SFWG00LB002
SFWG00LB002
    WISOL(威盛)
    SFWG00LB002
SFWG00LB002 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. SEMCO PART No. SFWG00LB002 DOC. No. SMS-51-L-SFT FW-51 DATE Jan 24, 2014 REVISION Preliminary WISOL Kim, Kyung-Sik Choi. Jae hyeong Hong, Seong-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 12 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 12 7-2. TEST ITEM & CONDITION ............................................................................................................... 13 8. REFLOW CONDITION ................................................................................................................................ 14 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 14 10. CAUTION ................................................................................................................................................... 15 11. PACKING ................................................................................................................................................... 16 11-1. DIMENSIONS.................................................................................................................................. 16 11-2. REELING QUANTITY ..................................................................................................................... 17 11-3. TAPING STRUCTURE .................................................................................................................... 17 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 18 11-5. OUTER BOX STRUCTURE ............................................................................................................ 19 12. TAPE SPECIFICATIONS .......................................................................................................................... 20 13. RoHS DATA ............................................................................................................................................... 21 SMS-51-L-SFT FW-51 Page 2/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 1. REVISION HISTORY Preliminary Jan 24, 2014 SMS-51-L-SFT FW-51 All Page Make specification Page 3/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 2. DEFINITION 2-1. PART No. SFWG00LB002 ① ② ③ ④ ⑤ No. ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency Filter1 1900.0MHz (1800~1920MHz) ④ Balanced Filter Input: Unbalanced 50 ohm Output: Balanced 100 ohm//6.8nH ⑤ Package size: 1.5×1.1mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION: TDSCDMA B39 + B34 Dual 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT FW-51 Page 4/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] RLXX O X SMS-51-L-SFT FW-51 Page 5/26 No. Function 1 B39 Unbalanced Input 4 B34 Unbalanced Input 6,9 B39 & B34 Balanced Output 2, 3, 5, 7, 8, 10 GND Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 SFWG00LB002 1900.0MHz 2017.5MHz 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out 5. MARKING RLXX O X 5-1. R L X X X st nd - The 1 2 character 'RL' indicates the model name of SAW Filter SFWG00LB002. rd - The 3 character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2013 P Q R S T U V W X Y Z a 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a ※ This rotates by the 3 years. - The th th 4 ,5 character 'X' indicates Lot No. 5-2. O - This symbol indicates input pin 1. - This indicates the producing center ○ : China, 5-3. Marking: Laser Marking SMS-51-L-SFT FW-51 Page 6/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT FW-51 Page 7/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ LTE B39 ITEM Insertion Loss Inband Ripple Input VSWR Output VSWR Amplitude Imbalance Phase Imbalance Absolute Attenuation UNIT LTE B34 Freq. Range [MHz] Min. Typ. (25℃) Max. Freq. Range [MHz] Min. Typ. (25℃) Max. dB 1880 ~ 1920 - 1.9 2.7 2010 ~ 2025 - 2.2 3.0 dB 1880 ~ 1920 - 0.4 1.3 2010 ~ 2025 - 0.2 1.1 - 1880 ~ 1920 - 1.4 2.0 2010 ~ 2025 - 1.4 2.0 - 1880 ~ 1920 - 1.3 2.0 2010 ~ 2025 - 1.3 2.0 dB 1880 ~ 1920 -2.0 - -2.0 2010 ~ 2025 -2.0 - -2.0 degree 1880 ~ 1920 -20 - +20 2010 ~ 2025 -20 - +20 dB DC ~ 915 50 64 - DC ~ 1805 35 41 - dB 915 ~ 1710 30 37 - 1805 ~ 1850 35 40 - dB 1710 ~ 1785 20 25 - 1850 ~ 1895 32 37 - dB 1785 ~ 1850 8 16 - 1925 ~ 1980 7 13 - dB 1950 ~ 2010 8 20 - 2050 ~ 2110 3 9 - dB 2010 ~ 2025 28 34 - 2110 ~ 2170 23 28 - dB 2025 ~ 2400 23 28 - 2170 ~ 2400 26 31 - dB 2400 ~ 2500 35 42 - 2400 ~ 2500 35 40 - dB 2500 ~ 6000 25 29 - 2500 ~ 6000 30 37 - Termination Impedance SMS-51-L-SFT FW-51 Input: Unbalanced 50 ohm Output: Balanced 100 ohm // 6.8nH Page 8/26 Input: Unbalanced 50 ohm Output: Balanced 100 ohm // 6.8nH Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 6-2-2. TEST FIXTURE < X-ray Top View > SMS-51-L-SFT FW-51 Page 9/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 SFWG00LB002 1900.0MHz 2017.5MHz 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out 6-2-3. GRAPH LTE B39 B39_Nearband IL[dB] 0 0 -10 -1 -20 -2 -30 -3 -40 -4 -50 -5 1.75 1.8 1.85 1.9 1.95 2 2.05 Frequency (GHz) B39_FullBand 0 -10 IL[dB] -20 -30 -40 -50 -60 -70 0 1 2 3 4 5 6 Frequency (GHz) SMS-51-L-SFT FW-51 Page 10/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out LTE B34 B34_Nearband IL[dB] 0 0 -10 -1 -20 -2 -30 -3 -40 -4 -50 -5 1.76 1.81 1.86 1.91 1.96 2.01 2.06 2.11 2.16 2.21 2.26 Frequency (GHz) B34_Fullband 0 -10 IL[dB] -20 -30 -40 -50 -60 -70 0 1 2 3 4 5 6 Frequency (GHz) SMS-51-L-SFT FW-51 Page 11/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) SMS-51-L-SFT FW-51 Page 12/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test JESD22A113F -30℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION SMS-51-L-SFT FW-51 Page 13/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [UNIT : mm] < SAW, X-ray Top View > SMS-51-L-SFT FW-51 Page 14/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT FW-51 Page 15/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 SFWG00LB002 1900.0MHz 2017.5MHz 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.35 +0.05 -0.05 1.75 +0.05 -0.05 Ø 1.50 +0.10 -0.00 Ø 0.50 +0.05 -0.05 1.75 +0.10 -0.10 3.50 +0.05 -0.05 4.00 +0.10 -0.10 4.00 +0.10 -0.10 2.00 +0.05 -0.05 0.25 +0.02 -0.02 0.70 +0.07 -0.07 8.00 +0.30 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø258.0 +1.0 -0.5 Ø81.0 +1.0 -1.0 Ø13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT FW-51 Page 16/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 Version: Preliminary 1.5×1.1×0.55mm 10pin lay-out 11-2. REELING QUANTITY 10 inch reel : 8,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. RLXX O X RLXX O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT FW-51 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8,000 / qAFYU Quantity / Marking Page 17/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 SFWG00LB002 1900.0MHz 2017.5MHz 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material: Polyethylene + Aluminium Size: 310×370mm Material: Size: 2 Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT FW-51 3 Page 18/26 Jan 24, 2014 EA . . Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 SFWG00LB002 1900.0MHz 2017.5MHz 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 11-5. OUTER BOX STRUCTURE Material: Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② - SIDE is the same as front side. SMS-51-L-SFT FW-51 Page 19/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT FW-51 Page 20/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Version: Preliminary 13. RoHS DATA SMS-51-L-SFT FW-51 Page 21/26 Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SMS-51-L-SFT FW-51 SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Page 22/26 Version: Preliminary Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SMS-51-L-SFT FW-51 SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Page 23/26 Version: Preliminary Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SMS-51-L-SFT FW-51 SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Page 24/26 Version: Preliminary Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SMS-51-L-SFT FW-51 SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Page 25/26 Version: Preliminary Jan 24, 2014 Surface Acoustic Wave Filter TDSCDMA B39 TDSCDMA B34 1900.0MHz 2017.5MHz SMS-51-L-SFT FW-51 SFWG00LB002 3 1.5×1.1×0.55mm 10pin lay-out Page 26/26 Version: Preliminary Jan 24, 2014
SFWG00LB002 价格&库存
很抱歉,暂时无法提供与“SFWG00LB002”相匹配的价格&库存,您可以联系我们找货
