LN4915
Low Current Consumption, High Sensitivity CMOS Hall IC
■ General Description
■ Operating Parameters
The LN4915 is an integrated hall-effect sensor designed
Operating temperature range
specifically to meet the requirements of low-power devices.
TMIN ≤ TA ≤ TMAX
−40°C ≤ TA ≤ 85°C
e.g. as an On/Off switch in cellular flip-phones, with battery
Operating voltage range
2.0V ≤ VDD ≤ 6.0V
operating voltages of 2.0V-5.5V.
■ Application
Precise magnetic switching points and high temperature
stability are achieved through the unique design of the
Mobile phones
internal circuit. An onboard clock scheme is used to reduce
Notebook
the average operating current of the IC. During the operate
Portable electronic devices
phase the IC compares the actual magnetic field detected
■ Package
with the internally compensated switching points. The
output Voltage is switched at the end of each operating
SOT-23-3
phase. During the Stand-by phase the output stage is
TSOT-23-3
latched and the current consumption of the device reduced
TO-92
to some µA.
TO-92S
The IC switching behavior is omnipolar, it can be switched
■ Typical Application Circuit
on with either the north or south pole of a magnet.
LN4915 is higher sensitivity of magnetic induction than
LN4913, it can be used in security systems 、 sensing
10K
magnet smaller occasions.
■ Features
VDD
LN4915
Micro power design
VOUT
2.0 V to 5.5 V battery operation
High sensitivity and high stability of the magnetic
1µF
Switching points
GND
High resistance to mechanical stress
Digital output signal
Switching for both poles of a magnet (omnipolar)
Not suitable for automotive application
■ Ordering Information
Package
Code
Package
Lot
Number
LN4915MR
M
SOT-23-3
15XY
LN4915NR
N
TSOT-23-3
LN4915TR
T
LN4915SR
S
Part Number
Rev.1.0 — Aug. 18, 2011
Package
Code
Package
Lot
Number
LN4915SRA
S
TO-92S
XXXX
15XY
LN4915TRB
T
TO-92
XXXX
TO-92
XXXX
LN4915SRB
S
TO-92S
XXXX
TO-92S
XXXX
LN4915TRA
T
TO-92
XXXX
1
Part Number
www.natlinear.com
LN4915
■ Pin Configuration
SOT-23-3/TSOT-23-3
(TOP VIEW)
GND
3
Marking
Sensitive Area
(感应区)
13
1
2
Hall series
8
5
Date Code
LN4915MR
VOUT
VDD
Pin Number
Pin Name
Function Description
2
VOUT
Output Pin
3
GND
Ground
1
VDD
Supply Voltage
Sensitive
Area
(感应区)
TO-92/TO-92S
(Front View)
LN4915XY
XXXX
XY:TR,TRA…
1
Ordering Name
Package
2
3
Pin Name
1
2
3
Marking
LN4915TR
TO-92
VDD
VOUT
GND
4915
LN4915SR
TO-92S
VDD
VOUT
GND
4915
LN4915TRA
TO-92
VOUT
GND
VDD
4915A
LN4915SRA
TO-92S
VOUT
GND
VDD
4915A
LN4915TRB
TO-92
VDD
GND
VOUT
4915B
LN4915SRB
TO-92S
VDD
GND
VOUT
4915B
2
www.natlinear.com
LN4915
■ Function Block Diagram
VDD
1
Bias and
compensation
circuits
Oscillator
Sequencer
Active Error
Compensation
Threshold
Generator
3
Comparator
With
Hysteresis Decision
Hall Probe
Logic
Chopped
Amplifer
GND
2
Latch
VOUT
■ Absolute Maximum Ratings
Symbol
Characteristics
Vdd
Supply voltage
IDD
Operating current
Values
Unit
2.0-6.0
V
-1-4.5
mA
VOUT
Output voltage
-0.3-6.0
V
IOUT
Output current
-1-2.0
mA
-40~+150
°C
TS
Storage temperature range
TJ
Maximum junction temperature
150
°C
ESD Protection
4000
V
■ Electrical Characteristics
AC/DC Characteristics
Symbol
(TA=+25℃,VDD=3.0V,Unless otherwise specified)
Characteristic
VDD
Supply voltage
ISAVG
Averaged supply current
ISOPAVG
Conditions
Min
Typ
Max
Unit
2.0
5.5
V
1
3
10
uA
0.5
2.0
3.5
mA
4.5
mA
1.9
8
uA
0.13
0.4
V
0.01
1
uA
Averaged current during operating time
ISOPT
Peak current during operating time
ISSTB
Supply current during standby time
VQSAT
Output Saturation Voltage
IQLEAK
Output on Leakage Current
1
IOUT=1mA
tr
Output rise time
RL=2.7KΩ CL=10pF
0.5
1
us
rf
Output fall time
RL=2.7KΩ CL=10pF
0.1
1
us
top
Operating time
25
100
160
us
tstb
Standby time
60
140
240
ms
top/tstb
tstu
Duty cycle
0.071
Start-up time of IC
12
3
us
www.natlinear.com
LN4915
■ Mangentic Characteristics
(TA=+25℃,VDD=2.7V, Unless otherwise specified)
Symbol
Min
Typ
Max
Unit
BOPS
1
1.5
2
mT
BOPN
-2
-1.5
-1
mT
BRPS
0.8
1.1
1.5
mT
BRPN
-1.8
-1.1
-0.8
mT
BHYS
0.1
0.4
0.7
mT
Is
Operating
Time
Isopavg
Standby Time
Isavg
Isstb
top
tstb
100µs
130ms
Latch
Output
t
VOUT
Output OFF
VOUTH
Output
ON
VOUTL
BOPN
BRPN
BRPS BOPS
B
VOUT as function of the applied B-Field
4
www.natlinear.com
LN4915
■ Package
SOT-23-3
5
www.natlinear.com
LN4915
TSOT-23-3
6
www.natlinear.com
LN4915
TO-92
7
www.natlinear.com
LN4915
TO-92S
8
www.natlinear.com
很抱歉,暂时无法提供与“LN4915NR-G”相匹配的价格&库存,您可以联系我们找货
