SS14HE
SS14HE
    JINGDAO(晶导微电子)
    SS14HE
SS14HE 数据手册
山东晶导微电子股份有限公司 SS14HE THRU SS120HE Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 40 to 200 V Forward Current - 1.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Simplified outline SOD-123HE and symbol MECHANICAL DATA • Case: SOD-123HE • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:15mg/0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS14HE SS16HE SS110HE SS115HE SS120HE Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 100 150 200 V Maximum RMS voltage V RMS 28 42 70 105 140 V Maximum DC Blocking Voltage V DC 40 60 100 150 200 V Maximum Average Forward Rectified Current I F(AV) 1.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 25 A Max Instantaneous Forward Voltage at 1 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 0.55 IR 0.5 20 0.3 15 mA Cj 60 40 pF 0.70 0.85 0.95 V RθJA 120 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 8X 8 mm copper pad areas. 2020.10 SOD-123HE-S-SS14HE~SS120HE-1A200V Page 1 of 4 山东晶导微电子股份有限公司 SS14HE THRU SS120HE Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 1.4 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 T J =75°C 10 2 T J =25°C 10 1 40V 60~200V 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance 500 T J =25°C Junction Capacitance ( pF) 20 10 1.0 40V 60V 100V 150~200V 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 20 40V 60~200V 10 1.8 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 200 Instaneous Forward Voltage (V) 10 100 Transient Thermal Impedance( °C /W) Peak Forward Surage Current (A) Instaneous Forward Current (A) Fig.3 Typical Forward Characteristic 200 100 10 Number of Cycles at 60Hz 2020.10 40 20 Percent of Rated Peak Reverse Voltage(%) 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 4 山东晶导微电子股份有限公司 SS14HE THRU SS120HE Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123HE ∠ALL ROUND C A ∠ALL ROUND HE E g Top View mil Bottom View A C D E e g L HE max 1.0 0.3 2.9 1.9 1.15 2.0 1.1 3.8 min 0.8 0.2 2.7 1.7 0.8 1.5 0.7 3.5 max 39 11.8 114 75 45 79 43 150 min 31 7.9 106 67 31 59 28 138 UNIT mm L e E D 12° The recommended mounting pad size 4.4 (173) Marking Type number SS14HE 1.3 (51) 1.4 (55) 2.6 (102) ∠ Marking code SK14 SS16HE SK16 SS110HE SK110 SS115HE SK115 SS120HE SK120 Unit: mm (mil) 2020.10 2010272A8 Page 3 of 4 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD SS14HE THRU SS120HE Important Notice and Disclaimer Jingdao Microelectronics reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. Jingdao Microelectronics makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Jingdao Microelectronics assume any liability for application assistance or customer product design. Jingdao Microelectronics does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Jingdao Microelectronics. Jingdao Microelectronics products are not authorized for use as critical components in life support devices or systems without express written approval of Jingdao Microelectronics. 2020.10 www.sdjingdao.com Page 4 of 4
SS14HE 价格&库存
很抱歉,暂时无法提供与“SS14HE”相匹配的价格&库存,您可以联系我们找货
