multimec
3A
3C
For
1A/1B/1M/1ZA/1ZB
w/LED for
1C/1H
3ATL6
3ATH9
3ATL600/20/40/80
basic switch modules
Through-hole Versions
3E
For
3E actuators/Varimec
3F
For 1D/1K/1N/1P/1S/1T/
1U/1V/1WA/1WD/1WG/
1WP/1X/1ZC/1GA/1GC
w/LED for
1D/1E/1F/1N/1Q/1R/
1S/1X
w/LED for
1K /1KB/1KC/1T/1U/1V/
1WA/1WD/1WP
3FTL6
3FTH9
3FTL600/20/40/60/80/
2040/8020/8040
3FTL623/45/88
Standard Versions
3CTL6/3CTL9
3CTH9
3ETLXX-H*
3ETHXX-H*
* 3E available in 6 standard heights: 08.0, 09.5, 10.4, 11.0, 12.0, 15.0 mm. Other heights between 08.0 and 15.0 mm are available upon request.
Specials: Gold contacts, quiet version and actuation force other than 3.0N
Surface Mount Versions
3C
3E
3A
For
1A/1B/1M/1ZA/1ZB
For 3E actuators/
Varimec
Right Angle Versions
3C
3F
1U/1V/WA/1WD/1WP/
1X/1ZC/1GA/1GC
For 3E actuators/
Varimec
Standard Versions
3ASH9/3ASH9R
3CSH9/3CSH9R
3FSH9/3FSH9R
3CTL6RAS
ed, all tolerances ± 0.2
multimec® Cross Section
cations please see www.mec.dk
0804
mec
www.mec.dk
3F
3F w/LED
1U/1V/1W/1WA/1WD/
1WP1X/1ZC/1GA/1GC
For 1D/1E/1F/1N/1Q/
1R/1S/1X
Standard Versions
3ESH9/3ESH9R
Co-planarity = ≤ 0.05
3E
3ETXX-X.XRAS
3FTL6RAS
2040/8020/8040RAS
27
multimec
3C/3E
Technical Data
through-hole or SMD
50mA/24VDC
single pole/momentary
10.000.000 operations life time
IP67 sealing
temperature range:
low temp:
-40/+115°C
high temp:
-40/+160°C
actuator:
in PPS:
-40/+160°C
in polycarbonate: -40/+85°C
Standard 3C
Dimensions (through-hole)
Variable heights 3E
Dimensions (SMD)
PCB layout
PCB layout
Dimensions (SMD)
PCB layout
PCB layout
How to order
3 C
Switch
Mounting
T through-hole
S surface mount
L 6 low temp. white
L 9 low temp. black
H 9 high temp.
3 E
Switch
9
Mounting
T through-hole
S surface mount
L low temp.
H high temp.
Black
Actuator made of PPS
Custom heights:
3E is available in any height from 08.0 to 15.0mm.
Min. order qty. for custom heights is 2.000 pcs.
3 E
Switch
T
Mounting
T through-hole
L
L low temp.
20 blue
23 grey
24 yellow
28 red
29 black
Actuator made of
polycarbonate
Standard overall height
08.0
09.5
10.4
11.0
12.0
15.0
08.0
09.5
10.4
11.0
12.0
15.0
Switch and 3E actuator can be delivered unassembled.
The actuators made of polycarbonate can also be used for high temperature switches,
however they must be mounted after soldering and the temp. range will be reduced to 85°C.
Ordering example: 3CTL6 and 3ETL9-09.5 or 3ETL23-08.0
For updates of products and/or changes of specifications please see www.mec.dk
www.mec.dk
mec
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
3E23-12.0 3E-12.0 3CTH9G 3E29-08.0
很抱歉,暂时无法提供与“3CTH9G”相匹配的价格&库存,您可以联系我们找货
