HSS3400A
Description
Product Summary
The HSS3400A is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS3400A meet the RoHS and Green Product
VDS
30
V
RDS(ON),max
26
mΩ
ID
5.5
A
requirement with full function reliability approved.
l
l
l
l
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
SOT23 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
±12
V
Continuous Drain Current, VGS @ 4.5V
1
5.5
A
1
4.5
A
22
A
1.0
W
Pulsed Drain Current
2
3
PD@TA=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.hs-semi.cn
Thermal Resistance Junction-Case
Ver 2.0
1
Typ.
Max.
Unit
100
℃/W
80
℃/W
1
HSS3400A
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
2
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.029
V/℃
VGS=10V , ID=5.9A
19
26
VGS=4.5V , ID=5A
23
31
VGS=2.5V , ID=4A
mΩ
38
48
0.7
0.9
1.4
V
-2.82
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=3A
19
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.5
3
Ω
Qg
Total Gate Charge (4.5V)
3.74
Qgs
Gate-Source Charge
0.62
Qgd
Gate-Drain Charge
1.82
Turn-On Delay Time
6.5
Td(on)
VDS=15V , VGS=4.5V , ID=3A
uA
nC
Rise Time
VDD=15V , VGS=4.5V , RG=3.3Ω
2
Turn-Off Delay Time
ID=3A
28.6
Fall Time
2.6
Ciss
Input Capacitance
614
Coss
Output Capacitance
78
Crss
Reverse Transfer Capacitance
61
Min.
Typ.
Max.
Unit
5.5
A
22
A
1.2
V
6.8
nS
2.3
nC
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
Pulsed Source Current
2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Conditions
1,4
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=3A , dI/dt=100A/µs , TJ=25℃
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS3400A
www.hs-semi.cn
Ver 2.0
3
HSS3400A
www.hs-semi.cn
Ver 2.0
4
HSS3400A
Ordering Information
Part Number
HSS3400A
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS3400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23166
- 200+0.18846
- 600+0.16686
