SX1308
85T
High Efficiency 1.2MHz 2A Step Up Converter 85T
FEATURES
GENERAL DESCRIPTION
• Integrated 80mΩ Power MOSFET
• 2V to 24V Input Voltage
• 1.2MHz Fixed Switching Frequency
• Internal 4A Switch Current Limit
• Adjustable Output Voltage
• Internal Compensation
• Up to 28V Output Voltage
• Automatic Pulse Frequency Modulation
Mode at Light Loads
• up to 96% Efficiency
• Available in a 6-Pin SOT23-6 Package
The SX1 308 is a constant frequency, 6-pin SOT23
current mode step-up converter intended for small,
low power applications. The SX1308 switches at
1.2MHz and allows the use of tiny, low cost
capacitors and inductors 2mm or less in height.
Internal soft-start results in small inrush current and
extends battery life.
The SX1308 features automatic shifting to pulse
frequency modulation mode at light loads. The
SX1308 includes under-voltage lockout, current
limiting, and thermal overload protection to prevent
damage in the event of an output overload. The
SX1308 is available in a small 6-pin SOT-23
package.
APPLICATIONS
• Battery-Powered Equipment
• Set-Top Boxed
• LCD Bais Supply
• DSL and Cable Modems and Routers
• Networking cards powered from PCI
or PCI express slots
TYPICAL APPLICATION
Efficiency (%)
Efficiency
Iout (mA)
Figure 1. Basic Application Circuit
Copyright ©2010 by Suosemi Corporation
Figure 2. Efficiency Curve
1
SX1308
ABSOLUTE MAXIMUM RATINGS
IN, EN voltages ………..….…… -0.3V to 26V
Operating Temperature….... -40°C to +85°C
FB Voltages ................................-0.3V to 6V
Junction Temperature ………………...160°C
SW Voltage ……………………..-0.3V to 30V
Storage Temperature Range -65°C to 150°C
Peak SW Sink and Source Current ………4A
Lead Temperature (Soldering, 10s) ...+300°C
PACKAGE/ORDER INFORMATION
SW
1
6
NC
GND
2
5
IN
FB
3
4
EN
SOT23-5
SOT23-6
(MT3540)
(SX1308)
PIN DESCRIPTION
PIN
NAME
FUNCTION
1
SW
Power Switch Output. SW is the drain of the internal MOSFET switch. Connect the
power inductor and output rectifier to SW. SW can swing between GND and 28V.
2
GND
Ground Pin
3
FB
Feedback Input. The FB voltage is 0.6V. Connect a resistor divider to FB.
4
EN
Regulator On/Off Control Input. A high input at EN turns on the converter, and a
low input turns it off. When not used, connect EN to the input supply for automatic
startup.
5
IN
6
NC
Input Supply Pin. Must be locally bypassed.
NC
2
SX1308
ELECTRICAL CHARACTERISTICS
(VIN=VEN=5V, TA = 25°C, unless otherwise noted.)
Parameter
Conditions
Operating Input Voltage
MIN
TYP
2
Under Voltage Lockout
Under Voltage Lockout Hysteresis
MAX
unit
24
V
1.98
V
100
mV
Current (Shutdown)
VEN= 0V
0.1
1
µA
Quiescent Current (PFM)
VFB=0.7V,No switch
100
200
µA
Quiescent Current (PWM)
VFB=0.5V,switch
1.6
2.2
mA
Switching Frequency
Maximum Duty Cycle
1.2
VFB = 0V
EN Input High Voltage
90
1.5
V
EN Input Low Voltage
FB Voltage
FB Input Bias Current
VFB = 0.6V
SW On Resistance (1)
0.588
0.6
-50
-10
80
SW Current Limit (1)
VIN= 5V, Duty cycle=50%
SW Leakage
VSW = 20V
Thermal Shutdown
MHz
0.4
V
0.612
V
nA
150
4
A
1
155
mΩ
μA
Note:
1) Guaranteed by design, not tested.
3
SX1308
OPERATION
The SX1308 uses a fixed frequency, peak current
mode boost regulator architecture to regulate
voltage at the feedback pin. The operation of the
SX1308 can be understood by referring to the block
diagram of Figure 3. At the start of each oscillator
cycle the MOSFET is turned on through the control
circuitry. To prevent sub-harmonic oscillations at
duty cycles greater than 50 percent, a stabilizing
ramp is added to the output of the current sense
amplifier and the result is fed into the negative input
of the PWM comparator. When this voltage equals
The output voltage of the error amplifier the power
MOSFET is turned off. The voltage at the output of
the error amplifier is an amplified version of the
difference between the 0.6V bandgap reference
voltage and the feedback voltage. In this way the
peak current level keeps the output in regulation. If
the feedback voltage starts to drop, the output of the
error amplifier increases. These results in more
current to flow through the power MOSFET, thus
increasing the power delivered to the output. The
SX1308 has internal soft start to limit the amount of
input current at startup and to also limit the amount
of overshoot on the output.
Figure 3. Functional Block Diagram
4
SX1308
TYPICAL OPERATING CHARACTERISTICS
Efficiency Curve
Efficiency
Current limit(A)
Efficiency Curve
Iout (mA)
Iout(mA)
Load regualation
Vout(V)
Vout(V)
line Regulation
Vin (V)
Freq VS Vin
Iout (mA)
Efficiency VS Vin
5
SX1308
APPLICATION INFORMATION
Setting the Output Voltage
Layout Consideration
The internal reference VREF is 0.6V (Typical).The
output voltage is divided by a resistor divider,R1 and
R2 to the FB pin. The output voltage is given by
For best performance of the SX1308, the following
guidelines must be strictly followed.
Input and Output capacitors should be placed
close to the IC and connected to ground plane
to reduce noise coupling.
The GND should be connected to a strong
ground plane for heat sinking and noise
protection.
Keep the main current traces as possible as
short and wide.
SW node of DC-DC converter is with high
frequency voltage swing. It should be kept at a
small area.
Place the feedback components as close as
possible to the IC and keep away from the
noisy devices.
VOUT = VREF × (1 +
R1
R2
Inductor Selection
The recommended values of inductor are 4.7 to
22μH. Small size and better efficiency are the major
concerns for portable device, such as SX1308 used
for mobile phone. The inductor should have low core
loss at 1.2MHz and low DCR for better efficiency. To
avoid inductor saturation current rating should be
considered.
Capacitor Selection
Input and output ceramic capacitors of 22μF are
recommended for SX1308 applications. For better
voltage filtering, ceramic capacitors with low ESR
are recommended. X5R and X7R types are suitable
because of their wider voltage and temperature
ranges.
Diode Selection
Schottky diode is a good choice for SX1308
because of its low forward voltage drop and fast
reverses recovery. Using Schottky diode can get
better efficiency. The high speed rectification is also
a good characteristic of Schottky diode for high
switching frequency. Current rating of the diode must
meet the root mean square of the peak current and
output average current multiplication as following :
I D ( RMS ) ≈ I OUT × I PEAK
The diode’ s reverse breakdown voltage should be
larger than the output voltage.
6
SX1308
PACKAGE DESCRIPTION
TOP VIEW
RECOMMENDED LAND PATTERN
FRONT VIEW
SIDE VIEW
DETAIL “A”
Figure 4. TSOT23-6/SOT23-6 Physical Dimensions
NOTE:
1)ALL DIMENSIONS ARE IN MILLIMETERS.
2) PACKAGE LENGTH DOES NOT INCLUDE MOLD FLASH,PROTRUSION OR GATE BURR.
3) PACKAGE WIDTH DOES NOT INCLUDE INTERLEAD FLASH OR PROTRUSION.
4) LEAD COPLANARITY (BOTTOM OF LEADS AFTER FORMING) SHALL BE 0.10 MILLIMETERS MAX.
5) DRAWING CONFORMS TO JEDEC MO-193, VARIATION AB.
6) DRAWING IS NOT TO SCALE.
7) PIN 1 IS LOWER LEFT PIN WHEN READING TOP MARK FROM LEFT TO RIGHT, (SEE EXAMPLE TOP MARK)
7
很抱歉,暂时无法提供与“SX1308”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.74842
- 50+0.61612
- 150+0.54808
- 500+0.49204
