508
Power Terminal Pin Outs
Ethernet Ports x4 Pin Outs
PIN
FUNCTION
PIN
FUNCTION
1
-V
1
RD+ / TD+
2
+VA
2
RD- / TD-
3
+VB
3
TD+ / RD+
4
-V
4
NC
5
Functional Earth
5
NC
6
TD- / RD-
7
NC
8
NC
Lifetime Warranty and Support:
We can help with every aspect of your project, from getting you up and running to
custom application.
SW-508
Packaging Information
Packaging
Quick Start Guide
Device
Ethernet Switch 8 port
Packaged Weight
0.244 kg, 8.61 ounces
Packaged Dims
160x135x49 mm, 6.3x5.3x1.9 inches
GTIN Universal Code
837324003833
Approvals
Industry Approvals
Microsoft Certified Gold Partner, WEEE, RoHS, AEO (C-TPAT), CE, METL
Complies with UL 60950-1
Product Support
Warranty
Lifetime - online registration required
Support
Lifetime Web, Email and Phone Support from fully qualified, friendly staff
who work in and alongside the Product Development Team
Additional Information
OEM option
Available for bulk buy OEM
Made In
Manufactured in the UK by Brainboxes Winner 2005 European Electronics
Industry Awards ‘Manufacturer of the Year’
Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users.
More info:sales@brainboxes.com
Customisable
PW-600
PW-650
SW Range
Power supply with connectors
for UK, USA, EU and AUS mains
socket. ‘Tails’ are suitable for
connecting to screw terminal
blocks.
Power supply with USB
connector and prewired screw
terminal block. Suitable for use
with 5V USB ports.
Switch products available
in a range of formats and
specifications.
www.brainboxes.com
© Brainboxes 2020
BBSW280220
很抱歉,暂时无法提供与“SW-508”相匹配的价格&库存,您可以联系我们找货
