9000 series
Momentary pushbutton switches
Distinctive features and specifications
❑ Two case lengths
❑ Three electrical functions
❑ Sealing options
❑ Model X1146 with Ø 16 (.630) bushing
B
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contact (A) : 0,3A 250VAC - 0,6A 125VAC - 1A 30VDC
- gold plated contacts (CD) : 100mA 30VDC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
1.500 Vrms 50 Hz min. between terminals and frame
• Electrical life : 250.000 cycles
MATERIALS
• Case : thermoplastique UL94-V0
• Actuator : polyamide, glass
filled
• Bushing : brass, nickel plated
• Contacts :
A : silver
CD : brass, gold plated
• Terminal seal : epoxy
B-52
GENERAL SPECIFICATIONS
• Total travel :
9600-9400-9400Y
9600N-9400N
Functions 3 and 5
Function 2
Function 3
1,3 mm
2 mm
0,9 mm
• Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut
• Operating temperature : -30°C to +65°C
www.apem.com
APEM
9000 series
Overview
9
Number of poles
SERIES
3
Single pole
Electrical functions
2
3
5
Normally closed (NC)
Normally open (NO)
Combined (NC/NO)
Terminals, case and bushing
B
Case length 11,2 (.440)
All models have Ø 6,35 (1/4) threaded bushing.
4
Straight PC terminals
6
Solder lug terminals
4..Y
Straight PC terminals, bracket mounting
Case length 8,5 (.334)
4..N
6..N
6..NZ1 Quick-connect terminals
Contact materials
A
CD
Silver
Brass, gold
plated
Sealing
Blank No sealing
B
Epoxy sealed
terminals
K
Front panel sealing
by two O-rings
Special options
X1146
X601
Bushing Ø 16 (.630)
Special contact, lower rating
Caps
U900
U1140
U1720
U480
U630
U2430
U2020
Ø 5 (.196)
Ø 8 (.314)
Ø 9,4 (.370)
Ø 10 (.393) standard
Ø 15 (.590)
Square - Height 4 (.157)
Square - Height 6 (.236)
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- their options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Sealing boots are available to protect the switches against dust and water. They are presented in section H.
Mounting accessories : standard hardware supplied with all switches : 2 hex nuts 8 mm (.314) across flats and 1 lockwasher.
Standard and special hardware available are presented in section I.
Packaging unit : 50 pieces, except for 9400Y (25 pieces)
APEM
www.apem.com
B-53
9000 series
9600 - 9400 - 9400Y
• Single pole
• Solder lug or straight PC terminals
2.80
(.110)
4.55
(.179)
5.20
(.204)
1.50
(.059)
1.20
(.047)
Function 5
(combined)
1.20
(.047)
1.00
(.039)
2.00
(.078)
MODEL
STRUCTURE
Solder lug terminals - case length 11,2 (.440) : 9600
6.00
(.236)
Ø4.00
(.157 DIA)
9635
Combined function
Ø10.0
(.393 DIA)
11.20
(.440)
Normally Closed
7.00
(.275)
9632
Ø6.35-40UNS
(1/4-40UNS)
Ø9.00
(.354 DIA)
NO
NO
NC
0.40
(.015)
5.20
(.204)
2.00
(.078)
5.08
(.200)
F2
F5
For Normally Open (function 3), see next page.
Straight PC terminals - case length 11,2 (.440) : 9400
5.08
(.200)
Ø6.35-40UNS
(1/4-40UNS)
5.08
(.200)
6.00
(.236)
Ø4.00
(.157 DIA)
11.85
(.466)
NO
NO
NC
1.00
(.039)
0.40
(.015)
5.08
(.200)
F2
5.08
(.200)
5.08
(.200)
Ø6.35-40UNS
(1/4-40UNS)
3.18
(.125)
Ø10.00
(.393 DIA)
Normally Open
0.40
(.015)
9435Y
Combined function
4.10
(.161)
1.17
(.046)
3.18
(.125)
8.20
(.322)
The bracket is not fastened to the switch.
B-54
F2
www.apem.com
Ø1.60
(.062 DIA)
NO
NO
NC
0.40
(.015)
5.08
(.200)
5.08
(.200)
9433Y
Normally Closed
13.00
(.511)
9432Y
15.75
(.620)
Ø4.00
(.157 DIA)
6.00
(.236)
Bracket mounting - case length 11,2 (.440) : 9400Y
F5
15.75
(.620)
15.75
(.620)
Combined function
Ø1.60
(.062 DIA)
Ø9.00
(.354 DIA)
5.08
(.200)
9435
Normally Open
4.55
(.179)
9433
Ø10.0
(.393 DIA)
Normally Closed
7.00
(.275)
9432
6.60
(.259)
B
Function 3
(NO)
9400
5.20
(.204)
8.70
(.342)
Function 2
(NC)
9600
2.40
(.094)
9600Z1
3.18
(.125)
F5
APEM
9000 series
9600N - 9400N
Solder lug terminals - case length 8,5 (.334) : 9600N
6.00
(.236)
Ø4.00
(.157 DIA)
Normally Open
0.40
(.015)
2.00
(.078)
5.00
(.196)
5.08
(.200)
1.50
(.059)
8.50
(.334)
Ø9.50
(.374 DIA)
7.00
(.275)
9633N
Ø6.35-40UNS
(1/4-40UNS)
Ø8.50
(.334 DIA)
B
Also available with quick-connect terminals 2,8 x 0,5 mm : 9633NZ1
Straight PC terminals - case length 8,5 (.334) : 9400N
6.00
(.236)
Ø4.00
(.157 DIA)
Ø9.50
(.374 DIA)
10.00
(.393)
Normally Open
Ø1.60
(.062 DIA)
0.40
(.015)
1.00
(.039)
3.50
(.137)
Ø8.50
(.334 DIA)
5.08
(.200)
5.08
(.200)
1.50
(.059)
7.00
(.275)
9433N
Ø6.35-40UNS
(1/4-40UNS)
PANEL CUT-OUT
Ø6.50
(.255 DIA)
2.00
(.078)
Panel cut-out : Ø 16,2 (.637)
Max. current/voltage rating. : 0,3A 250VAC - 1A 30VDC
Epoxy sealed terminals. Options of the following pages not applicable.
APEM
3.00
(.118)
19.00
(.748)
Ø16.00x1.00SI
(.629DIAx1.00IS)
www.apem.com
0.40
(.015)
5.08
(.200)
5.20
(.204)
Gold plated silver contacts
9633ADX1146
Normally open
7.40
(.291)
Normally open
Ø18.00
(.708DIA)
3.30
(.129)
Ø12.00
(.472DIA)
9.50
(.374)
Silver contacts
9633AX1146
1.50
(.059)
Bushing Ø 16 (.630) - metal button : 9633•X1146
Hex nut 19 (.748) across flats
B-55
9000 series
CONTACT MATERIALS
A
CD
Silver
Brass, gold plated
Special contact, lower rating : see X601 under "Special options".
SEALING
Blank
No sealing
B
K
Front panel sealing by two O-rings. Protects the switch against
water and dust.
Panel seal withstands 0,1 bar pressure and remains tight even when
switch is operated.
KB
Combined sealings
5.50 Maxi
(.216 MAX)
B
1
K
➀ O-rings
Sealing boots : see section H.
SPECIAL OPTIONS
X601
Silver plated brass contacts
Current/voltage rating for an electrical life of 20.000 cycles :
0,2A 250VAC - 0,4A 125VAC - 0,5A 30VDC.
Minimum quantity : 5.000 pieces per model and shipment.
X1146
Model with dia. 16 (.630) bushing and metal plunger
See previous page.
B-56
www.apem.com
APEM
9000 series
CAPS
+ U...
U900
U1140
B
U1720
Ø15.00
(.590 DIA)
Ø10.00
(.393)
Replace last
"0" by number
1
1/4
2
3
4
5
6
7
7/1
9
3.00
(.118)
3.00
(.118)
10.00
(.393)
7.50
(.295)
Cap colours
U480
Standard
U630
5.00
(.195)
4.00
(.157)
U2430
Square
blue
dark blue
black
green
grey
yellow
red
ivory
white
orange
6.00
(.236)
11.50x11.50
(.452 SQ)
11.50x11.50
(.452 SQ)
3.00
(.196)
6.35
(.250)
3.00
(.118)
6.35
(.250)
3.00
(.118)
4.00
(.157)
3.30
(.129)
Ø9.40
(.370)
Ø8.00
(.314)
Ø5.00
(.196)
U2020
Square
DRESS NUTS
Ø18.50
(.728 DIA)
Ø8.20
(.322 DIA)
Ø10.50
(.413 DIA)
Ø15.50
(.610 DIA)
U1636
Ø6.35-40UNS
(1/4-40UNS)
Ø6.35-40UNS
(1/4-40UNS)
Ø6.35-40UNS
(1/4-40UNS)
For cap U1140
8.00
(.314)
8.20
(.322)
8.00
(.314)
5.80
(.228)
Ø13.50
(.531 DIA)
6.20
(.244)
Ø12.70
(.500 DIA)
5.80
(.228)
Chrome plated
U825
U840
For cap U480
For cap U630
Dress nuts are to be ordered separately.
APEM
www.apem.com
B-57
9000 series
Alternate action or momentary pushbutton switches
❑ Bushing Ø 6,35 (1/4) and 11,9 (15/32)
❑ Two electrical functions
B
• Max. current/voltage rating with resistive load and electrical life :
- silver contacts (A) : 0,5A 250VAC - 1A 28VDC - 250.000 cycles
1,5A 250VAC - 3A 28VDC - 10.000 cycles
- gold plated contacts (CD) : 0,4VA 20V max. AC or DC
• Initial contact resistance : 10 mΩ max. at 0,1A 3VDC
• Insulation resistance : 10.000 MΩ min.
MATERIALS
• Case : diallylphthalate
• Actuator : nylon
black for series 9630M
white for series 9631
• Contacts :
A : silver
B-58
• Operating temperature : -30°C to +85°C
• Travels : see table below.
MODELS
9631
9633M
Total travel
3,48 (.137)
2,79 (.110)
Pre-travel
0,66 (.026)
Over travel
2,69 (.106)
0,51 (.020)
www.apem.com
APEM
9000 series
• Single pole
• Solder lug terminals
• Epoxy sealed terminals
Function 3
(NO)
2.55
(.100)
Function 1
OFF
ON
1.00
(.040)
5.60
(.220)
2.05
(.080)
1.25
(.050)
B
Bushing Ø 6,35 (1/4) - Alternate action - tactile feedback
Silver contacts
9631AB
ON
OFF
5.35
(.210)
6.35
(.250)
ON
Ø9.40
(.370 DIA)
16.25
(.640)
Gold plated contacts
9631CDB
Ø4.05
(.160 DIA)
Ø6.35-40UNS
(1/4-40UNS)
OFF
EPOXY
5.60
(.220)
0.40
(.015)
5.30
(.209)
Standard hardware : 1 conic nut and 1 lockwasher
Bushing Ø 11,9 (15/32) - front or rear mounting - NO
A
Ø8.40
(.330 DIA)
Normally open
9.25
(.365)
9633MCDB
16.65
(.655)
Ø11.90-32UNS
(15/32-32UNS)
Ø9.40
(.370 DIA)
MODEL
A
9633M
6.35 (.250)
EPOXY
5.60
(.220)
0.40
(.015)
5.30
(.209)
Standard hardware : 2 hex nuts 14 mm (.551) across flats and 1 lockwasher
APEM
www.apem.com
B-59
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
U1727 U242N U487 U907 U1636 U1721 U1722 U1723 U1726 U1727/1 U2022 U2026 U2432 U2436 U484
U487/1 U489 U631 U633 U634 U636 U637/1 U639 U902 U906
