Magnetic Proximity Sensors (Reed)
MP2018 Sensors
Reed based magnetic proximity sensor
in plastic flange-mount package
Description
The MP2 Series sensors are reed position sensors. Normally open or closed contacts change states when a magnetic field is
applied. The sensors act as non-latching electrical switches.
Typical Applications
Features
Contacts hermetically sealed for long life
Zero power consumption
Suitable for DC and AC circuits
Flange mount
RoHS compliant
IP65
Operate/Release Distances*: 6.35 mm – 17.8 mm (0.25” – 0.7”)
Door position & interlock
Limit switch
Flow/speed
Home security
Pedal switch
Environmental Specifications
20 g 10 Hz to 1 kHz (MP201801)
20 g 10 Hz to 55 Hz (MP201802)
-40 °C to 105 °C (-40 °F to 221 °F)
IP65
Vibration
Operating Temperature
Storage Temperature
Ingress Protection
Electrical Specifications
Typical Operating Time
Breakdown Voltage
Switching Voltage and Current
Contact Resistance and Power rating:
1 ms
200 VDC min.
See Products chart
See Products chart
Mechanical Specifications
Housing Material
*with AS201801 magnetic actuator
Glass-reinforced plastic
Products
Part Number
MP201801
MP201802
Contact
Form
SPST-NO
Form A
SPST-NC
Form B
Maximum
Power Rating
10 W
Maximum
Switching Volta ge
175 VAC/VDC
Maximum
Switching Current
0.5 A
Maximum
Contact Resistance
0.200 Ω
3W
30 VAC/VDC
0.2 A
0.100 Ω
All MP2018 sensors come with leads 24 AWG x 305 mm (12”)
www.cherryswitches.com
Page 1 of 2, Last saved by 2014-12-12, Specifications subject to change without notice.
Dimensions mm (inches)
Page 2 of 2, Last saved by 2014-12-12, Specifications subject to change without notice.
很抱歉,暂时无法提供与“AS201801”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+23.204704+2.81694
- 15+23.0962715+2.80378
- 30+23.0957630+2.80372
- 100+23.09524100+2.80366
- 200+23.09473200+2.80359
