206
    APEM(埃斐)
    TESTER CABLE PC/NETWORK
206 数据手册
30.46 O 27.31 O 26.20 O 20.99 O 29.43 . 00 2.10 R3 APEM APEM 9000 SERIES - CONTACTLESS JOYSTICKS ULTRA LOW PROFILE ONE, TWO, THREE AXIS HIGH EMC IMMUNITY CONTACTLESS SENSING WIDE VARIETY OF HANDLES 18 MONTH WARRANTY INFINITE RESOLUTION CONSISTENT PERFORMANCE OPTIONAL ‘AT CENTRE’ AND ‘INTERNAL FAULT‘ DETECTION IP65 ABOVE PANEL LONG SERVICE LIFE www.apem.com 870045v8 9000 SERIES - CONTACTLESS JOYSTICKS PRODUCT DESCRIPTION GENERAL DESCRIPTION The 9000 Series is ideal for those applications that demand proportional control with the lowest possible profile below the panel. Developed from the proven 7000 Series, the 9000 Series employs the same, highly proven, contactless, inductive sensing and circuitry. The mechanics have been radically improved to reduce the below-panel depth to a world class 35mm sub-panel or 31mm drop-through. This joystick offers self-centering, omni-directional functionality, and utilises the exclusive ‘locking cam’ system to rigidly secure the highly repeatable mechanism around the precision ground steel operating shaft. High precision air wound coils are mounted directly onto the SMT circuitry, delivering enviable accuracy whilst further minimising the installed depth of the joystick. CIRCUITRY The 9000 Series joystick operates by passing a oscillating current through a drive coil, directly mounted at the lower end of the operating lever, and immediately above the four sensing coils. When the shaft and drive coil moves away from the centre, the signals detected in each opposing pair of coils increase nominally in proportion to deflection. The phase of those signals determine the direction. Synchronous electronic switches followed by integrating amplifiers provide DC signals directly equivalent to those of potentiometer joysticks, but with fixed output impedance and free of wiper noise and track wear. DUAL DECODE Designed for use in the most safety-critical applications, the 9000 Series incorporates comprehensive internal monitoring circuitry whereby output signals are continually compared with separately generated ‘mirror signals’. In the unlikely event of an internal fault, the dual decode system will generate a separate fault signal, enabling the controller to fail-to-safe. The dual decode system is a complete internal self-monitoring system, providing a far higher standard of protection. An additional,‘away from centre’ signal is also available whenever required. Although the monitoring of the joystick is fully internal, the inverse ‘mirror signals’ can be available as external outputs where the monitor function is incorporated within the controller circuitry. GUIDED FEEL The 9000 Series may also be specified with guided feel. A joystick with guided feel moves more readily towards the poles ( N, S, E and W ) and whilst it can still move away from the poles, the force required to do so is greater. Unless specified otherwise, joysticks are supplied as standard without guiding. This standard configuration allows the user to move the joystick anywhere within the limiter with the same force and without any bias. FUNCTIONAL OPTIONS The 9000 Series can be configured in three different modes Orthoganol, standard signals - Replicating that of a potentiometer Deliberate signal mixing - Ideal for those applications whereby the method of steering is by controlling two motors. For example one motor uses X+Y signals and the other uses X-Y signals. This mixing is achieved by internally orientating the signals at 45 degrees to normal. Typical applications may be twin propeller boats, tracked vehicles, or wheelchairs. Deliberate signal interaction - Enables reduction in one signal as the other increases. This option is particularly beneficial where it is undesirable to maintain full forward speed while turning and vice versa. Note: The company reserves the right to change specifications without notice. www.apem.com 870045v8 9000 SERIES - CONTACTLESS JOYSTICKS PRODUCT CONFIGURATION STANDARD OPTIONS The 9000 Series is available with a range of standard options, to specify your joystick, simply choose one option from each column. An example is shown below. 9 S A 20 R C 6 2 00 SERIES SENSING DECODING GAIN LIMITER HANDLE BEZEL GAITER MODIFIER 9000 Mixed (M) Single Decode 20% (+/- 10%) Single Axis Round (C) Not supplied (0) Gloss Finish (2) None (00) Interacting (A) (10) Cross (C) Cylindrical Circular (4) Standard (5) Guided Feel (20) (20) Diamond (D) Conical (E) 66% (+/- 33%) Round (R) Conical (G) (33) Square 80% (+/- 40%) (S) Push Button Tactile (J) X Type Dual Decode Fault Detect (40) (X) (X) 100% (+/- 50%) Push Button Soft Touch (N) (50) Third Axis + Push Button (P) (9) (Q) Standard (S) Dual Decode Dual Outputs (M) Dual Decode Separate Fault & Centre Detect (W) Dual Decode Combined Fault & Centre Detect (Y) Dual Decode Centre Detect (Z) 40% (+/- 20%) (A) (D) Square (6) Push Button Tactile (M) Skirted (Q) Third Axis (R) Third Axis - Knurled (Y) BEZEL OPTIONS For drop in mounting, please specify bezel option 6. For sub-panel mounting, no bezel is necessary, unless the gaiter is required to seal to the face of the panel in which case bezel option 4 should be specified. SPRINGING As standard 9000 Series are offered sprung to centre. The standard spring force requires 1.3N (nominally) to off-centre the joystick. The 9000 Series may be specified with a lighter spring (1N), or a stronger spring (1.6N) Note: Forces quoted are subject to exact joystick configuration and are provided as a guide only. Owing to the size and weight of handle type P it is supplied as standard with a strong spring. DUAL DECODE INTERFACE For optimum performance of the centre detect and fault detect signals, Apem recommend the signals are “pulled high” via an input resistor of typically 22k, on the controller circuitry. CENTRE TAP REFERENCE All 9000 Series output a centre tap reference as standard. This reference is set within the joystick at 50% of Vcc (+/-1%). For optimum accuracy the wipers should be read relative to the centre tap. NON STANDARD Further non standard options including custom handles or special limiters are available. Please refer to Apem for further details. www.apem.com 870045v8 9000 SERIES - CONTACTLESS JOYSTICKS PRODUCT SPECIFICATION TECHNICAL SPECIFICATION All parameters and dimensions shown maybe subject to specification, please refer to Apem for details. Life Cycles : >10 Million Operations : +/-10% of Vcc to +/-50% of Vcc Signal Swing : +/-1% Output at Centre Signal Ripple : 12kV - Correctly Installed RFI Rejection : >40v/m - Correctly Installed Body Material : Glass Reinforced ABS : 5mm Shaft Diameter Gimbal Pivot : Acetal and Hardened Steel : 90 Grams Weight Temperature Range : -20°C to +55°C Max Load to Shaft - Vertical : 75Kg (Momentary) Supply Voltage Output Signal Tolerance Output Impedance Supply Current RFI Rejection Preferred Load Shaft Material Other Materials Gaiter Above Panel Seal Max Load to Shaft - Horizontal Operating Lever Deflection : 4.75V Min to 15V Max : +/-10% of Output : 1.8K +/-1% : Typically 10mA : >20V/m - Bare Joystick : >10K : Stainless Steel : Brass, Acetal, Nylon : Neoprene : IP65 : 25Kg (Momentary) : +/-18° NEAR EQUIVALENT CIRCUIT +Ve Supply Z Axis Output Y Axis Output 0V Supply Centre Tap Reference X Axis Output x2 Push Button Dual Decode CABLE SPECIFICATION Cable information may be subject to specification, please refer to Apem for details. 14/0.12 Red Blue Green Orange Brown - Fourteen strands of 0.12mm diameter tinned annealed copper wire PVC insulated to a nominal OD of 1mm. : 0V : +Vcc Black : X Axis Wiper Yellow : Y Axis Wiper : Centre Tap Reference Purple : Z Axis Wiper : Centre Detect, or Combined Fault & Centre Detect White : Fault Detect Grey : Mirror of Y Axis : Mirror of X Axis Wiper 7/0.127 - Seven strands of 0.127mm diameter tinned copper wire ETFE insulated, to a nominal OD of 0.7mm Orange : Push Button All 9000 Series are supplied with 150mm of twisted cable harness, with tinned ends. Connectors may be fitted upon request. www.apem.com 870045v8 9000 SERIES - CONTACTLESS JOYSTICKS USEFUL DIMENSIONS GENERAL DIMENSIONS GENERAL DIMENSIONS POLARITY Y+ 69.50 X+ X- Y- LEADS EXIT TO THE EAST 35.80 37.50 3.20 35.80 40.00 42.00 DROP IN MOUNTING - PANEL CUT-OUT & MOUNTING INSTALLATION MATERIAL: Nylon MOUNTING CUT-OUT Ø3.20 x 4 Ø41.00 35.80 35.80 The joystick is dropped into the panel cut-out. For panel thickness of
很抱歉,暂时无法提供与“206”相匹配的价格&库存,您可以联系我们找货
