VDV476M035S0ANE01K
VDV476M035S0ANE01K
    TEAPO(智宝电子)
    SMD_D6.3X5.4MM
    VDV476M035S0ANE01K
VDV476M035S0ANE01K 数据手册
Surface Mount Aluminium Electrolytic Capacitors DV General purpose Series ■ Endurance:105℃, 2000 hours ■Recommended Applications: Suitable for AV(TV,Video,Audio),Monitor/Computer, Home appliance, OA/HA/Communication,Industrial, Automobile, Meter. ■ Corresponding product to RoHS ■ Specifications Item Category Temperature Range Rated Voltage Range Rated Capacitance Range Capacitance Tolerance Characteristics -55 ~ +105℃ 6.3 ~100VDC 1~ 2200μF ± 20 % (120Hz , 20℃) -25 ~ +105℃ 160~450VDV 12.5 4~10Φ I≦0.01CV or 3(μA),whichever is greater. I≦0.01CV or 3(μA),whichever is greater. Leakage Current (20℃) (After rated voltage applied for 2 minutes) I= Leakage Current (μA) C= Nominal Capacitance (μF) V= Rated Voltage (V) Dissipation Factor(MAX) (tanδ) (120Hz ,20℃) Low Temperature Stability Impedance Ratio (MAX) 12.5 I≦0.04CV+100 uA (After rated voltage applied for 2 minutes) Shown in the table of standard ratings WV Z(120HZ) Z(-25℃) / Z(20℃) Z(-40℃) / Z(20℃) 6.3 10 16 25 35~100 160~450 4 8 3 6 2 4 2 4 2 3 4 ─ After applying rated voltage for 2000hrs at 105℃,Stay back to 20 ℃ temperature measurement,the capacitors shall meet the following requirements. Case (Ф) Endurance 4 6 3Ф 4~6.3Ф Within ±25% of the initial value Not more than 200% of the specified value Not more than the specified value Capacitance Change Dissipation Factor Leakage Current 8 12 5Ф 8~12.5Ф Within ±20% of the initial value After placed at 105℃without voltage applied for 1000 hours,Stay back to 20 ℃ temperature measurement, the capacitor shall meet the same requirement as Endurance. Shelf Life ■MARKING ■Dimensions [mm] Φ12.5=L±1.0 Dimensions B01 C01 E01 E04 G02 G03 H03 K05 K06 M06 L 5.4 5.4 5.4 7.7 6.2 10.2 10.2 13.5 16 16 5 16.5 ФD 4.0 5.0 6.3 6.3 8.0 8.0 10.0 12.5 12.5 16 0 16.0 A 4.3 5.3 6.6 6.6 8.3 8.3 10.3 10.3 10.3 10 3 10.3 H 5.5 Max 6.5 Max 7.8 Max 7.8 Max 9.5 Max 10.0 Max 12.0 Max 15.0 Max 15.0 Max 19 0 Max 19.0 M W 0.65±0.1 0.65±0.1 0.65±0.1 0.65±0.1 0.65±0.1 0.90±0.2 0.90±0.2 1.20±0.2 1.20±0.2 1 20±0 2 1.20±0.2 P 1.0 1.5 1.8 1.8 2.2 3.1 4.6 4.4 4.4 64 6.4 K 0.35+0.15/-0.2 0.35+0.15/-0.2 0.35+0.15/-0.2 0.35+0.15/-0.2 0.35+0.15/-0.2 0.70±0.20 0.70±0.20 0.70±0.30 0.70±0.30 0 70±0 30 0.70±0.30 ■ Multiplier for Ripple Current Frequency (Hz) Coefficient 60 0.85 120 1.00 1K 1.15 Product specifications in this catalog are subject to change without notice.Please refer to the website directory. 10K 1.25 Surface Mount Aluminium Electrolytic Capacitors DV General purpose Series ■STANDARD RATINGS Rated Voltage (SurageVoltage) (V) Case size ФDxL(mm) tanδ (mA/rms 105℃) (120Hz) 22 33 4x5.4 4x5.4 4x5.4 5x5.4 5x5.4 6.3x5.4 6.3x5.4 6.3x7.7 6.3x7.7 8x6.2 8x10.2 8x10.2 10x10.2 8x10.2 10x10.2 10x10.2 12.5x13.5 4x5.4 4x5.4 4x5.4 5x5.4 5x5.4 6.3x5.4 5x5 4 5x5.4 6.3x5.4 6.3x7.7 6.3x7.7 8x6.2 8x10.2 6.3x7.7 8x10.2 8x10.2 10x10.2 8x10.2 10x10.2 12.5x13.5 4x5.4 4x5.4 5x5.4 5x5.4 5x5.4 6.3x5.4 6.3x5.4 6.3x7.7 6.3x7.7 8x6.2 8x10.2 10x10.2 10x10.2 8x10.2 10x10.2 12.5x13.5 16x16.5 4x5.4 4x5.4 4x5.4 4x5.4 5x5.4 5x5.4 6.3x5.4 6 3x5 4 6.3x5.4 6.3x5.4 0.30 0.30 0.30 0.30 0.30 0.30 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.22 0.22 0.22 0.22 0.22 0.22 0 30 0.30 0.30 0.30 0.30 0.30 0.26 0.3 0.30 0.30 0.26 0.3 0.26 0.30 0.16 0.16 0.16 0.16 0.16 0.16 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.34 0.34 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0 14 0.14 0.16 26 29 31 46 47 71 80 120 140 140 290 290 380 290 410 460 680 20 23 26 45 60 70 60 71 110 120 120 260 200 290 320 380 360 410 680 28 29 39 40 42 70 71 130 130 130 150 210 230 240 380 550 900 18 22 25 25 28 28 55 65 65 47 100 220 6.3(8) 330 470 1000 1500 2200 10 22 33 47 100 10(13) 220 330 470 680 1000 2200 10 22 33 47 100 16(20) 220 330 470 1000 2200 3.3 4.7 6.8 25(32) Ripple current Cap (μF) 10 22 33 47 Rated Voltage (SurageVoltage) (V) Case size ФDxL(mm) tanδ (mA/rms 105℃) (120Hz) 47 6.3x7.7 6.3x7.7 8x6.2 8x10.2 8x10.2 10x10.2 8x10.2 10x10.2 10x10.2 12.5x13.5 12.5x16 16x16.5 4x5.4 4x5.4 5x5.4 5x5.4 6.3x5.4 6.3x7.7 8x6.2 6.3x5.4 6.3x7.7 8x10.2 6.3x7.7 8x10 2 8x10.2 10x10.2 12.5x13.5 8x10.2 10x10.2 10x10.2 12.5x13.5 12.5x13.5 16x16.5 16x16.5 4x5.4 4x5.4 4x5.4 5x5.4 5x5.4 5x5.4 6.3x5.4 6.3x5.4 6.3x7.7 6.3x7.7 8x6.2 6.3x7.7 8x6.2 8x10.2 8x10.2 10x10.2 10x10.2 10x10.2 12.5x13.5 12.5x16 16x16.5 6.3x7.7 8x10.2 8x10.2 10x10.2 10x10.2 12.5x13.5 12 5x13 5 12.5x13.5 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.26 0.26 0.26 0.12 0.12 0.12 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0 14 0.14 0.14 0.14 0.14 0.14 0.14 0.22 0.22 0.22 0.22 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.16 0.18 0.18 0.18 0.18 0.18 0.18 0.18 0.18 0 18 0.18 91 100 100 230 230 310 290 380 380 510 590 900 22 25 30 35 60 80 80 60 100 210 105 240 310 390 260 350 370 520 590 800 1000 10 16 16 23 30 35 40 42 65 91 110 110 110 210 240 320 300 330 490 550 800 50 100 120 150 170 250 300 100 220 25(32) 330 470 1000 1500 2200 4.7 6.8 10 22 33 47 35(44) 100 220 330 470 680 1000 1500 1 2.2 3.3 4.7 6.8 10 22 50(63) 33 47 100 150 220 330 470 1000 10 22 100(125) Ripple current Cap (μF) 33 47 100 Product specifications in this catalog are subject to change without notice.Please refer to the website directory. Surface Mount Aluminium Electrolytic Capacitors DV General purpose Series ■STANDARD RATINGS Rated Voltage (SurageVoltage) (V) 160(200) 200(250) 250(300) Cap (μF) Case size ФDxL(mm) tanδ (%) Ripple current 33 47 100 10 22 33 47 3.3 12.5x13.5 16x16.5 16x16.5 12.5x13.5 12.5x16 12.5x16 16x16.5 12.5x13.5 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 95 240 250 80 110 120 220 60 4.7 10 22 12.5x13.5 12.5x13.5 12.5x13.5 0.20 0.20 0.20 65 70 105 (mA/rms 105℃) (120Hz) Rated Voltage (SurageVoltage) (V) 250(300) 400(450) 450(500) Cap (μF) Case size ФDxL(mm) tanδ (%) Ripple current 33 47 3.3 4.7 10 22 33 3.3 16x16.5 16x16.5 12.5x13.5 12.5x13.5 12.5x13.5 16x16.5 16x16.5 12.5x13.5 0.20 0.20 0.25 0.25 0.25 0.25 0.25 0.25 180 220 40 45 50 85 85 40 4.7 10 22 12.5x13.5 12.5x16 16x16.5 0.25 0.25 0.25 45 75 85 Product specifications in this catalog are subject to change without notice.Please refer to the website directory. (mA/rms 105℃) (120Hz)
VDV476M035S0ANE01K 价格&库存
很抱歉,暂时无法提供与“VDV476M035S0ANE01K”相匹配的价格&库存,您可以联系我们找货
