SK52C-SK520C
Schottky rectifiers
Features
Low profile package
Ideal for automated placement
Ultrafast reverse recovery time
Low power losses, high efficiency
Low forward voltage drop
High surge capability
High temperature soldering:
260℃/10 seconds at terminals
Component in accordance to
RoHS 2002/95/1 and WEEE 2002/96/EC
Major Ratings and Characteristics
Mechanical Date
Case: JEDEC DO-214AB molded plastic
IF(AV)
5.0A
Terminals: Solder plated, solderable per
VRRM
20 V to 200 V
J-STD-002B and JESD22-B102D
IFSM
150A
VF
0.50V, 0.55V, 0.70V, 0.85V,0.95V
Tj max.
125 °C
Polarity: Laser band denotes cathode end
Maximum Ratings & Thermal Characteristics
(TA = 25 °C unless otherwise noted)
Symbol SK52C SK53C SK54C SK55C SK56C SK58C SK510CSK515CSK520C UNIT
Items
Maximum repetitive peak
reverse voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
21
28
35
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
150
200
V
Maximum average forward
rectified current
IF(AV)
5
A
Peak forward surge current 8.3
ms single half sine-wave
superimposed on rated load
IFSM
150
A
Voltage rate of change
(rated VR)
dv/dt
10000
V/µs
Thermal resistance from
junction to lead (1)
RθJL
℃/W
–65 to +125
Operating junction and storage
TJ,TSTG
temperature range
Note 1: Mounted on P.C.B. with 0.55 × 0.55'' ( 14 × 14 mm ) copper pad areas.
Electrical Characteristics
Items
Instantaneous forward
voltage
Reverse current
Test conditions
IF=5.0A(2)
VR=VDC
Tj=25℃
Tj=100℃
Symbol SK52C SK53-54C SK55-56C SK58-510C SK515-520C UNIT
VF
0.50
0.55
0.70
0.5
IR
10.0
0.85
0.95
V
mA
Note 2: Pulse test:300μs pulse width,1% duty cycle.
Rev : 01.06.2015
1/3
www.leiditech.com
SK52C-SK520C
Characteristic Curves (TA=25 ℃ unless otherwise noted)
SK52C
SK58C~SK510C
SK515C~SK520C
SK55C~SK56C
SK53C~SK54C
Rev : 01.06.2015
2/3
www.leiditech.com
SK52C-SK520C
Package Outline
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
3/3
www.leiditech.com
很抱歉,暂时无法提供与“SK54C”相匹配的价格&库存,您可以联系我们找货
