A02 SERIES
KEYLOCK SWITCHES
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
Panel cut-out .866" (22mm) or 1.161" x .846" (29.5mm x 21.5mm)
A keylock switch assembly requires:
Operator + one or two Switchblocks
To order, select desired model numbers from tables below.
Example: IP65 square 2 position maintained keylock switch with 2 N.O. contacts =
A028201 and A02503
Switches are normally shipped unassembled. Consult factory if factory assembly is required.
E
KEY POSITIONS
SWITCH BLOCK
OPERATOR
Bezel Description
2 pos. maintained
2 pos. momentary
3 pos. maintained
3 pos. momentary
3 pos. mainB, momC
3 pos. momB, mainC
2 pos. maintained
2 pos. momentary
3 pos. maintained
3 pos. momentary
3 pos. mainB, momC
3 pos. momB, mainC
z
2 pos. maintained
z
2 pos. momentary
z
3 pos. maintained
z
3 pos. momentary
z
3 pos. mainB, momC
z
3 pos. momB, mainC
Part no.
A028101
A028102
A028105
A028106
A028107
A028108
A028201
A028202
A028205
A028206
A028207
A028208
A028301
A028302
A028305
A028306
A028307
A028308
Key removable
A-C
A
A-B-C
A
A-B
A-C
A-C
A
A-B-C
A
A-B
A-C
A-C
A
A-B-C
A
A-B
A-C
Contacts
1 N.O.
1 N.C.
2 N.O.
2 N.C.
1 N.O./1 N.C.
Part no.
A02501
A02502
A02503
A02504
A02505
SECOND
SWITCH BLOCK
Contacts
1 N.O.
1 N.C.
2 N.O.
2 N.C.
1 N.O./1 N.C.
Part no.
A02506
A02507
A02508
A02509
A02510
To achieve 3 or 4 pole
switching, add second
switch block, from above
table.
Key rotation - 2 position switches
The model numbers shown are for
switches with counterclockwise lever
rotation. For clockwise rotation,
replace:
01 with 20
02 with 19
at the end of the model number.
2 standard keys are supplied.
20 key barrel types available from
stock.
FOR UNSEALED SWITCHES (IP40): Add '01' to end of OPERATOR model number.
NON-REMOVABLE KEY POSITIONS: Contact factory.
Bezel:
rectangular
square
z round
'momC' - momentary position C
'mainB' - maintained position B
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
A02504 109605
很抱歉,暂时无法提供与“109605”相匹配的价格&库存,您可以联系我们找货
