UP31-CV-G-CM
UP31-CV-G-CM
    CUIDEVICES
    UP31-CV-G-CM
UP31-CV-G-CM 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 4 MODEL: UP31-CV-G-CM | DESCRIPTION: USB PLUG FEATURES • USB Type C plug • USB 3.2 Gen 2 • 10 Gbit/s data transfer speed • reflow solder compatible SPECIFICATIONS parameter conditions/description USB standard USB 3.2 Gen 2 min typ rated input voltage rated input current as per EIA-364-70, Method B power pins collectively (A4, A9, B4, B9) GND pins collectively (A1, A12, B1, B12) VCONN pins individually (A5, B5) all other signal pins individually contact resistance1 between terminals and mating plug insulation resistance at 100 Vdc for 1 minute between adjacent contacts voltage withstand at 60 Hz for 1 minute between adjacent contacts insertion force at a rate of 12.5 mm/min 5 withdrawal force at a rate of 12.5 mm/min 8 life at a rate of 200 max cycles per hour max units 20 Vdc 5.0 6.25 1.25 0.25 A A A A 40 mΩ 100 MΩ 100 Vac 20 N 20 10,000 N cycles operating temperature -30 85 °C storage temperature -40 85 °C flammability rating UL94V-0 RoHS yes Note: 1. When measured at 20 mV max / 100 mA. SOLDERABILITY parameter conditions/description reel storage at relative humidity
UP31-CV-G-CM 价格&库存
很抱歉,暂时无法提供与“UP31-CV-G-CM”相匹配的价格&库存,您可以联系我们找货
