2494
    HEYCO
2494 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Double D Hole Plugs ® For Mounting Holes with Flats Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) PANEL DIMENSIONS D C Mounting Hole Dia. To Prevent Rotation in. mm. in. mm. PART NO. Black DESCRIPTION PART DIMENSIONS A B Head Diameter Overall Height in. mm. in. mm. White .375 9,5 .345 8,8 2617 2618 DP 375* .47 11,9 .437 11,1 .390 9,9 2488 2489 DD 437-390 .53 13,5 .500 12,7 .445 11,3 2491 2492 DD 500-445 .55 14,7 .562 14,3 .530 13,5 2494 2495 DD 562-530 .66 16,7 .625 15,9 .550 14,0 2497 2498 DD 625-550 .73 18,5 .750 19,1 .625 15,9 2503 2504 DD 750-625 .92 23,4 .875 22,2 .770 19,5 2509 2510 DD 875-770 1.02 25,8 2511 – .94 23,8 DD 875-770-9** 1.109 28,2 1.000 25,4 2717 2718 DD 1109-1000 1.22 30,9 2.000 50,8 1.875 47,6 2959 2963 DD 2000-1875 2.17 55,1 .41 10,3 .45 11,5 .48 12,1 • Close unwanted Strain Relief mounting holes or other double faced or Double D holes punched or molded with two opposing flats. • Convex, matte finish head tapers to a thin edge. • Quick and easy installation. • Lock firmly in panels up to .125˝ (3,2 mm) thick. • Locking fingers in fractional increments up to the maximum panel thickness. • Approximate Head Thickness: .062˝ (1,6 mm). Thickness may vary. Standard colors black and white. Consult Heyco for other colors. *On installation, DP 375 Locking Fingers must be aligned with Mounting Hole Flats. **Smaller than standard Head Diameter, for clearance situations. B A C A C B D A B .46 (11,8 mm) D MOUNTING HOLE MOUNTING HOLE DD Series RP Series 3299, 3388, 3389 Heyco Rectangular Blanking & Connector Port Plugs ® Multiple Locking Steps for Various Panel Thicknesses PANEL DIMENSIONS PART NO. DESCRIPTION Mounting Hole Maximum C D Black Thickness Length Width in. mm. in. mm. in. mm. PART DIMENSIONS A B Head Overall Dimensions Height in. mm. in. mm. Rectangular Blanking Plugs .03 0,64 .96 24,5 .96 24,5 13910 RP 245-245 1.06 x 1.06 26,9 x 26,9 13911 RB 245-245* 1.05 x 1.05 26,7 x 26,7 .30 7,6 .04 1,0 .27 6,9 .29 7,4 2512 RP 69-74 .37 x .37 9,4 x 9,4 .33 8,4 .10 2,5 .45 11,5 .51 13,9 1890 RP 115-130 .58 x .58 14,7 x 14,7 .40 10,2 .13 3,2 .94 23,8 1.65 42,0 2513 RP 239-419 2.17 x 1.38 55,1 x 35,0 .46 11,7 .16 4,0 .69 17,5 .69 17,5 1892 RP 175-175 .83 x .83 21,1 x 21,1 .47 11,9 .51 13,0 .41 10,5 • Blank unused rectangular panel holes. • PN 1890 - UR Recognized under the Component Program of Underwriters’ Laboratories File E15331. • PN 1892 - UR Recognized under the Component Program of Underwriters’ Laboratories File E51579 and CSA Certified by the Canadian Standards Association File 8919. Connector Port Plugs .14 3,5 .37 9,5 1.02 26,0 3299 RP 95-130-1 .63 16,0 3388 RP 95-130 .87 22,0 3389 RP 95-260 1.38 35,0 Standard color black. *Bushing version of the above plug. Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriter Laboratories File E51579 (DD only) 94V-2 -40°F (-40°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 6-34
很抱歉,暂时无法提供与“2494”相匹配的价格&库存,您可以联系我们找货
