Technical Data Sheet
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
SMA
Right Angle Jack PCB
32K201-400L5
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
IEC 60169-15, EN 122110, MIL-STD-348A, Fig. 310
Documents
PCB layout
B 30b
Material and plating
Connector parts
Center contact
Outer contact
Body
Dielectric
Material
CuBe
CuBe or equiv.
Brass
PTFE
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
AuroDur®, gold plated
Gold, min. 0.15 µm, over chemical nickel
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/2
SMA
32K201-400L5
RF_35/09.14/6.2
Electrical data
Impedance
Frequency
VSWR
50
DC to 18 GHz
1.05 + 0.005 x f [GHz], DC to 8 GHz
1.25
8 to 18 GHz
Insertion loss
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage
Working voltage
Power handling (at 20 °C, sea level, VSWR 1.0)
RF-leakage
0.04 x f(GHz) dB
5 x103 M
3 m
2 m
1000 V rms
480 V rms
200 W @ 2 GHz; 100 W @ 10 GHz
100 dB up to 1 GHz
- Connector only, VSWR in application depends decisive on PCB layout -
Mechanical data
Mating cycles
Center contact captivation: axial
radial
Coupling test torque
Recommended torque
min. 500
27 N
3 Ncm
max. 1.7 Nm
0.8 Nm to 1.1 Nm
Environmental data
Temperature range
Thermal shock
Corrosion
Vibration
Shock
Moisture resistance
Max. soldering temperature
RoHS
-65°C to +165°C
MIL-STD-202, Meth. 107, Cond. B
MIL-STD-202, Meth. 101, Cond. B
MIL-STD-202, Meth. 204, Cond. D
MIL-STD-202, Meth. 213, Cond. I
MIL-STD-202, Meth. 106
IEC 61760-1, +260°C for 10 sec.
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
3.48 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Rong Fang
30.03.04
Chr. Janßen
09.11.20
d00
20-1927
S. Huber-Siegl
09.11.20
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/2
很抱歉,暂时无法提供与“32K201-400L5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+72.20955
- 10+70.69954
- 25+67.86698
- 50+66.44028
- 100+65.00317
