TP1674-SR
TP1674-SR
    3PEAK(思瑞浦)
    TP1674-SR
TP1674-SR 数据手册
TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Features Description  Supply Voltage: 3V to 12V The TP167X series amplifiers are newest high supply voltage  Offset Voltage: ±250μV Maximum amplifiers with low offset, low power and stable high frequency  Low Supply Current: 850μA per channel  Rail to Rail Output  Bandwidth: 7MHz  Slew Rate: 20V/μs TP167X family can be used as plug-in replacements for many  Excellent EMI Suppress Performance commercially available op-amps to reduce power and improve  Offset Voltage Temperature Drift: 2 μV/°C input/output range and performance.  Low Noise: 25 nV/√Hz at 1kHz The combination of features makes the TP167X ideal choices  –40°C to 125°C Operation Temperature Range for industrial control, motor control and portable audio response. They incorporate 3PEAK’s proprietary and patented design techniques to achieve very good AC performance with 7MHz bandwidth, 20V/μs slew rate and low distortion while drawing only 850μA of quiescent current per amplifier. The amplification, sound ports, and other consumer Audio. Applications  Active Filters, ASIC Input or Output Amplifier  Motor Control  Industrial Control  Audio Pin Configuration Out 1 ﹣Vs 2 TP1671 TP1672 TP1674 5-Pin SOT23 8-Pin SOIC/TSSOP/MSOP 14-Pin SOIC/TSSOP -T and -C Suffixes -S and -V Suffixes -S and -T Suffixes 8 ﹢Vs Out A 1 7 Out B ﹣In A 2 ﹢In A 3 ﹢Vs 4 TP1671 ﹢In B 5 8-Pin SOIC (-S Suffix) ﹣In B 6 Out B 7 3 + In ﹢Vs 5 4 - In 1 ﹣In A 2 ﹢In A 3 ﹣Vs 4 A B 6 ﹣In B 5 ﹢In B A B NC 1 8 NC ﹣In 2 7 ﹢Vs ﹢In 3 6 Out ﹣Vs 4 5 NC www.3peakic.com.cn Out A 1 / 14 14 Out D 13 ﹣In D 12 ﹢In D 11 ﹣Vs 10 ﹢In C 9 ﹣In C 8 Out C D C Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Pin Configuration ............................................................................................................................................................ 1 Table of Contents ............................................................................................................................................................ 2 Revision History .............................................................................................................................................................. 3 Order Information ............................................................................................................................................................ 3 Absolute Maximum Ratings Note 1 ................................................................................................................................... 4 ESD Rating ....................................................................................................................................................................... 4 Thermal Information ....................................................................................................................................................... 4 Electrical Characteristics ............................................................................................................................................... 5 Typical Performance Characteristics ............................................................................................................................ 6 Tape and Reel Information ............................................................................................................................................. 8 Package Outline Dimensions ......................................................................................................................................... 9 SOT23-5 ....................................................................................................................................................................................... 9 SOP-8 ........................................................................................................................................................................................ 10 MSOP-8 ......................................................................................................................................................................................11 SOP-14 ...................................................................................................................................................................................... 12 TSSOP-14 .................................................................................................................................................................................. 13 www.3peakic.com.cn 2 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Revision History Date Revision Notes 2017/10/20 Rev.Pre Pre-Release Version 2018/1/10 Rev.0 Initial Version Order Information Order Number Operating Temperature Range Package Marking Information TP1671-SR -40 to 125°C 8-Pin SOIC TP1671-TR -40 to 125°C 5-Pin SOT23 TP1672-SR -40 to 125°C 8-Pin SOIC TP1672-VR -40 to 125°C 8-Pin MSOP TP1674-SR -40 to 125°C 14-Pin SOIC TP1674-TR -40 to 125°C 14-Pin TSSOP MSL Transport Media, Quantity 3 Tape and Reel, 4000 3 Tape and Reel, 3000 3 Tape and Reel, 4000 3 Tape and Reel, 3000 3 Tape and Reel, 2500 3 Tape and Reel, 3000 TP1671 XXXX Note 3 671XX Note 2 TP1672 XXXX Note 3 TP1672 XXXX Note 3 TP1674 XXXX Note 3 TP1674 XXXX Note 3 Note 1: The sample will be ready in 1 month. Note 2: XX is the date code. Note 3: XXXX is date code. www.3peakic.com.cn 3 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Absolute Maximum Ratings Note 1 Parameters Rating Supply Voltage, (+VS)– (-VS) 16 V Input Voltage (-VS) – 0.3 to (+VS) + 0.3 Differential Input Voltage +- 0.7V Input Current: +IN, –IN ±10mA Note 2 Output Short-Circuit Duration Note 3 Infinite Maximum Junction Temperature 150°C Operating Temperature Range –40 to 125°C Storage Temperature Range –65 to 150°C Lead Temperature (Soldering, 10 sec) 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 300mV beyond the power supply, the input current should be limited to less than 10mA. Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD Rating Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 2 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 1 kV Thermal Information Package Type θJA θJC Unit 5-Pin SOT23 250 81 °C/W 8-Pin SOIC 158 43 °C/W 8-Pin MSOP 210 45 °C/W 14-Pin SOIC 120 36 °C/W 14-Pin TSSOP 180 35 °C/W www.3peakic.com.cn 4 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Electrical Characteristics All test condition is VS = 10V, TA = 25°C, RL = 10kΩ, unless otherwise noted. Symbol Parameter VS Supply Voltage Range IQ Quiescent Current per Amplifier VS = 10V PSRR Power Supply Rejection Ratio VS = 3V to 12V 95 VOS Input Offset Voltage VS = 10V, VCM = 0V to 10V -250 VOS TC Input Offset Voltage Drift TA = -40°C to 125°C 2 μV/°C TA = 25°C 10 pA TA = -40°C to 85°C 200 pA TA = -40°C to 125°C 6000 pA 10 pA Differential Mode 5 pF Common Mode 5 pF 120 dB IB Input Bias Current IOS Input Offset Current CIN Input Capacitance Av Conditions Min Typ 3 850 Open-loop Voltage Gain 95 Max Unit 12 V 1500 μA 120 dB 250 μV Common-mode Input Voltage VCMR (V-) (V+) - 2 V Range CMRR Common Mode Rejection Ratio VCM = 0V to 8V 95 VOH, VOL Maximum Output Voltage Swing RLOAD = 100kΩ ISC Output Short-Circuit Current 70 mA GBW Gain-Bandwidth Product 7 MHz SR Slew Rate 20 V/μs tOR Overload Recovery 200 ns dB 0.8 μs Settling Time, 0.01% 1 μs PM Phase Margin 60 ° GM Gain Margin 15 dB EN Input Voltage Noise f = 0.1Hz to 10Hz 3 μVRMS eN Input Voltage Noise Density f = 1kHz 25 nV/√Hz iN Input Current Noise f = 1kHz 2 fA/√Hz THD+N Total Harmonic Distortion and f = 1kHz, AV =1, RL = 2kΩ, VOUT = 1VPP 0.001 % 50 Settling Time, 0.1% tS 120 AV= -1, 10V step mV Noise www.3peakic.com.cn 5 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Typical Performance Characteristics VS = 10V, VCM = 5V, RL = Open, unless otherwise specified. Figure 1. Quiescent Current vs. Supply Voltage Figure 2. Quiescent Current vs. Temperature Figure 3. Offset Voltage vs. Temperature Figure 4. Open-Loop Gain and Phase Figure 5. Unity Gain Bandwidth vs. Temperature Figure 6. EMIRR IN+ vs. Frequency www.3peakic.com.cn 6 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Figure 7. CMRR vs. Frequency Figure 8. PSRR vs. Frequency Figure 9. Negative Overload Recovery Figure 10. Positive Over-Voltage Recovery www.3peakic.com.cn 7 / 14 Rev.0 Tape and Reel Information Order Number Package D1 W1 A0 B0 K0 P0 W0 Pin1 Quadrant TP1671-TR 5-Pin SOT23 180.0 13.1 3.2 3.2 1.4 4.0 8.0 Q3 TP1671-SR 8-Pin SOIC 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TP1672-SR 8-Pin SOIC 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TP1672-VR 8-Pin MSOP 330.0 17.6 5.2 3.3 1.5 8.0 12.0 Q1 TP1674-SR 14-Pin SOIC 330.0 21.6 6.5 9.0 2.1 8.0 16.0 Q1 TP1674-TR 14-Pin TSSOP 330.0 17.6 6.8 5.4 1.2 8.0 12.0 Q1 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps Package Outline Dimensions SOT23-5 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 C 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950TYP 0.037TYP e1 1.800 0.071 L 0.700REF 0.028REF L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Symbol www.3peakic.com.cn 9 / 14 2.000 0.079 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps SOP-8 A2 C θ L1 A1 e E D Symbol E1 b 10 / 14 Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e www.3peakic.com.cn Dimensions 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 www.3peakic.com.cn L L2 11 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps SOP-14 Dimensions In Millimeters Symbol MIN 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 b1 0.35 c 0.16 c1 0.15 0.20 0.25 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 L 12 / 14 MAX A e www.3peakic.com.cn NOM 0.49 0.40 0.45 0.25 1.27 BSC 0.45 0.60 L1 1.04 REF L2 0.25 BSC 0.80 R 0.07 R1 0.07 h 0.30 θ 0° θ1 6° 8° 10° θ2 6° 8° 10° θ3 5° 7° 9° θ4 5° 7° 9° 0.40 0.50 8° Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps TSSOP-14 Dimensions In Millimeters E1 E A A2 e Symbol c D MIN TYP MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 b 0.20 - 0.28 c 0.10 - 0.19 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L A1 R1 R 0.65 BSC 0.45 0.60 L1 1.00 REF L2 0.25 BSC 0.75 R 0.09 - - θ 0° - 8° θ L1 www.3peakic.com.cn L L2 13 / 14 Rev.0 TP1671/ TP1672/ TP1674 12V, 7MHz, 20V/μs Op Amps 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. www.3peakic.com.cn 14 / 14 Rev.0
TP1674-SR 价格&库存
很抱歉,暂时无法提供与“TP1674-SR”相匹配的价格&库存,您可以联系我们找货
