Rotary Shaft Seals for Switches & Potentiometers
HEXSEAL® and E-SEEL® rotary shaft seals are molded from a high tear-strength silicone rubber (other materials
available for specific environments) bonded to a built-in mounting nut. Each seal surrounds the rotary shaft and forms a
watertight and dust-tight seal against the shaft and front panel surface.
SPECIFICATIONS
Material ........................HEXSEALS: Silicone rubber conforms to A-A-59588,
Class 3B, Gr. 60 unless otherwise specified.
E-SEELS: Silicone rubber polymer type ASTM D1418
Mounting Nut ..............HEXSEALS: Brass, nickel-plated
E-SEELS: Brass, black-oxide
Temperature Range....HEXSEALS: -94°F to +400°F (-70°C to +204°C)
E-SEELS: -80°F to +400°F (-62°C to +204°C)
Enclosure Protection..NEMA/UL/ULC Types 1, 2, 3, 3S, 3R, 4, 4X, 6P, 12, 13;
IEC IP66/IP68
Pressure Range ..........Exceeds 15 psi internal and 1500 psi external
Operational Life ..........100,000 actuations (minimum)
Shelf Life .....................Excess of 25 years
Resistant to.................Salt spray, sunlight, ozone, weather, fungus, and most
acids and lubricating oils
Military Specs*............Most HEXSEALS meet MIL-DTL-5423. (See listing on page 6)
Agency Recognition...UL & ULC Recognized Component to UL Std. 50
Installation...................Please see installation instructions on page 19
*APM’s policy is to manufacture our HEXSEAL® sealing boots as defined by the requirements of MIL-Spec MILDTL-5423 which we regard as the standard for the switch, circuit breaker and potentiometer industry. These
requirements were formulated based on our original patent.
HOW TO ORDER
For metric sizes, see page 20.
Specify APM boot part number and, if necessary, the appropriate bushing
adaptor part number (please see page 19).
Rotary Shaft Seals – IP66/68 Rated
1⁄ 4-28NF2B
1⁄ 4-32NEF-2B
3⁄ 8-32NEF-2B
3⁄ 8-32NEF-2B
3⁄ 8-32NEF-2B
3⁄ 8-32NEF-2B
15⁄ 32-32NS-2B
1⁄ 2-32NS-2B
5⁄ 8-24NEF-2B
5⁄ 8-24NEF-2B
3⁄ 8-32NEF-2B
A
Shaft Size
inch
mm
.125
3.18
.125
3.18
.125
3.18
.188
4.78
.250
6.35
.250
6.35
.250
6.35
.250
6.35
.375
9.53
.500
12.70
.250
6.35
B
Height
inch
mm
.219
5.56
.219
5.56
.219
5.56
.219
5.56
.219
5.56
.359
9.12
.219
5.56
.219
5.56
.219
5.56
.219
5.56
.219
5.56
C
Flat
inch
.375
.375
.500
.500
.500
.500
.625
.625
.750
.750
.500
Military
Part
Number
M5423/09-03
M5423/09-01
M5423/09-02
M5423/09-04
M5423/09-06
M5423/09-05
mm
9.53
9.53
12.70
12.70
12.70
12.70
15.88
15.88
19.05
19.05
12.70
APM Boot
Part Number
Color*
N9042 x 1⁄ 8
N9040 x 1⁄ 8
N9030 x 1⁄ 8
N9030 x 3⁄ 16
N9030 x 1⁄ 4
N9033 x 1⁄ 4
N9060 x 1⁄ 4
N9063 x 1⁄ 4
N9065 x 3⁄ 8
N9065 x 1⁄ 2
C1332/40
Gray
Gray
Gray
Gray
Gray
Gray
Gray
Gray
Gray
Gray
Black
E-SEEL
Thread Size**
Figure 21
HEXSEAL
FIGURE 21
*Other colors available. Please consult factory. **Metric thread sizes available; consult factory.
RFI/EMI Shielded Rotary Shaft Seals – IP66/68 Rated
Locking Rotary Shaft Seals – IP66/68 Rated
A
B
Shaft Size
Height
Thread Size
inch
mm
inch mm
1⁄ 4-32NS-2B
.125
3.18 .500 12.70
3⁄ 8-32NS-2B
.125
3.18 .531 13.49
3⁄ 8-32NS-2B
.250
6.35 .531 13.49
C
Flat
inch mm
.500 12.70
.625 15.88
.625 15.88
15
E-SEEL
Figure 23
Lock Nut
O.D.
inch
mm
.344
8.74
.469 11.91
.469 11.91
Military
Part
Number
APM Boot
Part Number
NLK9040 x 1⁄ 8
NLK9030 x 1⁄ 8
NLK9030 x 1⁄ 4
DIMENSIONS FOR REFERENCE ONLY.
Current dimensional drawings can be viewed on our website and CAD drawings can also be downloaded.
www.apmhexseal.com
800.498.9034
Color*
Gray
Gray
Gray
RoHS
Compliant
E-SEEL
FIGURE 23
HEXSEAL
Figure 22
A
B
C
Military
APM Boot
Shaft Size
Height
Flat
Part
Thread Size**
Color*
Part Number
Number
inch
mm
inch
mm
inch
mm
1⁄ 4-32NF2B
.125
3.18
.219
5.56
.375
9.53
M5423/09-09
N9040 x 1⁄ 8 RFI
Gray
3⁄ 8-32NEF-2B
.125
3.18
.219
5.56
.500
12.70
M5423/09-07
N9030 x 1⁄ 8 RFI
Gray
3⁄ 8-32NEF-2B
.250
6.35
.219
5.56
.500
12.70
M5423/09-08
N9030 x 1⁄ 4 RFI
Gray
3⁄ 8-32NEF-2B
.250
6.35
.359
9.12
.500
12.70
M5423/09-14
N9033 x 1⁄ 4 RFI
Gray
15⁄ 32-32NS-2B
.250
6.35
.219
5.56
.625
15.88
M5423/09-10
N9060 x 1⁄ 4 RFI
Gray
5⁄ 8-24NEF-2B
.375
9.53
.219
5.56
.750
19.05
M5423/09-11†
N9065 x 3⁄ 8 RFI
Gray
1⁄ 2-32NS-2B
.250
6.35
.219
5.56
.625
15.88
M5423/09-12
N9063 x 1⁄ 4 RFI
Gray
1⁄ 4-28NF-2B
.125
3.18
.219
5.56
.375
9.53
N9042 x 1⁄ 8 RFI
Gray
3⁄ 8-32NEF-2B
.125
3.18
.531
13.49
.625
15.88
NLK9030 x 1⁄ 8 RFI Gray
3⁄ 8-32NEF-2B
.250
6.35
.531
13.49
.625
15.88
NLK9030 x 1⁄ 4 RFI Gray
*Other colors available. Please consult factory. †Inactive for new designs. **Metric thread sizes available; consult factory.
All Standard RFI/EMI boots feature knitted Monel wire shields.
HEXSEAL
FIGURE 22
METRIC Sizes for Toggle, Pushbutton and Rotary
Switches and Circuit Breakers
Operator
Chamber
E-SEEL® Silicone
Rubber Boot
SPECIFICATIONS
Material ........................Silicone rubber polymer type ASTM D 1418
Mounting Nut ..............Brass, black-oxide. *Brass, nickel-plated.
Temperature Range....-80°F to +400°F (-62°C to +204°C)
Enclosure Protection..NEMA/UL/ULC Types 1, 2, 3, 3S, 3R, 4, 4X, 6P, 12, 13; IEC IP66/IP68
RoHS
Compliant
and most acids and lubricating oils
C
US
UL Recognized Component
Single Piece
Design
Molded-in
Mounting
Nut
Panel Sealing
Rib (eliminates
need for O-ring)
Panel
Switch Housing
Additional metric sizes available (consult factory)
Full Toggle (with Constant I.D.) Switch Boots
(covers all external portions of switch & seals switch mounting hole)
TOGGLE SWITCH BOOTS
Fig. A
Thread
Size
Throat Size1 (“A”)
Max Toggle Height2
Max Boot Height (“B”)
mm
in.
mm
in.
mm
in.
Figure A
Flat (“C”)
mm
in.
Color
APM Cat. No.
M6 X 0.75
2.9
0.116
10.8
0.43
14.3
0.562
9.0
0.352
Black
1131/25*
M12 X 0.75
5.3
0.21
16.2
0.64
21.6
0.85
15.8
0.625
Black
C1131/41
M12 X 0.75
5.5
0.219
22.8
0.90
27.7
1.1
15.8
0.625
Black
1131/26-M12-.75
M12 X 1
6.5
0.256
16.7
0.66
21.4
0.844
15.8
0.625
Black
1131/31-M12
M12 X 1
5.9
0.234
16.9
0.66
21.8
0.859
15.8
0.625
Black
1131/40
M12 X 1
5.5
0.219
22.8
0.90
27.7
1.1
15.8
0.625
Black
1131/26-M12-.10
1
2
IP66/IP68/NEMA 6P Enclosure Protection
Throat size is the maximum diameter of the switch toggle/handle (Dimension “A”).
Max toggle height is the maximum distance from the end of the switch mounting stem to the end of the switch toggle.
Half Toggle Switch Boots
(Seals switch mounting stem & hole; toggle actuator protrudes)
Fig. B
Thread
Size
Throat Size
(“A”)
mm
Toggle Diameter
Accomodated
Max Boot Height
(“B”)
in.
mm
in.
mm
in.
Figure B
Flat
(“C”)
Color
mm
in.
APM Cat. No.
M5 X 0.5
1.1
0.42
1.57-4.57
0.062-0.18
5.7
0.225/0.25
7.9
0.313
Black
1132/17-M5-5
M12 X 1
2.36
0.093
2.92-6.09
0.115-0.24
11.1
0.437
15.9
0.625
Black
1132/33-M12-1
PUSHBUTTON SWITCHES & CIRCUIT BREAKERS/PROTECTORS
Fig. C
Fig. D
Thread
Size1
A
1
Max Plunger
Height
Dimension “B”
Max Plunger
Diameter (“C”)
in.
mm
in.
mm
8.4
0.33
16.3
0.64
8.1
11.9
0.469
18.3
0.72
10.72
0.469
15.9
0.625
10.72
0.422
mm
in.
M10 X 1
15.47
0.62
M11 X 1
15.47
0.62
M12 X 1
18.64
0.47
11.9
C
Aluminum
insert
Max Boot Height
(“A”)
mm
Figures C & D
Color1
APM Cat. No.
Fig.
0.32
Black
C1221/21
D
0.422
Clear
C1221/27
D
Black
NC3030H-M12-1
C
in.
“Clear” allows viewing of breaker amp rating and trip state; please enquire for other available colors.
B
ROTARY SHAFT SEALS
Seal the shaft and mounting hole of standard rotary switches/potentiometers
that use a threaded stem and nut mounting.
Fig. E
Thread
Size
Shaft Size1 (“A”)
mm
in.
Height (“B”)
mm
Flat (“C”)
in.
mm
in.
Figure E
Color2
APM Cat. No.
M7 X 0.75
5.0
0.2
5.5
0.2
12.7
0.500
Gray
1332/39-2*
M9 X 0.75
6.35
0.250
5.56
0.219
12.7
0.500
Gray
C1332/41*
M10 X 1
6.0
0.236
5.9
0.236
12.7
0.500
Gray
1332/45*
Switch/potentiometer shaft must have a smooth, round cross-section where it meets the sealing edge of the shaft seal device.
2 Please enquire for other available colors.
1
www.apmhexseal.com
很抱歉,暂时无法提供与“N9040X1/8RFI2”相匹配的价格&库存,您可以联系我们找货
