SS22A THRU SS220A
2.0 A Surface Mount Schottky Barrier
Rectifiers - 20V-200V
Features
Package outline
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds at terminals
Compliant to RoHS Directive 2011/65/EU
SMA/DO-214AC
0.108(2.75)
0.096(2.45)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
Mechanical data
0.096(2.42)
0.078(1.98)
Case: JEDEC DO-214AC molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
T A=25 oC unless otherwise noted)
SYMBOLS SS22A SS23A SS24A SS25A SS26A SS28A SS210A SS215A SS220A UNITS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
200
105
150
140
200
V
V
V
I(AV)
2.0
A
IFSM
50.0
A
VF
0.85
0.95
0.1
0.5
10.0
IR
CJ
RθJA
TJ,
TSTG
0.70
0.55
5.0
220
80
-55 to +125
-55 to +150
-55 to +150
2.0
V
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas
www.fuxinsemi.com
Page 1
Ver2.1
SS22A THRU SS220A
2.0
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
P.C.B mounted on
0.2*0.2"(5.0*5.0mm)
copper pad areas
0.8
SS22A-SS24A
SS25A-SS220A
0.4
50
75
100
125
150
50
40
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
TJ=25 C
10.0
1
SS22A-SS24A
SS25A-SS26A
SS28A-SS210A
SS215A-SS220A
0.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.4
0.6
0.8
1.0
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
SS22A-SS24A
SS25A-SS220A
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
50
JUNCTION CAPACITANCE, pF
10
LEAD TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
CURRENT,AMPERES
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Rating and characteristic curves
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
www.fuxinsemi.com
t,PULSE DURATION,sec.
Page 2
Ver2.1
SS22A THRU SS220A
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
SS22
SS23
SS24
SS25
SS26
SS28
SS210
SS215
SS220
SS22A
SS23A
SS24A
SS25A
SS26A
SS28A
SS210A
SS215A
SS220A
Suggested solder pad layout
C
A
B
www.fuxinsemi.com
PACKAGE
A
B
C
SMA
0.110 (2.80)
0.063 (1.60)
0.087 (2.20)
Page 3
Ver2.1
SS22A THRU SS220A
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“SS210A”相匹配的价格&库存,您可以联系我们找货
