RSFD1702C
Band3 FBAR Duplexer
Description
RSFD1702C is a high performance duplexer
designed for applications in LTE Band 3 (1710 –
1785 MHz UL, 1805 – 1880 MHz DL).
RSFD1702C is designed with Film Bulk Acoustic
Resonator (FBAR) technology, which provides
high-Q filters and meet requirements of low
insertion loss, high out-of-band attenuation, high
power handling and stringent linearity.
RSFD1702C uses chip scale packaging (CSP)
technology to assembly the filters into a molded
chip-on-board module with the footprint of 1.8mm
x 1.4mm and height of 0.61mm.
Functional Block Diagram (Top Thru View)
Ant
7
6
8
Features
Miniature Size
1.8 mm x 1.4 mm x 0.61 mm
Low insertion loss
o TX band, 1710-1785MHz: 1.5dB Typ.
o RX band, 1805-1880MHz: 1.8dB Typ.
High Isolation
o TX isolation: 60dB Typ.
o RX isolation: 58dB Typ.
Input power
o +29 dBm CW for 5000h @ +55 deg.C
Single-ended(SE) 50ohm receive & transmit ports
Storage Temperature:-40 to +85 deg.C
Environmental
Rx
Full implement with RoHS compliant
Lead Free (Pb free)
@ROFS Microsystem All Right Reserved
Datasheet, 2019
R3
1
5
4
2
3
L1
R1
L2
R2
Tx
L3
Reference Des.
Value
Description
R1
50ohm
R2
50ohm
R3
50ohm
L1
3nH
Ideal inductor
L2
7.5nH
Ideal inductor
L3
5.1nH
Ideal inductor
Manuf.
Pin Connection
1/8
No.
Function
1
Rx
3
Tx
6
Ant
2,4,5,7,8
Ground
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Electrical Specification
Transmit Port to Antenna Port
Parameter(Operable Temperature: -20 to +85 deg.C)
Min
Typ*
Max
Unit
Insertion Loss (1710~1785MHz)
1.5
Ripple(1710~1785MHz)
0.4
VSWR (1710~1785MHz,ANT)
1.3
1.5
VSWR (1710~1785MHz,TX)
1.3
1.5
(10~1565.4MHz)
30
45
dB
Wideband GPS (1565.4~1573.4MHz)
40
43
dB
Regular GPS (1573.4~1577.5MHz)
40
43
dB
Wideband GPS (1577.5~1585.4MHz)
40
44
dB
GLONASS (1597.6~1605.9MHz)
42
48
dB
(1605.9~1680MHz)
8
40
dB
RX Band (1805~1880MHz)
43
53
dB
Band1 RX (2110~2170MHz)
36
40
dB
ISM Band (2400~2500MHz)
42
46
dB
Band7 RX (2620~2690MHz)
36
40
dB
(3420~3570MHz, 2f0)
30
34
dB
(5130~5355MHz, 3f0)
15
17
dB
Min
Typ*
Max
Unit
Insertion Loss (1805~1880MHz)
1.8
3.5
dB
Ripple(1805~1880MHz)
0.5
1(1)
dB
VSWR(1805~1880MHz,ANT)
1.6
1.9
VSWR (1805~1880MHz,RX)
1.6
1.9
(10~1710MHz)
25
50
dB
TX Band (1710~1785MHz)
43
60
dB
(1920~6000MHz)
30
45
dB
44
50
dB
Band7 TX (2500~2570MHz)
47
51
dB
(2570~3515MHz)
50
55
dB
(3515~3760MHz, 2f0)
50
53
dB
ISM 5G (4900~5950MHz)
31
39
dB
(5205~5660MHz, 3f0)
32
36
dB
2.5
1(1)
dB
dB
Absolute Attenuation
Antenna Port to Receive Port
Datasheet, 2019
2/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Min
Typ*
Max
Unit
Transmit Port to Receive Port
Isolation
1710~1785MHz
50
60
dB
1805~1880MHz
50
58
dB
*Data is the integrated value of the linear s-parameter over indicated band.
(1) Data is the integrated Max value of the linear S-parameter over 5MHz.
Datasheet, 2019
3/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Typical Performance at Tc=25 deg.C
Figure1. TX-ANT Passband
Figure2. ANT-RX Passband
Figure3. TX Port VSWR
Figure4. RX Port VSWR
Figure5. ANT Port VSWR
Figure6. TX RX Isolation
Datasheet, 2019
4/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Figure7. TX-ANT
Figure8. ANT-RX
Figure9. TX-ANT Wideband
Figure10. ANT-RX Wideband
Figure11. TX Port (TX Passband) Smith Chart
Datasheet, 2019
Figure12. ANT Port (TX Passband) Smith Chart
5/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Figure13. RX Port (RX Passband) Smith Chart
Figure14. ANT Port (RX Passband) Smith Chart
Package Outline
1.80
±0.05
1.2
0.61
±0.06
0.625
ANT
(5)
Ground
Ground
1702
Ground
Ground
(7)
6 0.35 0.25
0.475
1.40
±0.05
0.95
(4)
(Ground)
RX
(6)
TX
(3)
Ground
0.05
0.25
(2)
0.30
(8)
0.35
(1)
0.10±0.05
4x
PIN1 Mark
0.75 0.35
Top view
Note:
1.
2.
3.
4.
5.
Side view
Dimension: mm
Dimensions nominal unless otherwise noted
Contact area are gold plated
Pad(1) (2) is single size, others are same size
1702 is product code
Bottom view
No.
Function
1
Rx
3
Tx
6
Ant
2,4,5,7,8
Ground
Order Information
P/N
Qty/Reel
Container
RSFD1702C
4000
7 inch Reel
Datasheet, 2019
6/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Packing
1. Tape Dimension
2. Reel Dimension
4000Pcs/Reel
Trailer tape
160-190
Components
80-120
Leader Cavity
400-560
Unit:mm
2.0±0.5
60
178
9.0±0.5
13.5max
13.0±0.5
Datasheet, 2019
7/8
www.rofsmicro.com
RSFD1702C
Band3 FBAR Duplexer
Recommended Reflow Profile
For more information, please contact: sales@rofsmicro.com
Notes:
The specification may be changed or the product had been discontinued, please check with our
sales or product engineer before order.
Datasheet, 2019
8/8
www.rofsmicro.com
很抱歉,暂时无法提供与“RSFD1702C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.27808
- 50+1.13033
- 150+1.06704
- 500+0.98810
- 2500+0.86303
