ES2ABG THRU ES2JBG
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V Forward Current –2 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.055g / 0.002oz
Top View
Marking Code: ES2A~ES2J
Simplified outline SMB and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES2AB
G
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
Maximum RMS voltage
V RMS
35
Maximum DC Blocking Voltage
V DC
50
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
60
A
Maximum Forward Voltage at 2 A
VF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
ES2EB
G
ES2GB
G
ES2JB
G
Units
150
200
300
400
600
V
70
105
140
210
280
420
V
100
150
200
300
400
600
V
1.25
1
1.68
V
IR
5
100
μA
Cj
40
pF
t rr
35
ns
RθJA
RθJC
60
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
ES2DB
G
ES2BB ES2CB
G
G
1 of 3
ES2ABG THRU ES2JBG
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
10
T J =25°C
1.0
ES2ABG~ES2DBG
ES2EBG/ES2GBG
ES2JBG
0.01
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
80
70
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
REV.08
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1.0
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
10
100
T J =25°C
1
0.1
0.001
Fig.5 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
60
% of PIV.VOLTS
2 of 3
100
ES2ABG THRU ES2JBG
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
REV.08
3 of 3
Type number
Marking code
ES2ABG
ES2A
ES2BBG
ES2B
ES2CBG
ES2C
ES2DBG
ES2D
ES2EBG
ES2E
ES2GBG
ES2G
ES2JBG
ES2J
很抱歉,暂时无法提供与“ES2ABG”相匹配的价格&库存,您可以联系我们找货
