74HC132
Quad 2−Input NAND Gate with Schmitt−Trigger Inputs
High−Performance Silicon−Gate CMOS
The 74HC132 is identical in pinout to the LS132. The device inputs
are compatible with standard CMOS outputs; with pull−up resistors,
they are compatible with LSTTL outputs.
The HC132 can be used to enhance noise immunity or to square up
slowly changing waveforms.
14
1
Features
SOIC−14
Output Drive Capability: 10 LSTTL Loads
Outputs Directly Interface to CMOS, NMOS, and TTL
Operating Voltage Range: 2.0 to 6.0 V
Low Input Current: 1.0 mA
High Noise Immunity Characteristic of CMOS Devices
In Compliance with the Requirements as Defined by JEDEC
Standard No. 7A
• ESD Performance: HBM > 2000 V; Machine Model > 200 V
• Chip Complexity: 72 FETs or 18 Equivalent Gates
• These are Pb−Free Devices
14
1
TSSOP−14
FUNCTION TABLE
Inputs
A1
1
14
VCC
B1
2
13
B4
Y1
3
12
A4
A2
4
11
Y4
B2
5
10
B3
Y2
6
9
A3
GND
7
8
Y3
Output
A
B
Y
L
L
H
H
L
H
L
H
H
H
H
L
Figure 1. Pin Assignment
http://www.hgsemi.com.cn
1
2018 AUG
74HC132
A1
1
3
B1
A2
2
4
6
B2
A3
Y2
5
Y = AB
9
8
B3
Y1
Y3
10
A4 12
11
B4
Y4
13
PIN 14 = VCC
PIN 7 = GND
Figure 2. Logic Diagram
2
2018 AUG
74HC132
MAXIMUM RATINGS
Symbol
Parameter
Value
Unit
VCC
Positive DC Supply Voltage
0.5 to 7.0
V
VIN
Digital Input Voltage
0.5 to 7.0
V
VOUT
DC Output Voltage
0.5 to 7.0
0.5 to VCC 0.5
V
IIK
Input Diode Current
mA
IOK
Output Diode Current
mA
IOUT
DC Output Current, per Pin
25
mA
ICC
DC Supply Current, VCC and GND Pins
75
mA
IGND
DC Ground Current per Ground Pin
75
mA
TSTG
Storage Temperature Range
65 to 150
_C
260
_C
150
_C
14−SOIC
14−TSSOP
125
170
_C/W
SOIC
TSSOP
500
450
mW
Output in 3−State
High or Low State
TL
Lead Temperature, 1 mm from Case for 10 Seconds
TJ
Junction Temperature Under Bias
qJA
Thermal Resistance
PD
Power Dissipation in Still Air at 85_C
MSL
Moisture Sensitivity
FR
Flammability Rating
VESD
ILatchup
Level 1
Oxygen Index: 30% − 35%
ESD Withstand Voltage
Latchup Performance
UL 94 V−0 @ 0.125 in
Human Body Model (Note 1)
Machine Model (Note 2)
2000
200
V
Above VCC and Below GND at 85_C (Note 3)
300
mA
Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the
Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect
device reliability.
1. Tested to EIA/JESD22−A114−A.
2. Tested to EIA/JESD22−A115−A.
3. Tested to EIA/JESD78.
RECOMMENDED OPERATING CONDITIONS
Symbol
VCC
VIN, VOUT
Parameter
DC Supply Voltage (Referenced to GND)
DC Input Voltage, Output Voltage (Referenced to GND)
TA
Operating Temperature, All Package Types
tr, tf
Input Rise and Fall Time (Figure 3)
Min
Max
Unit
2.0
6.0
V
VCC
V
55
125
_C
No Limit
(Note 5)
ns
5. When VIN 0.5 VCC, ICC >> quiescent current.
6. Unused inputs may not be left open. All inputs must be tied to a high−logic voltage level or a low−logic input voltage level.
3
2018 AUG
74HC132
DC ELECTRICAL CHARACTERISTICS (Voltages Referenced to GND)
VCC
Test Conditions
Guaranteed Limit
Symbol
Parameter
(V)
*55_C to 25_C
85_C
125_C
Unit
VT+max
Maximum Positive−Going
Input Threshold Voltage
(Figure 5)
VOUT = 0.1 V
|IOUT| 20 mA
2.0
4.5
6.0
1.5
3.15
4.2
1.5
3.15
4.2
1.5
3.15
4.2
V
VT+min
Minimum Positive−Going
(Figure 5)
VOUT = 0.1 V
|IOUT| 20 mA
2.0
4.5
6.0
1.0
2.3
3.0
0.95
2.25
2.95
0.95
2.25
2.95
V
VT–max
Maximum Negative−Going
(Figure 5)
VOUT = VCC – 0.1 V
|IOUT| 20 mA
2.0
4.5
6.0
0.9
2.0
2.6
0.95
2.05
2.65
0.95
2.05
2.65
V
VT–min
Minimum Negative−Going
(Figure 5)
VOUT = VCC – 0.1 V
|IOUT| 20 mA
2.0
4.5
6.0
0.3
0.9
1.2
0.3
0.9
1.2
0.3
0.9
1.2
V
VHmax
(Note 7)
Maximum Hysteresis
Voltage
(Figure 5)
VOUT = 0.1 V or VCC – 0.1 V
|IOUT| 20 mA
2.0
4.5
6.0
1.2
2.25
3.0
1.2
2.25
3.0
1.2
2.25
3.0
V
VHmin
(Note 7)
Minimum Hysteresis
Voltage
(Figure 5)
|IOUT| 20 mA
2.0
4.5
6.0
0.2
0.4
0.5
0.2
0.4
0.5
0.2
0.4
0.5
V
VOH
Minimum High−Level
Output Voltage
VIN VT−min or VT+max
|IOUT| 20 mA
2.0
4.5
6.0
1.9
4.4
5.9
1.9
4.4
5.9
1.9
4.4
5.9
V
4.5
6.0
3.98
5.48
3.84
5.34
3.7
5.2
2.0
4.5
6.0
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
4.5
6.0
0.26
0.26
0.33
0.33
0.4
0.4
VIN
VOL
Maximum Low−Level
Output Voltage
−VT−min or VT+max
|IOUT| 4.0 mA
|IOUT| 5.2 mA
VIN ≥ VT+max
|IOUT| 20 mA
VIN ≥
VT+max
|IOUT| 4.0 mA
|IOUT| 5.2 mA
V
IIN
Maximum Input Leakage
Current
VIN = VCC or GND
6.0
0.1
1.0
1.0
mA
ICC
Maximum Quiescent
Supply Current
(per Package)
VIN = VCC or GND
IOUT = 0 mA
6.0
2.0
mA
7. VHmin (VT+min) (VT−max); VHmax = (VT+max) (VT−min).
8. Information on typical parametric values can be found in the ON Semiconductor High−Speed CMOS Data Book (DL129/D).
4
2018 AUG
74HC132
AC ELECTRICAL CHARACTERISTICS (CL = 50 pF, Input tr = tf = 6.0 ns)
VCC
Symbol
Parameter
Guaranteed Limit
(V)
*55_C to 25_C
85_C
125_C
Unit
tPLH,
tPHL
Maximum Propagation Delay, Input A or B to Output Y
(Figures 3 and 4)
2.0
4.5
6.0
125
25
21
155
31
26
190
38
32
ns
tTLH,
tTHL
Maximum Output Transition Time, Any Output
(Figures 3 and 4)
2.0
4.5
6.0
75
15
13
95
19
16
110
22
19
ns
Maximum Input Capacitance
10
10
10
pF
Cin
9. For propagation delays with loads other than 50 pF, and information on typical parametric values, see the ON Semiconductor High−Speed
Typical @ 25°C, VCC = 5.0 V
CPD
Power Dissipation Capacitance (per Gate) (Note 10)
24
10. Used to determine the no−load dynamic power consumption: P D = CPD VCC
tr
tPHL
tTHL
tPLH
OUTPUT
DEVICE
UNDER
TEST
GND
tTLH
CL*
*Includes all probe and jig capacitance
Figure 3. Switching Waveforms
+ ICC VCC . For load considerations, see the ON
VCC
90%
50%
10%
Y
pF
TEST POINT
tf
90%
50%
10%
INPUT
A OR B
2f
Figure 4. Test Circuit
5
2018 AUG
VT, TYPICAL INPUT THRESHOLD VOLTAGE
(VOLTS)
74HC132
4
3
VHtyp
2
1
2
3
4
5
VCC, POWER SUPPLY VOLTAGE (VOLTS)
VHtyp = (VT+ typ) − (VT− typ)
6
Figure 5. Typical Input Threshold, VT+, VT− Versus Power Supply Voltage
VH
VIN
VCC
VCC
VH
VT+
VT−
VT+
VT−
VIN
GND
GND
VOH
VOH
VOUT
VOUT
VOL
VOL
VCC
(a)A SCHMITT TRIGGER SQUARES UP INPUTS
(a)WITH SLOW RISE AND FALL TIMES
VOUT
VIN
(b)A SCHMITT TRIGGER OFFERS MAXIMUM
NOISE IMMUNITY
Figure 6. Typical Schmitt−Trigger Applications
6
2018 AUG
74HC132
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
7
2018 AUG
很抱歉,暂时无法提供与“74HC132M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59284
- 50+0.51509
- 150+0.47621
- 500+0.44706
- 2500+0.42373
- 国内价格
- 5+0.63400
- 50+0.55090
- 150+0.50930
- 500+0.47810
- 2500+0.45320
