BD035M101LO6.3*8L-1A4T 数据手册
BD Series
Low impedance, high ripple current, high voltage
Load life of 2000 hours at 105℃
RoHS Compliant
high
CN
BD
temperture
◆ 规格表 Specifications
项目Items
high
voltage
BC
特性参数Characteristics
使用温度范围
Category
Temperture Range
-55 ~ +105℃
额定工作电压范围
35 ~ 250 V
Rated Voltage Range
静电容量允许偏差
±20%(M)
Capacitance tolerance
(at 20℃,120Hz)
施加额定工作电压 2分钟后读数,小于或等于规格值 (at 20℃)
漏电流
Leakage Current
I≤0.15CV 或500μA(取大值)
Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20℃
损耗角正切值 tanδ
Dissipation Factor
温度特性
Low Temperture
Characteristics
(Max.Impedance Ratio)
小于或等于规格
(at 20℃,120Hz)
Z(-25℃)/Z(+20℃)
≤1.25
Z(-55℃)/Z(+20℃)
≤1.25
(100KHz)
105℃施加额定工作电压 2000 小时,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of
rated voltage for 2000 hours at 105℃.
Appearance
Capacitance change
耐久性
Endurence
No significant damage
D.F.(tanδ)
≦±20% of the initial value
≦150% of the specified value
ESR
Leakage current
≦The specified value
在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压 1000 小时后,恢复到 20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of
rated voltage for 1000 hours at 60℃,90%~ 95% RH.
耐湿负荷特性
Damp Heat
(Steady State)
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
浪涌电压 : 1、35-100W.V.:1.15*W.V.(V);2、160-400W.V.:1.1*W.V.(V)
Surge Voltage: 1、35-100W.V.:1.15*W.V.(V);2、160-400W.V.:1.1*W.V.(V)
在105℃环境中,按充电 30秒;放电 5分30秒,连续施加浪涌电压 1000 次(Rc=1kΩ),待恢复后测试,应满足以下要求
The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified
at 105℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds
浪涌电压特性
(Surge Voltage)
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
◆ 外形图Dimensions (mm)
Period
trademark
918
Capacitance 100
35V
BD
Series
Voltage
ΦD
5
6.3
8
10
P
2
2.5
3.5
5
Φd
0.5
0.5
0.6
0.6
ɑ
L
BD035M101LO6.3*8L-1A4T 价格&库存
很抱歉,暂时无法提供与“BD035M101LO6.3*8L-1A4T”相匹配的价格&库存,您可以联系我们找货
