DF30FC-34DP-0.4V(82) 数据手册
0.4mm Pitch, 0.9mm Height, Board-to-Board / Board-to-FPC Connectors
DF30 Series
Space-saving design
Connector footprint is minimized.
0)
(0.4
(0.90)
(3 .
76
56
( 4.
22)
(10.
Features
High contact reliability
1. High-density mounting
This connector offers a space-saving design that
reduces the connector footprint.
The low stacking height of 0.9mm is highly suited for
applications that require a low mounted height. (Fig.1)
2. High contact reliability
DF30*-*DP-0.4V
Projections on the header terminals increase the
wiping ability and provide superior mating reliability.
During mating, the projections of the header
terminals produce a tactile click, which helps to
confirm proper insertion. (Fig.2)
3. Self-alignment feature
A self-alignment range of 0.3mm is provided on the
receptacle and allows for easier mating in tight
spaces. (Fig.3)
DF30*-*DS-0.4V
strengthen mating retention.
4. Wide selection of pin counts
Standard pin counts are 20, 22, 24, 30, 34, 40, 50,
60, 70, and 80 positions. Smaller pin counts are
also available that are applicable to LCD and
camera modules in cell phones.
Mated height: 0.9 mm
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Fig.1
Fig.2
Wide self-alignment range: 0.3 mm
5. Suitable for automatic mounting
Although this connector is extremely small, it still
has a sufficient vacuum area for pick-and-place
machines to hold the part.
Receptacle area : 1.12mm
Header area : 1.11mm
0.3mm
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.12r
1
DF30 Series●0.4mm Pitch, 0.9mm Height, Board-to-Board / Board-to-FPC Connectors
Product Specifications
Rating
Operating temperature range : -35ç to 85ç (Note 1)
Rated current 0.3A
Rated voltage 30V AC Operating humidity range
: Relative humidity 20% to 80%
Item
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
Specification
50Mø min.
No flashover or insulation breakdown.
100mø max.
4. Vibration
No electrical discontinuity of 1µs or more
5. Humidity
Contact resistance : 100mø max.
Insulation resistance : 25Mø min.
6. Temperature cycle
Insulation resistance : 50Mø min.
Storage temperature range -10ç to 60ç (Note 2)
Storage humidity range
Relative humidity 40% to 70% (Note 2)
Conditions
100V DC
100V AC / 1 minute
100 mA
Frequency : 10 to 55 Hz, single amplitude of
0.75mm, 2 hours, 3 axis
96 hours at temperature of 40ç±2ç and RH of
90% to 95%
Temperature : -55ç➝+5ç to +35ç➝+85ç➝+5ç to +35ç
Duration : 30➝10➝30➝10(Minutes)
5 cycles
7. Durability
Contact resistance : 100 mø max.
(insertions/withdrawals)
50 cycles
8. Resistance to
soldering heat
Reflow : At the recommended temperature profile
Manual soldering: 350ç for 3 seconds
No deformation of components affecting
performance.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating temperature range
and humidity range covers non-conducting condition of installed connectors in storage, shipment or during transportation.
Materials
Connectors
Receptacles and
Headers
Component
Insulator
Contacts
Material
LCP
Phosphor bronze
Finish
Color : Black
Gold plated
Product Number Structure
Receptacles and Headers
DF30 FC * DS - 0.4
q
w
e
r
t
V
y
u
qSeries name: DF30
tContact pitch : 0.4mm
wConfiguration
yTermination section
FC/RC : Without metal fittings, without bosses
V : Straight SMT
eNumber of contacts : 20, 22, 24, 30, 34, 40, 50, 60, 70, 80 uPackaging
(81) : Embossed tape packaging (5,000 pcs/reel)
rConnector type
DS : Double row receptacle
(82) : Embossed tape packaging (1,000 pcs/reel)
DP : Double row header
2
Remarks
UL94V-0
Receptacles
A
B
Note 2
3.76
P=0.4
C
0.15
Flat surface
HRS logo
0.08
0.9
CAV. NO.
HRS No.
DF30FC-20DS-0.4V(**)
DF30FC-22DS-0.4V(**)
DF30FC-24DS-0.4V(**)
DF30FC-30DS-0.4V(**)
DF30FC-34DS-0.4V(**)
DF30FC-40DS-0.4V(**)
DF30FC-50DS-0.4V(**)
DF30FC-60DS-0.4V(**)
DF30FC-70DS-0.4V(**)
DF30FC-80DS-0.4V(**)
684-1109-8 **
684-1110-7 **
684-1111-0 **
684-1112-2 **
684-1113-5 **
684-1078-6 **
684-1114-8 **
684-1082-3 **
684-1115-0 **
684-1116-3 **
A
B
C
6.22 3.6
6.62 4.0
7.02 4.4
8.22 5.6
9.02 6.4
10.22 7.6
12.22 9.6
14.22 11.6
16.22 13.6
18.22 15.6
RoHS
BRecommended PCB
mounting pattern
B ±0.02
P=0.4±0.02
1.2
1.36
1.6
2.0
2.4
2.8
3.2
4.86 +0.05
Part No.
Yes
0.23±0.02
Recommended solder paste thickness: 120 μm
Note 1 : Order by number of reels.
Note 2 : Receptacles with 24 or fewer contacts positions will not have recessed areas.
Header
A
B
2.32
3.12
P=0.4
Note 2
[Specification number] -**, (**)
Note 2
A
CAV. NO.
C
0.15
Flat surface
HRS logo
0.08
0.8
Unit : mm
HRS No.
DF30RC-20DP-0.4V(**)
DF30RC-22DP-0.4V(**)
DF30RC-24DP-0.4V(**)
DF30RC-30DP-0.4V(**)
DF30RC-34DP-0.4V(**)
DF30RC-40DP-0.4V(**)
DF30RC-50DP-0.4V(**)
DF30RC-60DP-0.4V(**)
DF30FC-70DP-0.4V(**)
DF30FC-80DP-0.4V(**)
684-1268-1 **
684-1269-4 **
684-1270-3 **
684-1271-6 **
684-1272-9 **
684-1273-1 **
684-1275-7 **
684-1276-0 **
684-1077-3 **
684-1144-9 **
A
B
5.14 3.6
5.54 4.0
5.94 4.4
7.14 5.6
7.94 6.4
9.14 7.6
11.14 9.6
13.14 11.6
15.14 13.6
17.14 15.6
C
RoHS
BRecommended PCB
mounting pattern
1.2
B ±0.02
P=0.4±0.02
1.36
1.6
2.0
2.4
2.8
3.2
Yes
Part No.
No. of
contacts
24
30
34
40
50
60
70
80
3.42 +0.05
Unit : mm
No. of
contacts
24
30
34
40
50
60
70
80
4.56
0.23±0.02
3
Packaging Specification
Embossed Carrier Tape Dimensions - Receptacle
Reel Dimensions
0.2
3±
Unreeling direction
A
Ø380±2
Ø80±1
PS
A
B±0.1
A±0.3
A
.1
+00
F
Part number label
Ø1
4±0.1
8±0.1
2±0.1
C±0.1
5
Ø1.
1.75±0.1
F-F
(1.7)
1.4±0.15
0.3±0.1
D±0.5
E±1
G-G
H F
0.2±0.05
G
G
Unreeling direction
Unit : mm
.1
+0 0
H 75
R0
R0
.7
5
Part No.
DF30#-20DS-0.4V(**)
DF30#-22DS-0.4V(**)
DF30#-24DS-0.4V(**)
DF30#-30DS-0.4V(**)
DF30#-34DS-0.4V(**)
DF30#-40DS-0.4V(**)
DF30#-50DS-0.4V(**)
DF30#-60DS-0.4V(**)
DF30#-70DS-0.4V(**)
DF30#-80DS-0.4V(**)
A
B
16.0
C
D
E
7.5
17.5
21.5
11.5
25.5
29.5
14.2
33.5
37.5
24.0
32.0
28.4
Embossed tape 32mm or wider will have perforated feed holes on two sides.
Embossed Carrier Tape Dimensions - Header
Reel Dimensions
E-E
0.2
Part number label
3±
Unreeling direction
Ø380±2
A
A
A±0.3
PS
Ø80±1
E
Ø1
1.75±0.1
(1.6)
1.3±0.15
0.3±0.1
B±0.1
.1
+00
5
8±0.1
2±0.1
A
Ø1.
4±0.1
C±0.5
D±1
E
Unreeling direction
F
F
F-F
Unit : mm
Part No.
DF30#-20DP-0.4V(**)
DF30#-22DP-0.4V(**)
DF30#-24DP-0.4V(**)
DF30#-30DP-0.4V(**)
DF30#-34DP-0.4V(**)
DF30#-40DP-0.4V(**)
DF30#-50DP-0.4V(**)
DF30#-60DP-0.4V(**)
DF30#-70DP-0.4V(**)
DF30#-80DP-0.4V(**)
4
A
B
C
D
16.0
7.5
17.5
21.5
24.0
11.5
25.5
29.5
Usage Recommendations
1. Recommended temperature
● Ordinary solder cream
Temperature(ç)
profile
250
240
220
200
150
10 to 20 sec.
Soldering
60 to 90 sec.
Preheating
100
● Lead-free solder cream
Temperature(ç)
Time (seconds)
10 seconds or less
250
230
200
150
60 seconds or less
Soldering
150
60 to 120 sec.
Preheating
100
Time (seconds)
Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a
return to normal temperature between the first and second cycle.
Note 2 : The temperature profile indicates the board surface temperature at the point of contacts with the
connector terminals.
2. Recommended manual soldering Manual soldering : 340±10ç for 3 seconds
3. Recommended screen thickness Thickness : 0.12mm
and open area ratio
(Pattern area ratio)
4. Board warpage
Opening are ratio : DS side 100%, DP side 84%
Maximum of 0.02mm at the connector center, with both ends of the connector as
reference points.
5. Cleaning conditions
6. Precautions
Please refer to the “Handbook on the Use of Wire-to-Board Connectors”.
■ Terminals are exposed on the header side. Please note that touching them with bare
hands causes contact failure or static electricity, resulting in damage to the components.
■ Note that mating/unmating when the product is not mounted on the PCB could cause
damage or deformation of the terminal.
■ Avoid supporting the PCB using only the connectors. Other means of support are
needed.
■ Care should be taken that excessive prying during mating/unmating could cause
damage.
■ In the case of hand soldering, please do not apply any flux, which could cause flux
wicking.
■ The product may differ slightly in color due to different production lots of the resin. This
color variation has no influence on the performance.
■ Please refer to the next page for the precautions for mating/unmating.
■ Care should be taken to secure the mated connector and FPC within the device with
housings and cushioning materials. This will help prevent disconnections or unmating in
the event of dropping, other external forces or stressed routing of the FPC.
5
Handling Precautions when mating the connectors
DF30*-*DS-0.4V(**)
DF30*-*DP-0.4V(**)
0.3mm
0.3mm
Receptacle
Keep the connectors parallel to each other when
positioning.
Header
Do not attempt to mate the connectors starting at one
end or side.
Press-down evenly until slight resistance is felt.
Overcoming this slight resistance will complete the
mating of receptacle with the header.
A definite "click" sensation will confirm the fully mated
condition.
6
Handling Precautions when un-mating the connectors
DF30*-*DS-0.4V(**)
Fully mated
DF30*-*DP-0.4V(**)
Receptacle
Lift even one side, keeping both boards parallel to
each other.
Header
Fig. A
Fig. B
When handling circumstances prevent the connector
from being kept level during un-mating, one end may
be lifted separate as shown on Fig. A.
However, to utilize this procedure the connector must
be mounted on a sufficiently rigid circuit board.
Any deflection of the board during this operation may
result in damage to the connector or solder joints.
Do not attempt the start of the un-mating of the
connectors from one side (Fig. B).
When removal is from the width orientation as
illustrated in the diagram to the left, damage could be
caused to the connector. Do not perform removal from
the width orientation.
7
MEMO :
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
8
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 12/2021. Contents are subject to change without notice for the purpose of improvements.
