LM1085T-5.0
LM1085T-5.0
    HGSEMI(华冠)
    TO220-3
    LM1085T-5.0
LM1085T-5.0 数据手册
LM1085 3A L.D.O. VOLTAGE REGULATOR DESCRIPTION The LM1085 is a low dropout three terminal regulator with 3A output current capability. The output voltage is adjustable with the use of a resistor divider. Dropout is guaranteed at a maximum of 500 mV at maximum output current. It's low dropout voltage and fast transient response make it ideal for low voltage microprocessor applications. Internal current and thermal limiting provides protection against any overload condition that would create excessive junction temperature. FEATURES      Low Dropout Voltage 500mV at 3A Output Current Fast Transient Response 0.015% Line Regulation 0.1% Load Regulation Internal Thermal and Current Limiting  Adjustable or Fixed Output Voltage (1.5V、2.5V、 3.0V、3.3V、5.0V) Surface Mount Package TO-220 & TO-263 (S2 Package) 100% Thermal Limit Burn-in     High Efficiency "Green" Computer Systems SMPS Post-Regulator Power PC Supplies Powering VGA & Sound Card   APPLICATIONS      Battery Charger Adjustable Power Supplies Constant Current Regulators Portable Instrumentation High Efficiency Linear Power Supplies ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM1085T-1.5 TO220-3 LM1085-1.5 TUBE 1000pcs/box LM1085T-2.5 TO220-3 LM1085-2.5 TUBE 1000pcs/box LM1085T-3.0 TO220-3 LM1085-3.0 TUBE 1000pcs/box LM1085T-3.3 TO220-3 LM1085-3.3 TUBE 1000pcs/box LM1085T-5.0 TO220-3 LM1085-5.0 TUBE 1000pcs/box LM1085S-1.5/TR TO263-3 LM1085-1.5 REEL 500pcs/reel LM1085S-2.5/TR TO263-3 LM1085-2.5 REEL 500pcs/reel LM1085S-3.0/TR TO263-3 LM1085-3.0 REEL 500pcs/reel LM1085S-3.3/TR TO263-3 LM1085-3.3 REEL 500pcs/reel LM1085S-5.0/TR TO263-3 LM1085-5.0 REEL 500pcs/reel http://www.hgsemi.com.cn 1/5 2022 MAR LM1085 Pin Configuration and Functions TO220-3 TO263-3 TEST & TYPICAL APPLICATION CIRCUIT ABSOULTE MAXIMUM RATINS CHARACTERISTIC Supply Voltage Operating Junction Temperature Range Storage Temperature Range Thermal Resistance Junction to Case TO-263 Thermal Resistance Junction to Ambient TO-263 Lead Temperature (Soldering) 10 sec. Maximum Output Current http://www.hgsemi.com.cn SYMBOL Vin Topr Tstg Tjc Tja Tsol Imax 2/5 VALUE 7 0~125 -65~150 3 60 300 3 UNIT V ℃ ℃ C/W C/W ℃ A 2022 MAR LM1085 ELECTRICAL CHARACTERISTICS IOUT=100 ㎃, TA=25℃, unless otherwise specified PARAMETER 1.5V Version Output Voltage 2.5V Version Output Voltage TEST CONDITIONS MIN TYP MAX UNIT 0
LM1085T-5.0 价格&库存
很抱歉,暂时无法提供与“LM1085T-5.0”相匹配的价格&库存,您可以联系我们找货
