DF1B-6DS-2.5RC
DF1B-6DS-2.5RC
    HRS(广濑)
    P=2.5mm
    DF1B-6DS-2.5RC
DF1B-6DS-2.5RC 数据手册
2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Features 1. New Insulation Displacement and Crimping Ideas This connector is a new type to insert the ID contacts in the case. Using this method, the following merits can be gained. Cables with different current capacities can be mixed in one case ID terminal (24, 26, 28AWG) Crimping contact (20 to 30AWG) 1 By using the ID contact and crimping contact together, different current capacity cables can be mixed in one case. 2 After connection, the contact can be replaced in excellent maintainability. 3 Because the insulation displacement area is protected by the case, high reliability can be assured. 4 Since the insulation displacement process can be performed only by replacing the applicator of the existing crimping machine, no expensive machine for insulation displacement is required. 2. Potting Header Available The high profile header is also available, corresponding to the board potting process (sealed with resin) as waterproof measures. Fig.1 Potting status Potting resin 3. Broad Variations The single row and double row contacts are aligned for "Board to Cable" and "In-line" series, respectively, while standard tin and gold plating products are available. (Refer to the applicable combination pattern on next page.) 6 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF1B Series Fig.2 ■Applications Business equipment, particularly including the copy machine and printer 2019.8 1 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) BApplicable Combination K Single Row Type Socket (Cable Side) DF1B-*S-2.5R Straight Through hole Type Pin header DF1B(Z)-*P-2.5DSA Right angle Through hole Type Pin header DF1B(Z)-*P-2.5DS Panel Mount Type Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In-line plug (Cable side) DF1BA-*EP-2.5RC K Double Row Type Socket (Cable Side) DF1B-*DS-2.5RC Straight Through hole Type Pin header DF1B(Z)-*DP-2.5DSA Right angle Through hole Type Pin header DF1B(Z)-*DP-2.5DS Panel Mount Type In-line plug (Cable side) DF1BA-*DEP-2.5RC In-line Connection Product (Cable to Cable Connection) : Full Lock Type K Single Row Type Socket (Cable Side) DF1B-*ES-2.5RC In-line plug (Cable side) DF1B-*EP-2.5RC K Double Row Type Socket (Cable Side) DF1B-*DES-2.5RC 2 In-line plug (Cable side) DF1B-*DEP-2.5RC DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Product Specifications Cable Size Current rating Rating (Note1) Voltage rating 20 to 24AWG : 3A Operating Temperature Range -35 to +85ç (Note2) 26AWG : 2A Operating Humidity Range -40 to 80% 28AWG : 1A 30AWG : 0.5A Storage Temperature Range -10 to +60ç (Note3) Storage Humidity Range -40 to 70% (Note3) 250V AC/DC ■UL CSA Safety File No. UL : E52653 CSA : LR95109 UL-CSA Safety Standard Standardized Value 20 to 22AWG : 3A Current rating Rating 24 to 28AWG : 1A Cable Size (Note1) 30AWG Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Voltage rating : 0.5A 30V AC Item Specification Condition 1. Insulation Resistance 1000Mø Min 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 30mø Max 100mA 4. Insertor/Extraction Force MIN0.44N (45gf), MAX4.4N(450gf) Measure at the square steel pin of 0.635±0.002mm 5. Vibration No electrical discontinuity of 1μs or more 6. Humidity (Steady state) 7. Temperature Cycle 8. Operating Life 9. Resistance to Soldering heat Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. Contact resistance : 30mø max. 96 hours at temperature of 40±2ç and Insulation resistance : 1000Mø min. humidity of 90% to 95% Contact resistance : 30mø max. (-55ç : 30 minutes ➝ 5 to 35ç : 10 minutes Insulation resistance : 1000Mø min. (-85ç : 30 minutes ➝ 5 to 35ç : 10 minutes) 5 cycles Tin plating : 30 cycles Contact resistance : 30mø max. Gold plating : 50 cycles No deformation of components affecting performance. Flow : 260ç for 5 seconds Manual soldering : 300ç for 3 seconds Note 1 : Current rating of header is 3A. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Product Part Socket Insulator Polyamide White ID Contact for Socket Contact Phosphor copper Tin plated or gold plated Crimping Contact for Socket Pin Header In-line Plug Material Finish Contact Phosphor copper Tin plated or gold plated Insulator Polyamide White Contact Brass Tin plated or gold plated Insulator Polyamide White Remarks UL94V-0 –––––– –––––– UL94V-0 –––––– UL94V-0 ID Contact for In-line Plug Contact Phosphor copper Tin plated or gold plated –––––– Crimping Contact for In-line Plug Contact Phosphor copper Tin plated or gold plated –––––– 3 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. KConnector 1 q Series Name : DF 1B 2 3 4 5 6 r Connector Type w Style Symbol Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. - * S 2.5 RC DF1B t Contact Pitch : 2.5mm y Contact Type S : Single row socket Blank : Standard type DS : Double row socket RC : ID/crimping socket (Note) A : In-line Plug (Simple Lock type) P : Single row pin header DSA : Straight through hole D : Pin header (Potting type) DP : Double row pin header Z : Pin header (Standard type, Tin plated) ES : Single row in-line socket e Number of Contacts DS : Right angle through hole Note : The single row socket DF1B-*S-2.5R DES : Double row in-line socket only adds "R" to the tail, which has Single Row : 2 to 16, 18, 20 EP the same meaning as "RC". Double Row : 4 to 30, 34, 40 DEP : Double row in-line plug KSocket ID Contact : Single row in-line plug DF1B - R 24 F A q w q 1. Connection Type e r e Packaging Type R : ID Blank : Bag w Applicable Cable Size F : Reel r Plating Type 24 : 24AWG 26 : 26AWG Blank : Tin plated 28 : 28AWG A KPlug ID Contact : Gold plated DF1B - 24 P R F q w q Applicable Cable Size e r e Connection Type R : ID 24 : 24AWG r Packaging Type 26 : 26AWG Blank : Bag 28 : 28AWG w Connector Type F : Reel P : Plug KCrimping Contact DF1B - 2428 SCF A q q Applicable Cable Size w e e Plating Type 2022 : 20 to 22AWG Blank : Tin plated 2428 : 24 to 28AWG A : Gold plated B : Gold plated (Note) 30 : 30AWG w Packaging Type Note: In case of the socket contact, SCF : Socket Contact/Reel "A" is attached to the tail of SC the product name. In case of : Socket Contact/Bag PCF : Plug Contact/Reel the plug contact, "B" is PC attached thereto. : Plug Contact/Bag Note : Product Numbers of Gold plated Plug Contact for 24 to 28 AWG cable are DF1-PD2428SCFB(Reel) and DF1-PD2428SCB(Bag). 4 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Single Row Socket 1.6 P=2.5 1.9 A B Note 2 11.5 A 1 n Contact No1. mark Contact No. mark 4.4 Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A DF1B- 2S-2.5R 541-0200-6 2 5 DF1B- 3S-2.5R 541-0201-9 3 7.5 2.5 DF1B-11S-2.5R 541-0209-0 11 27.5 25 5 DF1B-12S-2.5R 541-0210-0 12 30 27.5 DF1B- 4S-2.5R 541-0202-1 4 10 DF1B- 5S-2.5R 541-0203-4 5 12.5 10 7.5 DF1B-13S-2.5R 541-0211-2 13 32.5 30 DF1B-14S-2.5R 541-0212-5 14 35 32.5 DF1B- 6S-2.5R 541-0204-7 6 15 12.5 DF1B-15S-2.5R 541-0213-8 15 37.5 35 DF1B- 7S-2.5R 541-0205-0 7 17.5 15 DF1B-16S-2.5R 541-0214-0 16 40 37.5 DF1B- 8S-2.5R 541-0206-2 8 DF1B- 9S-2.5R 541-0207-5 9 20 17.5 DF1B-18S-2.5R 541-0215-3 18 45 42.5 22.5 20 DF1B-20S-2.5R 541-0216-6 20 50 47.5 DF1B-10S-2.5R 541-0208-8 10 25 22.5 RoHS Yes B RoHS Yes Note 1 : The quantity at the specific No."None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 2 contact connector contains the convex portion to prevent mis-insertion in the center at one point, which is different from the above figure. The 3 to 6 contacts connectors have the area at both ends. ■Double Row Socket A B 8 P=2.5 P=2.5 Note 2 11.5 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Photo: Contact Inserted Photo: Contact Inserted. n 1 Contact No1. mark Contact No. mark Unit : mm Part No. HRS No. No. of Contacts Part No. HRS No. No. of Contacts DF1B- 4DS-2.5RC 541-0648-0 4 2.5 DF1B-22DS-2.5RC 541-0606-0 DF1B- 6DS-2.5RC 541-0649-3 6 DF1B- 8DS-2.5RC 541-0650-2 8 10 5 DF1B-24DS-2.5RC 12.5 7.5 DF1B-26DS-2.5RC DF1B-10DS-2.5RC 541-0600-4 10 15 DF1B-12DS-2.5RC 541-0601-7 12 17.5 12.5 DF1B-14DS-2.5RC 541-0602-0 14 20 DF1B-16DS-2.5RC 541-0603-2 16 22.5 17.5 DF1B-18DS-2.5RC 541-0604-5 18 25 DF1B-20DS-2.5RC 541-0605-8 20 27.5 22.5 A B 7.5 RoHS 10 15 20 Yes A B 22 30 25 541-0607-3 24 32.5 27.5 541-0608-6 26 35 30 DF1B-28DS-2.5RC 541-0609-9 28 37.5 32.5 DF1B-30DS-2.5RC 541-0610-8 30 40 35 DF1B-34DS-2.5RC 541-0612-3 34 45 40 DF1B-36DS-2.5RC 541-0613-6 36 47.5 42.5 DF1B-40DS-2.5RC 541-0615-1 40 52.5 47.5 RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.) If needed, please order the product per bag. Note 2 : The 4 contact connector contains the convex portion to prevent miss-insertion in the center at one point, which is different from the above figure. 5 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) 5.7 2.7 ■ Single Row Straight Pin Header B K Recommended PCB Layout (t=1.6±0.1mm) A A±0.1 2.5 P=2.5±0.05 Ø1 .1 +0 0 .1 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 2 3.6 +0.1 KBoard Through-hole Diameter : Ø1.1+0 2.5 9.5 4.5 A □0.64 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 2P-2.5DSA 541-2000-8 DF1B- 2P-2.5DSA(01) 541-0225-7 01 2 2.5 7.5 DF1BZ- 3P-2.5DSA 541-2001-0 DF1B- 3P-2.5DSA(01) 541-0226-0 01 3 5.0 10.0 DF1BZ- 4P-2.5DSA 541-2002-3 DF1B- 4P-2.5DSA(01) 541-0227-2 01 4 7.5 12.5 DF1BZ- 5P-2.5DSA 541-2003-6 DF1B- 5P-2.5DSA(01) 541-0228-5 01 5 10.0 15.0 DF1BZ- 6P-2.5DSA 541-2004-9 DF1B- 6P-2.5DSA(01) 541-0229-8 01 6 12.5 17.5 DF1BZ- 7P-2.5DSA 541-2005-1 DF1B- 7P-2.5DSA(01) 541-0230-7 01 7 15.0 20.0 DF1BZ- 8P-2.5DSA 541-2006-4 DF1B- 8P-2.5DSA(01) 541-0231-0 01 8 17.5 22.5 DF1BZ- 9P-2.5DSA 541-2007-7 DF1B- 9P-2.5DSA(01) 541-0232-2 01 9 20.0 25.0 DF1BZ-10P-2.5DSA 541-2008-0 DF1B-10P-2.5DSA(01) 541-0233-5 01 10 22.5 27.5 Yes DF1BZ-11P-2.5DSA 541-2009-2 _________ _________ 11 25.0 30.0 27.5 32.5 DF1BZ-12P-2.5DSA 541-2010-1 DF1B-12P-2.5DSA(01) 541-0235-0 01 12 DF1BZ-13P-2.5DSA 541-2011-4 _________ _________ 13 30.0 35.0 DF1BZ-14P-2.5DSA 541-2012-7 DF1B-14P-2.5DSA(01) 541-0237-6 01 14 32.5 37.5 DF1BZ-15P-2.5DSA 541-2013-0 DF1B-15P-2.5DSA(01) 541-0238-9 01 15 35.0 40.0 DF1BZ-16P-2.5DSA 541-2014-2 DF1B-16P-2.5DSA(01) 541-0239-1 01 16 37.5 42.5 DF1BZ-18P-2.5DSA 541-2015-5 DF1B-18P-2.5DSA(01) 541-0240-0 01 18 42.5 47.5 RoHS 20 DF1B-20P-2.5DSA(01) 541-0241-3 01 541-2016-8 DF1BZ-20P-2.5DSA 47.5 52.5 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.) If needed, please order the product per bag. Note 2 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure.In addition, the 4 to 6 contact connectors have two concave portions at both ends. 6 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row Right Angle Pin Header K Recommended PCB Layout (t=1.6±0.1mm) B 2.5 3.6 2.7 5.7 A A±0.1 □0.64 P=2.5±0.05 Ø1 .1 +0 0 .1 A 4.5 12.5 Note 2 2.9 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +0.1 K Board Through-hole Diameter : Ø1.1+0 7 No.1 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 2P-2.5DS 541-2034-0 DF1B- 2P-2.5DS(01) 541-0225-7 01 2 2.5 7.5 DF1BZ- 3P-2.5DS 541-2035-2 DF1B- 3P-2.5DS(01) 541-0226-0 01 3 5.0 10.0 DF1BZ- 4P-2.5DS 541-2036-5 DF1B- 4P-2.5DS(01) 541-0227-2 01 4 7.5 12.5 DF1BZ- 5P-2.5DS 541-2037-8 DF1B- 5P-2.5DS(01) 541-0228-5 01 5 10.0 15.0 DF1BZ- 6P-2.5DS 541-2038-0 DF1B- 6P-2.5DS(01) 541-0229-8 01 6 12.5 17.5 DF1BZ- 7P-2.5DS 541-2039-3 DF1B- 7P-2.5DS(01) 541-0230-7 01 7 15.0 20.0 DF1BZ- 8P-2.5DS 541-2040-2 DF1B- 8P-2.5DS(01) 541-0231-0 01 8 17.5 22.5 DF1BZ- 9P-2.5DS 541-2041-5 _________ _________ 9 20.0 25.0 DF1BZ-10P-2.5DS 541-2042-8 DF1B-10P-2.5DS(01) 541-0233-5 01 10 22.5 27.5 Yes DF1BZ-11P-2.5DS 541-2043-0 _________ _________ 11 25.0 30.0 DF1BZ-12P-2.5DS 541-2044-3 DF1B-12P-2.5DS(01) 541-0235-0 01 12 27.5 32.5 DF1BZ-13P-2.5DS 541-2045-6 _________ _________ 13 30.0 35.0 DF1BZ-14P-2.5DS 541-2046-9 DF1B-14P-2.5DS(01) 541-0237-6 01 14 32.5 37.5 DF1BZ-15P-2.5DS 541-2047-1 DF1B-15P-2.5DS(01) 541-0238-9 01 15 35.0 40.0 DF1BZ-16P-2.5DS 541-2048-4 DF1B-16P-2.5DS(01) 541-0239-1 01 16 37.5 42.5 DF1BZ-18P-2.5DS 541-2049-7 DF1B-18P-2.5DS(01) 541-0240-0 01 18 42.5 47.5 RoHS 20 47.5 52.5 541-0241-3 01 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure. DF1BZ-20P-2.5DS 541-2050-6 DF1B-20P-2.5DS(01) 7 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row Straight Pin Header for Potting K Recommended PCB Layout (t=1.6±0.1mm) B A A±0.1 2.5 1.7±0.05 Ø1 P=2.5±0.05 .1 +0 0 .1 4.5 1 1. Ø 1.2 10.5 Note 3 3 17.5 1 0. + 0 Contact No1. mark 2.25±0.05 A Ø1 □0.64 2.25 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Tube Size 1.7 Unit : mm Part No. HRS No. No. of Contacts A B 7.5 Tube Package Quantity RoHS DF1BD- 2P-2.5DSA(**) 541-0800-3 ** 2 2.5 DF1BD- 3P-2.5DSA(**) 541-0801-6 ** 3 5 10 48 DF1BD- 4P-2.5DSA(**) 541-0802-9 ** 4 7.5 12.5 38 DF1BD- 5P-2.5DSA(**) 541-0803-1 ** 5 15 32 10 64pieces Yes +0.1 K Board Positioning Boss Hole Diameter : Ø1.1+0 +0.1 K Board Through-hole Diameter : Ø1.1+0 [Specific No.] –* *, (* *) (05) : Tin plated (25) : Tin plated, tube packaging Note 1 : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per pack. Note 2 : Please order the tube packaging products, multiplying the packaging quantity (pieces). Note 3 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure.In addition, the 4 to 6 contacts connectors have two concave portions at both ends. BApplicable Potting Thickness : 6mm Potting status 6 Potting resin 8 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Double Row Straight Pin Header K Recommended PCB Layout (t=1.6±0.1mm) No.2 P=2.5 2.5 A±0.3 A P=2.5±0.05 8.6 6.6 Ø1 .1 +0 0 .1 P=2.5±0.05 A B No.1 2.5 +0.1 ●Board Through-hole Diameter : Ø1.1+0 3.6 9.5 4.5 Contact No1. mark Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. □0.64 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 4DP-2.5DSA 541-2017-0 DF1B- 4DP-2.5DSA(01) 541-0651-5 01 4 7.5 2.5 RoHS DF1BZ- 6DP-2.5DSA 541-2018-3 DF1B- 6DP-2.5DSA(01) 541-0652-8 01 6 10.0 5.0 DF1BZ- 8DP-2.5DSA 541-2019-6 DF1B- 8DP-2.5DSA(01) 541-0653-0 01 8 12.5 7.5 DF1BZ-10DP-2.5DSA 541-2020-5 DF1B-10DP-2.5DSA(01) 541-0616-4 01 10 15.0 10.0 DF1BZ-12DP-2.5DSA 541-2021-8 DF1B-12DP-2.5DSA(01) 541-0617-7 01 12 17.5 12.5 DF1BZ-14DP-2.5DSA 541-2022-0 DF1B-14DP-2.5DSA(01) 541-0618-0 01 14 20.0 15.0 DF1BZ-16DP-2.5DSA 541-2023-3 DF1B-16DP-2.5DSA(01) 541-0619-2 01 16 22.5 17.5 DF1BZ-18DP-2.5DSA 541-2024-6 DF1B-18DP-2.5DSA(01) 541-0620-1 01 18 25.0 20.0 DF1BZ-20DP-2.5DSA 541-2025-9 DF1B-20DP-2.5DSA(01) 541-0621-4 01 20 27.5 22.5 Yes DF1BZ-22DP-2.5DSA 541-2026-1 DF1B-22DP-2.5DSA(01) 541-0622-7 01 22 30.0 25.0 DF1BZ-24DP-2.5DSA 541-2027-4 DF1B-24DP-2.5DSA(01) 541-0623-0 01 24 32.5 27.5 DF1BZ-26DP-2.5DSA 541-2028-7 DF1B-26DP-2.5DSA(01) 541-0624-2 01 26 35.0 30.0 DF1BZ-28DP-2.5DSA 541-2029-0 DF1B-28DP-2.5DSA(01) 541-0625-5 01 28 37.5 32.5 DF1BZ-30DP-2.5DSA 541-2030-9 DF1B-30DP-2.5DSA(01) 541-0626-8 01 30 40.0 35.0 DF1BZ-34DP-2.5DSA 541-2031-1 DF1B-34DP-2.5DSA(01) 541-0628-3 01 34 45.0 40.0 DF1BZ-36DP-2.5DSA 541-2032-4 DF1B-36DP-2.5DSA(01) 541-0629-6 01 36 47.5 42.5 DF1BZ-40DP-2.5DSA DF1B-40DP-2.5DSA(01) 40 541-0631-8 01 541-2033-7 52.5 47.5 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure. 9 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Double Row Right Angle Pin Header A K Recommended PCB Layout (t=1.6±0.1mm) B 3.3 P=2.5±0.05 Ø1 No.2 .1 2.5 □0.64 +0 0 .1 2.5±0.05 A±0.3 P=2.5 6.6 8.6 A No.1 4.5 No1. terminal indication mark 2.6 2.5 2.5 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.5 7 +0.1 K Board Through-hole Diameter : Ø1.1+0 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 4DP-2.5DS 541-2051-9 DF1B- 4DP-2.5DS(01) 541-0654-3 01 4 7.5 2.5 RoHS DF1BZ- 6DP-2.5DS 541-2052-1 DF1B- 6DP-2.5DS(01) 541-0655-6 01 6 10.0 5.0 DF1BZ- 8DP-2.5DS 541-2053-4 DF1B- 8DP-2.5DS(01) 541-0656-9 01 8 12.5 7.5 DF1BZ-10DP-2.5DS 541-2054-7 DF1B-10DP-2.5DS(01) 541-0632-0 01 10 15.0 10.0 DF1BZ-12DP-2.5DS 541-2055-0 DF1B-12DP-2.5DS(01) 541-0633-3 01 12 17.5 12.5 DF1BZ-14DP-2.5DS 541-2056-2 DF1B-14DP-2.5DS(01) 541-0634-6 01 14 20.0 15.0 DF1BZ-16DP-2.5DS 541-2057-5 DF1B-16DP-2.5DS(01) 541-0635-9 01 16 22.5 17.5 DF1BZ-18DP-2.5DS 541-2058-8 DF1B-18DP-2.5DS(01) 541-0636-1 01 18 25.0 20.0 DF1BZ-20DP-2.5DS 541-2059-0 DF1B-20DP-2.5DS(01) 541-0637-4 01 20 27.5 22.5 Yes DF1BZ-22DP-2.5DS 541-2060-0 DF1B-22DP-2.5DS(01) 541-0638-7 01 22 30.0 25.0 DF1BZ-24DP-2.5DS 541-2061-2 DF1B-24DP-2.5DS(01) 541-0639-0 01 24 32.5 27.5 DF1BZ-26DP-2.5DS 541-2062-5 DF1B-26DP-2.5DS(01) 541-0640-9 01 26 35.0 30.0 DF1BZ-28DP-2.5DS 541-2063-8 DF1B-28DP-2.5DS(01) 541-0641-1 01 28 37.5 32.5 DF1BZ-30DP-2.5DS 541-2064-0 DF1B-30DP-2.5DS(01) 541-0642-4 01 30 40.0 35.0 DF1BZ-34DP-2.5DS 541-2065-3 DF1B-34DP-2.5DS(01) 541-0644-0 01 34 45.0 40.0 DF1BZ-36DP-2.5DS 541-2066-6 DF1B-36DP-2.5DS(01) 541-0645-2 01 36 47.5 42.5 DF1BZ-40DP-2.5DS DF1B-40DP-2.5DS(01) 40 541-0647-8 01 541-2067-9 52.5 47.5 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure. 10 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Plug(Simple Lock Type) B A KApplicable Socket : DF1B-*S-2.5R 4 6.1 8.1 P=2.5 Note 2 1.5 18.5 (3.2) Contact Inserted. Contact No1. mark Contact No. mark 3 2 1 A Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1BA- 2EP-2.5RC 541-0700-9 2 2.5 7.1 DF1BA- 8EP-2.5RC 541-0706-5 8 17.5 22.1 DF1BA- 3EP-2.5RC 541-0701-1 3 5 9.6 DF1BA- 9EP-2.5RC 541-0707-8 9 20 24.6 DF1BA- 4EP-2.5RC 541-0702-4 4 7.5 DF1BA-10EP-2.5RC 541-0708-0 10 22.5 27.1 DF1BA- 5EP-2.5RC 541-0703-7 5 10 14.6 DF1BA-12EP-2.5RC 541-0710-2 12 27.5 32.1 DF1BA- 6EP-2.5RC 541-0704-0 6 12.5 17.1 DF1BA- 7EP-2.5RC 541-0705-2 7 15 19.6 12.1 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 2 contacts connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure.In addition, the 3 to 6 contact connectors contain the concave portion at both sides. +0.1 0 +0.1 0 4.2 B Panel Cutouts 6.3 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n C±0.1 D +0.1 0 Unit : mm C Panel Note 3 Applicable Plug No. of Contacts Panel Board Thickness (Note 1) D 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 DF1BA- 2EP-2.5RC 2 11.2 11.9 12.6 DF1BA- 3EP-2.5RC 3 13.7 14.4 15.1 9.8 DF1BA- 4EP-2.5RC 4 16.2 16.9 17.6 12.3 DF1BA- 5EP-2.5RC 5 18.7 19.4 20.1 14.8 DF1BA- 6EP-2.5RC 6 21.2 21.9 22.6 17.3 DF1BA- 7EP-2.5RC 7 23.7 24.4 25.1 19.8 DF1BA- 8EP-2.5RC 8 26.2 26.9 27.6 22.3 DF1BA- 9EP-2.5RC 9 28.7 29.4 30.1 24.8 DF1BA-10EP-2.5RC 10 31.2 31.9 32.6 27.3 DF1BA-12EP-2.5RC 12 36.2 36.9 37.6 32.3 7.3 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. 11 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Double Row In-line Plug (Simple Lock Type) B A KApplicable Socket : DF1B-*DS-2.5RC 5 11.2 9.2 P=2.5 1.5 18.5 Contact No1. mark Note 2 (3.2) n-1 5 3 1 n 6 4 2 A Contact Inserted. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No. mark Unit : mm Part No. HRS No. No. of Contacts DF1BA- 4DEP-2.5RC 541-0719-7 4 2.5 DF1BA- 6DEP-2.5RC 541-0720-6 6 5 DF1BA- 8DEP-2.5RC 541-0721-9 8 7.5 DF1BA-10DEP-2.5RC 541-0722-1 10 10 DF1BA-12DEP-2.5RC 541-0723-4 12 12.5 18.6 DF1BA-14DEP-2.5RC 541-0724-7 14 15 21.1 DF1BA-16DEP-2.5RC 541-0725-0 16 17.5 23.6 DF1BA-18DEP-2.5RC 541-0726-2 18 20 26.1 A Part No. HRS No. No. of Contacts A B 8.6 DF1BA-20DEP-2.5RC 541-0727-5 20 22.5 28.6 11.1 DF1BA-22DEP-2.5RC 541-0728-8 22 25 31.1 13.6 DF1BA-24DEP-2.5RC 541-0729-0 24 27.5 33.6 16.1 DF1BA-26DEP-2.5RC 541-0730-0 26 30 36.1 DF1BA-28DEP-2.5RC 541-0731-2 28 32.5 38.6 DF1BA-30DEP-2.5RC 541-0732-5 30 35 41.1 DF1BA-34DEP-2.5RC 541-0734-0 34 40 46.1 B RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 contacts connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure. B Panel Cutouts Unit : mm C C±0.1 +0.1 0 +0.1 0 9.4 5.2 D Applicable Plug Note 3 Panel D 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 DF1BA- 4DEP-2.5RC 4 12.7 13.4 14.1 8.8 DF1BA- 6DEP-2.5RC 6 15.2 15.9 16.6 11.3 DF1BA- 8DEP-2.5RC 8 17.7 18.4 19.1 13.8 DF1BA-10DEP-2.5RC 10 20.2 20.9 21.6 16.3 DF1BA-12DEP-2.5RC 12 22.7 23.4 24.1 18.8 DF1BA-14DEP-2.5RC 14 25.2 25.9 26.6 21.3 DF1BA-16DEP-2.5RC 16 27.7 28.4 29.1 23.8 DF1BA-18DEP-2.5RC 18 30.2 30.9 31.6 26.3 DF1BA-20DEP-2.5RC 20 32.7 33.4 34.1 28.8 DF1BA-22DEP-2.5RC 22 35.2 35.9 36.6 31.3 DF1BA-24DEP-2.5RC 24 37.7 38.4 39.1 33.8 DF1BA-26DEP-2.5RC 26 40.2 40.9 41.6 36.3 DF1BA-28DEP-2.5RC 28 42.7 43.4 44.1 38.8 DF1BA-30DEP-2.5RC 30 45.2 45.9 46.6 41.3 DF1BA-34DEP-2.5RC 34 50.2 50.9 51.6 46.3 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. 12 No. of Contacts Panel Board Thickness (Note 1) +0.1 0 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Socket (Full Lock Type) B 1.5 (3) 11.5 KApplicable Socket : DF1B-*EP-2.5RC 3 6 3.8 A P=2.5 Contact Inserted. Contact No. mark Contact No1. mark 2 n 3 A Unit : mm Part No. HRS No. No. of Contacts DF1B- 2ES-2.5RC 541-0320-8 DF1B- 3ES-2.5RC DF1B- 4ES-2.5RC Part No. HRS No. No. of Contacts A B 6.5 DF1B- 8ES-2.5RC 541-0326-4 8 17.5 21.5 9 DF1B- 9ES-2.5RC 541-0327-7 9 20 24 11.5 DF1B-10ES-2.5RC 541-0328-0 10 22.5 26.5 DF1B-11ES-2.5RC 541-0329-2 11 25 29 16.5 DF1B-12ES-2.5RC 541-0330-1 12 27.5 31.5 19 DF1B-13ES-2.5RC 541-0331-4 13 30 34 A B 2 2.5 541-0321-0 3 5 541-0322-3 4 7.5 DF1B- 5ES-2.5RC 541-0323-6 5 10 14 DF1B- 6ES-2.5RC 541-0324-9 6 12.5 DF1B- 7ES-2.5RC 541-0325-1 7 15 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. B Panel Cutouts 3.7 +0.1 0 1.1MIN C +0.1 0 E +0.1 0 Panel 4.0 +0.1 0 +0.1 0 D +0.1 0 Note 3 3.2 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Unit : mm E Applicable Plug No. of Contacts C D Panel Board Thickness (Note 1) 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 DF1B- 2ES-2.5RC 2 4.7 6.7 10.8 11.3 12 DF1B- 3ES-2.5RC 3 7.2 9.2 13.3 13.8 14.5 DF1B- 4ES-2.5RC 4 9.7 11.7 15.8 16.3 17 DF1B- 5ES-2.5RC 5 12.2 14.2 18.3 18.8 19.5 DF1B- 6ES-2.5RC 6 14.7 16.7 20.8 21.3 22 DF1B- 7ES-2.5RC 7 17.2 19.2 23.3 23.8 24.5 DF1B- 8ES-2.5RC 8 19.7 21.7 25.8 26.3 27 DF1B- 9ES-2.5RC 9 22.2 24.2 28.3 28.8 29.5 DF1B-10ES-2.5RC 10 24.7 26.7 30.8 31.3 32 DF1B-11ES-2.5RC 11 27.2 29.2 33.3 33.8 34.5 DF1B-12ES-2.5RC 12 29.7 31.7 35.8 36.3 37 DF1B-13ES-2.5RC 13 32.2 34.2 38.3 38.8 39.5 Note 1 : The installation hole size C will be changed according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. 13 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Double Row In-line Socket (Full Lock Type) 1.5 B 1.5 (3.2) 11.5 KApplicable Socket : DF1B-*DEP-2.5RC 4 6.5 8.7 A P=2.5 Contact Inserted. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No1. mark 1 3 5 n-1 2 4 b n Contact No. mark Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1B-10DES-2.5RC 541-0351-1 10 10 15 DF1B-24DES-2.5RC 541-0357-8 24 27.5 32.5 DF1B-12DES-2.5RC 541-0352-4 12 12.5 17.5 DF1B-26DES-2.5RC 541-0358-0 26 30 35 DF1B-14DES-2.5RC 541-0353-7 14 15 20 DF1B-28DES-2.5RC 541-0359-3 28 32.5 37.5 DF1B-16DES-2.5RC 541-0354-0 16 17.5 22.5 DF1B-30DES-2.5RC 541-0360-2 30 35 40 DF1B-18DES-2.5RC 541-0346-1 18 20 25 DF1B-32DES-2.5RC 541-0361-5 32 37.5 42.5 DF1B-20DES-2.5RC 541-0355-2 20 22.5 27.5 DF1B-34DES-2.5RC 541-0362-8 34 40 45 DF1B-22DES-2.5RC 541-0356-5 22 25 30 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. 1.6MIN B Panel Cutouts C±0.1 D +0.1 0 E +0.1 0 Note 3 +0.1 0 4.2 6.7 +0.1 0 Panel Unit : mm C Applicable Plug No. of Contacts Panel Board Thickness (Note 1) 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 E DF1B-10DES-2.5RC 10 19.1 19.8 20.5 15.2 3.7 DF1B-12DES-2.5RC 12 21.6 22.3 23 17.7 3.7 DF1B-14DES-2.5RC 14 24.1 24.8 25.5 20.2 3.7 DF1B-16DES-2.5RC 16 26.6 27.3 28 22.7 3.7 DF1B-18DES-2.5RC 18 29.1 29.8 30.5 25.2 3.7 DF1B-20DES-2.5RC 20 31.6 32.3 33 27.7 5.2 DF1B-22DES-2.5RC 22 34.1 34.8 35.5 30.2 5.2 DF1B-24DES-2.5RC 24 36.6 37.3 38 32.7 5.2 DF1B-26DES-2.5RC 26 39.1 39.8 40.5 35.2 5.2 DF1B-28DES-2.5RC 28 41.6 42.3 43 37.7 5.2 DF1B-30DES-2.5RC 30 44.1 44.8 45.5 40.2 5.2 DF1B-32DES-2.5RC 32 46.6 47.3 48 42.7 5.2 DF1B-34DES-2.5RC 34 49.1 49.8 50.5 45.2 5.2 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. 14 D DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Plug (Full Lock Type) B 3.2 2.5 6 4 KApplicable Socket : DF1B-*ES-2.5RC P=2.5 Contact Inserted. Contact No1. mark Contact No. mark A a ad1 ad2 3 2 1 5 Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1B- 2EP-2.5RC 541-0332-7 2 8.9 2.5 DF1B- 8EP-2.5RC 541-0338-3 8 23.9 17.5 DF1B- 3EP-2.5RC 541-0333-0 3 11.4 5 DF1B- 9EP-2.5RC 541-0339-6 9 26.4 20 DF1B- 4EP-2.5RC 541-0334-2 4 13.9 DF1B-10EP-2.5RC 541-0340-5 10 28.9 22.5 DF1B- 5EP-2.5RC 541-0335-5 5 16.4 10 DF1B-11EP-2.5RC 541-0341-8 11 31.4 25 DF1B- 6EP-2.5RC 541-0336-8 6 18.9 12.5 DF1B-12EP-2.5RC 541-0342-0 12 33.9 27.5 DF1B- 7EP-2.5RC 541-0337-0 7 21.4 15 DF1B-13EP-2.5RC 541-0343-3 13 36.4 30 7.5 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. ■ Double Row In-line Plug (Full Lock Type) B KApplicable Socket : DF1B-*DES-2.5RC 2.5 6.7 8.7 P=2.5 18.5 Contact Inserted. 7 8 A 1 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7 18.5 8 A Polarizing mark Part No. HRS No. No. of Contacts A DF1B-10DEP-2.5RC 541-0366-9 10 17.2 DF1B-12DEP-2.5RC 541-0367-1 12 19.7 DF1B-14DEP-2.5RC 541-0368-4 14 DF1B-16DEP-2.5RC 541-0369-7 DF1B-18DEP-2.5RC Unit : mm Part No. HRS No. No. of Contacts A B 10 DF1B-24DEP-2.5RC 541-0372-1 24 34.7 27.5 12.5 DF1B-26DEP-2.5RC 541-0373-4 26 37.2 30 22.2 15 DF1B-28DEP-2.5RC 541-0374-7 28 39.7 32.5 16 24.7 17.5 DF1B-30DEP-2.5RC 541-0375-0 30 42.2 35 541-0350-9 18 27.2 20 DF1B-32DEP-2.5RC 541-0376-2 32 44.7 37.5 DF1B-20DEP-2.5RC 541-0370-6 20 29.7 22.5 DF1B-34DEP-2.5RC 541-0377-5 34 47.2 40 DF1B-22DEP-2.5RC 541-0371-9 22 32.2 25 B RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. 15 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ ID Contact for Socket BReel Contact (10,000/reel) ※Applicable Tool : Applicator 2 1.95 0.8 10.5 7.1 15 2.5 0.975 Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter DF1B-R24F 541-0217-9 00 Tin plated 1061 24 AWG 11cores./0.16mm 0.221mm2 0.9 to 1.39mm DF1B-R24FA(06)541-0261-0 06 Gold plated 1061 24 AWG 11cores./0.16mm 0.221mm2 0.9 to 1.39mm DF1B-R26F 541-0218-1 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm Yes DF1B-R26FA(06)541-0262-3 06 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm DF1B-R28F 541-0219-4 00 Tin plated 1061,1007 28 AWG 7cores./0.127mm 0.089mm2 0.9 to 1.39mm DF1B-R28FA(06)541-0263-6 06 Gold plated 1061,1007 28 AWG 7cores./0.127mm 0.089mm2 0.9 to 1.39mm Part No. HRS No. Finish Note : If other cables are used instead of the applicable cable, contact Hirose sales department. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 2 DF1B-R24 541-0220-3 00 Tin plated 1007 24 AWG 11cores./0.16mm 0.221mm 1.39mm DF1B-R24A(06) 541-0264-9 06 Gold plated 1007 24 AWG 11cores./0.16mm 0.221mm2 1.39mm DF1B-R26 541-0221-6 00 Tin plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm Yes DF1B-R26A(06) 541-0265-1 06 Gold plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm DF1B-R28 541-0222-9 00 Tin plated 1007 28 AWG 7cores./0.127mm 0.089mm2 1.2mm DF1B-R28A(06) 541-0266-4 06 Gold plated 1007 28 AWG 7cores./0.127mm 0.089mm2 1.2mm Part No. ●ID Contact Extraction Tool : DF-C-PO(A) HRS No. Finish Note : If Manual ID tool is used, the cables in the above table are only suitable. ■ Crimping Contact for Socket 0.975 1.6 14 9.5 6.1 2.5 1.75 1.95 BReel Contact (10,000/reel) ※Applicable Tool : Applicator Part No. HRS No. DF1B-2022SCF 541-0223-1 00 1.4 1 DF1B-2022SCFA 541-0662-1 00 DF1B-2428SCF 541-0678-1 00 DF1B-2428SCFA 541-0680-3 00 DF1B-30SCF DF1B-30SCFA Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 20 AWG 21cores./0.18mm 0.540mm2 Tin plated 1061,1007 1.2 to 1.9mm 22 AWG 17cores./0.16mm 0.342mm2 20 AWG 21cores./0.18mm 0.540mm2 Gold plated 1061,1007 1.2 to 1.9mm 22 AWG 17cores./0.16mm 0.342mm2 2 24 AWG 11cores./0.16mm 0.221mm Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm Yes 28 AWG 7cores./0.127mm 0.089mm2 24 AWG 11cores./0.16mm 0.221mm2 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm Finish 28 AWG 7cores./0.127mm 0.089mm2 541-0682-9 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.6 to 1.2mm 541-0684-4 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.6 to 1.2mm Note : If other cables are used instead of the applicable cable, contact Hirose sales department. ●Crimping Contact Extraction Tool : DF-C-PO(B) BBulk Contact (100/pack) ※Applicable Tool : Manual Crimping Tool Part No. DF1B-2022SC ●Strip Length : 2.0 to 2.5mm DF1B-2022SCA DF1B-2428SC DF1B-2428SCA DF1B-30SC DF1B-30SCA Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 20 AWG 21cores./0.18mm 0.540mm2 1.8mm 1007 541-0224-4 00 Tin plated 22 AWG 17cores./0.16mm 0.342mm2 1.6mm 20 AWG 21cores./0.18mm 0.540mm2 1.8mm 541-0663-4 00 Gold plated 1007 22 AWG 17cores./0.16mm 0.342mm2 1.6mm 24 AWG 11cores./0.16mm 0.221mm2 1.5mm 541-0679-4 00 Tin plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm Yes 28 AWG 7cores./0.127mm 0.089mm2 1.2mm 2 24 AWG 11cores./0.16mm 0.221mm 1.5mm 541-0681-6 00 Gold plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm 28 AWG 7cores./0.127mm 0.089mm2 1.2mm 541-0683-1 00 Tin plated 1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm 541-0685-7 00 Gold plated 1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm HRS No. Finish Note : If Manual crimping tool is used, the cables in the above table are only suitable. 16 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ ID Contact for Plug 1.2 BReel Contact (10,000/reel) ※Applicable Tool : Applicator 1.4 0.64 0.64 DF1B-24PRF DF1B-26PRF DF1B-28PRF HRS No. Finish 541-0666-2 00 Tin plated 541-0668-8 00 Tin plated 541-0670-0 00 Tin plated Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 1061 24 AWG 11cores./0.16mm 0.221mm2 0.9 to 1.39mm 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm Yes 1061,1007 28 AWG 7cores./0.127mm 0.089mm2 0.9 to 1.39mm 2.7 0.6 15.9 Note : If other cables are used instead of the applicable cable, contact Hirose sales department. 6.5 19.4 4 Part No. Part No. ●Crimping Contact Extraction Tool : DF-C-PO(C) DF1B-24PR DF1B-26PR DF1B-28PR HRS No. Finish 541-0667-5 00 Tin plated 541-0669-0 00 Tin plated 541-0671-2 00 Tin plated Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 2 1007 24 AWG 11cores./0.16mm 0.221mm 1.39mm 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm Yes 1007 28 AWG 7cores./0.127mm 0.089mm2 1.2mm Note : If Manual ID tool is used, the cables in the above table are only suitable. ■ Crimping Contact for Plug 6.5 BReel Contact (10,000/reel) ※Applicable Tool : Applicator 1.2 1.4 13.9 Ø0.64 18.9 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 20 AWG 21cores./0.18mm 0.540mm2 1.2 to 1.9mm DF1B-2022PCF 541-0259-9 00 Tin plated 1061,1007 22 AWG 17cores./0.16mm 0.342mm2 2 20 AWG 21cores./0.18mm 0.540mm 1.2 to 1.9mm DF1B-2022PCFB 541-0690-7 00 Gold plated 1061,1007 22 AWG 17cores./0.16mm 0.342mm2 24 AWG 11cores./0.16mm 0.221mm2 DF1B-2428PCF 541-0664-7 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm Yes 28 AWG 7cores./0.127mm 0.089mm2 24 AWG 11cores./0.16mm 0.221mm2 DF1-PD2428SCFB 541-0660-6 00 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm 28 AWG 7cores./0.127mm 0.089mm2 DF1B-30PCF 541-0686-0 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.8 to 1.1mm DF1B-30PCFB 541-0688-5 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.8 to 1.1mm Part No. HRS No. Finish Note : If other cables are used instead of the applicable cable, contact Hirose sales department. ●Crimping Contact Extraction Tool : DF-C-PO(C) ●Strip Length : 3.0 to 3.7mm BBulk Contact (100/pack) ※Applicable Tool : Manual Crimping Tool Applicable Cable(Tin Plated Annealing Copper Wire) RoHS UL Style AWG Wire Construction Sectional Area Jacket Diameter 20 AWG 21cores./0.18mm 0.540mm2 1.8mm DF1B-2022PC 541-0260-8 00 Tin plated 1061,1007 22 AWG 17cores./0.16mm 0.342mm2 1.6mm 20 AWG 21cores./0.18mm 0.540mm2 1.8mm DF1B-2022PCB 541-0691-0 00 Gold plated 1061,1007 22 AWG 17cores./0.16mm 0.342mm2 1.6mm 24 AWG 11cores./0.16mm 0.221mm2 1.5mm DF1B-2428PC 541-0665-0 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm Yes 28 AWG 7cores./0.127mm 0.089mm2 1.2mm 24 AWG 11cores./0.16mm 0.221mm2 1.5mm DF1-PD2428SCB 541-0661-9 00 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm 28 AWG 7cores./0.127mm 0.089mm2 1.2mm DF1B-30PC 541-0687-2 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm DF1B-30PCB 541-0689-8 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm Part No. HRS No. Finish Note : If Manual crimping tool is used, the cables in the above table are only suitable. 17 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) B Applicable Tool Connection Type Type Applicator ID Manual ID tool HRS No. Applicable Contacts 901-4507-4 DF1B-R**F(A)(##) **=24,26,28 (##)=blank,(06) AP105-DF1B-PR 901-4536-2 DF1B-**PRF**=24,26,28 DF1B-T2428HR 550-0171-0 DF1B-R**(A)(##) **=24,26,28 (##)=blank,(06) DF1B-T2428PHR 550-0221-7 DF1B-**PR/PRB **=24,26,28 AP105-DF1B-2022S 901-4510-9 DF1B-2022SCF(A) AP105-DF1B-2428S 901-4518-0 DF1B-2428SCF(A) AP105-DF1B-30S 901-4517-8 DF1B-30SCF(A) AP105-DF1B-2022P 901-4509-0 DF1B-2022PCF(B) AP105-DF1B-2428P 901-4521-5 DF1B-2428PCF,DF1-PD2428SCFB AP105-DF1B-30P 901-4519-3 DF1B-30PCF(B) DF1B-TA2022SHC 550-0182-7 DF1B-2022SC(A) DF1B-TA2428SHC 550-0209-1 DF1B-2428SC(A) Manual DF1B-TA30SHC 550-0211-3 DF1B-30SC(A) crimping tool DF1B-TA2022PHC 550-0183-0 DF1B-2022PC(B) DF1B-TA2428PHC 550-0224-5 DF1B-2428PC,DF1-PD2428SCB DF1B-TA30PHC 550-0210-0 DF1B-30PC(B) Applicator Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. AP105-DF1B-R Crimping Press Main Unit Extraction Tool CM-105C 901-0001-0 __________________________________ DF-C-PO(A) 550-0170-8 DF1B-R**F DF-C-PO(B) 550-0179-2 DF1B-****SCF DF-C-PO(C) 550-0198-7 DF1B-****PC,DF1B-**PRF Note 1 : Please conduct crimping work according to the "Crimp Quality Standards" (ETAD-H0909-00 or ETAD-H0913-00) and "Crimp Condition Table". Note 2 : If a trouble has occurred due to tools which are not designated by Hirose, Hirose won't quarantee any product. 18 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Crimping 19 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Applicable Tool BPrecautions 1. Recommended Soldering Condition Flow : 260ç for 5 seconds 2. Cleaning Condition Refer to Wire to Board Connector Use Hand book. Manual soldering : 300ç for 3 seconds 3. Connection Condition Refer to Wire to Board Connector Use Hand book. 4. Cautions ■The color phase of this product is slightly different from that of the formed product according to the manufacturing lot and future storage conditions, but the difference doesn't affect the performance. 5. Precaution Please refer to the following documents. ■Crimp Quality Standards (ETAD-H0909-00, ETAD-H0913-00) ■User Guide for Wire-to-Board Connector 20
DF1B-6DS-2.5RC 价格&库存
很抱歉,暂时无法提供与“DF1B-6DS-2.5RC”相匹配的价格&库存,您可以联系我们找货
DF1B-6DS-2.5RC
    • 1+1.755251+0.19698
    • 10+1.4408810+0.16170
    • 50+0.9169250+0.10290
    • 100+0.86453100+0.09702
    • 500+0.83833500+0.09408
    • 1000+0.812131000+0.09114
    • 2000+0.751002000+0.08428
    • 4000+0.751004000+0.08428
