VRD2833PTX
VRD2833PTX
    ANASEM(安纳森)
    SOT-23-6
    VRD2833PTX
VRD2833PTX 数据手册
AnaSem 安纳森 Analog Semiconductor IC VRD Series High speed, Low dropout, ±1% High output accuracy CMOS Voltage Regulator with Dual output (IMPORTANT: Please check the last page for Genuine Product Labeling) Website: Tel: Email: Rev. E13-01 www.anasemi.com +852-3590-8442 sales@anasemi.com AnaSem .......... Future of the analog world Rev. E13-01 Products Data Sheet AnaSem Analog Semiconductor IC High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series GENERAL DESCRIPTIONS The VRD series are dual positive voltage regulators with high speed, low voltage dropout and high accuracy output achieved by low current consumption. Because each regulator is completely separated, the crosstalk between each regulator can be reduced. The output voltage is guaranteed within ±1% within the given temperature range by Vref controlling the temperature characteristic. It corresponds to the low ESR capacitor as an output stabilization capacitor. The charged ESR capacitor can be discharged with an internal switch by making the CE=VSS, as a result the VOUT quickly returns to the VSS level. To make the current capacity of the output transistor not exceeded, the over-current protection circuit is built in. HALOGEN RoHS COMPLIANCE FEATURES Output voltage range ······································································· 0.8V~5.0V (selectable with a step of 0.05V) Operating voltage range ·································································· 1.6V~6.0V High accuracy output voltage ··························································· ±1% (Vout=1.95V~ 5.0V) / ±20mV (Vout=0.8V~1.9V) Maximum output current ·································································· 250mA / Channel Dropout voltage ················································································ Typ.90mV (output=3.0V, IOUT=100mA) Low current consumption ·································································· Typ. 25µA / Channel High ripple rejection ························································································· Typ. 75dB at 1KHz Low ESR capacitor ························································································· 1.0 µF ceramic capacitor Operating temperature range ·································································· –40°C ~ +85°C Built-in over-current protector ································································ Limit current : 300mA CL high-speed auto-discharge Built-in On/Off circuit Small package ························································································· SOT-26 (2.9×2.8×1.1mm), LLP-6 (1.8×2.0×0.6mm) APPLICATIONS Battery powered devices Cellular phone Digital / Video cameras Portable games Handheld instruments AnaSem 1 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 PRODUCTS NUMBERING GUIDE VRD Discharge function X : Auto discharge Package form T : SOT-26 L : LLP-6 Function specification L/M/N/P * Refer to the following selection table. Output voltage Ch-2 08 ~ 50 : Selectable with a step of 0.05V in the range of 0.8V ~ 5.0V e.g.) 2J : 2.85V, 33 : 3.30V * Refer to the following selection table. Output voltage Ch-1 Function specification selection table Symbol L M N P VR1 ±20mv ±20mv ±1% ±1% VR2 ±20mv ±1% ±20mv ±1% Function Specification VOUT1=0.80V~1.9V / VOUT2=0.80V~1.9V VOUT1=0.80V~1.9V / VOUT2=1.95V~5.0V VOUT1=1.95V~5.0V / VOUT2=0.80V~1.9V VOUT1=1.95V~5.0V / VOUT2=1.95V~5.0V Output voltage selection table Symbol Voltage 08 0J 09 0K 10 0.80 0.85 0.90 0.95 1.00 Symbol 1A 11 1B 12 1C 13 1D 14 1E 15 1F 16 1G 17 1H 18 1J 19 1K 20 Voltage 1.05 1.10 1.15 1.20 1.25 1.30 1.35 1.40 1.45 1.50 1.55 1.60 1.65 1.70 1.75 1.80 1.85 1.90 1.95 2.00 Symbol 2A 21 2B 22 2C 23 2D 24 2E 25 2F 26 2G 27 2H 28 2J 29 2K 30 Voltage 2.05 2.10 2.15 2.20 2.25 2.30 2.35 2.40 2.45 2.50 2.55 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 3.00 Symbol 3A 31 3B 32 3C 33 3D 34 3E 35 3F 36 3G 37 3H 38 3J 39 3K 40 Voltage 3.05 3.10 3.15 3.20 3.25 3.30 3.35 3.40 3.45 3.50 3.55 3.60 3.65 3.70 3.75 3.80 3.85 3.90 3.95 4.00 Symbol 4A 41 4B 42 4C 43 4D 44 4E 45 4F 46 4G 47 4H 48 4J 49 4K 50 Voltage 4.05 4.10 4.15 4.20 4.25 4.30 4.35 4.40 4.45 4.50 4.55 4.60 4.65 4.70 4.75 4.80 4.85 4.90 4.95 5.00 AnaSem 2 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 PIN CONFIGURATION / MARKING SPECIFICATION (SOT-26) - 1 Vout1 Vss Vout2 6 5 4 A B C D E F G G G G 1 2 3 EN1 Vin EN2 (Top view) Pin Configuration No. Symbol 1 2 3 4 5 6 EN1 VIN EN2 VOUT2 VSS VOUT1 Marking Specification Code Mark A BC DE F G D 08~50 08~50 X Internal rule Descriptions 1-Channel enable Voltage input 2-Channel enable 2-Channel output Power ground 1-Channel output Contents Products series name 1-Ch output voltage 2-Ch output voltage Discharge function Lot number PIN CONFIGURATION / MARKING SPECIFICATION (SOT-26) - 2 Vout1 Vss Vout2 6 5 4 A B C D E F F F F 1 2 3 EN1 Vin EN2 (Top view) Pin Configuration No. Symbol 1 2 3 4 5 6 EN1 VIN EN2 VOUT2 VSS VOUT1 Marking Specification Code Mark A BC DE F D 08~50 08~50 Internal rule Descriptions 1-Channel enable Voltage input 2-Channel enable 2-Channel output Power ground 1-Channel output Contents Products series name 1-Ch output voltage 2-Ch output voltage Lot number AnaSem 3 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 PIN CONFIGURATION / MARKING SPECIFICATION (LLP-6) Vout1 Vss Vout2 6 5 4 A B C D E F G G G G 1 2 EN2 Vin 3 EN1 (Top view) Pin Configuration No. Symbol 1 2 3 4 5 6 EN2 VIN EN1 VSS VOUT1 VOUT2 Marking Specification Code Mark A BC DE F G D 08~50 08~50 X Internal rule Descriptions 2-Channel enable Voltage input 1-Channel enable Power ground 1-Channel output 2-Channel output Contents Products series name 1-Ch output voltage 2-Ch output voltage Discharge function Lot number AnaSem 4 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 BLOCK DIAGRAM VIN VOUT1 Over-current Protector VOUT2 Over-current Protector + Voltage Reference + Voltage Reference _ Vss _ EN1 EN2 ABSOLUTE MAXIMUM RATINGS Items Symbol Ratings Unit VIN IOUT VOUT PD PD TOPR TSTG –0.3 ~ +7.0 500 VSS –0.3 ~ VIN +0.3 600 1000 –40 ~ +85 –55 ~ +125 V mA V mW mW °C °C Input voltage range Output current Output voltage range SOT-26 LLP-6 Operating temperature range Storage temperature range Power dissipation ※1) Note : ※1) Power dissipation depends on conditions of mounting on boards. PCB dimension is 50mm×50mm×1.6mm. TYPICAL APPLICATION CIRCUITS EN1 VOUT1 CL1 = 1µF EN2 VOUT2 CL2 = 1µF VSS VIN CIN = 1µF AnaSem 5 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 ELECTRICAL CHARACTERISTICS (Ta=25°C unless otherwise specified) Items Symbol Conditions Min. Typ. Max. Unit VOUT≧1.95V VOUT ×0.99 VOUT VOUT ×1.01 V VOUT≦1.90V –20 - +20 mV 0.9V≦VOUT≦1.15V - 250 - mA 1.2V≦VOUT≦1.65V - 250 - mA 1.7V≦VOUT≦2.25V - 250 - mA 2.3V≦VOUT≦2.85V - 250 - mA 2.9V≦VOUT≦3.45V - 250 - mA 3.5V≦VOUT≦4.05V - 250 - mA 4.0V≦VOUT≦5.00V - 250 - mA 0.9V≦VOUT≦1.15V - 580 910 mV 1.2V≦VOUT≦1.65V - 210 340 mV 1.7V≦VOUT≦2.25V - 130 205 mV 2.3V≦VOUT≦2.85V - 100 150 mV 2.9V≦VOUT≦3.45V - 90 137 mV 3.5V≦VOUT≦4.05V - 85 125 mV 4.1V≦VOUT≦5.00V - 80 115 mV VOUT+1.0V≦VIN≦6.0V Output voltage VOUT IOUT=30mA 1 Ta=–40°C ~ +85°C Output current Dropout voltage IOUT VDROP VIN≧VOUT+1.0V IOUT=100mA Test circuit 1 1 AnaSem 6 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 ELECTRICAL CHARACTERISTICS (CONTINUED) (Ta=25°C unless otherwise specified) Items Symbol Conditions Min. Typ. Max. Unit Test circuit Current consumption IDD VIN=VOUT+1.0V, VOUT=Open, IOUT=0mA - 50 80 µA 2 Standby current ISTB EN=VSS - 0.01 0.1 µA 2 Input voltage VIN 1.6 - 6.0 V 1 - 10 40 mV 1 - 0.01 0.1 %/V 1 - 75 - dB 3 300 - - mA 1 - 40 - mA 1 ppm /°C 1 ∆VOUT Load regulation VIN=VOUT+1.0V, IOUT=0.1mA ~100mA ∆VOUT / VOUT+1.0V≦VIN≦6.0V, IOUT=30mA ∆VIN•VOUT Line regulation Ripple rejection Rr Limit current ILIMIT Short circuit current ISHORT Output voltage temperature coefficient VIN=VOUT+1.0V, f=1KHz, ∆VRIP=0.5VP-P, IOUT=30mA EN=VIN VIN=VOUT+1.0V, VOUT=0V ∆VOUT / VEN=VIN, IOUT=300mA ∆Ta•VOUT Ta=–40°C ~ +85°C ±20 EN high level voltage VENH 1.2 - 6.0 V 1 EN low level voltage VENL - - 0.3 V 1 EN high level current IENH VEN= VIN –0.1 - 0.1 µA 1 EN low level current IENL VEN= VSS –0.1 - 0.1 µA 1 CL auto-discharge resistance RDIS VIN=6.0V, VOUT=4.0V, VEN= VSS - 160 - Ω 1 AnaSem 7 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TEST CIRCUITS Circuit (1) - Output voltage, Output current, Dropout voltage, Input voltage, Load regulation, Line regulation, Limit current, Short circuit current, Output voltage temperature coefficient, CL auto-discharge resistance, EN high level voltage, EN low level voltage, EN high level current, EN low level current VIN VOUT1 A CL VIN CIN V A EN1 IOUT1 V VOUT2 A IOUT2 A EN2 V CL VSS A Circuit (2) - Current consumption, Standby current VIN VOUT1 CL VIN CIN V EN1 VOUT2 EN2 VSS CL Circuit (3) - Ripple rejection VIN VOUT1 A CL V EN1 V IOUT1 A VOUT2 IOUT2 EN2 VSS CL V AnaSem 8 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 DESCRIPTION OF OPERATION General operation In reference to following a part of the block diagram of output voltage control of the VRD series ; *1) VIN VOUT Over-current Protector R1 RDIS VFEEDBACK + Voltage VREF Reference R2 _ Error Amp. VSS EN By the error amplifier, the reference voltage (VREF) is compared with VFEEDBACK which is divided by feedback resistors R1 and R2. It supplies the output transistor (see note *1) to keep a stabilized output voltage against with any fluctuation of input voltage by negative feedback system. Note *1) The VRD series has P-channel MOSFET which is connected to the VOUT terminal as the output transistor. To prevent the VRD series from being damaged due to inverse current from VOUT terminal to VIN terminal through a parasitic diode, VOUT should not be exceeded VIN+0.3V. EN terminal (shutdown function) & CL auto-discharge The VRD series can be shutdown through EN terminal. The P-channel MOSFET is turned off and operation of all internal circuits stops to reduce the current consumption when the signal of EN terminal is set to the shutdown level. In shutdown mode, the VRD series enables the electric charge at the CL to be discharged via the auto-discharge resistance (RDIS ; 160Ω), and the VOUT terminal can be rapidly returned to the VSS level as a result. Output capacitor (CL) For phase compensation, an output capacitor (CL) is required to connected between VOUT terminal and VSS terminal as close as possible. A ceramic capacitor with capacitance value of at least 1.0µF is recommended. Of course, the suitable capacitance value should be different by the condition of each application. In addition, an input capacitor (CIN) with capacitance value of at least 1.0µF is also recommended between VIN terminal and VSS terminal for stable input power. Over current protection and short circuit protection Built-in over current protection circuit performs circuit protection from over current as a current limiter. When the load current reaches the limit level, the output voltage drops and output current also decreases accordingly. A current of typ. 40mA will flow when output terminal is shorted. AnaSem 9 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Output Current VRD (VOUT=1.5V) VRD (VOUT=1.5V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 1.6 1.4 1.4 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 1.6 1.2 1.0 0.8 0.6 0.4 VIN=2.5V VIN=4.3V VIN=6.0V 0.2 0 1.2 1.0 0.8 0.6 0.4 Ta=+25°C Ta=–40°C Ta=+85°C 0.2 0 0 50 100 150 200 250 300 350 400 0 50 100 Out Current : IOUT (mA) 150 VRD (VOUT=1.8V) EN=VIN, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 250 300 350 400 VRD (VOUT=1.8V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 2.4 2.4 1.8 1.8 VIN=2.8V VIN=1.9V VIN=4.0V VIN=6.0V 1.2 200 Out Current : IOUT (mA) 1.2 0.6 0.6 0 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 50 100 150 200 250 300 350 0 Out Current : IOUT (mA) 50 100 150 200 250 300 350 Out Current : IOUT (mA) AnaSem 10 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Output Current (continued) VRD (VOUT=2.8V) VRD (VOUT=2.8V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 3.0 2.5 2.5 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.0 2.0 1.5 1.0 VIN=3.8V VIN=2.9V VIN=6.0V 0.5 0 2.0 1.5 1.0 Ta=+25°C Ta=–40°C Ta=+85°C 0.5 0 0 50 100 150 200 250 300 350 400 0 50 100 Out Current : IOUT (mA) VRD (VOUT=3.3V) 200 250 300 350 400 VRD (VOUT=3.3V) EN=VIN, Ta=25°C, CIN=CL=1.0µF VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 3.5 3.5 3.0 3.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 150 Out Current : IOUT (mA) 2.5 2.0 1.5 1.0 VIN=4.3V VIN=3.4V VIN=6.0V 0.5 0 2.5 2.0 1.5 1.0 Ta=+25°C Ta=–40°C Ta=+85°C 0.5 0 0 50 100 150 200 250 300 350 400 0 Out Current : IOUT (mA) 50 100 150 200 250 300 350 400 Out Current : IOUT (mA) AnaSem 11 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Input Voltage VRD (VOUT=1.5V) VRD (VOUT=1.5) EN=VIN, Ta=25°C, CIN=CL=1.0µF EN=VIN, Ta=25°C, CIN=CL=1.0µF 2.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 2.0 1.8 1.6 1.4 1mA 30mA 100mA 1.2 1.0 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.8 1.6 1.4 1.0 4.0 6.0 1mA 30mA 100mA 1.2 4.2 4.4 4.6 Input Voltage : VIN (V) VRD (VOUT=1.8V) 5.2 5.4 5.6 5.8 6.0 EN=VIN, Ta=25°C, CIN=CL=1.0µF 2.0 1.9 1.9 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 1.8 1.7 1.6 1mA 30mA 100mA 1.5 1.4 1 5.0 VRD (VOUT=1.8V) 2.0 0 4.8 Input Voltage : VIN (V) 2 3 4 5 6 1.8 1.7 1.6 1mA 30mA 100mA 1.5 1.4 2.5 Input Voltage : VIN (V) 3.0 3.5 4.0 4.5 5.0 5.5 6.0 Input Voltage : VIN (V) AnaSem 12 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Input Voltage (continued) VRD (VOUT=2.8V) VRD (VOUT=2.8V) EN=VIN, Ta=25°C, CIN=CL=1.0µF EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.1 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 3.1 2.9 2.7 2.5 1mA 30mA 100mA 2.3 1 2 3 4 5 2.9 2.7 2.5 2.3 3.0 6 1mA 30mA 100mA 3.5 4.0 Input Voltage : VIN (V) VRD (VOUT=3.3V) Output Voltage : VOUT (V) Output Voltage : VOUT (V) 3.4 3.3 3.2 3.1 1mA 30mA 100mA 3.0 2.5 3.0 5.5 6.0 3.5 4.0 4.5 5.0 5.6 EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.6 3.5 2.9 2.0 5.0 VRD (VOUT=3.3V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.6 4.5 Input Voltage : VIN (V) 6.0 3.5 3.4 3.3 3.2 3.1 1mA 30mA 100mA 3.0 2.9 3.5 4.0 4.5 5.0 5.5 6.0 Input Voltage : VIN (V) Input Voltage : VIN (V) AnaSem 13 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Dropout Voltage vs. Output Current VRD (VOUT=1.5V) VRD (VOUT=1.8V) EN=VIN, CIN=CL=1.0µF 0.35 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 EN=VIN, CIN=CL=1.0µF 0.40 Dropout Voltage : VDROP (V) Dropout Voltage : VDROP (V) 0.40 0 0.35 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 0 0 50 100 150 200 0 Output Current : IOUT (mA) 100 150 200 Output Current : IOUT (mA) VRD (VOUT=2.8V) VRD (VOUT=3.3V) EN=VIN, CIN=CL=1.0µF 0.40 0.35 EN=VIN, CIN=CL=1.0µF 0.40 Ta=+25°C Ta=–40°C Ta=+85°C Dropout Voltage : VDROP (V) Dropout Voltage : VDROP (V) 50 0.30 0.25 0.20 0.15 0.10 0.05 0 Ta=+25°C Ta=–40°C Ta=+85°C 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0 50 100 150 200 0 Output Current : IOUT (mA) 50 100 150 200 Output Current : IOUT (mA) AnaSem 14 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Ambient Temperature VRD (VOUT=1.5V) VRD (VOUT=1.8V) VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 1.90 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 1.60 1.55 1.50 1.45 1.40 -50 1.85 1.80 1.75 1.70 -25 0 25 50 75 100 -50 -25 Ambient Temperature : Ta (°C) VRD (VOUT=2.8V) VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 50 75 100 VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 3.40 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 25 VRD (VOUT=3.3V) 2.90 2.85 2.80 2.75 2.70 -50 0 Ambient Temperature : Ta (°C) -25 0 25 50 75 100 3.35 3.30 3.25 3.20 -50 Ambient Temperature : Ta (°C) -25 0 25 50 75 100 Ambient Temperature : Ta (°C) AnaSem 15 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Supply Current vs. Ambient Temperature (Total value of VR1 & VR2) VIN=EN=VOUT+1.0V 65 Supply Current : IDD (µA) 60 55 50 45 VR1=2.5V / VR2=3.3V VR1=1.5V / VR2=3.3V VR1=1.8V / VR2=3.0V VR1=1.2V / VR2=2.8V 40 35 -60 -40 -20 0 20 40 60 80 100 Ambient Temperature : Ta (°C) TYPICAL CHARACTERISTICS – Cross Talk 2.65 3.60 2.60 3.55 2.55 Output Voltage (VR1) 3.50 2.50 3.45 2.45 3.40 2.40 3.35 Output Voltage (VR2) 2.35 3.30 2.30 Output Voltage (VR2) : VOUT2 (V) Output Voltage (VR1) : VOUT1 (V) VOUT1=2.5V, VOUT2=3.3V Ch1→Ch2 VIN=4.3V, IOUT1=0.1↔100mA, IOUT2=30mA Tr/Tf=5µs, Ta=25°C, CIN=CL=1.0 µF 3.25 3.20 2.25 Time (100ms/div) AnaSem 16 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Supply Current vs. Input Voltage VRD (VOUT=1.5V) VRD (VOUT=1.8V) EN1=VIN, EN2=GND, CIN=CL=1.0µF EN1=VIN, EN2=GND, CIN=CL=1.0µF 70 Ta=+25°C Ta=–40°C Ta=+85°C 60 Supply Current : IDD (µA) Supply Current : IDD (µA) 70 50 40 30 20 10 0 Ta=+25°C Ta=–40°C Ta=+85°C 60 50 40 30 20 10 0 0 1 2 3 4 5 6 0 1 2 Input Voltage : VIN (V) VRD (VOUT=2.8V) 4 5 6 VRD (VOUT=3.3V) EN1=VIN, EN2=GND, CIN=CL=1.0µF EN1=VIN, EN2=GND, CIN=CL=1.0µF 70 70 Ta=+25°C Ta=–40°C Ta=+85°C 60 Supply Current : IDD (µA) Supply Current : IDD (µA) 3 Input Voltage : VIN (V) 50 40 30 20 10 0 Ta=+25°C Ta=–40°C Ta=+85°C 60 50 40 30 20 10 0 0 1 2 3 4 5 6 0 Input Voltage : VIN (V) 1 2 3 4 5 6 Input Voltage : VIN (V) AnaSem 17 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Load Transient Response VRD (VOUT=1.5V) VRD (VOUT=1.8V) 1.90 350 1.85 Output Voltage 1.50 300 1.45 250 1.40 200 1.35 150 Output Current 1.30 100 1.25 50 1.20 0 Output Voltage : VOUT (V) 1.55 400 Output Current : IOUT (mA) 350 Output Voltage 1.80 300 1.75 250 1.70 200 1.65 150 Output Current 1.60 100 1.55 50 1.50 Time (40µs/div) 0 Time (40µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage 400 3.40 350 3.35 2.80 300 2.75 250 2.70 200 2.65 150 Output Current 2.60 100 2.55 50 2.50 0 Output Voltage : VOUT (V) 2.85 VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Output Current : IOUT (mA) 2.90 Output Voltage : VOUT (V) 400 3.30 400 350 Output Voltage 300 3.25 250 3.20 200 150 3.15 Output Current 3.10 100 3.05 50 3.00 Time (40µs/div) Output Current : IOUT (mA) Output Voltage : VOUT (V) 1.60 VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Output Current : IOUT (mA) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) AnaSem 18 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (Iout=1mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 3 1.65 4 1.60 2 1.55 Output Voltage 1 1.50 0 1.45 -1 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 4 1.70 2.00 Input Voltage 3 1.90 2 1.85 Output Voltage 1 1.80 0 1.75 -1 1.40 1.70 Time (20µs/div) Time (20µs/div) VRD (VOUT=3.3V) VRD (VOUT=2.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 6 1.95 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 5 VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 6 3.00 3.50 2.90 2.85 3 Output Voltage 2 2.80 1 2.75 0 2.70 5 3.45 4 3.40 3.35 3 2 Output Voltage 1 3.25 0 Time (20µs/div) 3.30 Output Voltage : VOUT (V) 4 2.95 Input Voltage : VIN (V) Input Voltage : VIN (V) 5 Output Voltage : VOUT (V) Input Voltage Input Voltage 3.20 Time (20µs/div) AnaSem 19 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (Iout=30mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 1.60 1.55 2 Output Voltage 1 1.50 0 1.45 -1 2.00 Input Voltage 3 1.90 1.85 2 Output Voltage 1 1.80 0 1.75 -1 1.40 1.70 Time (20µs/div) Time (20µs/div) VRD (VOUT=3.3V) VRD (VOUT=2.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage 4 6 2.95 5 2.90 2.85 3 Output Voltage 2 2.80 1 2.75 0 2.70 Input Voltage : VIN (V) Input Voltage : VIN (V) 5 3.00 Output Voltage : VOUT (V) 6 1.95 3.50 Input Voltage 3.45 4 3.40 3 3.35 2 Output Voltage 1 3.25 0 Time (20µs/div) 3.30 Output Voltage : VOUT (V) 3 1.65 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 4 1.70 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 5 3.20 Time (20µs/div) AnaSem 20 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (Iout=100mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 1.65 4 3 1.60 2 1.55 Output Voltage 0 1.50 1.45 -1 2.00 Input Voltage 3 1.90 2 1.85 Output Voltage 1 1.75 -1 1.40 1.70 Time (20µs/div) VRD (VOUT=3.3V) VRD (VOUT=2.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 6 2.95 5 2.90 2.85 3 Output Voltage 2 2.80 1 2.75 0 2.70 Input Voltage : VIN (V) Input Voltage 3.00 Output Voltage : VOUT (V) Input Voltage : VIN (V) 5 1.80 0 Time (20µs/div) 6 1.95 3.50 Input Voltage 3.45 4 3.40 3 3.35 2 Output Voltage 1 3.25 0 Time (20µs/div) 3.30 Output Voltage : VOUT (V) 1 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 4 1.70 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 5 3.20 Time (20µs/div) AnaSem 21 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (Iout=1mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 3.0 2.5 2 1 2.0 Output Voltage 0 1.5 -1 1.0 -2 0.5 -3 7 Input Voltage 3 Input Voltage : VIN (V) Input Voltage 4 Output Voltage : VOUT (V) 2 5 1 4 0 3 Output Voltage -1 -3 0 Time (25µs/div) Time (25µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 3 6 7 5 6 5 2 1 4 Output Voltage 0 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 Output Voltage : VOUT (V) 5 4 2 1 -2 0 6 9 Input Voltage 8 4 7 3 6 2 5 1 Output Voltage 4 0 3 -1 2 -2 1 -3 Time (25µs/div) Output Voltage : VOUT (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 4 0 Time (25µs/div) AnaSem 22 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (Iout=30mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 3.0 2.5 2 1 2.0 Output Voltage 0 1.5 -1 1.0 -2 0.5 5 1 4 0 3 Output Voltage -1 0 -3 Time (25µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) 7 5 6 3 2 5 1 4 Output Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage : VIN (V) 6 Output Voltage : VOUT (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 9 Input Voltage 8 4 7 3 6 2 5 1 Output Voltage 4 0 3 -1 2 -2 1 0 -3 Time (25µs/div) Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 5 0 2 1 Time (25µs/div) 4 6 2 -2 0 -3 7 Input Voltage 3 Input Voltage : VIN (V) Input Voltage 4 Output Voltage : VOUT (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 4 Time (25µs/div) AnaSem 23 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (Iout=100mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 3.0 2.5 2 1 2.0 Output Voltage 0 1.5 -1 1.0 -2 0.5 5 1 4 0 3 Output Voltage -1 0 -3 Time (25µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) 7 5 6 5 2 1 4 Output Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage : VIN (V) 3 6 Output Voltage : VOUT (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 9 Input Voltage 8 4 7 3 6 2 5 1 Output Voltage 4 0 3 -1 2 -2 1 0 -3 Time (25µs/div) Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 5 0 2 1 Time (25µs/div) 4 6 2 -2 0 -3 7 Input Voltage 3 Input Voltage : VIN (V) Input Voltage 4 Output Voltage : VOUT (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 4 Time (25µs/div) AnaSem 24 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (Iout=1mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 5 4.0 4 2 3.5 1 3.0 0 2.5 -1 Output Voltage -2 2.0 1.5 5 1 4 3 0 Output Voltage -1 -4 0.5 -2 -5 0 -3 Time (40µs/div) 2 1 0 Time (40µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3 6 7 5 6 5 2 1 4 Output Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 Output Voltage : VOUT (V) 5 Input Voltage : VIN (V) 6 2 1.0 0 7 EN Input Voltage 3 -3 4 8 9 EN Input Voltage 8 4 7 3 6 2 5 Output Voltage 1 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) Input Voltage : VIN (V) 4.5 Input Voltage : VIN (V) EN Input Voltage Output Voltage : VOUT (V) 4 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) AnaSem 25 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (Iout=30mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 4.5 5 4.0 4 2 3.5 1 3.0 0 2.5 Output Voltage -2 2.0 1.5 6 2 5 1 4 3 0 Output Voltage -1 1.0 -4 0.5 -2 -5 0 -3 Time (40µs/div) 2 1 0 Time (40µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3 8 6 7 5 6 5 2 1 4 Output Voltage 0 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 5 Input Voltage : VIN (V) 7 EN Input Voltage 3 -3 4 8 9 EN Input Voltage 8 4 7 3 6 2 5 Output Voltage 1 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) -1 Input Voltage : VIN (V) Input Voltage : VIN (V) EN Input Voltage Output Voltage : VOUT (V) 4 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) AnaSem 26 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (Iout=100mA) VRD (VOUT=1.5V) VRD (VOUT=1.8V) 4.5 5 4.0 4 2 3.5 1 3.0 0 2.5 Output Voltage -2 2.0 1.5 6 2 5 1 4 3 0 Output Voltage -1 1.0 -4 0.5 -2 -5 0 -3 Time (40µs/div) 2 1 0 Time (40µs/div) VRD (VOUT=2.8V) VRD (VOUT=3.3V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3 8 6 7 5 6 5 2 1 4 Output Voltage 0 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 5 Input Voltage : VIN (V) 7 EN Input Voltage 3 -3 4 8 9 EN Input Voltage 8 4 7 3 6 2 5 Output Voltage 1 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) -1 Input Voltage : VIN (V) Input Voltage : VIN (V) EN Input Voltage Output Voltage : VOUT (V) 4 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) AnaSem 27 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TYPICAL CHARACTERISTICS – Ripple Rejection Rate VRD (VOUT=1.5V) VRD (VOUT=1.8V) VIN=EN=(VOUT+1.0)Vdc +0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 120 110 110 100 100 Ripple Rejection Rate : RR (dB) Ripple Rejection Rate : RR (dB) VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 120 90 80 70 60 50 40 30 90 80 70 60 50 40 30 20 20 10 10 0 0.01 0.1 1 10 100 0 0.01 1000 0.1 Ripple Frequency : f (KHz) VIN=EN=(VOUT+1.0)Vdc +0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 1000 VIN=EN=(VOUT+1.0)Vdc +0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 120 110 110 100 100 Ripple Rejection Rate : RR (dB) Ripple Rejection Rate : RR (dB) 100 VRD (VOUT=3.3V) 120 90 80 70 60 50 40 30 90 80 70 60 50 40 30 20 20 10 10 0.1 10 Ripple Frequency : f (KHz) VRD (VOUT=2.8V) 0 0.01 1 1 10 100 1000 0 0.01 Ripple Frequency : f (KHz) 0.1 1 10 100 1000 Ripple Frequency : f (KHz) AnaSem 28 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 PACKAGE DIMENSIONS (SOT-26) a Min 0.1 +0.10 0.65 –0.15 a 0.45 1.6±0.15 2.8±0.2 a (Unit : mm) 1.1~1.3 2.9±0.2 (Marked Side) 0~0.1 a 0.95 0.65 –0.15 a +0.10 3~7° a 0.95 1.9±0.2 +0.10 0.16 –0.15 +0.10 a = 0.4 –0.15 Flat length = 0.2 min. 2.9±0.2 1.1~1.3 Recommended land pattern 1.0 2.4 0~0.1 0.4 +0.10 –0.15 0.7 1.0 0.7 0.95 0.95 1.9 AnaSem 29 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (SOT-26) (Unit : mm) Mark 1.4±0.1 3.5±0.05 3.4±0.1 Mark 2.0±0.05 4.0±0.1 8.0±0.2 ø1.5 +0.1 –0 0.3±0.03 1.75±0.1 4.0±0.1 3.18±0.1 1.75 Max. Taping direction REEL DIMENSIONS (SOT-26) (Unit : mm) 120° ø60±1 2.0±0.5 (3,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 30 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 PACKAGE DIMENSIONS (LLP-6) (Unit : mm) 0.25±0.05 1.5±0.05 (0.075) 1.0±0.05 0.7±0.05 0.10 (0.3) (Marked Side) 1.3±0.05 (0.3) 2.0±0.05 1.8±0.05 0.3±0.05 (0.1) 5*0.2±0.05 0.15±0.05 Max. 0.6 (Typ. 0.55) (0.5) (0.5) Recommended land pattern 1.8 0.45 1.0 2.4 0.45 0.25 0.25 0.25 0.35 0.25 0.5 0.5 AnaSem 31 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (LLP-6) (Unit : mm) 0.75±0.1 Mark ø1.1±0.1 3.5±0.05 2.2±0.1 Mark 2.0±0.05 4.0±0.1 8.0±0.2 ø1.5 +0.1 –0 0.25±0.05 1.75±0.1 4.0±0.1 2.0±0.1 Taping direction REEL DIMENSIONS (LLP-6) (Unit : mm) 120° ø60±1 2.0±0.5 (3,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 32 www.anasemi.com sales@anasemi.com .......... Future of the analog world AnaSem AnaSem may change the products described in this data sheet, or may discontinue production or services without any notice in order to supply the best products through improve the design and performance. Customers are recommended to obtain the latest data or information before placing orders in order to make sure the data or information required is the newest. It is necessary for customers to fully understand the products described in this data sheet and to use it in accordance with its specifications. The products described in this data sheet are not intended to use for the apparatus which have influence on human lives due to the failure or malfunction of the products. AnaSem Corp. is not responsible for any support to customer’s application, product design, software performance, patent infringement or service. AnaSem Corp. does not disclose or imply a guarantee or description about being licensed based on patents, copy-rights, circuit location license, or other intellectual properties associated with the devices or combinations in which the products or service of AnaSem Corp. are used or can be used, or which cover the methods. Customers should not export, directly or indirectly, any products without obtaining required licenses and approvals in advance from appropriate government agencies. AnaSem www.anasemi.com sales@anasemi.com High speed, Low dropout, ±1% High output accuracy Dual CMOS Voltage Regulator VRD Series Rev. E13-01 GENUINE PRODUCT LEGITIMATE LABEL DEFINITION Green colored Circle “RoHS” Label Other specific customized Labels Ordinary Product Information Bar Code Our internal Outgoing Check Code 3 Our Internal QR Check Code 2 AnaSem Logo and Brand Name (Black color Logo) Our Internal Product Check Code 1 Genuine labels MUST include our correct contact information as shown 2 .......... Future of the AnaSem analog world www.anasemi.com sales@anasemi.com
VRD2833PTX 价格&库存
很抱歉,暂时无法提供与“VRD2833PTX”相匹配的价格&库存,您可以联系我们找货
