HT1621BRQZ
HT1621BRQZ
    HTCSEMI(海天芯)
    LQFP48
    HT1621BRQZ
HT1621BRQZ 数据手册
HT1621B RAM Mapping 32x4 LCD Controller for I/O MCU Features Operating voltage: 2.4V ~ 5.2V Built-in 256kHz RC oscillator External 32.768kHz crystal or 256 kHz frequency source input Selection of 1/2 or 1/3 bias, and selection of 1/2 or 1/3 or 1/4 duty LCD applications Internal time base frequency sources Two selectable buzzer frequencies (2kHz/4kHz) Power down command reduces power consumption Built-in time base generator and a WDT Time base or WDT overflow output 8 kinds of time base/WDT clock sources 32x4 LCD driver Built-in 32x4 bit display RAM 3-wire serial interface Internal LCD driving frequency source Software configuration feature Data mode and command mode instructions R/W address auto increment Three data accessing modes VLCD pin for adjusting LCD operating voltage HT1621B: 48-pin SSOP/LQFP packages HT1621D: 28-pin SKDIP package HT1621G: Gold bumped chip General Description The HT1621 is a 128 pattern (32x4), memory mapping, and multi-function LCD driver. The S/W configuration feature of the HT1621 makes it suitable for multiple LCD applications including LCD modules and display sub-systems. Only three or four lines are required for the interface between the host controller and the HT1621. The HT1621 contains a power down command to reduce power consumption. Selection Table HT162X HT1620 HT1621 HT1622 HT16220 HT1623 HT1625 HT1626 COM 4 4 8 8 8 8 16 SEG 32 32 32 32 48 64 48 Built-in Osc. — √ √ — √ √ √ Crystal Osc. √ √ — √ √ √ √ Rev. 00 HT1621B Block Diagram Note: :chip selection BZ, : Tone outputs , ,DATA: Serial interface COM0~COM3, SEG0 ~SEG31:LCD outputs : Time base or WDT overflow output Pin Assignment HT1621B HT1621D -48 SSOP -A -28 SKDIP -A Rev. 00 HT1621B Absolute Maximum Ratings Supply Voltage…………………VSS –0.3V to VSS +5.5V Storage Temperature…………………………-50℃ to 125℃ Input Voltage…………………VSS –0.3V to VDD +0.3V Operating Temperature………………………-40℃ to 85℃ Note: These are stress ratings only. Stresses exceeding the range specified under “ Absolute Maximum Ratings” may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. D.C. Characteristics Ta=25℃ Symbol Parameter VDD IDD1 Operating Voltage Operating Current IDD2 Operating Current IDD3 Operating Current ISTB Standby Current VIL Input Low Voltage VIH Input High Voltage IOL1 DATA, BZ, IOH1 DATA, BZ, IOL2 LCD Common Sink Current IOH2 LCD Common Source Current IOL3 LCD Segment Sink Current IOH3 LCD Segment Source Current RPH Pull-high Resistor , Test Conditions Conditions VDD — — 3V No load/LCD ON On-chip RC oscillator 5V 3V No load/LCD ON Crystal oscillator 5V 3V No load/LCD ON External clock source 5V 3V No load, Power down mode 5V 3V , , DATA, 5V 3V , , DATA, 5V 3V VOL=0.3V 5V VOL=0.5V 3V VOH=2.7V 5V VOH=4.5V 3V VOL=0.3V 5V VOL=0.5V 3V VOH=2.7V 5V VOH=4.5V 3V VOL=0.3V 5V VOL=0.5V 3V VOH=2.7V 5V VOH=4.5V 3V , , DATA, 5V Min. 2.4 — — — — — — — — 0 0 2.4 4.0 0.5 1.3 -0.4 -0.9 80 150 -80 -120 60 120 -40 -70 60 30 Typ. — 150 300 60 120 100 200 0.1 0.3 — — — — 1.2 2.6 -0.8 -1.8 150 250 -120 -200 120 200 -70 -100 120 60 Max. 5.2 300 600 120 240 200 400 5 10 0.6 1.0 3.0 5.0 — — — — — — — — — — — — 200 100 Rev. 00 Unit V µA µA µA µA µA µA µA µA V V V V mA mA mA mA µA µA µA µA µA µA µA µA kΩ kΩ HT1621B Ta=25℃ A.C. Characteristics Symbol Parameter fSYS1 fSYS2 fSYS3 System clock System clock System clock fLCD LCD Clock tCOM fCLK1 LCD Common Period Serial Data Clock ( Serial Data Clock ( fTONE tCS Tone Frequency Serial Interface Reset Pulse Width (Figure 3) tCLK , Input Pulse Width (Figure 1) tau Setup Time for DATA to Max. Unit — — — — — — — 150 300 75 150 — kHz kHz kHz Hz Hz Hz s kHz kHz kHz kHz kHz — 250 — ns Write mode Read mode Write mode Read mode 3.34 6.67 1.67 3.34 — — — — 125 — 125 — — — — 120 — ns , — — — 120 — ns , — — — 120 — ns , — — — 100 — ns , — — — 100 — ns Duty cycle 50% Duty cycle 50% On-chip RC oscillator — 3V 5V Rise/Fall Time Serial Data Clock Width (Figure 1) Typ. 256 32.768 256 fSYS1/1024 fSYS2/128 fSYS3/1024 n/ fLCD — — — — 2.0 or 4.0 pin) tr, tf Min. — — — — — — — 4 4 — — — pin) fCLK2 VDD — — — — — — — 3V 5V 3V 5V — Test Conditions Conditions On-chip RC oscillator Crystal oscillator External clock source On-chip RC oscillator Crystal oscillator External clock source n: Number of COM µs µs Clock Width (Figure 2) th Hold Time for DATA to Clock Width (Figure 2) tau1 Setup Time for to Clock Width (Figure 3) th1 Hold Time for to Clock Width (Figure 2) Figure 1 Figure 2 Figure 3 Rev. 00 HT1621B Functional Description Display Memory –RAM The static display memory (RAM) is organized into 32x4 bits and stores the displayed data. The contents of the RAM are directly mapped to the contents of the LCD driver. Data in the RAM can be accessed by the READ, WRITE, and READ-MODIFY- WRITE commands. The following is a mapping from the RAM to the LCD pattern: command, using the SYS DIS command reduces power consumption, serving as a system power down command. But if the external clock source is chosen as the system clock, using the SYS DIS command can neither turn the oscillator off nor carry out the power down mode. The crystal oscillator option can be applied to connect an external frequency source of 32kHz to the OSCI pin. In this case, the system fails to enter the power down mode, similar to the case in the external 256kHz clock source operation. At the initial system power on, the HT1621 is at the SYS DIS state. Time Base and Watchdog Timer (WDT) The time base generator is comprised by an 8-stage count-up ripple counter and is designed to generate an accurate time base. The watch dog timer (WDT), on the other hand, is composed of an 8-stage time base generator along with a 2-stage count-up counter, and is designed to break the host controller or other subsystems from abnormal states such as unknown or unwanted jump, execution errors, etc. The WDT time-out will result in the setting of an internal WDT time-out flag. The outputs of the time base generator and of the WDT time-out flag can be connected to output by a command option. There are totally eight the frequency sources available for the time base generator and the WDT clock. The frequency is calculated by the following equation. RAM Mapping System Oscillator The HT1621 system clock is used to generate the time base/Watchdog Timer (WDT) clock frequency, LCD driving clock, and tone frequency. The source of the clock may be from an on-chip RC oscillator (256kHz), a crystal oscillator (32.768kHZ), or an external 256kHz clock by the S/W setting. The configuration of the system oscillator is as shown. After the SYS DIS command is executed, the system clock will stop and the LCD bias generator will turn off. That command is ,however, available only for the on-chip RC oscillator or for the crystal oscillator. Once the system clock stops, the LCD display will become blank, and the time base/WDT lose its function as well. The LCD OFF command is used to turn the LCD bias generator off. After the LCD bias generator switches off by issuing the LCD OFF Where the value of n ranges from 0 to 7 by command options. The 32kHz in the above equation indicates that the source of the system frequency is derived from a crystal oscillator of 32.768kHz, an on-chip oscillator (256kHz), or an external frequency of 256KHz. If an on-chip oscillator (256kHz) or an external 256kHz frequency is chosen as the source of the system frequency, the frequency source is by default prescaled to 32kHz by a 3-stage prescaler. Employing both the time base generator and the WDT related commands, one should be careful since the time base generator and WDT share the same 8-stage counter. For example, invoking the WDT DIS command disables the time base generator whereas executing the WDT EN command not only enables the time base generator but activates System Oscillator Configuration Rev. 00 HT1621B Timer and WDT Configurations The WDT time-out flag output (connect the WDT time-out flag to the pin). After the TIMER EN command is transferred, the WDT is disconnected from the pin, and the output of the time base generator is connected to the pin. The WDT can be cleared by executing the CLR WDT command, and the contents of the time base generator is cleared by executing the CLR WDT or the CLR TIMER command. The CLR WDT or the CLR TIMER command should be executed prior to the WDT EN or the TIMER EN EN command command respectively. Before executing the the CLR WDT or CLR TIMER command should be executed first. The CLR TIMER command has to be executed before switching from the WDT mode to the time base mode. Once the WDT time-out pin will stay at a logic low level until the CLR WDT occurs, the DIS command is issued. After the output is or the disabled the pin will remain at the floating state. The output can be enabled or disabled by executing the EN or the DIS command, respectively. The EN makes the output of the time base generator or of the WDT time-out flag appear on pin. The configuration of the time base generator along the with the WDT are as shown. In the case of on-chip RC oscillator or crystal oscillator, the power down mode can reduce power consumption since the oscillator can be turned on or off by the corresponding system commands. At the power down mode the time base/WDT loses all its functions. On the other hand if an external clock is selected as the source of system frequency the SYS DIS command turns out invalid and the power down mode fails to be carried out. That is, after the external clock source is selected, the HT1621 will continue working until system power fails or the external clock source is removed. After the will be disabled. system power on, the Name Tone Output A simple tone generator is implemented in the HT1621.The tone generator can output a pair of differential driving signals on the BZ , which are used to generate a single tone. By executing the and TONE4K and TONE2K commands there are two tone frequency outputs selectable. The TONE4K and TONE2K commands set the tone frequency to 4kHz and 2kHz, respectively. The tone output can be turned on or off by invoking the TONE ON or the TONE OFF command. The tone outputs , namely BZ and , are a pair of differential driving outputs used to drive a piezo buzzer. Once the system is disabled or the tone output is inhibited, the BZ and the outputs will remain at low level. LCD Driver The HT1621 is a 128 (32x4) pattern LCD driver. It can be configured as 1/2 or 1/3 bias and 2 or 3 or 4 commons of LCD driver by the S/W configuration. This feature makes the HT1621 suitable for multiply LCD applications. The LCD driving clock is derived from the system clock. The value of the driving clock is always 256Hz even when it is at a 32.768kHz crystal oscillator frequency, an on-chip RC oscillator frequency, or an external frequency. The LCD corresponding commands are summarized in the table. The bold form of 100, namely 100, indicates the command mode ID. If successive commands have been issued, the command mode ID except for the first command, will be omitted. The LCD OFF command turns the LCD display off by disabling the LCD bias generator. The LCD ON command, on the other hand, turns the LCD display on by enabling the LCD bias generator. The BIAS and COM are the LCD panel related commands. Using the LCD related commands, the HT1621 can be compatible with most types of LCD panels. Command Code Function LCD OFF 10000000010X Turn off LCD outputs LCD ON 10000000011X Turn on LCD outputs BIAS & COM 1000010abxcx C=0:1/2 bias option C=1: 1/3 bias option ab=00:2 commons option ab=01:3 commons option ab=10:4 commons option Rev. 00 HT1621B Command Format The HT1621 can be configured by the S/W setting . There are two mode commands to configure the HT1621 resources and to transfer the LCD display data. The configuration mode of the HT1621 is called command mode, and its command mode ID is 100. The command mode consists of a system configuration command, a system frequency selection command, a LCD configuration command, a tone frequency selection command, a timer/WDT setting command, and an operating command. The data mode, on the other hand, includes READ, WRITE, and READ-MODIFY-WRITE operations. The following are the data mode IDS and the command mode ID; Operation Mode ID Read Data 110 Write Data 101 Read-Modify-write Data 101 Command Command 100 The mode command should be issued before the data or command is transferred. If successive commands have been issued. The command mode ID, namely 100, can be omitted. While the system Before issuing a mode command or mode switching, a high level pulse is required to initialize the serial interface of the HT1621. The DATA line is the serial data input/output line. Data to be read or written or commands to be written have to be passed through the DATA line. The line is the READ clock input Data in the RAM signal, and the clocked are clocked out on the falling edge of the out data will then appear on the DATA line. It is recommended that the host controller read in correct data during the interval between the rising edge and the next falling edge of the signal. The line is the WRITE clock input. The data, address, and command on the DATA line are all clocked into the HT1621 on the rising edge of the signal. There is an optional line to be used as an interface between the host controller and the HT1621. The pin can be selected as a timer output or a WDT overflow flag output by the S/W setting. The host controller can perform the time base or the WDT function by being connected with the pin of the HT1621. Crystal Selection A 32768Hz crystal can be directly connected to the HT1621 via OSCI and OSCO. In order to obtain the correct frequency, two additional load capacities (C1, C2) are needed. The value of the capacity depends on how accurate the crystal is. We suggest that you can follow the table. Which suggests the value of capacities. The table illustrations the suggestion value of capacities (C1, C2) is operating in the non-successive command or the non-successive address data mode, the pin should be set to “1” and the previous operation mode will be reset also. Once the pin returns to “0” a new operation mode ID should be issued first. Interfacing Only four lines are required to interface with the HT1621, the line is used to initialize the serial interface circuit and to terminate the communication between the host controller and the HT1621. If pin is set to 1, the data and command issued between the the host controller and the HT1621 are first disabled and then initialized. Crystal Error Capacity Value ±10ppm 0~10p 10~20ppm 10~20p Timing Diagrams READ Mode (Command Code:110) Rev. 00 HT1621B READ Mode (Successive Address Reading) WRITE Mode (Command Code: 101) Write Mode (Successive Address Writing) Read-Modify-Write Mode (Command Code: 101) Rev. 00 HT1621B Read-Modify-Write Mode (Successive Address Accessing) Command Mode (Command Code : 100) Mode (Data and Command Mode) Note: It is recommended that the host controller should read in the data from the DATA line between the rising edge of the line and the falling edge of the next line. 9 Rev. 00 HT1621B Application Circuits Host Controller with an HT1621 Display System Note: The connection of and pin can be selected depending on the requirement of the MCU. The voltage applied to VLCD pin must be lower than VDD. Adjust VR to fit LCD display, at VDD = 5V, VLCD = 4V, VR=15kΩ ± 20%. Adjust R (external pull-high resistance) to fit user’s time base clock. In order to obtain the correct frequency, two additional load capacities (C1,C2) are needed. The value of the capacity depends on how accurate the crystal is. We suggest that you can follow the table, which suggests the value of capacities. The table illustrations the suggestion value of capacities (C1,C2) Crystal Error Capacity Value ±10ppm 0~10p 10~20ppm 10~20p Command Summary Name READ WRITE READ-MODIFYWRITE SYS DIS ID 110 101 101 Command Code A5A4A3A2A1A0D0D1D2D3 A5A4A3A2A1A0D0D1D2D3 A5A4A3A2A1A0D0D1D2D3 D/C D D D Function Read data from the RAM Write data to the RAM READ and WRITE to the RAM Def. 100 0000-0000-X C SYS EN LCD OFF LCD ON TIMER DIS WDT DIS TIMER EN WDT EN 100 100 100 100 100 100 100 0000-0001-X 0000-0010-X 0000-0011-X 0000-0100-X 0000-0101-X 0000-0110-X 0000-0111-X C C C C C C C Turn off both system oscillator and LCD Bias generator Turn on system oscillator Turn off LCD bias generator Turn on LCD bias generator Disable time base output Disable WDT time-out flag output Enable time base output Enable WDT time-out flag output Yes Yes Rev. 00 HT1621B Name ID Command Code D/C Function Def. TONE OFF 100 0000-1000-X C Turn off tone outputs Yes TONE ON 100 0000-1001-X C Turn on tone outputs CLR TIMER 100 0000-11XX-X C Clear the contents of time base generator CLR WDT 100 0000-111X-X C Clear the contents of WDT stage XTAL 32K 100 0001-01XX-X C System clock source, crystal oscillator RC 256K 100 0001-10XX-X C System clock source, on-chip RC oscillator EXT 256K 100 0001-11XX-X C System clock source, external clock source C BIAS 1/2 100 0010-abX0-X BIAS 1/3 100 0010-abX1-X C TONE 4K 100 010X-XXXX-X C LCD 1/2 bias option ab=00:2 commons option ab=01:3 commons option ab=10:4 commons option LCD 1/3 bias option ab=00:2 commons option ab=01:3 commons option ab=10:4 commons option Tone frequency, 4kHz TONE 2K 100 011X-XXXX-X C Tone frequency, 2kHz DIS 100 100X-0XXX-X C Disable output EN 100 010X-1XXX-X C Enable output F1 100 101X-X000-X C F2 100 101X-X001-X C F4 100 101X-X010-X C F8 100 101X-X011-X C F16 100 101X-X100-X C F32 100 101X-X101-X C F64 100 101X-X110-X C F128 100 101X-X111-X C TEST 100 1110-0000-X C Time base/WDT clock output: 1Hz The WDT time-out flag after: 4s Time base/WDT clock output: 2Hz The WDT time-out flag after: 2s Time base/WDT clock output: 4Hz The WDT time-out flag after: 1s Time base/WDT clock output: 8Hz The WDT time-out flag after: 1/2s Time base/WDT clock output: 16Hz The WDT time-out flag after: 1/4s Time base/WDT clock output: 32Hz The WDT time-out flag after: 1/8s Time base/WDT clock output: 64Hz The WDT time-out flag after: 1/16s Time base/WDT clock output: 128Hz The WDT time-out flag after: 1/32s Test mode, user don’t use. NORMAL 100 1110-0011-X C Normal mode Yes Yes Yes Yes Note: x: Don’t care A5~A0:RAM addresses D3~D0: RAM data D/C: Data/command mode Def.: Power on reset default All the bold forms, namely 110,101, and 100, are mode commands, of these, 100 indicates the command mode ID. If successive commands have been issued, the command mode ID except for the first command will be omitted. The source of the tone frequency and of the time base/WDT clock frequency can be derived from an on-chip 256kHz RC oscillator, a 32.768kHz crystal oscillator, or an external 256kHz clock. Calculation of the frequency is based on the system frequency sources as stated above. It is recommended that the host controller should initialize the HT1621 after power on reset, for power on reset may fail, which in turn leads to the malfunctioning of the HT1621. Rev. 00 HT1621B Package Information 48-pin SSOP (300mil) Outline Dimensions Dimensions in mil Symbol Min. Nom. Max. A 395 — 420 B 291 — 299 C 8 — 12 C’ 613 — 637 D 85 — 99 E — 25 — F 4 — 10 G 25 — 35 H 4 — 12 α 0˚ — 8˚ Rev. 00 HT1621B 48-pin LQFP (7x7) Outline Dimensions Dimensions in mil Symbol Min. Nom. Max. A 8.90 — 9.10 B 6.90 — 7.10 C 8.90 — 9.10 D 6.90 — 7.10 E — 0.50 — F — 0.20 — G 1.35 — 1.45 H — — 1.60 I — 0.10 — J 0.45 — 0.75 K 0.10 — 0.20 α 0˚ — 7˚ Rev. 00 HT1621B 28-pin SKDIP (300mil) Outline Dimensions Dimensions in mil Symbol Min. Nom. Max. A 1375 — 1395 B 278 — 298 C 125 — 135 D 125 — 145 E 16 — 20 F 50 — 70 G — 100 — H 295 — 315 I 330 — 375 α 0˚ — 15˚ Rev. 00
HT1621BRQZ 价格&库存
很抱歉,暂时无法提供与“HT1621BRQZ”相匹配的价格&库存,您可以联系我们找货
HT1621BRQZ
  • 1+3.24000
  • 10+2.88360
  • 30+2.71080
  • 100+2.53800
  • 500+1.93320
  • 1000+1.87920
