HSU1241
N-Ch 40V Fast Switching MOSFETs
Description
Product Summary
The HSU1241 is the high cell density trenched Nch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSU1241 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
40
V
RDS(ON),max
16.5
mΩ
ID
40
A
TO252 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
40
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
40
A
ID@TC=100℃
23
A
IDM
Pulsed Drain Current2
85
A
EAS
Single Pulse Avalanche Energy3
31.3
mJ
IAS
Avalanche Current
25
A
PD@TC=25℃
Total Power Dissipation4
31.3
W
PD@TA=25℃
2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
Max.
Unit
65
℃/W
3
℃/W
1
HSU1241
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
40
V
Reference to 25℃ , ID=1mA
0.032
V/℃
VGS=10V , ID=15A
13.5
16.5
VGS=4.5V , ID=10A
18.4
24
1.2
1.6
2.5
V
-4.8
mV/℃
VDS=32V , VGS=0V , TJ=25℃
1
VDS=32V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=15A
34
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.1
Qg
Total Gate Charge (4.5V)
10
Qgs
Gate-Source Charge
2.55
Qgd
Gate-Drain Charge
4.8
Turn-On Delay Time
2.8
Td(on)
Tr
Td(off)
Tf
VDS=32V , VGS=4.5V , ID=15A
Rise Time
VDD=20V , VGS=10V , RG=3.3
12.8
Turn-Off Delay Time
ID=15A
21.2
nC
ns
Fall Time
6.4
Ciss
Input Capacitance
1013
Coss
Output Capacitance
107
Crss
Reverse Transfer Capacitance
76
Min.
Typ.
Max.
Unit
40
A
85
A
1.2
V
VDS=15V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
Parameter
Conditions
IS
Continuous Source Current1,5
ISM
Pulsed Source Current2,5
VSD
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
trr
Reverse Recovery Time
IF=15A , dI/dt=100A/µs ,
10
nS
Qrr
Reverse Recovery Charge
TJ=25℃
3.1
nC
VG=VD=0V , Force Current
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=25A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSU1241
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
IS Source Current(A)
12
8
TJ=150℃
TJ=25℃
4
0.25
0.50
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics of Reverse
diode
1.8
Normalized On Resistance
1.8
Normalized VGS(th)
1.4
1.4
1
1.0
0.6
0.6
0.2
0.2
-50
100
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSU1241
10000
F=1.0MHz
Capacitance (pF)
Ciss
1000
Coss
100
Crss
10
1
5
9
13
17
21
25
VDS Drain to Source Voltage (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.01
0.1
0.05
0.02
0.01
P DM
SINGLE
T ON
T
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
BVDSS
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform waveform
www.hs-semi.cn
Ver 2.0
4
HSU1241
Ordering Information
Part Number
HSU1241
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU1241”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.11176
- 50+0.89403
- 150+0.80072
- 500+0.68429
