KLJ-5030
KLJ-5030
    KELIKING(凯丽金)
    SMD
    KLJ-5030
KLJ-5030 数据手册
DESCRIPTION :SMD BUZZER PART :KLJ-5030 NO. USER’S PART NO. : DATE :2008.12.1 CUSTOMER APPROVED : Approved By Checked By Made 地址:常州市新北区漓江路 电话:0519-88671999 手机:13656128000 Http://www.kailijin.cn E-mail:866@kailijin.cn By KLJ-5030B-03040 DATE:2008.08.11 1﹒Electrical Characteristics Oscillation Frequency (Hz) Operating Voltage (Vp-p) Rated Voltage (Vp-p) VER .:0 4000 2.0 ~4.0 3.0 Current Consumption (mA/max.) 100 at Rated Voltage Sound Pressure Level (dB/min.) 82 at 10cm at Rated Voltage Coil Resistance (Ω) 12 ±2 Operating Temperature (℃) -20 ~ +60 Storage Temperature (℃) -30 ~ +80 Environmental protection rule PS:Vp-p=1/2duty , square wave 2﹒Typical Frequency Response Curve RoHS 3﹒Dimensions and Material 3-1 Shape - Unit : mm TOL:±0.3 3-2 Material Housing LCP plastic resin (Color : Black) Leading Pin Tin Plated Brass Weight (Gram) 0.5 4﹒Recommend Driving Circuit The base current Ib should high enough so that it saturates the collector current of the transistor with the CB load. 5. TESTING METHOD .Standard Measurement conditions Temperature:25±2℃ Humidity:45-60% .Acoustic Characteristics The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below. 10cm FUNCTION GENERATOR AMPERE METER SOUNDER MICROPHONE In the measuring test, buzzers is placed as follows: SAMPLE MICROPHONE 1OCM dB METER 6. RELIABILITY ITEMS Coldness withstanding METHOD OF TEST AND MEASUREMENTS After 98 hours of being exposed to -30℃ environment, should be returned to normal environment for 2 hours, then re-proceed to test. PERFORMANCE No abnormality shall exist Hotness withstanding After 98 hours of being exposed to +80℃ Humidity withstanding After 98 hours of being exposed to 40℃ 95%RH Durability Testing after 1,000 hours actual continuous operation. (at standard measurement conditions) No abnormality shall exist Drop withstanding A natural drop from 75cm high down to the ground. No abnormality shall exist Vibration withstanding Vibration of 2,000 cycles per minute, 2mm amplitude, applied in X, Y and Z directions for 30 No abnormality shall exist environment, should be returned to normal environment for 2 hours, then re-proceed to test. environment in actual operation, should be returned to normal environment for 2 hours, then re-proceed to test. minutes each. No abnormality shall exist No abnormality shall exist 7.Soldering Condition (1)Recommendable reflow soldering condition is as follows (Reflow soldering is twice) after heat of product goes down to normal. Heat resistant line (Used when heat resistant reliablity test is performed) (2)Manual soldering Manual soldering temperature 350 C within 10 sec. 8. PACKAGE METHOD CARRIER REEL 3000 PCS BUZZER INNER BOX 1 ROLL CARRIER REEL CARTON BOX 10 INNER BOX 30K PCS BUZZER Unit:mm
KLJ-5030 价格&库存
很抱歉,暂时无法提供与“KLJ-5030”相匹配的价格&库存,您可以联系我们找货
