IT213
IT213
    SCHAFFNER(夏弗纳)
    IT213
IT213 数据手册
DATA SHEET Pulse Transformers IT series with double secondary winding Pulse Transformer with Double Secondary Winding Galvanic separation of drive and power circuit Approvals & Compliances Voltage resistance up to 4 kV Ignition current up to 1 A Turns ratio up to 3:1:1 Features and Benefits Galvanic separation with secondary winding Voltage resistance up to 4 kV Allows high potential difference voltage scaling Vacuum potting Very low partial discharge effects PCB through hole mounting Custom-specific versions on request Typical Applications Gate drive circuit Technical Specifications Power supplies Power converters Nominal operating voltage Up to 500 V Frequency converters Operating frequency 40 kHz max. 500 kHz max. for data transmission DC to 40000 Hz Switching applications Ignition currents 0.025 to 1 A @ 40°C Rise time 0.4 to 4 µs Test voltage Up/50 Hz/2 s max. according to VDE 110b Max. partial discharge voltage 1.5 x Unom Temperature range (operation and storage) -25°C to +70°C (25/70/21) Flammability corresponding to UL 94 V-0 listed materials DC/DC converters Line coupling transformers in high-speed data transmission 2 Pulse Transformers Schaffner Group DATA SHEET 15. Jun 2022 Pulse Transformer Selection Table Pulse transformer Turns ratio Ignition Voltage current Iign Voltage Rise Inductance * Resistance Coupling Input/Output capacitance connections time area time Unom Up V0t tr Lp Lstr Rp Rs Ck Weight [A] [V] [kV] [Vμs] [μs] [mH] [μH] [Ω] [Ω] [pF] IT 143 1:1:1 0.025 500 4 800 0.6 15 200 3 3 10 02 [g] 14 IT 242 1:1:1 0.1 500 3.2 250 0.9 2.5 75 0.75 0.75 7 02 6 IT 243 1:1:1 0.1 500 3.2 250 1 2.5 85 0.8 0.8 7 02 6 IT 213 1:1:1 0.25 380 2.5 450 0.4 6.5 20 1.4 1.4 40 02 9 IT 233 1:1:1 0.25 500 4 300 1.3 3 45 0.8 0.8 7 02 13 IT 253 1:1:1 0.25 500 3.2 160 1.3 1.1 45 0.55 0.55 6 02 6 IT 312 1:1:1 0.25 380 2.5 1200 1 21 35 2.4 2.7 30 02 24 IT 313 1:1:1 1 380 2.5 450 0.6 3 6 0.33 0.4 27 02 24 IT 249 2:1:1 0.25 500 3.2 330 4 17 140 3.1 1.5 9 02 6 IT 244 3:1:1 0.1 500 3.2 200 0.7 15 70 2.8 0.9 9 02 6 IT 234 3:1:1 0.25 500 4 280 1 17 40 2 0.7 9 02 13 IT 314 3:1:1 1 380 2.5 500 1 35 20 1.6 0.7 30 02 25 * Tolerance: +50%; -30% Explanations: – tr rise time at given load resistor R and 70% of the output pulse height. – Lp primary inductance measured at 1 kHz (secondary coile open). – Lstr stray inductance measured at the secondary side, short circuit at the primary side. If there are several secondary coils only one at the time is connected (measuring frequency 10 kHz). – The ignition current is a set peak value where the voltage drop over the coil resistance is still insignificant (mostly below 1 V). Mechanical Data IT 213 IT 243, IT 244, IT 249, IT 253 IT 242 IT 143, IT 154, IT 233, IT 234 3 Pulse Transformers Schaffner Group DATA SHEET 15. Jun 2022 IT 312, IT 313, IT 314 Dimensions IT 213 IT 243 IT 244 IT 249 IT 253 IT 242 IT 143 IT 154 IT 233 IT 234 IT 312 IT 313 IT 314 Tol. Ø19 17.6 17.6 17.6 17.6 17.6 27* 27* 27* 27* 25.5* 25.5* 25.5* ±0.1 16.7 16.7 16.7 16.7 16.7 22.5* 22.5* 22.5* 22.5* 25.5* 25.5* 25.5* ±0.1 C 20 11.3 11.3 11.3 11.3 11.3 13.7 13.7 13.7 13.7 25* 25* 25* ±0.1 D 5 5 5 5 5 5 5 5 5 5 5 5 5 +1/-0 E 0.45 0.42 0.42 0.42 0.42 0.42 0.45 0.45 0.45 0.45 0.5 0.5 0.5 F 1 0.4 0.4 0.4 0.4 0.4 0.7 0.7 0.7 0.7 0.5 0.5 0.5 G 10 15.3 15.3 15.3 15.3 15.3 20 20 20 20 15 15 15 H 5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 ±0.2 I 2.1 2.1 2.1 2.1 2.1 3.75 3.75 3.75 3.75 5.25 5.25 5.25 ±0.2 K 5 5 5 5 5 5 5 5 ±0.2 L 2 2 2 2 2 3 3 3 A B * Tolerance is ±0.2 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. 2.5 2.5 2.5 2.5 4 Pulse Transformers Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
IT213 价格&库存
很抱歉,暂时无法提供与“IT213”相匹配的价格&库存,您可以联系我们找货
