PANEL SWITCHES
SW
1
80
-1
KG
KG series
Power rocker switches
DISTINCTIVE FEATURES
Protected rocker
Illuminated or non-illuminated
VDE (EN 61058-1) approved
Sealed to IP65
ENVIRONMENTAL SPECIFICATIONS
• Degree of protection : IP65 according to IEC 60529
• Shock resistance : 100 g according to IEC 512-4, test 6c
• Vibration resistance : 10-500 Hz - 10 g according to IEC 512-4, test 6d
• Salt spray resistance : 96 hours according to IEC 512-6, test 11f
• Operating temperature :
2 position models : -40 °C to + 85 °C (-40 °F to +185 °F)
3 position models : -10 °C to + 65 °C (-14 °F to +149 °F)
ELECTRICAL AND GENERAL SPECIFICATIONS
• Currrent/voltage rating :
- functions 1 (ON-OFF) and 6 (ON-ON) : 15 A 12 VDC, 10 A 24 VDC max.,
10 mA 14 VDC min.
- functions 4 ( ON ON ON) and 4-1R (ON ON MOM) : 8 A 12 VDC,
5A 24VDC max.
- other functions : 10 A 12 VDC, 8 A 24 VDC max.
• Initial contact resistance : 10 mΩ max. at 1 A 2 VDC
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength : 2,000 Vrms 50 Hz min. between terminals
• Electrical life : 10,000 cycles min.
• Mechanical life : 2 position models : 100,000 cycles min.
3 position models : 30,000 cycles min.
• Panel cut-out : 36.80 x 21.08 mm (1.149 x .830)
• Panel thickness : 0.8 mm to 4.6 mm
• Recommended thickness : between 2 mm and 3.5 mm
The company reserves the right to change specifications without notice.
1
MATRIX MOUNTING
AGENCY APPROVAL
12(4) A 250 VAC
T85/55 °C
25.00 mini.
(.984 min.)
4.00
(.157)
49.00 mini.
(1.929 min.)
12.20
(.480)
EN 61058-1
Availability : double pole models, functions ON-OFF and
ON-ON.
Marking : to order switches marked VDE, add “VDE” at
the end of model number..
MATERIALS
• Case : thermoplastic UL94-V0
• Terminals : brass, silver plated
25.00 mini.
(.984 min.)
4.00
(.157)
49.00 mini.
(1.929 min.)
12.20
(.480)
• Contacts : silver grain
• Contact roller : brass, nickel plated
25.00 mini.
(.984 min.)
4.00
(.157)
49.00 mini.
(1.929 min.)
12.20
(.480)
ELECTRICAL FUNCTIONS
2
1
PANEL CUT-OUT
TERMINALS
Ø3.00x0.50 SI
(.118DIAx0.50 IS)
21.08 0/+0.3
(.830 0/+.012)
6.35
(.25)
0.80
(.031)
Screw
Z
Z
Normalized quick-connect 6.35x0.8
2
6.35x0.80
(.25x.031)
Solder lug / quick-connect
Ó
CKRDE3-C
Ø3.10
(.122DIA)
4.50
(.177)
3
36.80 0/+0.3
(1.449 0/+.012)
PANEL SWITCHES
KG series
BUILD YOUR PART NUMBER
CASE + LAMPS
KG
Side A
SERIES
POLES
LAMPS
TERMINALS
LED 6 V, 12 V, 18 V
1
ON
OFF
Screw
4
ON
ON
ON
2
ON
ON
MOM
Solder lug /
quick- connect
3
Normalized
quick-connect
3
Single pole
4
4-1R
Double pole
5
MOM
ON
6
ON
ON
7
MOM
OFF
MOM
8
ON
OFF
MOM
9
ON
OFF
ON
Side B
Neon 125 V or 250 V
Filament 6 V, 12 V, 24 V
Fluorescent 220 V or 110 V
Codes, see website.
LAMP WIRING
BEZEL
See following
pages.
Black, sealed
to IP65
2
CONTACTS
A
Silver grain
ACTUATOR
Side A
ROCKER COLOR
1
X
No lens
9
Orange
1
Blue*
B
White
Ivory
3
Green*
T
Translucent
Orange
6
Red
Blue
5
Yellow
Dark blue
6
Red
2
Black
7
3
Green
9
4
Grey
1/4
LENS COLOR
ROCKER SHAPE
Full rocker, opening
on one side or on two
sides : see following
pages.
Side B
*Blue or green lens recommended
with fluorescent lamp.
Actuator marking and symbols : see end of the series.
ABOUT THIS SERIES
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Sealing boot are available to protect the switches against dust and water. See "Sealing Boots" section of website.
3
PANEL SWITCHES
KG series
OFF
ON
ON
KG44-1R* ON
ON
MOM
KG35
KG45
MOM
KG36
KG46
ON
KG37
KG47
MOM
OFF
MOM
KG38
KG48
ON
OFF
MOM
KG39
KG49
ON
OFF
ON
10.50
(.413)
10.50
(.413)
23.50
(.925)
23.50
(.925)
12.00
(.472)
12.00
(.472)
ON
ON
20.00
(.787)
20.00
(.787)
48.5048.50
(1.909)
(1.909)
ON
43.7043.70
(1.720)
(1.720)
ON
6.85 6.85
(.269)(.269)
KG41
KG44*
14.6514.65
(.576)(.576)
KG31
Double pole
1-2
4-5
24.5024.50
(.964)(.964)
Single pole
2-3
5-6
11.0011.00
(.433)(.433)
FLAT SEAL
SOLDER LUG / QUICK-CONNECT TERMINALS
* Function 4 : single pole in double pole case
CASE + LAMPS
TERMINALS
ACTUATOR
BASIC P/N
3
Screw
Side A
Ø3.00x0.50 SI
(.118DIAx0.50 IS)
6.35
(.25)
0.80
(.031)
CASE + LAMPS
Ø3.10
(.122DIA)
6.35x0.80
(.25x.031)
4.50
(.177)
PANEL SWITCHES
KG series
2
Ó
BASIC P/N
4
2
5
3
6
Terminals 1 to 6 are marked
on the case.
Side A : terminals 1 and 4
Side B : terminals 3 and 6
3
Side B
CONTACT MATERIALS
ACTUATOR
Silver grain
CASE + LAMPS
2
4
Z
Z
BASIC P/N
A
1
Black, sealed to IP65
BEZEL
ACTUATOR
CASE + LAMPS
LAMPS
Side B
Side A
BASIC P/N
ACTUATOR
Complete each enlarged box with one of the codes listed below.
X
M
N
O
P
R
S
T
Without LED
Neon 125 V
Neon 250 V
Filament 6 V
Filament 12 V
Filament 24 V
Fluorescent 220 V
Fluorescent 110 V
Red
Green
Yellow
Blue
White
6 VDC
A
B
C
1
W
12 VDC
D
E
F
Z
V
18 VDC
G
H
I
24 VDC
J
K
L
Y
U
Side A
4
1
4
1
4
1
4
1
5
2
5
2
5
2
5
2
6
3
6
3
6
3
6
3
Side B
CASE + LAMPS
LAMP WIRING
BASIC P/N
ACTUATOR
The lamp wiring diagram is shown on the case.
To order case only (without rocker), finish your order number with the lamp wiring code.
1
4
1
2
5
2
3
6
3
4
1
5
6
4
2
5
3
6
4
5
2
1
6
3
D
2
3
4
5
6
3
1
4
2
5
3
6
1
4
2
+ E
3
5
6
CKGRLE-A
1
2
3
B
CKGRLA-B
5
6
4
2
A
standard
1
1
1
2
3
1
4
5
6
4
2
+ F
3
5
6
4
5
6
1
4
2
5
3
6
1
2
3
4
5
6
C
* For function 1 (on-off) with LED on side A
Note : If not available, terminals are
added to connect the LED.
CKRRLF-A
CKGRLD-B
CATAL92/CATAL2001
5
PANEL SWITCHES
KG series
PANEL SWITCHES
KG series
ACTUATOR
ROCKER COLOR
BASIC P/N
CASE + LAMPS
To order rocker only (without case), begin the order number with code KGR, then follow the order format from
”rocker color” until the end of the options.
1
1/4
2
3
4
5
6
7
9
Blue
Dark blue
Black
Green
Grey
Yellow
Red
Ivory
Orange
ACTUATOR
ROCKER SHAPE
BASIC P/N
1
4
6
8
CASE + LAMPS
Full rocker
Opening on side A
Opening on side B
Opening on sides A and B
Other rocker shapes on customer specifications : on request.
1
4
ACTUATOR
BASIC P/N
6
8
LENS COLOR
CASE + LAMPS
Side A
Side B
To order lenses only, begin the order number with the codes : KGLA for lens A and KGLB for lens B, then follow the
order format from ”lens color” until the end of the options.
Side A
X
No lens
1
Blue *
3
Green *
6
Red
9
Orange
B White
T Translucent
* Blue or green lens recommended with fluorescent lamp.
6
4
1
4
1
5
2
5
2
6
3
6
3
Side B
ACTUATOR
BASIC P/N
MARKING
CASE + LAMPS
If no marking required, leave box blank.
Marking by hot stamping
4
1
Other orientations : on request
5
2
6
3
4
A
CV
5
B
CASE + LAMPS
Marking area
For illuminated versions. The symbol will be included in the
hatched area.
6
1
CH
3
A
B
11.00
(.433)
4
1
5
2
6
3
4
A
5
2
B
6
CKGR2-A
CKGR-A
ech 0.6
indice A
le 14/05/08
1
3
CKGR1-A
11.00
(.433)
4
1
5
2
6
3
12.40
(.488)
Marking color
White marking for black rockers - Black marking for color
rockers
5
CKGR1-A
No symbol
Available symbols
Complete each enlarged box with the one of the codes
listed on the following pages.
4
2
6
11.00
(.433)
XX
3
11.00
(.433)
BASIC P/N
SYMBOLS
2
12.40
(.488)
ACTUATOR
1
CKGR2-A
CKGR-A
ech 0.6
indice A
le 14/05/08
7
PANEL SWITCHES
KG series
PANEL SWITCHES
K range
Power rocker switches and indicators •
symbols and accessories
Most symbols meet the ISO 7000 standard “graphical symbols for
use on equipment” (code given in bracket in the description).
Contact us for symbols not featured in the following tables.
CODE
SYMBOL
XX
None
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
16
Revolving light
32
Emergency first
aid vehicle (2565)
01
17
Rear ventilator
33
Load tipping (1557)
02
18
Heating (0637)
34
Loading light (2457)
03
19
Door opening
35
Tractor, rear-ward
(1667)
04
Windshield demister/
defroster (0635)
36
Combine, direction
of movement (1678)
05
21
Windshield
wiper (0086)
37
Use no forks
(2406)
06
22
Windshield
washer (0088)
38
Transmission
(1166)
07
Stop
23
Ventilator fan
(0089)
39
Working spot
light (1145)
08
Motion
24
Side mirror
defroster
40
Engine (0640)
09
Up motion
25
Restarting
pump
41
Horn (0244)
10
Down motion
26
Front fog lights
(0633)
42
Lock (1656)
11
Hot
27
Rear fog lights
(0634)
43
Taxi sign light (2551)
12
Cold
28
Propulsion
system trim
44
Working light (1204)
13
Hazard warning
(0085)
29
Beacon
(1141)
45
Working light
symmetric (1204)
14
Traveller lighting
30
Anchor
46
15
Driver lighting
(1421 )
31
Electric motor
(0011)
47
1
PANEL SWITCHES
K range
CODE
2
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
48
All wheel drive
69
Engine idle control
90
ECAS reset
49
Differential lock
(1662)
70
Cruise res/set
91
Driver windows
heating
50
71
Driver windows up/
down
92
Cruise set
51
72
Middle door
opening
93
Air bag up/down
52
73
Front door opening
94
Read lighting
53
74
Lighting in baggage
room
95
Lighting main
switch
54
Rear window wiper
(0097)
75
Cruise on/off
96
Heating using water
55
Rear window
washer (0099)
76
TV
97
Low beam
56
Lower load (2223)
77
Pump
98
Position lights
57
Cab lock (1560)
78
Toilet
99
Diesel acceleration
58
Extraction
79
Toilet
decontamination
A1
Manual mode
59
Pumping in
80
Front windshield
heating
A2
Clockwise
cabin rotation
60
Rear PTO (1572)
81
Aus
A3
Anticlockwise
cabin rotation
61
Front PTO
82
Radiator fan
A4
62
Rockshaft down
83
Remove retarder
A5
63
Rockshaft up
84
Restricted speed
A6
64
Indicator
85
Preheater
A7
65
Brake release
86
ABS detection
A8
66
Baggage room
left door
87
ECAS detection
A9
67
Baggage room
right door
88
Engine stop
AA
68
Power blinds
89
Cruise res/cancel
AB
Parking brake
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
AC
AV
AD
AW
AE
AY
AF
AZ
AG
Battery charging
condition (0247)
B1
AH
Turn signals (0084)
B2
AJ
High beam (0082)
B3
AK
Differential lock,
bogie (2600)
AL
Brushing with a
rotating brush (0070)
AM
Differential lock,
transfer case 4x4 (2475)
AN
Loader bucket,
float (1441)
AP
Loader bucket
(1437)
AQ
Rear window washer
& wiper (0098)
AR
Header, Header drive
(1579)
AS
Excavator/backhoe
boom side shift (2091)
AT
Chemical water
treatment (1851)
AU
Legend scale
Depending on space available on the product (see “Symbols” section at the
end of each series).
Grapple skidder, single
funct° boom (1762)
3
PANEL SWITCHES
K range
MOUNTING PANELS
(NOT AVAILABLE FOR USE WITH THE KH SERIES)
MOUNTING PANEL END
SINGLE MOUNTING PANEL
56.00
(2.205)
56.00
(2.205)
MOUNTING PANEL MIDDLE
56.00
(2.205)
3.80
(.150)
3.80
(.150)
29.26
(1.152)
26.50
(1.043)
U2261
26.50
(1.043)
U2262
CKRU2261-C
3.80
(.150)
26.26
(1.034)
32.26
(1.270)
26.50
(1.043)
U2267
CKRU2262-C
Recommended panel thickness : 1.10 mm - 1.80 mm - 2.60 mm - 3.40 mm - 4.20 mm - 5 mm - 5.80 mm
MOUNTING PANEL CUT-OUT
25.00 0/+0.20
(.984 0/+.008)
51.00 0/+0.20
(2.008 0/+.008)
77.50 0/+0.20
(3.051 0/+.008)
For 1 element U2267
4
48.20 0/+0.20
(1.898 0/+.008)
48.20 0/+0.20
(1.898 0/+.008)
For additional
elements, add
26.40 mm (1.039)
48.20 0/+0.20
(1.898 0/+.008)
PANEL SWITCHES
K range
For 2 elements U2261
CKRDE2-C
For 3 elements (2xU2261 + 1x U2262)
25.00
(.984)
19.00
(.748)
K range
CKRAD-1
3.50
(.138)
PANEL SWITCHES
50.00
(1.969)
50.00
(1.969)
3.50
(.138)
22 X 44 ADAPTERS
FRONT PANEL DISMOUNTING
REAR PANEL DISMOUNTING
PANEL CUT-OUT
19.00
3.50
(.748)
(.138)
25.00
(.984)
U3060
25.00
(.984)
CKRAD-1
3.50
(.138)
44.00 0/+0.1
(1.732 0/+.004)
50.00
(1.969)
50.00
(1.969)
19.00
(.748)
19.00
3.50
(.748)
(.138)
CKRAD-1
19.00
(.748)
U3070
U3060 0.60 mm to 1.50 mm
U3070 1.60 mm -0.1/0 to 5.60 mm -0.1/0 in stages of 0.40 mm
22.00 0/+0.1 22.00 0/+0.1
(.866 0/+.004)(.866 0/+.004)
25.00
(.984)
25.00
(.984)
CKRAD-2
CKRAD-3
CKRAD-2
Adapter colors (replace 0 with code)
1/4
Dark blue
2 Black
4 Grey
5
Yellow
6
Red
7/1
White
ACTUATOR REMOVING TOOL
44.00 0/+0.1
(1.732 0/+.004)
(NOT SUITABLE FOR USE WITH KH1 MODELS - 4-SIDE PROTECTION GUARDS)
44.00 0/+0.1
(1.732 0/+.004)
Extract actuator (KR only)
Allows the extraction of the rocker / rocker support assembly. Place
the 2 claws under the support and push as indicated by the arrow.
Extract rocker (KR only)
Allows to separate the rocker from its support. InsertCKRAD-3
the toolCKRAD-3
between
rocker and support as indicated by the arrrow. Pull out the tool in the
opposite direction.
U3052
Extract switch (KR, KL and KI)
Allows to extract switch from panel mounting units. 2 Tools are necessary. Insert the tools between switch and panel mounting units from
the rear to compress the snap-in device. Pull off switch manually.
to be ordered by pairs
Blue
Dark blue
Black
Green
Grey
U2275
U2276
U2277
U2279
Yellow
Red
Ivory
Orange
FICHIER:FICHIER:
CKRAD CKRAD
ECHELLE:
ECHELLE:
0.625
0.625
le 02/02/10
le 02/02/10
22.00
(.866)
U2271
U2271/4
U2272
U2273
U2274
6.30
(.248)
Usefull for future extensions.
Connectors can be hanged on specific hole plugs. Contact APEM.
1.50
(.059)
BLANKING CAPS
44.10
(1.736)
20.80
(.819)
25.00
(.984)
3.50
(.138)
50.00
(1.969)
50.00
(1.969)
22.00 0/+0.1
(.866 0/+.004)
Recommended
panel thickness :
1.50 mm to 6 mm
46.80
(1.843)
5
CONNECTORS
Standard color : black. Other colors : on request. Connectors cannot be combined with wiring types H and I.
U2260 6 terminal version. For use with terminals type 2, 3, 4 or 5.
6.35 (1/4) tabs to be fitted by the user (example : TE42282-2).
Can be used for the KG series.
U2282 10 terminal version. For use with terminals type H or J.
2.8 (.110) tabs to be fitted by the user (example : AMP/Tyco 0-927779-3).
U2292 10 terminal version : For use with terminals type B, C, E or F.
U3152 10 terminal version. For use with terminals type B, C, E or F.
6.35 (1/4) tabs to be fitted by the user (example : "Timer" terminals TE927833-2)
45.00
(1.772)
29.40
(1.157)
24.40
(.961)
25.00
(.984)
33.40
(1.315)
36.60
(1.441)
U2260
U2292
CKRU2290-A
CKRU2260-A
24.40
(.961)
29.40
(1.157)
36.60
(1.441)
U2282
CKRU2280-A
6
20.40
(.803)
1
U3152
20.80
(.819)
11.00
(.433)
20.80
(.819)
11.00
(.433)
1
11.00
(.433)
PANEL SWITCHES
K range
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
KG312A2DXD246X KG352A2XXA21XX KG372A2DXA246X KG382A2XXA21XX KG392A2XXA21XX
KG472A2DXA246X KG472A2XXA21XX KG492A2DXA246X KG492A2XXA21XX KG352A2DX246X
KG352A2DXA246X KG372A2XXA21XX KG362A2DXA246X KG362A2XXA21XX KG312A2XXA21XX
KG452A2DXA246X KG452A2XXA21XX KG462A2DXA246X KG462A2XXA21XX KG412A2XXA21XX
KG412A2DXD246X KG312A2KXD24TX KG312A2SXD241XCV01XX02 KG312A2XXA KG312A2XXA21XXCV01XX02
KG312A2XXA61XX KG313A2KXD24TX KG313A2XXA21XX KG372A2EEA28TTCV09XX10 KG372A2TTA2833XX
KG373A2XXA21XXCV09XX10 KG410A2SXD241X KG410A2TXD243X KG412A2XDA26X6 KG412A2XEA26X3
KG412A2XNA26X6 KG412A2XSA26X3 KG412A2XXA KG412A2XXA61XX KG462A2XXA
KG463A2XXA61XXCH03XX04 KG492A2XXA KG463A2RXB246X
