STE14D331K1EN0FSB0R0 数据手册
Metal Oxide Varistors-S Series (Standard)
Metal Oxide Varistors-S Series (Standard) Data
Sheet
Feature
■Wide operating voltage range from 18V to 1100V
■Operating Temperature: -40℃~ +105℃
■Storage Temperature: 15℃~35℃
Applications
■The over-voltage protection for transistors, IC, SCR and semiconductor switching components and
a variety of electronic, electrical equipment
■Surge absorption and over-voltage protection for household appliances
■Industrial electrical surge absorption
■Electrostatic discharge and noise signal cancellation
■Surge absorption of relays and solenoid valves
■Over-voltage protection for leakage switch
■The lightning protection and over-voltage protection for Telephone program-controlled switches and
communications equipment
Applicable Standard
Approval
Organization
Safety Standards
Certificate No.
5D: CQC07001020534
7D: CQC07001020533
China
GB/T10193
CQC
GB/T10194
10D: CQC07001020532
14D: CQC07001020531
20D: CQC07001020530
USA
Canada
UL
UL1449
E330837
Germany
VDE
IEC61051
40023049
Revision: 2018-04-29
1
Email: info@songtian.cn
Website: http://www.songtian-ste.com
Part Number Code
STE
10
Songtian
(STE)
D
471
Product
Categories
D: (Circular)
Core Diameter
05:5mm
07:7mm
10:10mm
14:14mm
20:20mm
Inner Management
K
Tolerance
K:±10%
E
N0
Pitch
B:5.0mm
E:7.5mm
D:10.0mm
Foot Type
1:Long straight
2:Outside Crimped
3:Short Straight
8:Vertical Crimped
Nominal Varistor Voltage
220:22V
471:470V
122:1200V
1
F
S
B
Package
B: Bulk
T:Tape
R
Environmental
Standard
R:RoHS
F:RoHS+Halogen-Free
Style
S: Standard
Lead Material
F: Tinned copper clad steel wire
C:Copper wire
Lead Length
S0~S9:1.0~1.9mm
X0~X9:2.0~2.9mm
A0~A9:3.0~3.9mm
B0~B9:4.0~4.9mm
C0~C9:5.0~5.9mm
D0~D9:6.0~6.9mm
E0~E9:7.0~7.9mm
2
Lead Length
F0~F9:8.0~8.9mm
G0~G9:9.0~9.9mm
H0~H9:10.0~10.9mm
J0~J9:11.0~11.9mm
K0~K9:12.0~12.9mm
L0~L9:13.0~13.9mm
M0~M9:14.0~14.9mm
Lead Length
M0~M9:14.0~14.9mm
N0:16~27.0mm(Bulk)
Crimped Lead Taped
N0:H0=16.5mm
P0:H0=17.0mm
Q0:H0=19.0mm
Straight Lead
Q0:20.0mm
Electrical Characteristics
5D-S Series
Part Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Peak Current
Rating(8/20μs)
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
ACrms
(V)
DCrms
(V)
V0.1mA
(V)
VC
(V)
IP
(A)
1 pulse
(A)
2 pulse
(A)
(J)
(W)
1KHz
(pF)
STE-05D180KS
11
14
18(15-21.6)
40
1
100
50
0.4
0.01
1400
STE-05D220KS
14
18
22(19.5-26)
48
1
100
50
0.5
0.01
1150
STE-05D270KS
17
22
27(24-31)
60
1
100
50
0.6
0.01
930
STE-05D330KS
33(29.5-36.5)
73
1
100
50
0.8
0.01
760
STE-05D390KS
25
31
39(35-43)
80
1
100
50
0.9
0.01
640
STE-05D470KS
30
38
47(42-52)
104
1
100
50
1.1
0.01
530
STE-05D560KS
35
45
56(50-62)
123
1
100
50
1.3
0.01
450
STE-05D680KS
40
56
68(61-75)
145
1
100
50
1.6
0.01
370
STE-05D820KS
50
65
82(74-90)
150
5
400
200
2.5
0.1
300
STE-05D101KS
60
85
100(90-110)
175
5
400
200
3.0
0.1
250
STE-05D121KS
75
100
120(108-132)
210
5
400
200
3.5
0.1
210
STE-05D151KS
95
125
150(135-165)
260
5
400
200
4.5
0.1
165
STE-05D181KS
115
150
180(162-198)
320
5
400
200
5.9
0.1
140
STE-05D201KS
130
170
200(180-220)
355
5
400
200
6.5
0.1
125
STE-05D221KS
140
180
220(198-242)
380
5
400
200
7.0
0.1
110
STE-05D241KS
150
200
240(216-264)
415
5
400
200
8.0
0.1
100
STE-05D271KS
175
225
270(243-297)
475
5
400
200
8.5
0.1
95
STE-05D301KS
190
250
300(270-330)
520
5
400
200
9.0
0.1
85
STE-05D331KS
210
275
330(297-363)
570
5
400
200
9.5
0.1
75
STE-05D361KS
230
300
360(324-396)
620
5
400
200
10.0
0.1
70
STE-05D391KS
250
320
390(351-429)
675
5
400
200
12.0
0.1
65
STE-05D431KS
275
350
430(387-473)
745
5
400
200
13.0
0.1
60
STE-05D471KS
300
385
470(423-517)
810
5
400
200
15.0
0.1
55
STE-05D511KS
320
415
510(459-561)
845
5
400
200
16.0
0.1
50
STE-05D561KS
350
460
560(504-616)
920
5
400
200
16.8
0.1
45
STE-05D621KS
385
505
620(558-682)
1025
5
400
200
17.7
0.1
40
STE-05D681KS
420
560
680(612-748)
1120
5
400
200
19.4
0.1
38
3
7D-S Series
Part Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Peak Current
Rating(8/20μs)
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
ACrms
(V)
DCrms
(V)
V1mA
(V)
VC
(V)
IP
(A)
1 pulse
(A)
2 pulse
(A)
(J)
(W)
1KHz
(pF)
STE-07D180KS
11
14
18(15-21.6)
36
2.5
250
125
0.9
0.02
2800
STE-07D220KS
14
18
22(19.5-26)
43
2.5
250
125
1.1
0.02
2300
STE-07D270KS
17
22
27(24-31)
53
2.5
250
125
1.4
0.02
1800
STE-07D330KS
33(29.5-36.5)
65
2.5
250
125
1.7
0.02
1500
STE-07D390KS
25
31
39(35-43)
77
2.5
250
125
2.1
0.02
1300
STE-07D470KS
30
38
47(42-52)
93
2.5
250
125
2.5
0.02
1100
STE-07D560KS
35
45
56(50-62)
110
2.5
250
125
3.1
0.02
890
STE-07D680KS
40
56
68(61-75)
135
2.5
250
125
3.6
0.02
740
STE-07D820KS
50
65
82(74-90)
135
10
1200
600
5.5
0.25
810
STE-07D101KS
60
85
100(90-110)
165
10
1200
600
6.5
0.25
700
STE-07D121KS
75
100
120(108-132)
200
10
1200
600
7.8
0.25
590
STE-07D151KS
95
125
150(135-165)
250
10
1200
600
9.7
0.25
500
STE-07D181KS
115
150
180(162-198)
300
10
1200
600
11.7
0.25
280
STE-07D201KS
130
170
200(180-220)
340
10
1200
600
13.0
0.25
200
STE-07D221KS
140
180
220(198-242)
360
10
1200
600
14.0
0.25
190
STE-07D241KS
150
200
240(216-264)
395
10
1200
600
15.0
0.25
170
STE-07D271KS
175
225
270(243-297)
455
10
1200
600
18.0
0.25
150
STE-07D301KS
190
250
300(270-330)
500
10
1200
600
20.0
0.25
140
STE-07D331KS
210
275
330(297-363)
550
10
1200
600
23.0
0.25
130
STE-07D361KS
230
300
360(324-396)
595
10
1200
600
24.0
0.25
130
STE-07D391KS
250
320
390(351-429)
650
10
1200
600
26.0
0.25
130
STE-07D431KS
275
350
430(387-473)
710
10
1200
600
28.0
0.25
120
STE-07D471KS
300
385
470(423-517)
775
10
1200
600
29.0
0.25
100
STE-07D511KS
320
415
510(459-561)
845
10
1200
600
31.0
0.25
90
STE-07D561KS
350
460
560(504-616)
925
10
1200
600
35.0
0.25
90
STE-07D621KS
385
505
620(558-682)
1025
10
1200
600
38.0
0.25
80
STE-07D681KS
420
560
680(612-748)
1120
10
1200
600
42.0
0.25
75
4
10D-S Series
Part Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Peak Current
Rating(8/20μs)
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
ACrms
(V)
DCrms
(V)
V1mA
(V)
VC
(V)
IP
(A)
1 pulse
(A)
2 pulse
(A)
(J)
(W)
1KHz
(pF)
STE-10D180KS
11
14
18(15-21.6)
36
5
500
250
2.1
0.05
5600
STE-10D220KS
14
18
22(19.5-26)
43
5
500
250
2.5
0.05
4500
STE-10D270KS
17
22
27(24-31)
53
5
500
250
3.0
0.05
3700
STE-10D330KS
33(29.5-36.5)
65
5
500
250
4.0
0.05
3000
STE-10D390KS
25
31
39(35-43)
77
5
500
250
4.6
0.05
2400
STE-10D470KS
30
38
47(42-52)
93
5
500
250
5.5
0.05
2100
STE-10D560KS
35
45
56(50-62)
110
5
500
250
7.0
0.05
1800
STE-10D680KS
40
56
68(61-75)
135
5
500
250
8.2
0.05
1500
STE-10D820KS
50
65
82(74-90)
135
25
2500
1250
12.0
0.4
2000
STE-10D101KS
60
85
100(90-110)
165
25
2500
1250
15.0
0.4
1700
STE-10D121KS
75
100
120(108-132)
200
25
2500
1250
18.0
0.4
1400
STE-10D151KS
95
125
150(135-165)
250
25
2500
1250
22.0
0.4
1100
STE-10D181KS
115
150
180(162-198)
300
25
2500
1250
27.0
0.4
560
STE-10D201KS
130
170
200(180-220)
340
25
2500
1250
30.0
0.4
430
STE-10D221KS
140
180
220(198-242)
360
25
2500
1250
32.0
0.4
410
STE-10D241KS
150
200
240(216-264)
395
25
2500
1250
35.0
0.4
380
STE-10D271KS
175
225
270(243-297)
455
25
2500
1250
37.0
0.4
350
STE-10D301KS
190
250
300(270-330)
500
25
2500
1250
40.0
0.4
330
STE-10D331KS
210
275
330(297-363)
550
25
2500
1250
43.0
0.4
300
STE-10D361KS
230
300
360(324-396)
595
25
2500
1250
47.0
0.4
300
STE-10D391KS
250
320
390(351-429)
650
25
2500
1250
60.0
0.4
300
STE-10D431KS
275
350
430(387-473)
710
25
2500
1250
65.0
0.4
270
STE-10D471KS
300
385
470(423-517)
775
25
2500
1250
67.0
0.4
230
STE-10D511KS
320
415
510(459-561)
845
25
2500
1250
69.0
0.4
210
STE-10D561KS
350
460
560(504-616)
925
25
2500
1250
70.0
0.4
180
STE-10D621KS
385
505
620(558-682)
1025
25
2500
1250
72.0
0.4
190
STE-10D681KS
420
560
680(612-748)
1120
25
2500
1250
75.0
0.4
170
STE-10D751KS
460
615
750(675-825)
1240
25
2500
1250
77.0
0.4
160
STE-10D781KS
485
640
780(702-858)
1290
25
2500
1250
80.0
0.4
125
STE-10D821KS
510
670
820(738-902)
1355
25
2500
1250
85.0
0.4
140
STE-10D911KS
550
745
910(819-1001)
1500
25
2500
1250
93.0
0.4
120
STE-10D102KS
625
825
1000(900-1100)
1650
25
2500
1250
102.0
0.4
110
STE-10D112KS
680
895
1100(990-1210)
1815
25
2500
1250
115.0
0.4
90
5
14D-S Series
Part Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Peak Current
Rating(8/20μs)
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
ACrms
(V)
DCrms
(V)
V1mA
(V)
VC
(V)
IP
(A)
1 pulse
(A)
2 pulse
(A)
(J)
(W)
1KHz
(pF)
STE-14D180KS
11
14
18(15-21.6)
36
10
1000
500
4.0
0.1
11100
STE-14D220KS
14
18
22(19.5-26)
43
10
1000
500
5.0
0.1
9100
STE-14D270KS
17
22
27(24-31)
53
10
1000
500
6.0
0.1
7400
STE-14D330KS
33(29.5-36.5)
65
10
1000
500
7.5
0.1
6100
STE-14D390KS
25
31
39(35-43)
77
10
1000
500
8.6
0.1
5100
STE-14D470KS
30
38
47(42-52)
93
10
1000
500
10.0
0.1
4300
STE-14D560KS
35
45
56(50-62)
110
10
1000
500
11.0
0.1
3600
STE-14D680KS
40
56
68(61-75)
135
10
1000
500
14.0
0.1
2900
STE-14D820KS
50
65
82(74-90)
135
50
4500
2500
22.0
0.6
3700
STE-14D101KS
60
85
100(90-110)
165
50
4500
2500
28.0
0.6
3200
STE-14D121KS
75
100
120(108-132)
200
50
4500
2500
32.0
0.6
2700
STE-14D151KS
95
125
150(135-165)
250
50
4500
2500
40.0
0.6
2200
STE-14D181KS
115
150
180(162-198)
300
50
4500
2500
50.0
0.6
1100
STE-14D201KS
130
170
200(180-220)
340
50
4500
2500
57.0
0.6
770
STE-14D221KS
140
180
220(198-242)
360
50
4500
2500
60.0
0.6
740
STE-14D241KS
150
200
240(216-264)
395
50
4500
2500
63.0
0.6
700
STE-14D271KS
175
225
270(243-297)
455
50
4500
2500
70.0
0.6
640
STE-14D301KS
190
250
300(270-330)
500
50
4500
2500
77.0
0.6
670
STE-14D331KS
210
275
330(297-363)
550
50
4500
2500
85.0
0.6
580
STE-14D361KS
230
300
360(324-396)
595
50
4500
2500
93.0
0.6
540
STE-14D391KS
250
320
390(351-429)
650
50
4500
2500
100
0.6
500
STE-14D431KS
275
350
430(387-473)
710
50
4500
2500
115
0.6
450
STE-14D471KS
300
385
470(423-517)
775
50
4500
2500
118
0.6
400
STE-14D511KS
320
415
510(459-561)
845
50
4500
2500
121
0.6
350
STE-14D561KS
350
460
560(504-616)
925
50
4500
2500
125
0.6
360
STE-14D621KS
385
505
620(558-682)
1025
50
4500
2500
128
0.6
330
STE-14D681KS
420
560
680(612-748)
1120
50
4500
2500
130
0.6
320
STE-14D751KS
460
615
750(675-825)
1240
50
4500
2500
143
0.6
310
STE-14D781KS
485
640
780(702-858)
1290
50
4500
2500
148
0.6
260
STE-14D821KS
510
670
820(738-902)
1355
50
4500
2500
157
0.6
280
STE-14D911KS
550
745
910(819-1001)
1500
50
4500
2500
175
0.6
250
STE-14D102KS
625
825
1000(900-1100)
1650
50
4500
2500
190
0.6
230
STE-14D112KS
680
895
1100(990-1210)
1815
50
4500
2500
213
0.6
180
6
20D-S Series
Part Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
2 pulse
(A)
(J)
(W)
1KHz
(pF)
Peak Current
Rating(8/20μs)
ACrms
(V)
DCrms
(V)
V1mA
(V)
VC
(V)
IP
(A)
1 pulse
(A)
STE-20D180KS
11
14
18(15-21.6)
36
1000
11
0.2
28500
STE-20D220KS
14
18
22(19.5-26)
43
1000
14
0.2
18500
STE-20D270KS
17
22
27(24-31)
53
1000
16
0.2
13000
STE-20D330KS
33(29.5-36.5)
65
1000
23
0.2
11500
STE-20D390KS
25
31
39(35-43)
77
1000
26
0.2
8500
STE-20D470KS
30
38
47(42-52)
93
1000
30
0.2
7400
STE-20D560KS
35
45
56(50-62)
110
1000
38
0.2
6500
STE-20D680KS
40
56
68(61-75)
135
1000
41
0.2
5800
STE-20D820KS
50
65
82(74-90)
135
100
6500
4500
45
1.0
7500
STE-20D101KS
60
85
100(90-110)
165
100
6500
4500
50
1.0
6500
STE-20D121KS
75
100
120(108-132)
200
100
6500
4500
55
1.0
5500
STE-20D151KS
95
125
150(135-165)
250
100
6500
4500
70
1.0
4500
STE-20D181KS
115
150
180(162-198)
300
100
6500
4500
85
1.0
2200
STE-20D201KS
130
170
200(180-220)
340
100
6500
4500
95
1.0
1700
STE-20D221KS
140
180
220(198-242)
360
100
6500
4500
100
1.0
1600
STE-20D241KS
150
200
240(216-264)
395
100
6500
4500
108
1.0
1500
STE-20D271KS
175
225
270(243-297)
455
100
6500
4500
127
1.0
1300
STE-20D301KS
190
250
300(270-330)
500
100
6500
4500
136
1.0
1300
STE-20D331KS
210
275
330(297-363)
550
100
6500
4500
150
1.0
1100
STE-20D361KS
230
300
360(324-396)
595
100
6500
4500
163
1.0
1100
STE-20D391KS
250
320
390(351-429)
650
100
6500
4500
180
1.0
1100
STE-20D431KS
275
350
430(387-473)
710
100
6500
4500
190
1.0
1000
STE-20D471KS
300
385
470(423-517)
775
100
6500
4500
204
1.0
900
STE-20D511KS
320
415
510(459-561)
845
100
6500
4500
210
1.0
800
STE-20D561KS
350
460
560(504-616)
925
100
6500
4500
215
1.0
710
STE-20D621KS
385
505
620(558-682)
1025
100
6500
4500
224
1.0
700
STE-20D681KS
420
560
680(612-748)
1120
100
6500
4500
230
1.0
650
STE-20D751KS
460
615
750(675-825)
1240
100
6500
4500
255
1.0
600
STE-20D781KS
485
640
780(702-858)
1290
100
6500
4500
265
1.0
510
STE-20D821KS
510
670
820(738-902)
1355
100
6500
4500
282
1.0
530
STE-20D911KS
550
745
910(819-1001)
1500
100
6500
4500
310
1.0
500
STE-20D102KS
625
825
1000(900-1100)
1650
100
6500
4500
342
1.0
450
STE-20D112KS
680
895
1100(990-1210)
1815
100
6500
4500
383
1.0
360
7
Dimensions (mm) and Approval
5D-S Series
Size (mm)
Part No.
cUL
(Canada)
D Max.
T Max.
F±0.8
d±0.05
STE-05D180KS
7.5
3.0
5.0
0.5
STE-05D220KS
7.5
3.5
5.0
0.5
STE-05D270KS
7.5
3.5
5.0
0.5
STE-05D330KS
7.5
3.5
5.0
0.5
STE-05D390KS
7.5
3.5
5.0
0.5
STE-05D470KS
7.5
4.0
5.0
0.5
STE-05D560KS
7.5
4.0
5.0
0.5
STE-05D680KS
7.5
4.5
5.0
0.5
STE-05D820KS
7.5
3.5
5.0
0.5
STE-05D101KS
7.5
3.5
5.0
0.5
STE-05D121KS
7.5
3.5
5.0
0.5
STE-05D151KS
7.5
3.5
5.0
0.5
STE-05D181KS
7.5
4.0
5.0
0.5
STE-05D201KS
7.5
4.0
5.0
0.5
STE-05D221KS
7.5
4.0
5.0
0.5
STE-05D241KS
7.5
4.0
5.0
0.5
STE-05D271KS
7.5
4.0
5.0
0.5
STE-05D301KS
7.5
4.5
5.0
0.5
STE-05D331KS
7.5
4.5
5.0
0.5
STE-05D361KS
7.5
4.5
5.0
0.5
STE-05D391KS
7.5
5.0
5.0
0.5
STE-05D431KS
7.5
4.5
5.0
0.5
STE-05D471KS
7.5
4.5
5.0
0.5
STE-05D511KS
7.5
5.0
5.0
0.5
STE-05D561KS
7.5
5.0
5.0
0.5
STE-05D621KS
7.5
5.0
5.0
0.5
STE-05D681KS
7.5
5.5
5.0
0.5
8
CQC
Approval
UL
VDE
(USA)
7D-S Series
Size (mm)
Part No.
Approval
UL
(USA)
cUL
(Canada)
0.5
5.0
0.5
3.5
5.0
0.5
9.0
3.5
5.0
0.5
STE-07D390KS
9.0
3.5
5.0
0.5
STE-07D470KS
9.0
4.0
5.0
0.5
STE-07D560KS
9.0
4.0
5.0
0.5
STE-07D680KS
9.0
4.5
5.0
0.5
STE-07D820KS
9.0
3.5
5.0
0.5
STE-07D101KS
9.0
3.5
5.0
0.5
STE-07D121KS
9.0
3.5
5.0
0.5
STE-07D151KS
9.0
3.5
5.0
0.5
STE-07D181KS
9.0
4.0
5.0
0.5
STE-07D201KS
9.0
4.0
5.0
0.5
STE-07D221KS
9.0
4.5
5.0
0.5
STE-07D241KS
9.0
4.0
5.0
0.5
STE-07D271KS
9.0
4.0
5.0
0.5
STE-07D301KS
9.0
4.5
5.0
0.5
STE-07D331KS
9.0
4.5
5.0
0.5
STE-07D361KS
9.0
4.5
5.0
0.5
STE-07D391KS
9.0
5.0
5.0
0.5
STE-07D431KS
9.0
4.5
5.0
0.5
STE-07D471KS
9.0
4.5
5.0
0.5
STE-07D511KS
9.0
5.0
5.0
0.5
STE-07D561KS
9.0
5.0
5.0
0.5
STE-07D621KS
9.0
5.0
5.0
0.5
STE-07D681KS
9.0
5.5
5.0
0.5
D Max.
T Max.
F±0.8
d±0.05
STE-07D180KS
9.0
3.5
5.0
STE-07D220KS
9.0
3.5
STE-07D270KS
9.0
STE-07D330KS
9
CQC
VDE
10D-S Series
Size (mm)
Part No.
Approval
UL
(USA)
cUL
(Canada)
0.7
7.5
0.7
4.0
7.5
0.7
12.5
4.0
7.5
0.7
STE-10D390KS
12.5
4.0
7.5
0.7
STE-10D470KS
12.5
4.0
7.5
0.7
STE-10D560KS
12.5
4.5
7.5
0.7
STE-10D680KS
12.5
5.0
7.5
0.7
STE-10D820KS
12.5
4.0
7.5
0.7
STE-10D101KS
12.5
4.0
7.5
0.7
STE-10D121KS
12.5
4.0
7.5
0.7
STE-10D151KS
12.5
4.5
7.5
0.7
STE-10D181KS
12.5
4.5
7.5
0.7
STE-10D201KS
12.5
4.5
7.5
0.7
STE-10D221KS
12.5
4.5
7.5
0.7
STE-10D241KS
12.5
4.5
7.5
0.7
STE-10D271KS
12.5
4.5
7.5
0.7
STE-10D301KS
12.5
5.0
7.5
0.7
STE-10D331KS
12.5
5.0
7.5
0.7
STE-10D361KS
12.5
5.0
7.5
0.7
STE-10D391KS
12.5
5.0
7.5
0.7
STE-10D431KS
12.5
5.0
7.5
0.7
STE-10D471KS
12.5
5.0
7.5
0.7
STE-10D511KS
12.5
5.5
7.5
0.7
STE-10D561KS
12.5
5.5
7.5
0.7
STE-10D621KS
12.5
5.5
7.5
0.7
STE-10D681KS
12.5
6.0
7.5
0.7
STE-10D751KS
12.5
6.0
7.5
0.7
STE-10D781KS
12.5
6.5
7.5
0.7
STE-10D821KS
12.5
6.5
7.5
0.7
STE-10D911KS
12.5
7.0
7.5
0.7
STE-10D102KS
12.5
7.5
7.5
0.7
STE-10D112KS
12.5
7.5
7.5
0.7
D Max.
T Max.
F±0.8
d±0.05
STE-10D180KS
12.5
3.5
7.5
STE-10D220KS
12.5
3.5
STE-10D270KS
12.5
STE-10D330KS
10
CQC
VDE
14D-S Series
Size (mm)
Part No.
Approval
UL
(USA)
cUL
(Canada)
0.7
7.5
0.7
4.0
7.5
0.7
16.5
4.0
7.5
0.7
STE-14D390KS
16.5
4.0
7.5
0.7
STE-14D470KS
16.5
4.0
7.5
0.7
STE-14D560KS
16.5
4.5
7.5
0.7
STE-14D680KS
16.5
5.0
7.5
0.7
STE-14D820KS
16.5
4.0
7.5
0.7
STE-14D101KS
16.5
4.0
7.5
0.7
STE-14D121KS
16.5
4.0
7.5
0.7
STE-14D151KS
16.5
4.5
7.5
0.7
STE-14D181KS
16.5
4.5
7.5
0.7
STE-14D201KS
16.5
4.5
7.5
0.7
STE-14D221KS
16.5
4.5
7.5
0.7
STE-14D241KS
16.5
4.5
7.5
0.7
STE-14D271KS
16.5
4.5
7.5
0.7
STE-14D301KS
16.5
5.0
7.5
0.7
STE-14D331KS
16.5
5.0
7.5
0.7
STE-14D361KS
16.5
5.0
7.5
0.7
STE-14D391KS
16.5
5.0
7.5
0.7
STE-14D431KS
16.5
5.0
7.5
0.7
STE-14D471KS
16.5
5.0
7.5
0.7
STE-14D511KS
16.5
5.5
7.5
0.7
STE-14D561KS
16.5
5.5
7.5
0.7
STE-14D621KS
16.5
5.5
7.5
0.7
STE-14D681KS
16.5
6.0
7.5
0.7
STE-14D751KS
16.5
6.0
7.5
0.7
STE-14D781KS
16.5
6.5
7.5
0.7
STE-14D821KS
16.5
6.5
7.5
0.7
STE-14D911KS
16.5
7.0
7.5
0.7
STE-14D102KS
16.5
7.5
7.5
0.7
STE-14D112KS
16.5
7.5
7.5
0.7
D Max.
T Max.
F±0.8
d±0.05
STE-14D180KS
16.5
3.5
7.5
STE-14D220KS
16.5
3.5
STE-14D270KS
16.5
STE-14D330KS
11
CQC
VDE
20D-S Series
Size (mm)
Part No.
Approval
d±0.05
D Max.
T Max.
F±0.8
STE-20D180KS
23.0
4.0
STE-20D220KS
23.0
STE-20D270KS
CQC
VDE
UL
(USA)
cUL
(Canada)
Straight lead
Crimped lead
10.0
1.0
0.7
4.0
10.0
1.0
0.7
23.0
4.5
10.0
1.0
0.7
STE-20D330KS
23.0
4.5
10.0
1.0
0.7
STE-20D390KS
23.0
4.5
10.0
1.0
0.7
STE-20D470KS
23.0
5.0
10.0
1.0
0.7
STE-20D560KS
23.0
5.0
10.0
1.0
0.7
STE-20D680KS
23.0
5.5
10.0
1.0
0.7
STE-20D820KS
23.0
4.0
10.0
1.0
0.7
STE-20D101KS
23.0
4.5
10.0
1.0
0.7
STE-20D121KS
23.0
4.5
10.0
1.0
0.7
STE-20D151KS
23.0
5.0
10.0
1.0
0.7
STE-20D181KS
23.0
5.0
10.0
1.0
0.7
STE-20D201KS
23.0
5.0
10.0
1.0
0.7
STE-20D221KS
23.0
5.5
10.0
1.0
0.7
STE-20D241KS
23.0
5.0
10.0
1.0
0.7
STE-20D271KS
23.0
5.0
10.0
1.0
0.7
STE-20D301KS
23.0
5.5
10.0
1.0
0.7
STE-20D331KS
23.0
5.5
10.0
1.0
0.7
STE-20D361KS
23.0
5.5
10.0
1.0
0.7
STE-20D391KS
23.0
5.5
10.0
1.0
0.7
STE-20D431KS
23.0
5.5
10.0
1.0
0.7
STE-20D471KS
23.0
5.5
10.0
1.0
0.7
STE-20D511KS
23.0
6.0
10.0
1.0
0.7
STE-20D561KS
23.0
6.0
10.0
1.0
0.7
STE-20D621KS
23.0
6.5
10.0
1.0
0.7
STE-20D681KS
23.0
6.5
10.0
1.0
0.7
STE-20D751KS
23.0
7.0
10.0
1.0
0.7
STE-20D781KS
23.0
7.0
10.0
1.0
0.7
STE-20D821KS
23.0
7.0
10.0
1.0
0.7
STE-20D911KS
23.0
7.5
10.0
1.0
0.7
STE-20D102KS
23.0
8.0
10.0
1.0
0.7
STE-20D112KS
23.0
8.0
10.0
1.0
0.7
12
Lead Configuration
Lead Length
L (mm)
Coating Lead Length
C (mm)
Height
H (mm)
Long Straight
16.0 min
3.0 Max
Short Straight
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
3.0 Max
Outside Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Not exceed the bend point
5.5mm
Max
Vertical Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
4.5mm
Max
Lead Style
Drawing
13
Taping And Dimensions (mm)
Fig.1
Fig.2
Figure
Fig.1 (P=5.0)
Symbol
P=5.0
P=7.5
P=10.0
Po
12.7±0.3
12.7±0.3
12.7±0.3
P
12.7±1.0
25.4±1.0
25.4±1.0
P1
3.85±0.7
8.95±0.7
7.7±0.7
P2
6.35±1.3
12.7±1.3
12.7±1.3
F
5±0.8
7.5±0.8
10.0±0.8
Δh
0±2.0
0±2.0
0±2.0
W
18.0+1.5/-1.0
18.0 +1.5/-1.0
18.0 +1.5/-1.0
Wo
10.5 Max
10.5 Max
10.5 Max
W1
9.0+0.75/-0.5
9.0+0.75/-0.5
9.0+0.75/-0.5
W2
3.0 Max
3.0 Max
3.0 Max
Do
4.0±0.2
4.0±0.2
4.0±0.2
H
20+1.5/-1.0
20+1.5/-1.0
20+1.5/-1.0
16.5&17.0&19.0
16.5&17.0&19.0
16.5&17.0&19.0
Ho
+1.5/-1.0
+1.5/-1.0
+1.5/-1.0
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
11.0
Max
9.0
Max
11.0
Max
9.0
Max
11.0
Max
9.0
Max
L
Fig.2 (P=7.5 & 10)
t1
0.5±0.2
0.5±0.2
0.5±0.2
t2
1.7 Max
1.7 Max
1.7 Max
14
STE14D331K1EN0FSB0R0 价格&库存
很抱歉,暂时无法提供与“STE14D331K1EN0FSB0R0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.77362
- 50+0.63574
- 250+0.51019
