RS8032XM
RS8032XM
    RUNIC(润石)
    MSOP-8
    RS8032XM
RS8032XM 数据手册
RS8031, RS8032, RS8034 15kHz, 670nA, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION • • GAIN BANDWIDTH:15kHz RAIL-TO-RAIL INPUT AND OUTPUT 0.5mV Typical Vos • • INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V SUPPLY RANGE: +1.4V to +5.5V • SPECIFIED UP TO +125°C • Micro SIZE The RS8031, RS8032, RS8034, families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (15kHz) and slew rate of 7.5V/ms. The op-amps are unity gain stable and feature an ultra-low input bias current. PACKAGES: SOT23-5 The devices are ideal for sensor interfaces, active filters and portable applications. The RS8031, RS8032, RS8034 families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 1.4V to 5.5V. APPLICATIONS • • SENSORS PHOTODIODE AMPLIFICATION • WEARABLE PRODUCTS • TEMPERATURE MEASUREMENT • BATTERY POWERED SYSTEM PIN CONFIGURATIONS 5 1 V+ + IN 5 1 V+ + V+IN 2 3 V- + - 4 -IN - IN SOT23-5 2 - 3 4 OUT NC 1 -IN 2 +IN 3 V- 4 8 NC 7 V+ + OUT RS8031 RS8031B - RS8031 6 OUT 5 NC SOT23-5 SOIC-8(SOP8),MSOP-8 RS8034 RS8032 OUT A 1 -IN A 2 +IN A V- 3 4 + A 8 V+ 7 OUTB 6 B+ 5 -IN B +IN B SOIC-8(SOP8),MSOP-8 OUT A 1 -IN A 2 14 OUT D 13 -IN D +IN A V+ 3 12 +IN D 4 11 V- +IN B 5 10 +IN C -IN B 6 9 -IN C OUT B 7 8 OUT C A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14 Note: NC indicates no internal connection REV B.3 1 www.run-ic.com RS8031, RS8032, RS8034 ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-...............................................7.0V Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V Current (2)…………………....…..... ±10mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….………… −40°C to +125°C Junction Temperature................................................150°C Package Thermal Resistance @ TA = +25°C SOT23-5, SOT23-6………………….………………200°C/W MSOP-10, SOIC-8 …………………….…………... 150°C/W SOIC-14, TSSOP-14………….……….……………100°C/W Lead Temperature (Soldering, 10s) ……………........260°C ESD Susceptibility HBM …......................................................................5000V MM ……………………….........………………...……….400V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION 2 www.run-ic.com RS8031, RS8032, RS8034 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5.0V, RL = 1MΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS RS8031,RS8032,RS8034 MIN TYP MAX UINTS 5.5 V 670 1500 nA POWER SUPPLY Vs Operating Voltage Range IQ Quiescent Current/Amplifier PSRR 1.4 Power-Supply Rejection Ratio Vs=2.5V to 5.5V, Vcm=(V-)+0.5V Input Offset Voltage Vcm=Vs/2 0.5 Input Offset Voltage Drift Vcm=Vs/2, -40°C ≤ TA ≤125°C 2.3 62 70 dB INPUT Vos ΔVos/ΔT 3 mV µV/°C IB Input Bias Current 1 10 pA Ios Input Offset Current Common-Mode Voltage Range 1 10 pA 5.6 V Vcm CMRR Vs= 5.5V -0.1 Vs= 5.5V, Vcm=-0.1V to 4V 73 90 dB Vs= 5.5V, Vcm=-0.1V to 5.6V 60 83 dB Vs=1.4V, RL=50KΩ, Vo=Vs-0.1V 85 102 dB Vs=5.0V, RL=50kΩ, Vo=Vs-0.1V 92 106 dB 5 mV 11 mA Slew Rate 7.5 V/ms Gain-Bandwidth Product 15 kHz Phase Margin 60 ° Common-Mode Rejection Ratio OUTPUT AOL Open-Loop Voltage Gain Output Swing From Rail Iout RL=50KΩ Output Short-Circuit Current FREQUENCY RESPONSE SR GBP PM NOISE enp-p en Input Voltage Noise f = 0.1 Hz to 10 Hz 2.4 μVpp Input Voltage Noise Density f = 1 kHz 160 nV/√Hz 3 www.run-ic.com RS8031, RS8032, RS8034 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 1MΩ connected to VS/2, CL=60pF VCM = VS/2, unless otherwise noted. SMALL−SIGNAL STEP RESPONSE SMALL−SIGNAL STEP RESPONSE CL=60PF 50mV/div 50mV/div CL=60PF 200us/div 200us/div LARGE−SIGNAL STEP RESPONSE LARGE−SIGNAL STEP RESPONSE CL=60PF 1V/div 1V/div CL=60PF 200us/div 200us/div SOURCE CURRENT vs TEMPERATURE 16 22 14 20 Source Current(mA) Sink Current(mA) SINK CURRENT vs TEMPERATURE 12 10 8 6 18 16 14 12 10 -40 -20 0 20 40 60 80 100 120 140 Temperature(C) -40 -20 4 0 20 40 60 80 100 120 140 Temperature(C) www.run-ic.com RS8031, RS8032, RS8034 PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 5 www.run-ic.com RS8031, RS8032, RS8034 MSOP-8 b e E E1 4.8 1.02 D 0.65 0.41 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.250 0.380 0.010 0.015 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.650(BSC) 0.026(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 6 www.run-ic.com RS8031, RS8032, RS8034 TSSOP-14 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 7 1° 7° www.run-ic.com RS8031, RS8032, RS8034 SOIC-8(SOP8) b e 5.2 E1 E 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 8 www.run-ic.com RS8031, RS8032, RS8034 SOIC-14(SOP14) e b 5.2 1.27 E E1 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 c A θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 9 www.run-ic.com
RS8032XM 价格&库存
很抱歉,暂时无法提供与“RS8032XM”相匹配的价格&库存,您可以联系我们找货
