2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard)
■Features
1. New Insulation Displacement and Crimping Ideas
This connector is a new type to insert the ID contacts in the case. Using this
method, the following merits can be gained.
Cables with different current capacities
can be mixed in one case
ID terminal (24, 26, 28AWG)
Crimping contact (20 to 30AWG)
1 By using the ID contact and crimping contact together, different current
capacity cables can be mixed in one case.
2 After connection, the contact can be replaced in excellent maintainability.
3 Because the insulation displacement area is protected by the case, high
reliability can be assured.
4 Since the insulation displacement process can be performed only by
replacing the applicator of the existing crimping machine, no expensive
machine for insulation displacement is required.
2. Potting Header Available
The high profile header is also available, corresponding to the board potting
process (sealed with resin) as waterproof measures.
Fig.1
Potting status
Potting resin
3. Broad Variations
The single row and double row contacts are aligned for "Board to Cable" and
"In-line" series, respectively, while standard tin and gold plating products are
available.
(Refer to the applicable combination pattern on next page.)
6
Jul.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF1B Series
Fig.2
■Applications
Business equipment, particularly including the copy machine and printer
2019.8
1
DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard)
BApplicable Combination
K Single Row Type
Socket (Cable Side)
DF1B-*S-2.5R
Straight Through hole Type
Pin header
DF1B(Z)-*P-2.5DSA
Right angle Through hole Type
Pin header
DF1B(Z)-*P-2.5DS
Panel Mount Type
In-line plug (Cable side)
DF1BA-*EP-2.5RC
K Double Row Type
Socket (Cable Side)
DF1B-*DS-2.5RC
Pin header
DF1B(Z)-*DP-2.5DSA
Pin header
DF1B(Z)-*DP-2.5DS
Panel Mount Type
DF1BA-*DEP-2.5RC
In-line Connection Product (Cable to Cable Connection) : Full Lock Type
K Single Row Type
Socket (Cable Side)
DF1B-*ES-2.5RC
DF1B-*EP-2.5RC
K Double Row Type
Socket (Cable Side)
DF1B-*DES-2.5RC
2
DF1B-*DEP-2.5RC
■Product Specifications
Cable Size
Current rating
Rating
(Note1)
Voltage rating
20 to 24AWG : 3A
Operating Temperature Range
-35 to +85ç (Note2)
26AWG
: 2A
Operating Humidity Range
-40 to 80%
28AWG
: 1A
30AWG
: 0.5A
Storage Temperature Range
-10 to +60ç (Note3)
Storage Humidity Range
-40 to 70% (Note3)
250V AC/DC
■UL CSA Safety File No.
UL
: E52653
CSA : LR95109
UL-CSA Safety Standard Standardized Value
20 to 22AWG : 3A
Current rating
Rating
24 to 28AWG : 1A
Cable Size
(Note1)
30AWG
Voltage rating
: 0.5A
30V AC
Item
Specification
Condition
1. Insulation Resistance
1000Mø Min
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
30mø Max
100mA
4. Insertor/Extraction Force
MIN0.44N (45gf), MAX4.4N(450gf)
Measure at the square steel pin of 0.635±0.002mm
5. Vibration
No electrical discontinuity of 1μs or more
6. Humidity (Steady state)
7. Temperature Cycle
8. Operating Life
9. Resistance to Soldering heat
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
2 hours in each of the 3 directions.
Contact resistance : 30mø max.
96 hours at temperature of 40±2ç and
Insulation resistance : 1000Mø min.
humidity of 90% to 95%
(-55ç : 30 minutes ➝ 5 to 35ç : 10 minutes
(-85ç : 30 minutes ➝ 5 to 35ç : 10 minutes) 5 cycles
Tin plating : 30 cycles
Gold plating : 50 cycles
No deformation of components affecting performance.
Flow : 260ç for 5 seconds
Manual soldering : 300ç for 3 seconds
Note 1 : Current rating of header is 3A.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
■Materials / Finish
Product
Part
Socket
Insulator
Polyamide
White
ID Contact for Socket
Contact
Phosphor copper
Tin plated or gold plated
Crimping Contact for Socket
Pin Header
In-line Plug
Material
Finish
Contact
Phosphor copper
Insulator
Polyamide
White
Contact
Brass
Insulator
Polyamide
White
Remarks
UL94V-0
UL94V-0
UL94V-0
ID Contact for In-line Plug
Contact
Phosphor copper
Crimping Contact for In-line Plug
Contact
Phosphor copper
3
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
KConnector
1
q Series Name : DF 1B
2
3
4
5
6
r Connector Type
w Style Symbol
t Contact Pitch : 2.5mm
y Contact Type
S
: Single row socket
Blank : Standard type
DS
: Double row socket
RC : ID/crimping socket (Note)
A
: In-line Plug (Simple Lock type)
P
: Single row pin header
DSA : Straight through hole
D
: Pin header (Potting type)
DP
: Double row pin header
Z
: Pin header (Standard type, Tin plated)
ES
: Single row in-line socket
e Number of Contacts
- * S 2.5 RC
DF1B
DS
: Right angle through hole
Note : The single row socket DF1B-*S-2.5R
DES : Double row in-line socket
only adds "R" to the tail, which has
Single Row : 2 to 16, 18, 20
EP
the same meaning as "RC".
Double Row : 4 to 30, 34, 40
DEP : Double row in-line plug
KSocket ID Contact
: Single row in-line plug
DF1B - R 24 F A
q
w
q 1. Connection Type
e
r
e Packaging Type
R : ID
Blank : Bag
w Applicable Cable Size
F
: Reel
r Plating Type
24 : 24AWG
26 : 26AWG
Blank : Tin plated
28 : 28AWG
A
KPlug ID Contact
: Gold plated
DF1B - 24 P R F
q
w
q Applicable Cable Size
e
r
e Connection Type
R : ID
24 : 24AWG
r Packaging Type
26 : 26AWG
Blank : Bag
28 : 28AWG
w Connector Type
F
: Reel
P : Plug
KCrimping Contact
DF1B - 2428 SCF A
q
w
e
e Plating Type
2022 : 20 to 22AWG
Blank : Tin plated
2428 : 24 to 28AWG
A
: Gold plated
B
: Gold plated (Note)
30
: 30AWG
w Packaging Type
Note: In case of the socket contact,
SCF : Socket Contact/Reel
"A" is attached to the tail of
SC
the product name. In case of
: Socket Contact/Bag
PCF : Plug Contact/Reel
the plug contact, "B" is
PC
attached thereto.
: Plug Contact/Bag
Note : Product Numbers of Gold plated Plug Contact for 24 to 28 AWG cable
are DF1-PD2428SCFB(Reel) and DF1-PD2428SCB(Bag).
4
■Single Row Socket
1.6
P=2.5
1.9
A
B
Note 2
11.5
A
1
n
Contact No1. mark
Contact No. mark
4.4
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
Part No.
HRS No.
No. of Contacts
A
DF1B- 2S-2.5R
541-0200-6
2
5
DF1B- 3S-2.5R
541-0201-9
3
7.5
2.5
DF1B-11S-2.5R
541-0209-0
11
27.5
25
5
DF1B-12S-2.5R
541-0210-0
12
30
27.5
DF1B- 4S-2.5R
541-0202-1
4
10
DF1B- 5S-2.5R
541-0203-4
5
12.5
10
7.5
DF1B-13S-2.5R
541-0211-2
13
32.5
30
DF1B-14S-2.5R
541-0212-5
14
35
32.5
DF1B- 6S-2.5R
541-0204-7
6
15
12.5
DF1B-15S-2.5R
541-0213-8
15
37.5
35
DF1B- 7S-2.5R
541-0205-0
7
17.5
15
DF1B-16S-2.5R
541-0214-0
16
40
37.5
DF1B- 8S-2.5R
541-0206-2
8
DF1B- 9S-2.5R
541-0207-5
9
DF1B-18S-2.5R
541-0215-3
18
45
42.5
22.5
DF1B-20S-2.5R
541-0216-6
47.5
DF1B-10S-2.5R
541-0208-8
10
25
22.5
RoHS
Yes
B
RoHS
Yes
Note 1 : The quantity at the specific No."None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag.
Note 2 : The 2 contact connector contains the convex portion to prevent mis-insertion in the center at one point, which is different from
the above figure. The 3 to 6 contacts connectors have the area at both ends.
■Double Row Socket
A
B
8
P=2.5
P=2.5
Note 2
11.5
Photo: Contact Inserted
Photo: Contact Inserted.
n
1
Contact No1. mark
Contact No. mark
Unit : mm
Part No.
HRS No.
No. of Contacts
Part No.
HRS No.
No. of Contacts
DF1B- 4DS-2.5RC
541-0648-0
4
2.5
DF1B-22DS-2.5RC
541-0606-0
DF1B- 6DS-2.5RC
541-0649-3
6
DF1B- 8DS-2.5RC
541-0650-2
8
10
5
DF1B-24DS-2.5RC
12.5
7.5
DF1B-26DS-2.5RC
DF1B-10DS-2.5RC
541-0600-4
10
15
DF1B-12DS-2.5RC
541-0601-7
12
17.5 12.5
DF1B-14DS-2.5RC
541-0602-0
14
DF1B-16DS-2.5RC
541-0603-2
16
22.5 17.5
DF1B-18DS-2.5RC
541-0604-5
18
25
DF1B-20DS-2.5RC
541-0605-8
A
B
7.5
RoHS
10
15
Yes
A
B
22
30
25
541-0607-3
24
32.5
27.5
541-0608-6
26
35
30
DF1B-28DS-2.5RC
541-0609-9
28
37.5
32.5
DF1B-30DS-2.5RC
541-0610-8
30
40
35
DF1B-34DS-2.5RC
541-0612-3
34
45
40
DF1B-36DS-2.5RC
541-0613-6
36
47.5
42.5
DF1B-40DS-2.5RC
541-0615-1
40
52.5
47.5
RoHS
Yes
Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.) If needed, please order the product per bag.
Note 2 : The 4 contact connector contains the convex portion to prevent miss-insertion in the center at one point, which is different
from the above figure.
5
5.7
2.7
■ Single Row Straight Pin Header
B
K Recommended PCB Layout (t=1.6±0.1mm)
A
A±0.1
2.5
P=2.5±0.05
Ø1
.1
+0
0 .1
Note 2
3.6
+0.1
KBoard Through-hole Diameter : Ø1.1+0
2.5
9.5
4.5
A
□0.64
Unit : mm
Tin plated
Gold plated
Part No.
HRS No.
Part No.
HRS No.
No. of Contacts
A
B
DF1BZ- 2P-2.5DSA
541-2000-8
DF1B- 2P-2.5DSA(01)
541-0225-7 01
2
2.5
7.5
DF1BZ- 3P-2.5DSA
541-2001-0
DF1B- 3P-2.5DSA(01)
541-0226-0 01
3
5.0 10.0
DF1BZ- 4P-2.5DSA
541-2002-3
DF1B- 4P-2.5DSA(01)
541-0227-2 01
4
7.5 12.5
DF1BZ- 5P-2.5DSA
541-2003-6
DF1B- 5P-2.5DSA(01)
541-0228-5 01
5
10.0 15.0
DF1BZ- 6P-2.5DSA
541-2004-9
DF1B- 6P-2.5DSA(01)
541-0229-8 01
6
12.5 17.5
DF1BZ- 7P-2.5DSA
541-2005-1
DF1B- 7P-2.5DSA(01)
541-0230-7 01
7
15.0 20.0
DF1BZ- 8P-2.5DSA
541-2006-4
DF1B- 8P-2.5DSA(01)
541-0231-0 01
8
17.5 22.5
DF1BZ- 9P-2.5DSA
541-2007-7
DF1B- 9P-2.5DSA(01)
541-0232-2 01
9
20.0 25.0
DF1BZ-10P-2.5DSA
541-2008-0
DF1B-10P-2.5DSA(01)
541-0233-5 01
10
22.5 27.5 Yes
DF1BZ-11P-2.5DSA
541-2009-2
_________
_________
11
25.0 30.0
27.5 32.5
DF1BZ-12P-2.5DSA
541-2010-1
DF1B-12P-2.5DSA(01)
541-0235-0 01
12
DF1BZ-13P-2.5DSA
541-2011-4
_________
_________
13
30.0 35.0
DF1BZ-14P-2.5DSA
541-2012-7
DF1B-14P-2.5DSA(01)
541-0237-6 01
14
32.5 37.5
DF1BZ-15P-2.5DSA
541-2013-0
DF1B-15P-2.5DSA(01)
541-0238-9 01
15
35.0 40.0
DF1BZ-16P-2.5DSA
541-2014-2
DF1B-16P-2.5DSA(01)
541-0239-1 01
16
37.5 42.5
DF1BZ-18P-2.5DSA
541-2015-5
DF1B-18P-2.5DSA(01)
541-0240-0 01
18
42.5 47.5
RoHS
DF1B-20P-2.5DSA(01)
541-0241-3 01
541-2016-8
DF1BZ-20P-2.5DSA
47.5 52.5
Note 2 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is
different from the above figure.In addition, the 4 to 6 contact connectors have two concave portions at both ends.
6
■ Single Row Right Angle Pin Header
B
2.5
3.6
2.7
5.7
A
A±0.1
□0.64
P=2.5±0.05
Ø1
.1
+0
0 .1
A
4.5
12.5
Note 2
2.9
+0.1
K Board Through-hole Diameter : Ø1.1+0
7
No.1
Unit : mm
Tin plated
Gold plated
Part No.
HRS No.
Part No.
HRS No.
No. of Contacts
A
B
DF1BZ- 2P-2.5DS
541-2034-0
DF1B- 2P-2.5DS(01)
541-0225-7 01
2
2.5
7.5
DF1BZ- 3P-2.5DS
541-2035-2
DF1B- 3P-2.5DS(01)
541-0226-0 01
3
5.0 10.0
DF1BZ- 4P-2.5DS
541-2036-5
DF1B- 4P-2.5DS(01)
541-0227-2 01
4
7.5 12.5
DF1BZ- 5P-2.5DS
541-2037-8
DF1B- 5P-2.5DS(01)
541-0228-5 01
5
10.0 15.0
DF1BZ- 6P-2.5DS
541-2038-0
DF1B- 6P-2.5DS(01)
541-0229-8 01
6
12.5 17.5
DF1BZ- 7P-2.5DS
541-2039-3
DF1B- 7P-2.5DS(01)
541-0230-7 01
7
15.0 20.0
DF1BZ- 8P-2.5DS
541-2040-2
DF1B- 8P-2.5DS(01)
541-0231-0 01
8
17.5 22.5
DF1BZ- 9P-2.5DS
541-2041-5
_________
_________
9
20.0 25.0
DF1BZ-10P-2.5DS
541-2042-8
DF1B-10P-2.5DS(01)
541-0233-5 01
10
22.5 27.5 Yes
DF1BZ-11P-2.5DS
541-2043-0
_________
_________
11
25.0 30.0
DF1BZ-12P-2.5DS
541-2044-3
DF1B-12P-2.5DS(01)
541-0235-0 01
12
27.5 32.5
DF1BZ-13P-2.5DS
541-2045-6
_________
_________
13
30.0 35.0
DF1BZ-14P-2.5DS
541-2046-9
DF1B-14P-2.5DS(01)
541-0237-6 01
14
32.5 37.5
DF1BZ-15P-2.5DS
541-2047-1
DF1B-15P-2.5DS(01)
541-0238-9 01
15
35.0 40.0
DF1BZ-16P-2.5DS
541-2048-4
DF1B-16P-2.5DS(01)
541-0239-1 01
16
37.5 42.5
DF1BZ-18P-2.5DS
541-2049-7
DF1B-18P-2.5DS(01)
541-0240-0 01
18
42.5 47.5
RoHS
541-0241-3 01
Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag.
Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is
DF1BZ-20P-2.5DS
541-2050-6
DF1B-20P-2.5DS(01)
7
■ Single Row Straight Pin Header for Potting
B
A
A±0.1
2.5
1.7±0.05
Ø1
P=2.5±0.05
.1
+0
0 .1
4.5
1
1.
Ø
1.2
10.5
Note 3
3
17.5
1
0.
+ 0
Contact No1. mark
2.25±0.05
A
Ø1
□0.64
2.25
B Tube Size
1.7
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
7.5
Tube Package Quantity RoHS
DF1BD- 2P-2.5DSA(**) 541-0800-3 **
2
2.5
DF1BD- 3P-2.5DSA(**) 541-0801-6 **
3
5
10
48
DF1BD- 4P-2.5DSA(**) 541-0802-9 **
4
7.5
12.5
38
DF1BD- 5P-2.5DSA(**) 541-0803-1 **
5
15
32
10
64pieces
Yes
+0.1
K Board Positioning Boss Hole Diameter : Ø1.1+0
+0.1
[Specific No.] –* *, (* *)
(05) : Tin plated
(25) : Tin plated, tube packaging
Note 1 : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per pack.
Note 2 : Please order the tube packaging products, multiplying the packaging quantity (pieces).
Note 3 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is
different from the above figure.In addition, the 4 to 6 contacts connectors have two concave portions at both ends.
BApplicable Potting Thickness : 6mm
Potting status
6
Potting resin
8
■ Double Row Straight Pin Header
No.2
P=2.5
2.5
A±0.3
A
P=2.5±0.05
8.6
6.6
Ø1
.1
+0
0 .1
P=2.5±0.05
A
B
No.1
2.5
+0.1
●Board Through-hole Diameter : Ø1.1+0
3.6
9.5
4.5
Contact No1. mark
□0.64
Unit : mm
Tin plated
Gold plated
Part No.
HRS No.
Part No.
HRS No.
No. of Contacts
A
B
DF1BZ- 4DP-2.5DSA
541-2017-0
DF1B- 4DP-2.5DSA(01)
541-0651-5 01
4
7.5
2.5
RoHS
DF1BZ- 6DP-2.5DSA
541-2018-3
DF1B- 6DP-2.5DSA(01)
541-0652-8 01
6
10.0 5.0
DF1BZ- 8DP-2.5DSA
541-2019-6
DF1B- 8DP-2.5DSA(01)
541-0653-0 01
8
12.5 7.5
DF1BZ-10DP-2.5DSA
541-2020-5
DF1B-10DP-2.5DSA(01)
541-0616-4 01
10
15.0 10.0
DF1BZ-12DP-2.5DSA
541-2021-8
DF1B-12DP-2.5DSA(01)
541-0617-7 01
12
17.5 12.5
DF1BZ-14DP-2.5DSA
541-2022-0
DF1B-14DP-2.5DSA(01)
541-0618-0 01
14
20.0 15.0
DF1BZ-16DP-2.5DSA
541-2023-3
DF1B-16DP-2.5DSA(01)
541-0619-2 01
16
22.5 17.5
DF1BZ-18DP-2.5DSA
541-2024-6
DF1B-18DP-2.5DSA(01)
541-0620-1 01
18
25.0 20.0
DF1BZ-20DP-2.5DSA
541-2025-9
DF1B-20DP-2.5DSA(01)
541-0621-4 01
27.5 22.5 Yes
DF1BZ-22DP-2.5DSA
541-2026-1
DF1B-22DP-2.5DSA(01)
541-0622-7 01
22
30.0 25.0
DF1BZ-24DP-2.5DSA
541-2027-4
DF1B-24DP-2.5DSA(01)
541-0623-0 01
24
32.5 27.5
DF1BZ-26DP-2.5DSA
541-2028-7
DF1B-26DP-2.5DSA(01)
541-0624-2 01
26
35.0 30.0
DF1BZ-28DP-2.5DSA
541-2029-0
DF1B-28DP-2.5DSA(01)
541-0625-5 01
28
37.5 32.5
DF1BZ-30DP-2.5DSA
541-2030-9
DF1B-30DP-2.5DSA(01)
541-0626-8 01
30
40.0 35.0
DF1BZ-34DP-2.5DSA
541-2031-1
DF1B-34DP-2.5DSA(01)
541-0628-3 01
34
45.0 40.0
DF1BZ-36DP-2.5DSA
541-2032-4
DF1B-36DP-2.5DSA(01)
541-0629-6 01
36
47.5 42.5
DF1BZ-40DP-2.5DSA
DF1B-40DP-2.5DSA(01)
40
541-0631-8 01
541-2033-7
52.5 47.5
Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center area at one point, which is
9
■Double Row Right Angle Pin Header
A
B
3.3
P=2.5±0.05
Ø1
No.2
.1
2.5
□0.64
+0
0 .1
2.5±0.05
A±0.3
P=2.5
6.6
8.6
A
No.1
4.5
No1. terminal indication mark
2.6
2.5
2.5
12.5
7
+0.1
Unit : mm
Tin plated
Gold plated
Part No.
HRS No.
Part No.
HRS No.
No. of Contacts
A
B
DF1BZ- 4DP-2.5DS
541-2051-9
DF1B- 4DP-2.5DS(01)
541-0654-3 01
4
7.5
2.5
RoHS
DF1BZ- 6DP-2.5DS
541-2052-1
DF1B- 6DP-2.5DS(01)
541-0655-6 01
6
10.0 5.0
DF1BZ- 8DP-2.5DS
541-2053-4
DF1B- 8DP-2.5DS(01)
541-0656-9 01
8
12.5 7.5
DF1BZ-10DP-2.5DS
541-2054-7
DF1B-10DP-2.5DS(01)
541-0632-0 01
10
15.0 10.0
DF1BZ-12DP-2.5DS
541-2055-0
DF1B-12DP-2.5DS(01)
541-0633-3 01
12
17.5 12.5
DF1BZ-14DP-2.5DS
541-2056-2
DF1B-14DP-2.5DS(01)
541-0634-6 01
14
20.0 15.0
DF1BZ-16DP-2.5DS
541-2057-5
DF1B-16DP-2.5DS(01)
541-0635-9 01
16
22.5 17.5
DF1BZ-18DP-2.5DS
541-2058-8
DF1B-18DP-2.5DS(01)
541-0636-1 01
18
25.0 20.0
DF1BZ-20DP-2.5DS
541-2059-0
DF1B-20DP-2.5DS(01)
541-0637-4 01
27.5 22.5 Yes
DF1BZ-22DP-2.5DS
541-2060-0
DF1B-22DP-2.5DS(01)
541-0638-7 01
22
30.0 25.0
DF1BZ-24DP-2.5DS
541-2061-2
DF1B-24DP-2.5DS(01)
541-0639-0 01
24
32.5 27.5
DF1BZ-26DP-2.5DS
541-2062-5
DF1B-26DP-2.5DS(01)
541-0640-9 01
26
35.0 30.0
DF1BZ-28DP-2.5DS
541-2063-8
DF1B-28DP-2.5DS(01)
541-0641-1 01
28
37.5 32.5
DF1BZ-30DP-2.5DS
541-2064-0
DF1B-30DP-2.5DS(01)
541-0642-4 01
30
40.0 35.0
DF1BZ-34DP-2.5DS
541-2065-3
DF1B-34DP-2.5DS(01)
541-0644-0 01
34
45.0 40.0
DF1BZ-36DP-2.5DS
541-2066-6
DF1B-36DP-2.5DS(01)
541-0645-2 01
36
47.5 42.5
DF1BZ-40DP-2.5DS
DF1B-40DP-2.5DS(01)
40
541-0647-8 01
541-2067-9
52.5 47.5
10
■ Single Row In-line Plug(Simple Lock Type)
B
A
KApplicable Socket : DF1B-*S-2.5R
4
6.1
8.1
P=2.5
Note 2
1.5
18.5
(3.2)
Contact Inserted.
Contact No1. mark
Contact No. mark
3 2 1
A
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
Part No.
HRS No.
No. of Contacts
A
B
DF1BA- 2EP-2.5RC
541-0700-9
2
2.5
7.1
DF1BA- 8EP-2.5RC
541-0706-5
8
17.5
22.1
DF1BA- 3EP-2.5RC
541-0701-1
3
5
9.6
DF1BA- 9EP-2.5RC
541-0707-8
9
DF1BA- 4EP-2.5RC
541-0702-4
4
7.5
DF1BA-10EP-2.5RC
541-0708-0
10
22.5
27.1
DF1BA- 5EP-2.5RC
541-0703-7
5
10
14.6
DF1BA-12EP-2.5RC
541-0710-2
12
27.5
32.1
DF1BA- 6EP-2.5RC
541-0704-0
6
12.5
17.1
DF1BA- 7EP-2.5RC
541-0705-2
7
15
19.6
12.1
RoHS
Yes
RoHS
Yes
Note 2 : The 2 contacts connector contains the concave portion to prevent miss-insertion in the center area at one point, which is
different from the above figure.In addition, the 3 to 6 contact connectors contain the concave portion at both sides.
+0.1
B Panel Cutouts
6.3
n
C±0.1
D
+0.1
Unit : mm
C
Panel
Note 3
Applicable Plug
No. of Contacts
Panel Board Thickness (Note 1)
D
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
DF1BA- 2EP-2.5RC
2
11.2
11.9
12.6
DF1BA- 3EP-2.5RC
3
13.7
14.4
15.1
9.8
DF1BA- 4EP-2.5RC
4
16.2
16.9
17.6
12.3
DF1BA- 5EP-2.5RC
5
18.7
19.4
20.1
14.8
DF1BA- 6EP-2.5RC
6
21.2
21.9
22.6
17.3
DF1BA- 7EP-2.5RC
7
23.7
24.4
25.1
19.8
DF1BA- 8EP-2.5RC
8
26.2
26.9
27.6
22.3
DF1BA- 9EP-2.5RC
9
28.7
29.4
30.1
24.8
DF1BA-10EP-2.5RC
10
31.2
31.9
32.6
27.3
DF1BA-12EP-2.5RC
12
36.2
36.9
37.6
32.3
7.3
Note 1 : The installation hole size C according to panel board thickness.
Note 2 : Fabricate installation holes so that no burr can occur.
Note 3 : At the panel tab portion, use the surface that will not be rounded.
11
■ Double Row In-line Plug (Simple Lock Type)
B
A
KApplicable Socket : DF1B-*DS-2.5RC
5
11.2
9.2
P=2.5
1.5
18.5
Contact No1. mark
Note 2
(3.2)
n-1
5 3 1
n
6 4 2
A
Contact Inserted.
Contact No. mark
Unit : mm
Part No.
HRS No.
No. of Contacts
DF1BA- 4DEP-2.5RC
541-0719-7
4
2.5
DF1BA- 6DEP-2.5RC
541-0720-6
6
5
DF1BA- 8DEP-2.5RC
541-0721-9
8
7.5
DF1BA-10DEP-2.5RC
541-0722-1
10
10
DF1BA-12DEP-2.5RC
541-0723-4
12
12.5
18.6
DF1BA-14DEP-2.5RC
541-0724-7
14
15
21.1
DF1BA-16DEP-2.5RC
541-0725-0
16
17.5
23.6
DF1BA-18DEP-2.5RC
541-0726-2
18
A
Part No.
HRS No.
No. of Contacts
A
B
8.6
DF1BA-20DEP-2.5RC
541-0727-5
28.6
11.1
DF1BA-22DEP-2.5RC
541-0728-8
22
25
31.1
13.6
DF1BA-24DEP-2.5RC
541-0729-0
24
27.5
33.6
16.1
DF1BA-26DEP-2.5RC
541-0730-0
26
30
36.1
DF1BA-28DEP-2.5RC
541-0731-2
28
32.5
38.6
DF1BA-30DEP-2.5RC
541-0732-5
30
35
41.1
DF1BA-34DEP-2.5RC
541-0734-0
34
40
46.1
B
RoHS
Yes
RoHS
Yes
Note 2 : The 4 contacts connector contains the concave portion to prevent miss-insertion in the center at one point, which is different
B Panel Cutouts
Unit : mm
C
C±0.1
+0.1
5.2
D
Applicable Plug
Note 3
Panel
D
0.5 to 1.2 1.3 to 1.6 1.7 to 2.0
DF1BA- 4DEP-2.5RC
4
12.7
13.4
14.1
8.8
DF1BA- 6DEP-2.5RC
6
15.2
15.9
16.6
11.3
DF1BA- 8DEP-2.5RC
8
17.7
18.4
19.1
13.8
DF1BA-10DEP-2.5RC
10
20.2
20.9
21.6
16.3
DF1BA-12DEP-2.5RC
12
22.7
23.4
24.1
18.8
DF1BA-14DEP-2.5RC
14
25.2
25.9
26.6
21.3
DF1BA-16DEP-2.5RC
16
27.7
28.4
29.1
23.8
DF1BA-18DEP-2.5RC
18
30.2
30.9
31.6
26.3
DF1BA-20DEP-2.5RC
33.4
34.1
28.8
DF1BA-22DEP-2.5RC
22
35.2
35.9
36.6
31.3
DF1BA-24DEP-2.5RC
24
37.7
38.4
39.1
33.8
DF1BA-26DEP-2.5RC
26
40.2
40.9
41.6
36.3
DF1BA-28DEP-2.5RC
28
42.7
43.4
44.1
38.8
DF1BA-30DEP-2.5RC
30
45.2
45.9
46.6
41.3
DF1BA-34DEP-2.5RC
34
50.2
50.9
51.6
46.3
12
No. of Contacts Panel Board Thickness (Note 1)
+0.1
■ Single Row In-line Socket (Full Lock Type)
B
1.5
(3)
11.5
KApplicable Socket : DF1B-*EP-2.5RC
3
6
3.8
A
P=2.5
Contact Inserted.
Contact No. mark
Contact No1. mark
2
n
3
A
Unit : mm
Part No.
HRS No.
No. of Contacts
DF1B- 2ES-2.5RC
541-0320-8
DF1B- 3ES-2.5RC
DF1B- 4ES-2.5RC
Part No.
HRS No.
No. of Contacts
A
B
6.5
DF1B- 8ES-2.5RC
541-0326-4
8
17.5
21.5
9
DF1B- 9ES-2.5RC
541-0327-7
9
11.5
DF1B-10ES-2.5RC
541-0328-0
10
22.5
26.5
DF1B-11ES-2.5RC
541-0329-2
11
25
29
16.5
DF1B-12ES-2.5RC
541-0330-1
12
27.5
31.5
19
DF1B-13ES-2.5RC
541-0331-4
13
30
34
A
B
2
2.5
541-0321-0
3
5
541-0322-3
4
7.5
DF1B- 5ES-2.5RC
541-0323-6
5
10
14
DF1B- 6ES-2.5RC
541-0324-9
6
12.5
DF1B- 7ES-2.5RC
541-0325-1
7
15
RoHS
Yes
RoHS
Yes
B Panel Cutouts
3.7
+0.1
1.1MIN
C
+0.1
E
+0.1
Panel
4.0
+0.1
D
+0.1
Note 3
3.2
1
Unit : mm
E
Applicable Plug
No. of Contacts
C
D
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
DF1B- 2ES-2.5RC
2
4.7
6.7
10.8
11.3
12
DF1B- 3ES-2.5RC
3
7.2
9.2
13.3
13.8
14.5
DF1B- 4ES-2.5RC
4
9.7
11.7
15.8
16.3
17
DF1B- 5ES-2.5RC
5
12.2
14.2
18.3
18.8
19.5
DF1B- 6ES-2.5RC
6
14.7
16.7
20.8
21.3
22
DF1B- 7ES-2.5RC
7
17.2
19.2
23.3
23.8
24.5
DF1B- 8ES-2.5RC
8
19.7
21.7
25.8
26.3
27
DF1B- 9ES-2.5RC
9
22.2
24.2
28.3
28.8
29.5
DF1B-10ES-2.5RC
10
24.7
26.7
30.8
31.3
32
DF1B-11ES-2.5RC
11
27.2
29.2
33.3
33.8
34.5
DF1B-12ES-2.5RC
12
29.7
31.7
35.8
36.3
37
DF1B-13ES-2.5RC
13
32.2
34.2
38.3
38.8
39.5
Note 1 : The installation hole size C will be changed according to panel board thickness.
13
■ Double Row In-line Socket (Full Lock Type)
1.5
B
1.5
(3.2)
11.5
KApplicable Socket : DF1B-*DEP-2.5RC
4
6.5
8.7
A
P=2.5
Contact Inserted.
Contact No1. mark
1
3
5
n-1
2
4
b
n
Contact No. mark
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
Part No.
HRS No.
No. of Contacts
A
B
DF1B-10DES-2.5RC
541-0351-1
10
10
15
DF1B-24DES-2.5RC
541-0357-8
24
27.5
32.5
DF1B-12DES-2.5RC
541-0352-4
12
12.5
17.5
DF1B-26DES-2.5RC
541-0358-0
26
30
35
DF1B-14DES-2.5RC
541-0353-7
14
15
DF1B-28DES-2.5RC
541-0359-3
28
32.5
37.5
DF1B-16DES-2.5RC
541-0354-0
16
17.5
22.5
DF1B-30DES-2.5RC
541-0360-2
30
35
40
DF1B-18DES-2.5RC
541-0346-1
18
DF1B-32DES-2.5RC
541-0361-5
32
37.5
42.5
DF1B-20DES-2.5RC
541-0355-2
27.5
DF1B-34DES-2.5RC
541-0362-8
34
40
45
DF1B-22DES-2.5RC
541-0356-5
22
25
30
RoHS
Yes
RoHS
Yes
1.6MIN
B Panel Cutouts
C±0.1
D
+0.1
E
+0.1
Note 3
+0.1
6.7
+0.1
Panel
Unit : mm
C
Applicable Plug
No. of Contacts
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
E
DF1B-10DES-2.5RC
10
19.1
19.8
20.5
15.2
3.7
DF1B-12DES-2.5RC
12
21.6
22.3
23
17.7
3.7
DF1B-14DES-2.5RC
14
24.1
24.8
25.5
20.2
3.7
DF1B-16DES-2.5RC
16
26.6
27.3
28
22.7
3.7
DF1B-18DES-2.5RC
18
29.1
29.8
30.5
25.2
3.7
DF1B-20DES-2.5RC
32.3
33
27.7
5.2
DF1B-22DES-2.5RC
22
34.1
34.8
35.5
30.2
5.2
DF1B-24DES-2.5RC
24
36.6
37.3
38
32.7
5.2
DF1B-26DES-2.5RC
26
39.1
39.8
40.5
35.2
5.2
DF1B-28DES-2.5RC
28
41.6
42.3
43
37.7
5.2
DF1B-30DES-2.5RC
30
44.1
44.8
45.5
40.2
5.2
DF1B-32DES-2.5RC
32
46.6
47.3
48
42.7
5.2
DF1B-34DES-2.5RC
34
49.1
49.8
50.5
45.2
5.2
14
D
■ Single Row In-line Plug (Full Lock Type)
B
3.2
2.5
6
4
KApplicable Socket : DF1B-*ES-2.5RC
P=2.5
Contact Inserted.
Contact No1. mark
Contact No. mark
A
a ad1 ad2
3
2
1
5
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
Part No.
HRS No.
No. of Contacts
A
B
DF1B- 2EP-2.5RC
541-0332-7
2
8.9
2.5
DF1B- 8EP-2.5RC
541-0338-3
8
23.9
17.5
DF1B- 3EP-2.5RC
541-0333-0
3
11.4
5
DF1B- 9EP-2.5RC
541-0339-6
9
26.4
DF1B- 4EP-2.5RC
541-0334-2
4
13.9
DF1B-10EP-2.5RC
541-0340-5
10
28.9
22.5
DF1B- 5EP-2.5RC
541-0335-5
5
16.4
10
DF1B-11EP-2.5RC
541-0341-8
11
31.4
25
DF1B- 6EP-2.5RC
541-0336-8
6
18.9
12.5
DF1B-12EP-2.5RC
541-0342-0
12
33.9
27.5
DF1B- 7EP-2.5RC
541-0337-0
7
21.4
15
DF1B-13EP-2.5RC
541-0343-3
13
36.4
30
7.5
RoHS
Yes
RoHS
Yes
■ Double Row In-line Plug (Full Lock Type)
B
KApplicable Socket : DF1B-*DES-2.5RC
2.5
6.7
8.7
P=2.5
18.5
Contact Inserted.
7
8
A
1
7
18.5
8
A
Polarizing mark
Part No.
HRS No.
No. of Contacts
A
DF1B-10DEP-2.5RC
541-0366-9
10
17.2
DF1B-12DEP-2.5RC
541-0367-1
12
19.7
DF1B-14DEP-2.5RC
541-0368-4
14
DF1B-16DEP-2.5RC
541-0369-7
DF1B-18DEP-2.5RC
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
10
DF1B-24DEP-2.5RC
541-0372-1
24
34.7
27.5
12.5
DF1B-26DEP-2.5RC
541-0373-4
26
37.2
30
22.2
15
DF1B-28DEP-2.5RC
541-0374-7
28
39.7
32.5
16
24.7
17.5
DF1B-30DEP-2.5RC
541-0375-0
30
42.2
35
541-0350-9
18
27.2
DF1B-32DEP-2.5RC
541-0376-2
32
44.7
37.5
DF1B-20DEP-2.5RC
541-0370-6
22.5
DF1B-34DEP-2.5RC
541-0377-5
34
47.2
40
DF1B-22DEP-2.5RC
541-0371-9
22
32.2
25
B
RoHS
Yes
RoHS
Yes
15
■ ID Contact for Socket
BReel Contact (10,000/reel) ※Applicable Tool : Applicator
2
1.95
0.8
10.5
7.1
15
2.5
0.975
Applicable Cable(Tin Plated Annealing Copper Wire)
RoHS
UL Style AWG Wire Construction Sectional Area Jacket Diameter
DF1B-R24F
541-0217-9 00 Tin plated
1061 24 AWG 11cores./0.16mm 0.221mm2 0.9 to 1.39mm
DF1B-R24FA(06)541-0261-0 06 Gold plated 1061 24 AWG 11cores./0.16mm 0.221mm2 0.9 to 1.39mm
DF1B-R26F
541-0218-1 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm
Yes
DF1B-R26FA(06)541-0262-3 06 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm
DF1B-R28F
541-0219-4 00 Tin plated 1061,1007 28 AWG 7cores./0.127mm 0.089mm2 0.9 to 1.39mm
DF1B-R28FA(06)541-0263-6 06 Gold plated 1061,1007 28 AWG 7cores./0.127mm 0.089mm2 0.9 to 1.39mm
Part No.
HRS No.
Finish
Note : If other cables are used instead of the applicable cable, contact Hirose sales department.
BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool
RoHS
2
DF1B-R24
541-0220-3 00 Tin plated
1007 24 AWG 11cores./0.16mm 0.221mm 1.39mm
DF1B-R24A(06) 541-0264-9 06 Gold plated 1007 24 AWG 11cores./0.16mm 0.221mm2 1.39mm
DF1B-R26
541-0221-6 00 Tin plated
1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm
Yes
DF1B-R26A(06) 541-0265-1 06 Gold plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm
DF1B-R28
541-0222-9 00 Tin plated
1007 28 AWG 7cores./0.127mm 0.089mm2 1.2mm
DF1B-R28A(06) 541-0266-4 06 Gold plated 1007 28 AWG 7cores./0.127mm 0.089mm2 1.2mm
Part No.
●ID Contact Extraction
Tool : DF-C-PO(A)
HRS No.
Finish
Note : If Manual ID tool is used, the cables in the above table are only suitable.
■ Crimping Contact for Socket
0.975
1.6
14
9.5
6.1
2.5
1.75
1.95
Part No.
HRS No.
DF1B-2022SCF
541-0223-1 00
1.4
1
DF1B-2022SCFA 541-0662-1 00
DF1B-2428SCF
541-0678-1 00
DF1B-2428SCFA 541-0680-3 00
DF1B-30SCF
DF1B-30SCFA
RoHS
20 AWG 21cores./0.18mm 0.540mm2
1.2 to 1.9mm
22 AWG 17cores./0.16mm 0.342mm2
1.2 to 1.9mm
2
Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm
Yes
Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm
Finish
541-0682-9 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.6 to 1.2mm
541-0684-4 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.6 to 1.2mm
●Crimping Contact
Extraction Tool :
DF-C-PO(B)
BBulk Contact (100/pack) ※Applicable Tool : Manual Crimping Tool
Part No.
DF1B-2022SC
●Strip Length :
2.0 to 2.5mm
DF1B-2022SCA
DF1B-2428SC
DF1B-2428SCA
DF1B-30SC
DF1B-30SCA
RoHS
20 AWG 21cores./0.18mm 0.540mm2 1.8mm
1007
541-0224-4 00 Tin plated
22 AWG 17cores./0.16mm 0.342mm2 1.6mm
541-0663-4 00 Gold plated 1007
24 AWG 11cores./0.16mm 0.221mm2 1.5mm
541-0679-4 00 Tin plated
Yes
2
24 AWG 11cores./0.16mm 0.221mm 1.5mm
541-0681-6 00 Gold plated 1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm
541-0683-1 00 Tin plated
1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm
541-0685-7 00 Gold plated 1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm
HRS No.
Finish
Note : If Manual crimping tool is used, the cables in the above table are only suitable.
16
■ ID Contact for Plug
1.2
1.4
0.64
0.64
DF1B-24PRF
DF1B-26PRF
DF1B-28PRF
HRS No.
Finish
541-0666-2 00 Tin plated
541-0668-8 00 Tin plated
541-0670-0 00 Tin plated
RoHS
1061
1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.39mm Yes
2.7
0.6
15.9
6.5
19.4
4
Part No.
Part No.
●Crimping Contact
Extraction Tool :
DF-C-PO(C)
DF1B-24PR
DF1B-26PR
DF1B-28PR
HRS No.
Finish
541-0667-5 00 Tin plated
541-0669-0 00 Tin plated
541-0671-2 00 Tin plated
RoHS
2
1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm Yes
■ Crimping Contact for Plug
6.5
1.2
1.4
13.9
Ø0.64
18.9
RoHS
1.2 to 1.9mm
DF1B-2022PCF
541-0259-9 00 Tin plated 1061,1007
2
1.2 to 1.9mm
DF1B-2022PCFB 541-0690-7 00 Gold plated 1061,1007
DF1B-2428PCF
541-0664-7 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm
Yes
DF1-PD2428SCFB 541-0660-6 00 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 0.9 to 1.5mm
DF1B-30PCF
541-0686-0 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.8 to 1.1mm
DF1B-30PCFB
541-0688-5 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 0.8 to 1.1mm
Part No.
HRS No.
Finish
●Crimping Contact
Extraction Tool :
DF-C-PO(C)
●Strip Length :
3.0 to 3.7mm
RoHS
DF1B-2022PC
541-0260-8 00 Tin plated 1061,1007
DF1B-2022PCB 541-0691-0 00 Gold plated 1061,1007
DF1B-2428PC
541-0665-0 00 Tin plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm
Yes
DF1-PD2428SCB 541-0661-9 00 Gold plated 1061,1007 26 AWG 7cores./0.16mm 0.141mm2 1.3mm
DF1B-30PC
541-0687-2 00 Tin plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm
DF1B-30PCB
541-0689-8 00 Gold plated 1061,1007 30 AWG 7cores./0.1mm 0.055mm2 1.1mm
Part No.
HRS No.
Finish
17
B Applicable Tool
Connection Type
Type
Applicator
ID
Manual ID tool
HRS No.
Applicable Contacts
901-4507-4
DF1B-R**F(A)(##) **=24,26,28 (##)=blank,(06)
AP105-DF1B-PR
901-4536-2
DF1B-**PRF**=24,26,28
DF1B-T2428HR
550-0171-0
DF1B-R**(A)(##) **=24,26,28 (##)=blank,(06)
DF1B-T2428PHR
550-0221-7
DF1B-**PR/PRB **=24,26,28
AP105-DF1B-2022S
901-4510-9
DF1B-2022SCF(A)
AP105-DF1B-2428S
901-4518-0
DF1B-2428SCF(A)
AP105-DF1B-30S
901-4517-8
DF1B-30SCF(A)
AP105-DF1B-2022P
901-4509-0
DF1B-2022PCF(B)
AP105-DF1B-2428P
901-4521-5
DF1B-2428PCF,DF1-PD2428SCFB
AP105-DF1B-30P
901-4519-3
DF1B-30PCF(B)
DF1B-TA2022SHC
550-0182-7
DF1B-2022SC(A)
DF1B-TA2428SHC
550-0209-1
DF1B-2428SC(A)
Manual
DF1B-TA30SHC
550-0211-3
DF1B-30SC(A)
crimping tool
DF1B-TA2022PHC
550-0183-0
DF1B-2022PC(B)
DF1B-TA2428PHC
550-0224-5
DF1B-2428PC,DF1-PD2428SCB
DF1B-TA30PHC
550-0210-0
DF1B-30PC(B)
Applicator
Part No.
AP105-DF1B-R
Crimping
Press Main Unit
Extraction Tool
CM-105C
901-0001-0
__________________________________
DF-C-PO(A)
550-0170-8
DF1B-R**F
DF-C-PO(B)
550-0179-2
DF1B-****SCF
DF-C-PO(C)
550-0198-7
DF1B-****PC,DF1B-**PRF
Note 1 : Please conduct crimping work according to the "Crimp Quality Standards"
(ETAD-H0909-00 or ETAD-H0913-00) and "Crimp Condition Table".
Note 2 : If a trouble has occurred due to tools which are not designated by Hirose,
Hirose won't quarantee any product.
18
B Crimping
19
B Applicable Tool
BPrecautions
1. Recommended Soldering Condition
2. Cleaning Condition
Refer to Wire to Board Connector Use Hand book.
3. Connection Condition
4. Cautions
■The color phase of this product is slightly different from that of the formed product according to
the manufacturing lot and future storage conditions, but the difference doesn't affect the
performance.
5. Precaution
Please refer to the following documents.
■Crimp Quality Standards (ETAD-H0909-00, ETAD-H0913-00)
■User Guide for Wire-to-Board Connector
