79210997
    CROUZET(高诺斯)
    ACT ARM OFFSET FOR LIMITS
79210997 数据手册
Miniature Limit Switches Series 83 800 Type Degree of protection : IP 55 or IP 65 - Nema 4, 12, 13 Plug in version Version : SPDT - double break Function : Four terminal double break contact element (form Za). The contacts must be of the same polarity. Layout : A - For 83 803 B - Other types Electrical characteristics : Assigned insulation voltage (Ui): 250 V Current Rating Assigned working currents (Ie): 5 A Features Top mounted plunger Top mounted plunger with threaded barrel Top mounted roller plunger with threaded barrel Side rotary head - momentary Top mounted roller plunger Flexible metal spring Fiberglass Rod Mechanical Characteristics Operating force Total travel force - min. Operating Travel - min Movement differential Total travel - max Mechanical life Operating temp. Degree of protection Weight N (oz) N (oz) mm (in) mm (in) mm (in) operation C˚ (F˚) grams (oz) Operating curve : Accessories for 83 803 - Sold separately Resistive circuit Inductive circuit * Lever settings or positions dictated by direction in which block is fitted L = 5 ms R cos ϕ = 0.8 { Adjustable in 6° steps Adjustable in 90° steps 107 5 2 106 5 2 105 5 Dimensions Axis of head rotation 2 104 0.1 0.2 0.5 1 2 5 10 16 25.5 (1) 25 (.98) 19 (.75) Ø8 (.315) 21.5 (.85) 11 (.43) Connections : - Plug in : - Non Plug in : Connection : For N° 9 sealing gland, 15.2 dia., 1.411 pitch -25356113 - metal -25356109 - plastic 13 (.51) 2x04.2 (.08x.17) 60.5 (2.38) Screw terminals - max. wire section 2.5 mm2 Solder tags (able to accept 2.8 x 0.5 mm clips). Contact Crouzet for part # and availability 22 (.87) 27 (1.06) For N° 9 sealing gland Approvals: UL cUL mm(in) Other information For other accessories and special contacts, or special modes of operation, please contact factory. Low temperature version available. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/44 1 83800151 83801051 83802051 83803051 83805051 83806051 83807051 • • • • • • • 10 (35.3) 22 (77.6) 1.5 (.06) 0.4 (.016) 5 (.2) 107 -10 to 70 (-14 to 158) IP 55 50 (1.8) 10 (35.3) 22 (77.6) 1.5 (.06) 0.4 (.016) 5 (.2) 107 -20 to 70 (- 4 to 158) IP 55 57 (2) 7 NcM 10 in.oz. 18 NcM 25 in.oz. 15˚ 6˚ 60˚ 107 -20 to 70 (- 4 to 158) IP 55 60 (2.1) 10 (35.3) 22 (77.6) 1.5 (.06) 0.4 (.016) 5 (.2) 107 -20 to 70 (- 4 to 158) IP 55 57 (2) 10 (35.3) 22 (77.6) 1.5 (.06) 0.6 (.24) 5 (.2) 107 -10 to 70 (-14 to 158) IP 65 50 (1.8) 1.2 (4.23) 2.5 (8.8) 8˚ 2˚ 10˚ 107 -10 to 70 (14 to 158) IP65 50 (2.65) .8 (2.8) 2 (7.05) 8˚ 2˚ 10˚ 107 -10 to 70 (14 to 158) IP65 60 (2.1) 2 Accessories for 83 803 - Sold separately Galvanized, passivated steel roller arm. Thermoplastic roller. Lever supplied with nut, washer and locating block (loose).* 79 210 997 79 210 998 Bent roller lever R: 1 1/8 (30mm) Straight roller lever R:11/8” (30mm) 79 215 332 Adjustable Straight roller lever 1 3/16” ➞ 2 7/8” (28 ➞ 72mm) 3 Dimensions 26.3 (1.04) 83 807 (08) 0 " (02) 0 mm(in) " 4 " (113) " R30 (1.18) 17/8" (50) / 83 807 83 806 11/16" 12.3 (.48) (Ø15) 7 " 8 83 806 11/2" (26.3) (Ø11x3.4) Ø 7/ 16"x 1/8" (163) (36.3) 83 805 / 7 " 8 15/16" (37.5) 11/2" 79 215 332 36.3 (1.42) 50.3 (1.98) (33) (22) 7maxi (.28) 42 (1.65) 79 210 998 56 (2.2) Ø20x6 (.79x.24) 83 803 M16x1 (28 ➞ 72) 79 210 997 Ø 5/16" 2.75" max. (7 max.) (42) 15/8" (23) 1" 32.3 (1.27) (Ø8) Ø11x3.4 (.43x.13) M5x5 83 802 M16x1 (22.5) 83 801 Ø15 (.59) Ø8 (.315) 13/16" ➞ 27/8 83 800 To order, specify: Standard products 1 Part number Example: 83 800 151 Standard products, non stocked 1 Part number 2 Accessory Example: 83 803 0 - Actuator 79 210 997 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/45
79210997 价格&库存
很抱歉,暂时无法提供与“79210997”相匹配的价格&库存,您可以联系我们找货
  • 10+63.54777
