N3030B4
N3030B4
    GEEHY(极海)
    PUSHBUTTONHALFBOOTCLEAR
N3030B4 数据手册
SPECIFICATIONS Material: HEXSEALS: Silicone rubber conforms to A-A-59588, Class lll, GR50 (unless otherwise specified). Mounting Nut: HEXSEALS: Brass, nickel-plated Temperature Range: HEXSEALS: -94 F to +400 F (-70 C to +204 C). Pressure Range: Exceeds 15 psi internal and 1500 psi external. Operational Life: 50,000 actuations (minimum). Shelf Life: Excess of 25 years. Resistant to: Salt spray, sunlight, ozone, weather, fungus,and most acids and lubricating oils. Agency Recognition: UL & ULC Recognized to UL Std. 50 HALF PUSHBUTTON BOOT CUSTOMER'S PANEL A CUSTOMER'S BACKING FASTENER A 0.625 [15.88] HEX CUSTOMER'S PUSHBUTTON SWITCH 0.250 [6.35] HALF PUSHBUTTON BOOT CUSTOMER'S PANEL 0.547 [13.89] PERMISSIBLE RUBBER OVERLAY .005 [0.127] MAX. CUSTOMER'S BACKING FASTENER CUSTOMER'S PUSHBUTTON SWITCH 15/32-32NS-2B G F E REV. MAT'L CHANGED and REDRAWN CAD COMPUTER GENERATED UPDATED DESCRIPTION MAXIMUM AND MINIMUM MEASUREMENTS ARE STATED DIRECTLY ON EACH DIMENSION. MAT'L: Silicone Rubber A-A-59588, GR.60 FINISH: S.GOK 06.15.09 09.23.02 R.C. 08.27.74 DATE S. GOK 06.15.09 B. FLAMCE 05.12.59 J. CELLA 06.15.09 CLEAR TITLE: SWITCH BOOT, PLUNGER (N3030B) APM-HEXSEAL CORPORATION ENG. DWN: CHKD. SCALE 1:1 DWG.NO. N3030B THIS DRAWING COVERS PROPRIETARY ITEM AND IS THE PROPERTY OF THE APM-HEXSEAL CORPORATION. THIS DRAWING IS NOT TO BE COPIED OR USED WITHOUT THE WRITTEN APPROVAL OF AN OFFICER OF THE APM-HEXSEAL CORPARATION.
N3030B4 价格&库存
很抱歉,暂时无法提供与“N3030B4”相匹配的价格&库存,您可以联系我们找货
