VDR-07D330K
VDR-07D330K
    VDRSAS(嵩隆)
    插件
    VDR-07D330K
VDR-07D330K 数据手册
VDR Varistor 07D SERIES 嵩隆力上 SONGLONG LISHANG METAL OXIDE VARISTOR – 07D SERIES FEATURES * Wide operating voltage (V1mA) range from 18V to 820V. * Fast responding to transient over-voltage. * Large absorbing transient energy capability. * Low clamping ratio and no follow-on current. * Meets MSL level 1, per J-STD-020 * Safety number : CUL- E317616 VDE- 40028836 CQC-12001076478 ISO9001-2018 APPLICATION *Transistor, Diode, IC, Thyristor or Triac semiconductor protection. * Surge protection in consumer electronics. * Surge protection in industrial electronics. * Surge protection in electronic home appliances, gas and petroleum appliances. * Relay and electromagnetic valve surge absorption. General Characteristics Definition *Operating Temperature: (-40 ℃ ~ +85 ℃ ) o & ( -40 ℃ ~ +125 ℃) o *Storage Temperature: (-40 C ~ +125 C) *Working Surface Temperature: +115 C > 100M Ω Flame-Retardant to UL 94 V-0 o *Insulation Resistance: *Coating (Epoxy Resin): Material *Coating: Epoxy Resin *Lead Wire: The Copper Wire *Electrode: *Disk: Silver Solder Zinc Oxide PART NUMBER CODE VDR Brand Mark □□ D □□□ K Element Diameter Type: D: Disk , S: Square Varistor Voltage Tolerance : K±10%, L±15% □ □□ Sapce:Straight 85℃ H:125℃ C:Crimped , Y:Y kink I:Inner,Tor G :Plaster Lead Form : Short leg : NO : □.□ E: 4KV2KA S:6KV/3KA Y:10KV/5KA =ABCDEF Times □ J:High Surge & High Energy PH=Ultra Surge Taping : TA : Ammo, TR : Reel Page-1 VDR Varistor 07D SERIES 嵩隆力上 SONGLONG LISHANG Part No. Part No. T Max. D Max. VDR-07D180L VDR-07D220K VDR-07D270K VDR-07D330K VDR-07D390K VDR-07D470K VDR-07D560K VDR-07D680K VDR-07D820K VDR-07D101K VDR-07D121K VDR-07D151K VDR-07D181K VDR-07D201K VDR-07D221K VDR-07D241K VDR-07D271K VDR-07D301K VDR-07D331K VDR-07D361K VDR-07D391K VDR-07D431K VDR-07D471K VDR-07D511K VDR-07D561K VDR-07D621K VDR-07D681K VDR-07D751K VDR-07D781K VDR-07D821K VDR-07D180LJ VDR-07D220KJ VDR-07D270KJ VDR-07D330KJ VDR-07D390KJ VDR-07D470KJ VDR-07D560KJ VDR-07D680KJ VDR-07D820KJ VDR-07D101KJ VDR-07D121KJ VDR-07D151KJ VDR-07D181KJ VDR-07D201KJ VDR-07D221KJ VDR-07D241KJ VDR-07D271KJ VDR-07D301KJ VDR-07D331KJ VDR-07D361KJ VDR-07D391KJ VDR-07D431KJ VDR-07D471KJ VDR-07D511KJ VDR-07D561KJ VDR-07D621KJ VDR-07D681KJ VDR-07D751KJ VDR-07D781KJ VDR-07D821KJ 4.5 4.6 4.7 4.9 4.8 4.9 5.0 5.2 4.1 4.3 4.5 4.8 4.3 4.4 4.5 4.6 4.9 5.0 5.1 5.2 5.4 5.7 6.0 6.2 6.5 7.1 7.3 7.5 7.7 8.0 9.0 H Max. S I/C/Y 11.0 14.0 L min. 20.0 F ±0.8 d + 0.05 5.0 0.6 Page-2 VDR Varistor 07D SERIES 嵩隆力上 SONGLONG LISHANG ELECTRICAL CHARACTERISTIC Part Number Standard High Surge Maximum Varistor Withstanding Energy Allowable Voltage Maximum Clamping Voltage Voltage Surge Current 10/1000μS AC (V) DC (V) V1mA(V) IP(A) VC(V) I(A) I(A) I(A) I(A) Standard High Surge Standard High Surge Typical Rated Capacitance Powe (Reference) (W) @1KHzPF 07D180L 07D180LJ 11 14 18(15.0~21.6) 2.5 36 250 500 0.9 2.0 0.02 2800 07D220K 07D220KJ 14 18 22(19.5~26.0) 2.5 43 250 500 1.1 2.4 0.02 2300 07D270K 07D270KJ 17 22 27(24-31) 2.5 53 250 500 1.4 3.0 0.02 1800 07D330K 07D330KJ 20 26 33(29.5~36.5) 2.5 65 250 500 1.7 3.5 0.02 1500 07D390K 07D390KJ 25 31 39(35 ~43) 2.5 77 250 500 2.1 4.0 0.02 1300 07D470K 07D470KJ 30 38 47(42~52) 2.5 93 250 500 2.5 5.0 0.02 1100 07D560K 07D560KJ 35 45 56(50~62) 2.5 110 250 500 3.1 6.0 0.02 890 07D680K 07D680KJ 40 56 68(61~75) 2.5 135 250 500 3.6 7.0 0.02 740 07D820K 07D820KJ 50 65 82(74~90) 10 135 1200 1750 5.5 10.0 0.25 600 07D101K 07D101KJ 60 85 100(90~110) 10 165 1200 1750 6.5 12.0 0.25 500 07D121K 07D121KJ 75 100 120(108~132) 10 200 1200 1750 7.8 12.0 0.25 420 07D151K 07D151KJ 95 125 150(135~165) 10 250 1200 1750 9.7 13.0 0.25 330 07D181K 07D181KJ 115 150 180(162~198) 10 300 1200 1750 11.7 16.0 0.25 280 07D201K 07D201KJ 130 170 200(185~225) 10 330 1200 1750 13.0 17.0 0.25 250 07D221K 07D221KJ 140 180 220(198~242) 10 360 1200 1750 14.0 19.0 0.25 230 07D241K 07D241KJ 150 200 240(216~264) 10 395 1200 1750 15.0 21.0 0.25 210 07D271K 07D271KJ 175 225 270(243~297) 10 455 1200 1750 18.0 24.0 0.25 185 07D301K 07D301KJ 190 250 300(270~330) 10 505 1200 1750 20.0 26.0 0.25 165 07D331K 07D331KJ 210 275 330(297~363) 10 550 1200 1750 23.0 28.0 0.25 150 07D361K 07D361KJ 230 300 360(324~396) 10 595 1200 1750 25.0 32.0 0.25 140 07D391K 07D391KJ 250 320 390(351~429) 10 650 1200 1750 25.0 35.0 0.25 130 07D431K 07D431KJ 275 350 430(387~473) 10 710 1200 1750 28.0 40.0 0.25 115 07D471K 07D471KJ 300 385 470(423~517) 10 775 1200 1750 30.0 42.0 0.25 105 07D511K 07D511K 320 415 510(459~561) 10 845 1200 1750 30.0 45.0 0.25 100 07D561K 07D561KJ 350 460 560(504~616) 10 920 1200 1750 30.0 49.0 0.25 90 07D621K 07D621KJ 385 505 620(558~682) 10 1025 1200 1750 33.0 55.0 0.25 80 07D681K 07D681KJ 420 560 680(612~748) 10 1120 1200 1750 33.0 60.0 0.25 75 07D751K 07D751KJ 460 615 750(675~825) 10 1240 1200 1750 65.0 67.2 0.25 70 07D781K 07D781KJ 485 640 780(702~858) 10 1290 1200 1750 65.0 67.2 0.25 70 07D821K 07D821KJ 510 670 820(738~902) 10 1355 1200 1750 65.0 70.0 0.25 60 The tolerance of varistor voltage between 18V and 68V is more than 10%. Page-3 嵩隆力上 SONGLONG LISHANG Mechanical Ratings VDR Varistor 07D SERIES Reliability Test Performance Requirements Test Parameter Test Condition / Description Terminal Pull Strength After gradually applying the load specified below and keeping the unit fixed for ten seconds, the terminal shall be visually examined for any damage. The unit shall be secured with its terminal kept vertical and the weight specified below be applied in the axial direction. The Terminal Bending terminal shall gradually be bent by 90° in one direction, then 90° Strength in the opposite direction, and again back to the original position. The damage of the terminal shall be visually examined. Vibration Solderingsolderability SolderingResistance to Solder Heat Diameter Loading 0.6mm 1.0 Kg 0.8mm 1.0 Kg 1.0mm 2.0 Kg Diameter Loading 0.6mm 0.5 Kg 0.8mm 0.5 Kg 1.0mm 1.0 Kg The Specimen shall be vibrated by its lead wires with a total amplitude of 1.5㎜ and a varying frequency of 10~55~10HZ(each minutes) for a period of 2 hours respectively in each X,Yand Z directions. No visible damage No visible damage No visible damage △VB/VB%≦±5% After dipping the terminal to depth of approximately 3㎜ from the specimen in a soldering Terminations shall bath of 260℃ for 10±1(D5: 5±1) seconds. Thereafter the terminal shall be visually be uniformly tinned examined. After preheating the specimen, the specimen shall be completely immersed into a soldering bath having a temperature of 260±5℃ for 10±1 (D5: 5±1) seconds or iron of 400±5℃ for 3±0.5 seconds. There after the change of Vb and mechanical damage shall be examined. No visible damage △VB/VB%≦±5% ENVIRONMENTAL RATINGS The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal Dry Heat Loading humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be △VB/VB%≦±10% examined. Ambient temp:125±2℃ ; Period:1000±24hours. High Temperature In a drying oven without load. Storage Ambient temp:125±2℃ ; period:1000±24hours Damp Heat Loading △VB/VB%≦±5% The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be △VB/VB%≦±10% examined. Ambient condition:40±2℃ , 90 to 95%R.H. ; period:1000±24 hours Step Temperature Cycle Condition the specimen to each temperature form step 1 to step 4 in this order for the period shown in the table of specifications. The change of Vb and mechanical damage shall be examined after 2 hours. o Period o Temp C 1 -40+3 C 30 min. 2 Room Temp 15 min. 3 85+2 C 30 min. 4 Room Temp 15 min. o Surge Lifetime Rating The change of Vb shall be measured after the impulse listed below is applied 10,000 times continuously with the interval of ten seconds at room temperature. Voltage Proof Voltage:2500VAC Leakage Current≦0.5mA Time:60 Seconds No visible damage △VB/VB%≦±10% No visible damage △VB/VB%≦±10% No Breakdown Page-4 VDR Varistor 07D SERIES 嵩隆力上 SONGLONG LISHANG MARKING CODE 1 SongLong Lishang Logo 2 Disk Size 3 CUL Accreditation Logo 4 “Y” &“M” Product Line Code 5 Varistor Voltage 6 VDE Accreditation Logo 7 Energy and frequency of combined wave “J” is High Surge Code,not “J” is Standard Surge “H” is High temperature range ,not “H” is Standard Packaging specification / bulk packaging quantity Unit:Pcs Dimension Part No. Bag Small Carton Carton 07D 180L to 821K 1,000 10,000 20,000 07D (Short leg) 180L to 821K 1,000 15,000 30,000 Page-5
VDR-07D330K 价格&库存
很抱歉,暂时无法提供与“VDR-07D330K”相匹配的价格&库存,您可以联系我们找货
VDR-07D330K
    • 20+0.25650
    • 200+0.20790
    • 1000+0.17820
    • 2000+0.16200
    库存:5067
