Zetta ZD24C64A
ZD24C64A
I2C-Compatible (2-wire) Serial EEPROM
64-Kbit (8,192 x 8)
DATASHEET
Features
Low Voltage Operation
̶ VCC = 1.7V to 5.5V
Internally Organized as 8,192 x 8 (64Kb)
Additional Write lockable page
I2C-compatible (2-wire) Serial Interface
̶ 100kHz Standard Mode, 1.7V to 5.5V
̶ 400kHz Fast Mode, 1.7V to 5.5V
̶ 1MHz Fast Mode Plus (FM+), 2.5V to 5.5V
Schmitt Trigger Filtered Inputs for Noise Suppression
Bidirectional Data Transfer Protocol
Write Protect Pin for Full Array Hardware Data Protection
Ultra Low Active Current (300μA max) and Standby Current (0.5μA Max)
32-byte Page Write Mode
̶ Partial Page Writes Allowed
Random and Sequential Read Modes
Self-timed Write Cycle Within 5ms Max
High Reliability
̶ Endurance: 1,000,000 Write Cycles
̶ Data Retention: 100 Years
Green Package Options (Lead-free/Halide-free/RoHS Compliant)
̶ 8-lead SOIC, 8-lead TSSOP, 8-pad UDFN, 8-lead PDIP, 5-lead SOT23
Die Sale Options: Wafer Form and Tape and Reel Available
Identification Page Options(Contact our sales for details)
Description
The ZD24C64A provides 65,536 bits of Serial Electrically Erasable and Programmable Read-Only Memory (EEPROM)
organized as 8,192 words of 8 bits each. The device offers an additional page, named the Identification Page(32
bytes). The Identification Page can be used to store sensitive application parameters which can be (later) permanently
locked in Read-only mode. The device’s cascadable feature allows more devices to share a common 2-wire bus.
This device is optimized for use in many industrial and commercial applications where low-power and low voltage
operation are essential. The device is available in space-saving 8-lead SOIC, 8-lead TSSOP, 8-pad UDFN, 8-lead
PDIP(1), 5-lead SOT23, and 8-ball UDFN packages. The entire family of packages operates from 1.7V to 5.5V.
Note: 1.Contact Sales for the availability of this package.
ZettaDevice Electronics Technology Co.,Ltd
www.zettadevice.com
1 / 28
Zetta ZD24C64A
1.
Pin Descriptions and Pinouts
Table 1-1.Pin Descriptions
Pin
Number
1, 2, 3
4
Pin
Symbol
A0, A1, A2
GND
Pin Name and Functional Description
Device Address Input: The A2 pin is used to select the hardware
device address and correspond to the fifth bit of the I2C seven bit slave
address. This pin can be directly connected to VCC or GND, allowing up
to two devices on the same bus.
Ground: The ground reference for the power supply. GND should be
connected to the system ground.
Asserted
State
Pin
Type
Input
Power
Input/
Output
Input
High
Input
Power
Serial Data: The SDA pin is an open-drain bidirectional input/output pin
used to serially transfer data to and from the device.
5
6
SDA
SCL
The SDA pin must be pulled-high using an external pull-up resistor (not to
exceed 10KΩ in value) and may be wire-ORed with any number of other
open-drain or open-collector pins from other devices on the same bus.
Serial Clock: The SCL pin is used to provide a clock to the device and to
control the flow of data to and from the device. Command and input data
present on the SDA pin is always latched in on the rising edge of SCL, while
output data on the SDA pin is clocked out on the falling edge of SCL.
The SCL pin must either be forced high when the serial bus is idle or pulledhigh using an external pull-up resistor.
7
WP
Write Protect: Connecting the WP pin to GND will ensure normal write
operations. When the WP pin is connected to VCC, all write operations to the
memory are inhibited.
Refer to Note 1 for behavior of the pin when not connected.
8
VCC
Device Power Supply: The VCC pin is used to supply the source voltage to
the device. Operations at invalid VCC voltages may produce spurious results
and should not be attempted.
Note:1. If the WP pin is not driven, it is internally pulled down to GND. In order to operate in a wide variety of application
environments, the pull-down mechanism is intentionally designed to be somewhat strong. Once these pins are biased above the
CMOS input buffer’s trip point (~0.5 x VCC), the pull-down mechanism disengages. Zetta recommends connecting these pins to a
known state whenever possible.
www.zettadevice.com
2 / 28
Zetta ZD24C64A
2.
Device Block Diagram and System Configuration
Figure 2-2.
System Configuration Using 2-Wire Serial EEPROMs
www.zettadevice.com
3 / 28
Zetta ZD24C64A
3.
Device Operation and Communication
The ZD24C64A operates as a slave device and utilizes a simple I2C-compatible 2-wire digital serial interface
to communicate with a host controller, commonly referred to as the bus Master. The Master initiates and
controls all read and write operations to the slave devices on the serial bus, and both the Master and the
slave devices can transmit and receive data on the bus.
The serial interface is comprised of just two signal lines: Serial Clock (SCL) and Serial Data (SDA). The
SCL pin is used to receive the clock signal from the Master, while the bidirectional SDA pin is used to
receive command and data information from the Master, as well as, to send data back to the Master. Data is
always latched into the ZD24C64A on the rising edge of SCL and always output from the device on the
falling edge of SCL. Both the SCL and SDA pin incorporate integrated spike suppression filters and Schmitt
Triggers to minimize the effects of input spikes and bus noise.
All command and data information is transferred with the Most-Significant Bit (MSB) first. During bus
communication, one data bit is transmitted every clock cycle, and after eight bits (one byte) of data have
been transferred, the receiving device must respond with either an Acknowledge (ACK) or a NoAcknowledge (NACK) response bit during a ninth clock cycle (ACK/NACK clock cycle) generated by the
Master. Therefore, nine clock cycles are required for every one byte of data transferred. There are no
unused clock cycles during any read or write operation, so there must not be any interruptions or breaks in
the data stream during each data byte transfer and ACK or NACK clock cycle.
During data transfers, data on the SDA pin must only change while SCL is low, and the data must remain
stable while SCL is high. If data on the SDA pin changes while SCL is high, then either a Start or a Stop
condition will occur. Start and Stop conditions are used to initiate and end all serial bus communication
between the Master and the slave devices. The number of data bytes transferred between a Start and a
Stop condition is not limited and is determined by the Master. In order for the serial bus to be idle, both the
SCL and SDA pins must be in the logic-high state at the same time.
3.1
Clock and Data Transition Requirements
The SDA pin is an open drain terminal and therefore must be pulled high with an external pull-up resistor.
Data on the SDA pin may change only during SCL low time periods. Data changes during SCL high periods
will indicate a Start or Stop condition as defined below.
www.zettadevice.com
4 / 28
Zetta ZD24C64A
3.2
Start and Stop Conditions
3.2.1
Start Condition
A Start condition occurs when there is a high-to-low transition on the SDA pin while the SCL pin is at a
stable Logic 1 state and will bring the device out of standby mode. The Master uses a Start condition to
initiate any data transfer sequence, therefore every command must begin with a Start condition. The device
will continuously monitor the SDA and SCL pins for a Start condition but will not respond unless one is
detected. Please refer to Figure 3-1 for more details.
3.2.2
Stop Condition
A Stop condition occurs when there is a low-to-high transition on the SDA pin while the SCL pin is stable in
the Logic 1 state. The Master can use the Stop condition to end a data transfer sequence with the ZD24C64A
which will subsequently return to standby mode. The Master can also utilize a repeated Start condition instead
of a Stop condition to end the current data transfer if the Master will perform another operation. Please refer
3.3
Acknowledge and No-Acknowledge
After every byte of data is received, the receiving device must confirm to the Master that it has successfully
received the data byte by responding with what is known as an acknowledge (ACK). An ACK is accomplished
by the transmitting device first releasing the SDA line at the falling edge of the eighth clock cycle followed by
the receiving device responding with a Logic 0 during the entire high period of the ninth clock cycle.
When the ZD24C64A is transmitting data to the Master, the Master can indicate that it is done receiving
data and wants to end the operation by sending a Logic 1 response to the ZD24C64A instead of an ACK
response during the ninth clock cycle. This is known as a no-acknowledge (NACK) and is accomplished by
the Master sending a Logic 1 during the ninth clock cycle, at which point the ZD24C64A will release the
SDA line so the Master can then generate a Stop condition.
The transmitting device, which can be the bus Master or the Serial EEPROM, must release the SDA line at
the falling edge of the eighth clock cycle to allow the receiving device to drive the SDA line to a Logic 0 to
ACK the previous 8-bit word. The receiving device must release the SDA line at the end of the ninth clock
cycle to allow the transmitter to continue sending new data. A timing diagram has been provided in Figure 31 to better illustrate these requirements.
Figure 3-1.Start Condition, Data Transitions, Stop Condition and Acknowledge
SDA
SDA
Allowed
Allowed
SDA line low to ACK the previous 8-bit word.
www.zettadevice.com
5 / 28
Zetta ZD24C64A
3.4
Standby Mode
The ZD24C64A features a low-power standby mode which is enabled when any one of the following occurs:
A valid power-up sequence is performed (see Section 8.5, “Pin Capacitance”).
A Stop condition is received by the device unless it initiates an internal write cycle (see Section 5.,
“Write Operations”).
At the completion of an internal write cycle (see Section 5.).
An unsuccessful match of the device type identifier or hardware address in the Device Address byte
occurs (see Section 4.1, “Device Addressing”).
The bus Master does not ACK the receipt of data read out from the device; instead it sends a NACK
response. (see Section 6., “Read Operations”).
3.5
Software Reset
After an interruption in protocol, power loss, or system reset, any 2-wire part can be protocol reset by
following these steps:
1.
Create a Start condition (if possible).
2.
Clock nine cycles.
3.
Create another Start condition followed by a Stop condition as seen in Figure 3-2.
The device should be ready for the next communication after above steps have been completed. In the event
that the device is still non-responsive or remains active on the SDA bus, a power cycle must be used to reset
the device (see Section 8.6.1, “Device Reset”).
Figure 3-2. Software Reset
Dummy Clock Cycles
SCL
1
Start
Condition
2
3
8
9
Start
Condition
Stop
Condition
SDA
www.zettadevice.com
6 / 28
Zetta ZD24C64A
4.
Memory Organization
The ZD24C64A is internally organized as 256 pages of 32 bytes each.
4.1
Device Addressing
Accessing the device requires an 8-bit Device Address word following a Start condition to enable the device
for a read or write operation. Since multiple slave devices can reside on the serial bus each slave device
must have its own unique address so the Master can access each device independently.
The most significant four bits of the Device Address word is referred to as the device type identifier. The
device type identifier is required in bits seven through four of the Device Address byte (Table 4-1).
Following the 4-bit device type identifier are the hardware slave address bits, A0, A1, and A2. These bits can
be used to expand the address space by allowing up to eight 64-Kbit Serial EEPROM devices on the same
bus.
The eighth bit (bit 0) of the Device Address byte is the read/write operation select bit. A read operation is
initiated if this bit is high and a write operation is initiated if this bit is low.
Upon the successful comparison of the Device Address byte, the ZD24C64A will return an ACK. If a valid
comparison is not made, the device will NACK and return to a standby state.
Table 4-1.Device Address Byte
Hardware Slave Address Bits
Device Type Identifier
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Device select code
when addressing the
memory array
1
Device select code
when accessing the
Identification Page
1
1
Package
Read/
Write
Bit 0
R/W
R/W
www.zettadevice.com
7 / 28
Zetta ZD24C64A
For all operations (except the Current Address Read), a two 8-bit Word Address byte must be transmitted to
the device immediately following the Device Address byte. The Word Address bytes consist of the 13-bit
memory array word address, and is used to specify which byte location in the EEPROM to start reading or
writing.
The first Word Address byte contains the five most significant bits of the word address (A12 through A8) in
bit positions four through zero, as seen in Table 4-2. The remainder of the first Word Address byte are don’t
care bits and (in bit positions seven through five) as they all outside of the addressable 64-Kbit range. Upon
completion of the first Word Address byte, the ZD24C64A will return an ACK.
Table 4-2.First Word Address Byte
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
X
X
X
A12
A11
A10
A9
A8
Note:
Bit 7 through Bit 5 are don’t care values as they fall outside the addressable 64-Kbit range.
Next, the second Word Address byte is sent to the device which provides the remaining eight bits of the word
address (A7 though A0). Upon completion of the second Word Address byte, the ZD24C64A will return an
ACK. Please consult Table 4-3 to review these bit positions.
Table 4-3.Second Word Address Byte
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
A7
A6
A5
A4
A3
A2
A1
A0
The relationship of the AC timing parameters with respect to SCL and SDA for the ZD24C64A are shown in
the timing waveform Figure 8-1 on page 15. The AC timing characteristics and specifications are outlined in
Section 8.4 “AC Characteristics” on page 15.
www.zettadevice.com
8 / 28
Zetta ZD24C64A
5.
Write Operations
All write operations for the ZD24C64A begin with the Master sending a Start condition, followed by a Device
Address byte with the R/W bit set to ‘0’, and then by the Word Address byte. The data value(s) to be written
to the device immediately follow the Word Address byte.
5.1
Byte Write
The ZD24C64A supports the writing of single 8-bit bytes. Selecting a data word in the ZD24C64A requires a
13bit word address.
Upon receipt of the proper Device Address and Word Address bytes, the EEPROM will send an
Acknowledge.
The device will then be ready to receive the first 8-bit data word. Following receipt of the 8-bit data word, the
EEPROM will respond with an Acknowledge. The addressing device, such as a bus Master, must then
terminate the Write operation with a Stop condition. At that time the EEPROM will enter an internally selftimed write cycle, which will be completed within tWR, while the data word is being programmed into the
nonvolatile EEPROM. All inputs are disabled during this write cycle, and the EEPROM will not respond until
the Write is complete.
Figure 5-1. Byte Write
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
A8
SCL
Device Address Byte
SDA
1
MSB
A
A2
1
A0
X
X
X
A12 A11
A10 A9
MSB
Start Condition
by Master
ACK
from Slave
1
2
3
4
5
ACK
from Slave
6
7
8
9
1
2
3
A7
A6
A5
A4
A3
A2
A1
A0
7
8
9
D7 D6
D5
D4
D3
D2
D1
D0
MSB
ACK
from Slave
5.2
5
Data Word
MSB
4
Stop Condition
ACK
from Slave by Master
Page Write
A Page Write operation allows up to 32 bytes to be written in the same write cycle, provided all bytes are in
the same row of the memory array (where address bits A12 through A5 are the same). Partial Page Writes
of less than 32 bytes are also allowed.
A Page Write is initiated the same way as a Byte Write, but the bus Master does not send a Stop condition
after the first data word is clocked in. Instead, after the EEPROM acknowledges receipt of the first data word,
the bus Master can transmit up to thirty one additional data words. The EEPROM will respond with an ACK
after each data word is received. Once all data to be written has been sent to the device, the bus Master
must issue a Stop condition (Figure 5-2) at which time the internally self-timed write cycle will begin.
www.zettadevice.com
9 / 28
Zetta ZD24C64A
The lower five bits of the word address are internally incremented following the receipt of each data word.
The higher order address bits are not incremented and retain the memory page row location. Page Write
operations are limited to writing bytes within a single physical page, regardless of the number of bytes
actually being written. When the incremented word address reaches the page boundary, the address
counter will “roll over” to the beginning of the same page. Nevertheless, creating a roll over event should be
avoided as previously loaded data in the page could become unintentionally altered.
Figure 5-2.Page Write
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
A8
SCL
Device Address Byte
SDA
1
MSB
A
A2
1
A0
Start Condition
by Master
X
X
X
A12 A11 A10
A9
MSB
ACK
from Slave
ACK
from Slave
5.3
Acknowledge Polling
An Acknowledge Polling routine can be implemented to optimize time sensitive applications that would
prefer not to wait the fixed maximum write cycle time (tWR). This method allows the application to know
immediately when the Serial EEPROM write cycle has completed, so a subsequent operation can be
started.
Once the internally self-timed write cycle has started, an Acknowledge Polling routine can be initiated. This
involves repeatedly sending a Start condition followed by a valid Device Address byte with the R/W bit set at
Logic 0. The device will not respond with an ACK while the write cycle is ongoing. Once the internal write
cycle has completed, the EEPROM will respond with an ACK, allowing a new Read or Write operation to be
immediately initiated. A flow chart has been included below in Figure 5-3 to better illustrate this technique.
Figure 5-3. Acknowledge Polling Flow Chart
Send any
Write
protocol
Send
Stop
condition
to initiate the
write cycle
Send Start
condition followed
by a valid
Device Address
byte with R/W = 0
Did
YES
the device
ACK?
Proceed to
next Read or
Write operation
NO
www.zettadevice.com
10 / 28
Zetta ZD24C64A
5.4
Write Cycle Timing
The length of the self-timed write cycle, or tWR, is defined as the amount of time from the Stop condition that
begins the internal Write operation, to the Start condition of the first Device Address byte sent to the
ZD24C64A that it subsequently responds to with an ACK. Figure 5-4 has been included to show this
measurement. During the internally self-timed write cycle, any attempts to read from or write to the memory
array will not be processed.
Figure 5-4.Write Cycle Timing
5.5
Write Protection
The ZD24C64A utilizes a hardware data protection scheme that allows the user to write protect the entire
memory contents when the WP pin is at VCC (or a valid VIH). No write protection will be set if the WP pin is at
GND or left floating.
Table 5-1.ZD24C64A Write Protect Behavior
WP Pin Voltage
Part of the Array Protected
VCC
Full Array
GND
None — Write Protection Not Enabled
The status of the WP pin is sampled at the Stop condition for every Byte Write or Page Write command prior
to the start of an internally self-timed Write operation. Changing the WP pin state after the Stop condition
has been sent will not alter or interrupt the execution of the write cycle. The WP pin state must be valid with
respect to the associated setup (tSU.WP) and hold (tHD.WP) timing as shown in the Figure 5-5 below. The WP
setup time is the amount of time that the WP state must be stable before the Stop condition is issued. The
WP hold time is the amount of time after the Stop condition that the WP state must remain stable.
If an attempt is made to write to the device while the WP pin has been asserted, the device will acknowledge
the Device Address, Word Address, and Data bytes but no write cycle will occur when the Stop condition is
issued, and the device will immediately be ready to accept a new Read or Write command.
www.zettadevice.com
11 / 28
Zetta ZD24C64A
Figure 5-5. Write Protect Setup and Hold Timing
SCL
1
2
7
8
9
Stop Condition
by Master
Data Word Input Sequence Page/Byte Write Operation
SDA IN
D7
D6
D1
D0
ACK by Slave
tSU.WP
tHD.WP
WP
www.zettadevice.com
12 / 28
Zetta ZD24C64A
6.
Read Operations
Read operations are initiated the same way as Write operations with the exception that the Read/Write
Select bit in the Device Address word must be a Logic 1. There are three Read operations:
6.1
Current Address
Read
Random Address
Read
Sequential Read
The internal data word address counter maintains the last address accessed during the last read or write
operation, incremented by one. This address stays valid between operations as long as the VCC is maintained
to the part. The address “roll over” during read is from the last byte of the last page to the first byte of the first
page of the memory.
A Current Address Read operation will output data according to the location of the internal data word
address counter. This is initiated with a Start condition, followed by a valid Device Address byte with the
R/W bit set to Logic 1. The device will ACK this sequence and the current address data word is serially
clocked out on the SDA line. All types of Read operations will be terminated if the bus Master does not
respond with an ACK (it NACKs) during the ninth clock cycle, which will force the device into standby mode.
After the NACK response, the Master may send a Stop condition to complete the protocol, or it can send a
Start condition to begin the next sequence.
Figure 6-1.Current Address Read
1
SCL
2
3
4
5
6
7
8
9
1
2
Device Address Byte
SDA
1
MSB
A2
Start Condition
by Master
6.2
4
5
6
7
8
9
D2
D1
D0
1
Data Word (n)
A
A1
3
D7
D6
D5
D4
D3
MSB
ACK
from Slave
Stop Condition
NACK
by Master
from Master
Random Read
A Random Read begins in the same way as a Byte Write operation does to load in a new data word
address. This is known as a “dummy write” sequence; however, the Data Byte and Stop condition of the
Byte Write must be omitted to prevent the part from entering an internal write cycle. Once the Device
Address and Word Address bytes are clocked in and acknowledged by the EEPROM, the bus Master must
generate another Start condition. The bus Master now initiates a Current Address Read by sending a Start
condition, followed by a valid Device Address byte with the R/W bit set to Logic 1. The EEPROM will ACK
the Device Address and serially clock out the data word on the SDA line. All types of Read operations will
be terminated if the bus Master does not respond with an ACK (it NACKs) during the ninth clock cycle,
which will force the device into standby mode. After the NACK response, the Master may send a Stop
condition to complete the protocol, or it can send a Start condition to begin the next sequence.
www.zettadevice.com
13 / 28
Zetta ZD24C64A
Figure 6-2.Random Read
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
A0
SCL
Device Address Byte
SDA
1
MSB
A
A2
A0
1
X
X
X
A12 A11
A10 A9
A8
A7
MSB
Start Condition
by Master
A6
A5
A4
A3
A2
A1
MSB
ACK
from Slave
ACK
from Slave
ACK
from Slave
Dummy Write
1
2
3
4
5
6
7
8
9
1
2
3
1
A2
A1
A0
1
6.3
5
6
7
8
9
D7
D6
D5
D4
D3
D2
D1
D0
1
MSB
Start Condition
by Master
Data Word (n)
Device Address Byte
MSB
4
Stop Condition
NACK
from Master by Master
ACK
from Slave
Sequential Read
Sequential Reads are initiated by either a Current Address Read or a Random Read. After the bus Master
receives a data word, it responds with an acknowledge. As long as the EEPROM receives an ACK, it will
continue to increment the word address and serially clock out sequential data words. When the maximum
memory address is reached, the data word address will “roll over” and the sequential read will continue from
the beginning of the memory array. All types of Read operations will be terminated if the bus Master does
not respond with an ACK (it NACKs) during the ninth clock cycle, which will force the device into standby
mode. After the NACK response, the Master may send a Stop condition to complete the protocol, or it can
1
2
3
4
5
6
7
Figure 6-3.Sequential Read
8
9
1
2
3
4
5
6
7
8
9
D2
D1
D0
SCL
Device Address Byte
SDA
1
MSB
A
A2
Start Condition
by Master
1
Data Word (n)
A0
1
D7
D6
D5
D4
D3
MSB
ACK
from Slave
ACK
from Master
www.zettadevice.com
14 / 28
Zetta ZD24C64A
7.
Device Default Condition from Zetta Device
The ZD24C64A is delivered with the EEPROM array set to Logic 1, resulting in FFh data in all locations.
8.
Electrical Specifications
8.1
Absolute Maximum Ratings
Temperature under Bias. . . . . . . -55°C to +125°C
Storage Temperature. . . . . . . . . -65°C to +150°C
Supply Voltage with respect to
ground . . . . . . . . .. . . .. . . .. . . . .-0.5V to +5.50V
Functional operation at the “Absolute Maximum Ratings” or any
other conditions beyond those indicated in Section 8.2 “DC and
AC Operating Range” is not implied or guaranteed. Stresses
beyond those listed under “Absolute Maximum Ratings” and/or
exposure to the “Absolute Maximum Ratings” for extended
periods may affect device reliability and cause permanent
damage to the device.
The voltage extremes referenced in the “Absolute Maximum
Voltage on any pin with respect to
ground . . . . .. . . .. . . .. . . . . . .-0.6V to VCC + 0.5V Ratings” are intended to accommodate short duration
undershoot/overshoot pulses that the device may be subjected
to during the course of normal operation and does not imply or
DC Output Current . . . . . . . . . . . . . . . . . . . 5.0mA guarantee functional device operation at these levels for any
extended period of time.
8.2
DC and AC Operating Range
Table 8-1.DC and AC Operating Range
Operating Temperature (Case)
Industrial Temperature Range
VCC Power Supply
Low Voltage Grade
ZD24C64A
-40°C to +85°C
1.7V to 5.5V
www.zettadevice.com
15 / 28
Zetta ZD24C64A
8.3
DC Characteristics
Table 8-2.DC Characteristics
Parameters are applicable over the operating range in specified Section 8.2, unless otherwise noted.
Symbol
VCC
Parameter
Test Conditions
Min
Typical(1)
Max
Units
Supply Voltage
1.7
5.5
V
VCC = 1.8V(2)
Supply Current, Read
VCC = 5.5V
ICC1
Supply Current, Write
ICC2
VCC = 5.5V
Read at 400kHz
0.08
0.3
mA
Read at 1MHz
0.15
0.5
mA
Write at 1MHz
0.20
1.0
mA
0.08
0.4
μA
VCC = 1.8V(2)
ISB
Standby Current
ILI
Output Leakage Current
VIL
VIH
VOL1
Notes:
0.10
0.5
μA
VIN = VCC or VSS
0.10
3.0
μA
VOUT = VCC or VSS
0.05
3.0
μA
Input Low Level(2)
–0.6
VCC x 0.3
Input High Level(2)
VCC x 0.7
VCC + 0.5
Output Low Level
VOL2
VIN = VCC or VSS
VCC = 5.5V
Input Leakage Current
ILO
Output Low Level
V
VCC = 1.8V
IOL = 0.15mA
0.2
V
VCC = 5.5V
IOL = 2.1mA
0.4
V
1.
Typical values characterized at TA = +25°C unless otherwise noted.
2.
This parameter is characterized but is not 100% tested in production.
V
www.zettadevice.com
16 / 28
Zetta ZD24C64A
8.4
AC Characteristics
Table 8-3. AC Characteristics
Parameters are applicable over operating range in Section 8.2 unless otherwise noted. Test conditions shown in Note 2.
Fast Mode
Standard Mode
VCC = 1.7V to
5.5V
Symbol
Min
Parameter
Clock Frequency, SCL
fSCL
VCC = 1.7V to
5.5V
Max
100
Fast Mode Plus
VCC = 2.5V to
5.5V
Max
Min
400
Min
Max
1000
Units
kHz
Clock Pulse Width Low
4,700
1300
500
ns
Clock Pulse Width High
4,000
600
400
ns
tLOW
tHIGH
tI
Input Filter Spike Suppression
(SCL,SDA)(1)
100
100
100
ns
tAA
Clock Low to Data Out Valid
4,500
900
450
ns
Bus Free Time between Stop and Start(1)
4,700
1300
500
ns
Start Condition Hold Time
4,000
600
250
ns
Start Condition Set-up Time
4,700
600
250
ns
ns
200
100
100
ns
tBUF
tHD.STA
tSU.STA
Data In Hold Time
tHD.DAT
Data In Set-up Time
tSU.DAT
t R
Inputs Rise Time(1)
1,000
300
100
ns
tF
Inputs Fall Time(1)
300
300
100
ns
Stop Condition Set-up Time
4,700
600
250
ns
Write Protect Setup Time
4,000
600
100
ns
Write Protect Hold Time
4,000
600
400
ns
100
50
50
ns
tSU.STO
tSU.WP
tHD.WP
tDH
Data Out Hold Time
Write Cycle Time
tWR
5
5
5
ms
www.zettadevice.com
17 / 28
Zetta ZD24C64A
Notes:
1. These parameters are determined through product characterization and are not 100% tested in production.
2. AC measurement conditions:
C
L : 100pF
RPUP (SDA bus line pull-up resistor to VCC): 1.3kΩ(1000kHz), 4kΩ (400kHz), 10kΩ (100kHz)
Input pulse voltages: 0.3 x VCC to 0.7 x VCC
Input rise and fall times: ≤ 50ns
Input and output timing reference voltages: 0.5 x VCC
Figure 8-1.
Bus Timing
8.5
Pin Capacitance
Table 8-4.Pin Capacitance(1)
Applicable over recommended operating range from TA = 25°C, f = 1.0MHz, VCC = 3.0V
Symbol
Test Condition
Max
Units
Conditions
CI/O
Input/Output Capacitance (SDA)
8
pF
VI/O = 0V
CIN
Input Capacitance (A0, A1, A2, SCL)
6
pF
VIN = 0V
Note:
8.6
Power-Up Requirements and Reset Behavior
1.
During a power-up sequence, the VCC supplied to the ZD24C64A should monotonically rise from GND to the
minimum VCC level as specified in Section 8.2, “DC and AC Operating Range” with a slew rate no greater
than 1V/μs.
8.6.1
Device Reset
To prevent inadvertent write operations or other spurious events from happening during a power-up
sequence, the ZD24C64A includes a power-on-reset (POR) circuit. Upon power-up, the device will not
respond to any commands until the VCC level crosses the internal voltage threshold (VPOR) that brings the
device out of reset and into standby mode.
The system designer must ensure that instructions are not sent to the device until the VCC supply has reached
a stable value greater than or equal to the minimum VCC level. Additionally, once the VCC is greater than or
www.zettadevice.com
18 / 28
Zetta ZD24C64A
equal to the minimum VCC level, the bus Master must wait at least tPUP before sending the first command to
the device. See Table 8-5 for the values associated with these power-up parameters.
Table 8-5.Power-up Conditions(1)
Symbol
Parameter
Min
Time required after VCC is stable before the device can accept commands.
100
tPUP
VPOR
Power-On Reset Threshold Voltage
Note:
1.
μs
1.5
1
Minimum time at VCC = 0V between power cycles.
Units
tPOFF
Max
V
ms
These parameters are characterized but they are not 100% tested in production.
If an event occurs in the system where the VCC level supplied to the ZD24C64A drops below the maximum
VPOR level specified, it is recommended that a full power cycle sequence be performed by first driving the VCC
pin to GND, waiting at least the minimum tPOFF time, and then performing a new power-up sequence in
compliance with the requirements defined in this section.
8.7
EEPROM Cell Performance Characteristics
Table 8-6.EEPROM Cell Performance Characteristics
Operation
Test Condition
Min
Max
Units
1,000,000
Write Cycles
100
Years
TA = 25°C, VCC(min)< VCC < VCC(max)
Write Endurance(1)
Data Retention(2)
Notes:
1.
Byte or Page Write Mode
TA = 55°C, VCC(min)< VCC < VCC(max)
Write endurance performance is determined through characterization and the qualification process.
2. The data retention capability is determined through qualification and is checked on each device in
production.
www.zettadevice.com
19 / 28
Zetta ZD24C64A
9.
Ordering Information
ZD
24C 64 A - SS G M T
Zetta Designator
Product Family
24 C = Standard I C-compatible
Serial EEPROM
2
Shipping Carrier Option
T = Tape and Reel, Standard Quantity Option
B = Bulk (Tubes)
Device Density
64 = 64 Kilobit
Device Revision
Operating Voltage
M = 1.7V to 5.5V
Package Device Grade
G = Low-halogen, Lead(Pb)-free
P = Lead (Pb) - free
Package Option
SS = JEDEC SOIC
X
= TSSOP
MA = 2.0mm x 3.0mm UDFN
P
= PDIP
ST = SOT23
C
= VFBGA
U
= 3x3 Grid, 5-ball WLCSP
U1 = 2x2 Grid, 4-ball WLCSP
WU = Wafer Unsawn
www.zettadevice.com
20 / 28
Zetta ZD24C64A
10.
Packaging Information
10.1
8-lead JEDEC SOIC
www.zettadevice.com
21 / 28
Zetta ZD24C64A
10.2
8-lead TSSOP
www.zettadevice.com
22 / 28
Zetta ZD24C64A
10.3
8-pad UDFN
www.zettadevice.com
23 / 28
Zetta ZD24C64A
10.4
5-lead SOT23
www.zettadevice.com
24 / 28
Zetta ZD24C64A
10.5
8-ball VFBGA
www.zettadevice.com
25 / 28
Zetta ZD24C64A
10.6
5-ball WLCSP
www.zettadevice.com
26 / 28
Zetta ZD24C64A
10.7
4-ball WLCSP
www.zettadevice.com
27 / 28
Zetta ZD24C64A
11.
Revision History
Doc. No.
Date
08/2015
Comments
Initial document release.
www.zettadevice.com
28 / 28
