AST2130202
AST2130202
    METZCONNECT
    P=3.5mm
    AST2130202
AST2130202 数据手册
Data Sheet SR213xxVBNC Page 1/4 P/N AST213xx xx=number of poles 2013/12/05 Illustration see enlarged drawing at the end of the document Product specification • spring clamp terminal block, THR solderable, double solder pins • centerline 3.50 mm, direction of connection vertical 0° • fittable without loss of poles • color black • Tape & Reel packaging • push-button • Connection data V / A / AWG 150 / 10 / 28 - 16 0.08 - 1.5mm² 130 V / 1.3 kV / 17.5 A Page 2/4 P/N AST213xx xx=number of poles 2013/12/05 Data Sheet SR213xxVBNC Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage Min. insul. strip length 3.5 mm 2 12 CTI 600 2 mm IP 20 III 3 160 V 2.5 kV 8.5 mm III 2 400 V 2.5 kV II 2 400 V 2.5 kV Connection data V / A / AWG 150 / 10 / 28 - 16 0.08 - 1.5mm² 130 V / 1.3 kV / 17.5 A Material insulating material flammability class PA66/6T V0 Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance For THR products acc. to IPC/JEDEC J-STD-020D-MSL 1 | For THT products max. 260 °C / 10 s ISO 2768 -mH Data Sheet SR213xxVBNC Illustration Drawing L=(pole size - 1) x centerline + 3.5 [0.138] Page 3/4 P/N AST213xx xx=number of poles 2013/12/05 Data Sheet SR213xxVBNC PCB Layout Powered by TCPDF (www.tcpdf.org) Page 4/4 P/N AST213xx xx=number of poles 2013/12/05
AST2130202 价格&库存
很抱歉,暂时无法提供与“AST2130202”相匹配的价格&库存,您可以联系我们找货
