3CTL9
3CTL9
    APEM(埃斐)
    SWITCHTACTILESPST-NO0.05A24V
3CTL9 数据手册
multimec 3A ® 3C For 1A/1B/1M/1ZA/1ZB w/LED for 1C/1H 3ATL6 3ATH9 3ATL600/20/40/80 basic switch modules Through-hole Versions 3E For 3E actuators/Varimec 3F For 1D/1K/1N/1P/1S/1T/ 1U/1V/1WA/1WD/1WG/ 1WP/1X/1ZC/1GA/1GC w/LED for 1D/1E/1F/1N/1Q/1R/ 1S/1X w/LED for 1K /1KB/1KC/1T/1U/1V/ 1WA/1WD/1WP 3FTL6 3FTH9 3FTL600/20/40/60/80/ 2040/8020/8040 3FTL623/45/88 Standard Versions 3CTL6/3CTL9 3CTH9 3ETLXX-H* 3ETHXX-H* * 3E available in 6 standard heights: 08.0, 09.5, 10.4, 11.0, 12.0, 15.0 mm. Other heights between 08.0 and 15.0 mm are available upon request. Specials: Gold contacts, quiet version and actuation force other than 3.0N Surface Mount Versions 3C 3E 3A For 1A/1B/1M/1ZA/1ZB For 3E actuators/ Varimec Right Angle Versions 3C 3F For 1D/1K/1N/1P/1S/1T/ 1U/1V/WA/1WD/1WP/ 1X/1ZC/1GA/1GC For 3E actuators/ Varimec Standard Versions 3ASH9/3ASH9R 3CSH9/3CSH9R 3FSH9/3FSH9R 3CTL6RAS ed, all tolerances ± 0.2 multimec® Cross Section cations please see www.mec.dk 0804 | mec | www.mec.dk 3F 3F w/LED For 1D/1K/1N/1P/1S/1T/ 1U/1V/1W/1WA/1WD/ 1WP1X/1ZC/1GA/1GC For 1D/1E/1F/1N/1Q/ 1R/1S/1X Standard Versions 3ESH9/3ESH9R Co-planarity = ≤ 0.05 3E 3ETXX-X.XRAS 3FTL6RAS 3FTL600/20/40/60/80/ 2040/8020/8040RAS 27 multimec ® 3C/3E Technical Data ■ ■ ■ ■ ■ ■ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations life time IP67 sealing temperature range: low temp: -40/+115°C high temp: -40/+160°C actuator: in PPS: -40/+160°C in polycarbonate: -40/+85°C Standard 3C Dimensions (through-hole) Variable heights 3E Dimensions (SMD) PCB layout Dimensions (through-hole) PCB layout Dimensions (SMD) PCB layout PCB layout How to order 3 C Switch Mounting T through-hole S surface mount L 6 low temp. white L 9 low temp. black H 9 high temp. 3 E Switch 9 Mounting T through-hole S surface mount L low temp. H high temp. - Black Actuator made of PPS Custom heights: 3E is available in any height from 08.0 to 15.0mm. Min. order qty. for custom heights is 2.000 pcs. 3 E Switch T Mounting T through-hole L L low temp. 20 blue 23 grey 24 yellow 28 red 29 black Actuator made of polycarbonate . Standard overall height 08.0 09.5 10.4 11.0 12.0 15.0 . Standard overall height 08.0 09.5 10.4 11.0 12.0 15.0 Switch and 3E actuator can be delivered unassembled. The actuators made of polycarbonate can also be used for high temperature switches, however they must be mounted after soldering and the temp. range will be reduced to 85°C. Ordering example: 3CTL6 and 3ETL9-09.5 or 3ETL23-08.0 For updates of products and/or changes of specifications please see www.mec.dk www.mec.dk | mec
3CTL9 价格&库存
很抱歉,暂时无法提供与“3CTL9”相匹配的价格&库存,您可以联系我们找货
