Glass Gas Discharge (GGD)
RLM102 Series
Features
l RoHS compliant.
l Bilateral symmetrical.
l Less decay at on/off state.
l Approximately zero leaking current before clamping
voltage
l High capability to withstand repeated lightning strikes.
l Low electrode capacitance(≤1.0pF) and high isolation
(≥100MΩ).
l Temperature, humidity and lightness insensitive.
l Working temperature range: : -45℃ ~ +85℃
l Storaging temperature range: -45℃ ~ +85℃
Applications
l Power Supplies
l Satellite antenna
l Motor sparks eliminating
l Radio amplifiers
l Relay switching spark absorbing
l Alarm systems
l Data line pulse guarding
l Cathode ray tubes in Monitors/ Television Viewing
l Telephone/Fax/Modem
Systems
l High frequency signal transmitters/receivers
Part Number Code
R
L
M
Brand Name
1
1
4
Surge Current
Capacity
DC Spark-over
voltage(Vs)
102:1KA
14*10 =140V
Taping form
Blank: Line
N
DC Spark–
over voltage
tolerance
N:30%
M:SMD
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
1
1
M:20%
Revised: 2018-07-13
Page:1
RLM102 Series
Electrical Characteristics
Type Number
DC
Spark-Over
Voltage
Min.
Insulation
Resistance
Max.
Capacitance
(1kHz-6Vmax. )
Surge
Current
Capacity
Surge Life Test
@8/20μs
Vs
Test Voltage
IR
Cj
8/20μs
V
V
MΩ
pF
A
RLM102-141N
140(126~210)
50
100
1
1000
100A 10 times
RLM102-181N
180±30%
50
100
1
1000
100A 10 times
RLM102-201M
200±20%
100
100
1
1000
100A 10 times
RLM102-301M
300±20%
100
100
1
1000
100A 10 times
RLM102-401M
400±20%
250
100
1
1000
100A 10 times
RLM102-501M
500±20%
250
100
1
1000
100A 10 times
Test Methods And Results
Test Item
Test Method
Specification
DC Spark-over
Voltage Vs(V)
Add and measure the DC Voltage gradually Maxto get the discharge threshold
voltage. The measuring current is 1mA/1 second max.
It depands on each spec.
Insulation
Resistance
Measure the insulation resistance of two end of leadwire under the specified DC
voltage.
100MΩ min.
Capacitance Cj(pF)
Measure the Electrostatic Capacitance under the test condition of 1KHz,DC
6V(max).
1pF max.
Life(JSE)
Apply a standard impulse voltage (8X20μsec)of 100A for 5 times with intervals of 30
sec., and then change the polarity of the surge and apply a impulse again. Then
measure DC spark-over voltage, IR & Capacitance.
JSE:∣△ Vs/Vs ∣ ≤30%
Life(JSE)
Apply 10 KV voltage charged in 1500pF condenser and apply the current to the
specimen,200 times at 10 seconds of intervals
Insulation Resistance &
Capacitance to meet the
specified value. Appearance:
No cracks or failures.
Cold Resistance
Measurement after -40℃ /1000 HRS & normal temperature/2 HRS.
Heat Resistance
Measurement after 125℃ /1000 HRS & normal temperature/2 HRS.
Humidity Resistance
Measurement after humidity 90~95 ℃ (45 ℃ ) /1000 HRS & normal
temperature/2 HRS.
Temperature Cycle
10 times repetition of cycle -40 ℃ /30min →normal, temp/2 min →125℃ /30min,
measurement after normal temp/2 HRS.
Pull Strength
Apply 0.5kg load for 10sec.
Flexural Strength
Bend lead wire at the point of 2mm from body under 0.25 load and back to its
original point. Repeat 1 time.
Revised: 2018-07-13
Features are conformed to
rated spec.
Lead shall not pull out to snap.
Page:2
RLM102 Series
Recommended Soldering Conditions
Flow Soldering Conditions
Hand Soldering
Solder iron temperature: 350±5℃
Heating time: 3 seconds max.
Air Priheat
Soldering
Cooling
General attention to soldering
260℃
Temperature(℃ )
250
1.High soldering temperatures and long soldering times can cause
T
200
leaching of the termination, decrease in adherence strength, and
the change of characteristic may occur.
150
2.For soldering, please refer to the soldering curves above.
150~180℃
However, please keep exposures to temperatures exceeding 200℃
100
to fewer than 50 seconds.
50
3.Please use a mild flux (containing less than 0.2wt% CI). Also, if
the flux is water soluble, be sure to wash thoroughly to remove any
60~120 sec
3~4 sec
residue from the underside of components that could affect
resistance.
1) Time shown in the above figures is measured from the point when chip surface reaches temperature.
2) Temperature difference in high temperature part should be within 110℃
3) After soldering, do not force cool, allow the parts to cool gradually.
Cleaning
When using ultrasonic cleaning, the board may resonate if the output power is too high. Since this vibration can cause cracking or a decrease
in the adherence of the termination, we recommend that you use the conditions below.
Frequency: 40kHz max.
Output power: 20W/liter
Cleaning time: 5 minutes max.
Dimensions
Revised: 2018-07-13
DIM
Millimeters
Inches
A
5.0±0.5
0.197±0.02
C
Φ2.6±0.5
0.102±0.02
D
Φ2.7±0.5
0.106±0.02
Page:3
RLM102 Series
Taping and Reel Specifications
Symbol
Millimeters
Inches
W
12.0±0.2
0.472±0.008
P0
4.0±0.1
0.157±0.004
P1
4.0±0.1
0.157±0.004
P2
2.0±0.1
0.079±0.004
D
Φ1.5±0.1
0.059±0.004
d
Φ1.5±0.1
0.059±0.004
E
1.75±0.1
0.069±0.004
F
5.5±0.05
0.217±0.002
D1
178.0
7.007
D0
13.0
0.512
W1
15.0
0.591
Quantity:1500PCS / inner box
Revised: 2018-07-13
Page:4
很抱歉,暂时无法提供与“RLM102-501M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.98194
- 10+0.79143
- 30+0.70978
- 100+0.60794
- 500+0.56258
- 1500+0.49896
