SS22F THRU SS220F
Surface Mount Schottky Rectifiers
Reverse Voltage - 20 to 200 V
Forward Current - 2.0A
PINNING
DESCRIPTION
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS22 — SS220
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 27mg 0.00086oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS22F
SS24F
SS26F
SS28F
SS210F
SS212F
SS215F
SS220F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
at Rated DC Reverse Voltage
VF
50
0.55
IR
T a =125°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
1) Measured
2)
version: 02
Cj
40
0.70
80
V
mA
pF
RθJA
70
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
at 1MHz and applied reverse voltage of 4 V D.C.
P.C.B. mounted with 0.5 X 0.5" (12.7 X 12.7 mm) copper pad areas.
http://www.trr-jx.com
0.3
5
220
A
0.95
0.85
0.5
5
T a = 25°C
T a =100°C
A
2.0
SS22F THRU SS220F
Characteristic Curves (T
=25 ℃ unless otherwise noted)
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
100LFM
2.5
2.0
1.5
1.0
Single phase half-wave 60 Hz
0.5
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
SS22F/SS24F
SS26F-SS220F
10
1
T J =25°C
10 0
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
10
1.0
SS22F/SS24F
SS26F/SS28F
SS210F/SS212F
SS215F/SS220F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
60
8.3 ms Single Half Sine Wave
(JEDEC Method)
50
40
30
SS22F-SS28F
10
SS210F-SS220F
00
1
10
Number of Cycles at 60Hz
T J =25°C
200
100
50
SS22F/SS24F
SS26F-SS220F
10
0.1
1
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
T J =75°C
10 2
Ambient Temperature (°C)
version: 02
T J =100°C
10 3
100
100
SS22F THRU SS220F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.23
3.7
2.7
1.6
1.3
4.9
min
0.9
0.18
3.3
2.4
1.3
1.0
4.4
max
47
9.1
146
106
63
51
193
min
35.4
7.1
130
94
51
39
173
UNIT
mm
g
pad
e
E
A
pad
HE
7°
The recommended mounting pad size
Marking
Type number
2.8(110)
1.6(63)
1.8(71)
1.6(63)
Unit:mm(mil)
version: 02
Marking code
SS22F
SS22
SS24F
SS24
SS26F
SS26
SS28F
SS28
SS210F
SS210
SS212F
SS212
SS215F
SS215
SS220F
SS220
很抱歉,暂时无法提供与“SS24F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31336
- 100+0.25288
- 300+0.22264
- 3000+0.18598
- 6000+0.16784
- 9000+0.15876
