AS201701
AS201701
    ZF
    ACTUATOR MAGNET SMOOTH
AS201701 数据手册
Magnetic Proximity Sensors (Reed) MP2017 Sensors Reed based magnetic proximity sensor encapsulated in smooth plastic barrel Description The MP2 Series sensors are reed proximity sensors. Normally open or closed contacts change states when a magnetic field is applied. The sensors act as non-latching electrical switches. Features       Typical Applications Contacts hermetically sealed for long life Zero power consumption Suitable for DC and AC circuits RoHS compliant IP65 Operate/Release Distances*: 3.81 mm – 12.7 mm (0.15” – 0.5”)      Door position & interlock Limit switch Flow/speed Home security Pedal switch Environmental Specifications Vibration 20 g 10 Hz to 1 kHz (MP201701), 20 g 10 Hz to 55 Hz (MP201702, MP201703) -40 °C to 105 °C (-40 °F to 221 °F) -40 °C to 105 °C (-40 °F to 221 °F) IP65 Operating Temperature Storage Temperature Ingress Protection Electrical Specifications Typical Operating Time Breakdown Voltage Switching Voltage and Current Contact Resistance and Power rating: 1 ms 200 VDC min. See Products chart See Products chart Mechanical Specifications Housing Material Operate/Release Distances* *with AS201701 magnetic actuator Glass-reinforced Plastic 3.81 mm – 12.7 mm (0.15” – 0.5”) Products Part Number MP201701 MP201702 MP201703 Contact Form SPST-NO Form A SPST-NC Form B SPDT-CO Form C Maximum Power Rating 10 W Maximum Switching Volta ge 175 VAC/VDC Maximum Switching Current 0.5 A Maximum Contact Resistance 0.200 Ω 3W 30 VAC/VDC 0.2 A 0.100 Ω 3W 30 VAC/VDC 0.2 A 0.100 Ω All MP2017 sensors come with leads 24 AWG x 305 mm (12”) www.cherryswitches.com Page 1 of 2, last update 2014-12-12, Specifications subject to change without notice. Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, last update 2014-12-12, Specifications subject to change without notice.
AS201701 价格&库存
很抱歉,暂时无法提供与“AS201701”相匹配的价格&库存,您可以联系我们找货
