Page 1/6
Data sheet
P/N
313491xx
xx=number of poles
RP015xxVBLC Typ 349
2022/04/05
Version: S
Illustrations
Dimensional drawing
See enlarged drawings at the end of document
Product specification
• screw type terminal block, pluggable
• centerline 5.00 mm, direction of connection vertical 0°
• lift system, fittable without loss of poles
• color black
• wire entry codeable side perpendicular to plug direction
Data sheet
Page 2/6
RP015xxVBLC Typ 349
P/N
313491xx
xx=number of poles
2022/04/05
Version: S
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
0.5 Nm
min. number of poles
2
max. number of poles
24
Insulating material class
CTI 600
clearance/creepage dist.
3.6 mm
Protection category
IP20
Min. insul. strip length
8 mm
Rated current
12 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
160 V
400 V
400 V
Rated test voltage
2.5 kV
2.5 kV
2.5 kV
4.4 lb-in
Terminal data
rat.wiring solid AWGmax
0.08 mm² - 2.5 mm² / AWG 28 - AWG 12
rat.wiring strand.AWGmax
Approvals
extended wiring UL
V / A / AWG
approval UL - File No.
2.5 mm²
2 AWG 16-18, or 1 AWG 16 stranded with 1 AWG 18 solid, or 1
AWG 16 stranded with 1 AWG 18 stranded
300 / 16 / 28 - 12
E121004
320 V / 4 kV / 13.5 A
Material
insulating material
PA66
flammability class
V0
contact material
CuSn
Contact surface
Sn
terminal body thread
M3
terminal body material
CuZnPb
terminal body surface
Ni
screw thread
M3
screw material
8,8
screw surface
Zn Cr(VI)-frei/free
Data sheet
Page 3/6
RP015xxVBLC Typ 349
P/N
313491xx
xx=number of poles
2022/04/05
Version: S
Technical Data
Glow-Wire Flammability GWFI
960 °C acc. to IEC 60695-2-12
Glow-Wire Flammability GWIT
775 °C acc. to IEC 60695-2-13
REACh
compliant
REACh - substance (SVHC)
Lead / 7439-92-1
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Data sheet
Page 4/6
RP015xxVBLC Typ 349
P/N
313491xx
xx=number of poles
2022/04/05
Version: S
Accessories
P/N
Designation
700025-01-9
Coding star white with a group of 6 coding pins
Data sheet
Page 5/6
RP015xxVBLC Typ 349
P/N
313491xx
xx=number of poles
2022/04/05
Version: S
Counterpart
P/N
Designation
311761
PR065xxHBBN Typ 176
311771
PR065xxVBBN Typ 177
312701
PT175xxVGDN Typ 270
312741
PT165xxVGDN Typ 274
312761
PT165xxHGDN Typ 276
312781
PT105xxVGDN Typ 278
312801
PT105xxHGDN Typ 280
313191
PT115xxVBEC Typ 319
313201
PT115xxVBBN Typ 320
313291
PT115xxHBEC Typ 329
313301
PT115xxHBBN Typ 330
313371
PR075xxHBEL Typ 337
313381
PR075xxHBER Typ 338
314761
PR065xxHBEC Typ 476
314771
PR065xxVBEC Typ 477
Data sheet
RP015xxVBLC Typ 349
Page 6/6
P/N
313491xx
xx=number of poles
2022/04/05
Version: S
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 5 mm [0.197]
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“31349102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+5.94101100+0.72062
- 300+5.91325300+0.71725
- 500+5.91311500+0.71723
- 1500+5.912991500+0.71722
- 2500+5.912852500+0.71720
- 国内价格 香港价格
- 100+6.07603100+0.73699
- 300+6.04764300+0.73355
- 500+6.04751500+0.73353
- 1500+6.047371500+0.73352
- 2500+6.047242500+0.73350
