KCT8522C
KCT8522C
    KCT(康希通信)
    QFN16_EP
    KCT8522C
KCT8522C 数据手册
KCT8522C PRODUCT DATASHEET 5GHz High-Power WLAN 802.11ac RFIC WITH PA, LNA AND SPDT LNA_EN RX_EN GND ANT 16 15 14 13 Description NC 1 12 GND RX 2 11 VCC NC 3 10 VCC VDD 4 9 5 6 7 8 DET TX_EN GND TX NC KCT8522C is a highly integrated RF Front-End Integrated Circuit incorporates key RF functionality needed for IEEE 802.11a/n/ac WLAN systems operating in the 5.15-5.85GHz range. KCT8522C integrates a high-efficiency high-linearity power amplifier (PA), a low noise amplifier (LNA) with bypass, the associated matching network, LO rejection, and harmonic filters all in one device. KCT8522C has simple and low-voltage control logic, and requires minimal external components. A power detector is also integrated for accurate monitoring of output power from the PA. KCT8522C is assembled in a compact, low-profile 3x3x0.55mm 16-lead QFN package. KCT8522C is the ideal RF front-end solution for implementing 5GHz high-power WLAN systems supporting multiple standards including 802.11a/n/ac. Applications     802.11ac Wi-Fi Devices Tablets / MIDs Wi-Fi Media Gateways Consumer Electronics     Notebook / Netbook / Ultrabook Access Points / Routers Set Top Boxes / Wireless IPTVs Other 5GHz ISM Platforms FEATURES  Integrated high performance 5GHz PA,LNA with bypass and T/R switch  Fully-matched input and output  Integrated power detector  Transmit gain : 29dB  Receive gain: 13dB  Output power: +21dBm @ 1.8% DEVM, VHT80/MCS9, 5V  Output power: +22.5dBm @ 3% DEVM, HT40/MCS7, 5V  ESD protection circuitry on all PINs  DC decoupled RF ports  Minimal external components required  Small package: QFN16 3mm x 3mm x0.55mm (MSL3, 260 C per JEDEC J-STD-020)  RoHS and REACH Compliant o This product datasheet is a general list of parameters to provide information on the capabilities of this device and is subject to change without notice. Rev A Dec. 29, 2017 KCT8522C PRODUCT DATASHEET PIN ASSIGNMENTS Pin Number Pin Name Description 1,3,9 NC Internally Not Connected 2 RX RF Output Port from LNA or Bypass – DC Shorted to GND 4 VDD LNA/Switch/Regulator Supply Voltage 5 DET Detector Output Voltage 6 TX_EN Input to Control TX Enable 8 TX RF Input Port from the Transceiver – DC Shorted to GND 10,11 VCC PA Supply Voltage 13 ANT Antenna Port – RF Signal from the PA or RF Signal Applied to the LNA – DC Shorted to GND 15 RX_EN Input to Control RX Enable 16 LNA_EN Input to Control LNA Enable or Bypass Mode 7, 12, 14 GND Ground – Must Be Connected to GND in the Application Circuit PIN-OUT DIAGRAM NC LNA_EN RX_EN GND ANT 16 15 14 13 1 12 GND 17 GND RX 2 11 VCC NC 3 10 VCC VDD 4 9 NC 5 6 7 8 DET TX_EN GND TX This product datasheet is a general list of parameters to provide information on the capabilities of this device and is subject to change without notice. Rev A Dec. 29, 2017 KCT8522C PRODUCT DATASHEET ABSOLUTE MAXIMUM RATINGS Parameters Min Units Max Conditions DC Supply Voltage V 0 +6.0 VDD and VCC Control Pin Voltage V 0 3.6 All Control Pins DC Current Consumption mA 600 Maximum TX Input Power (50 ohm load, No Damage) dBm +12 LNA On Maximum RX Input Power (No Damage) dBm +12 Bypass Mode Maximum RX Input Power (No Damage) dBm +25 o Storage Temperature -40 C 150 ESD – Human Body Mode V 2500 HBM ESD – Charge Device Mode V 1000 CDM ESD – Machine Mode V 50 Moisture Sensitivity MM MSL3 NOTE: Sustained operation at or above the Absolute Maximum Ratings for any one or combinations of the above parameters may result in permanent damage to the device and is not recommended. All Maximum RF Input Power Ratings assume 50-ohm terminal impedance. NOMINAL OPERATING CONDITIONS Parameters Units Min Typ Max DC Supply Voltage V 4.5 5 5.5 Control Pin Voltage “High” V 1.8 3.6 Control Pin Voltage “Low” V 0 0.4 Control Pin DC Current uA 50 Leakage Current - Nominal μA 20 Operation Temperature o C -40 Conditions VDD and VCC RF Off; TX_EN=Low; LNA_EN=Low +25 +85 KCT8522C ELECTRICAL SPECIFICATIONS o (VDD=VCC= 5V, T = 25 C, Unless Otherwise Noted) Parameters Frequency Range Units Min GHz 5.15 dB 28 Typ Max Conditions 5.85 Transmit Mode Gain 29 30 This product datasheet is a general list of parameters to provide information on the capabilities of this device and is subject to change without notice. Rev A Dec. 29, 2017 KCT8522C PRODUCT DATASHEET Parameters Units Min Typ Max +21 Output Power EVM Floor dBm VHT80/MCS9, 1.8% DEVM, Preamble only +22.5 dB Conditions HT40/MCS7, 3% DEVM, Preamble Only +25 HT20/MCS0, Mask Compliance -40 Pout=18dBm, VHT80/MCS9, DEVM, Preamble Only CW Signal Current Consumption mA 250 260 @ No RF 300 320 @+20dBm 350 380 @+23dBm 400 450 @+25dBm Pout = +22dBm, HT20/MCS0 Harmonics dBm/MHz Input Return Loss dB Output Return Loss dB Power Detector Output 8 -35 2nd harmonics -55 3rd harmonics 10 12 V 0.35 @ No RF 0.6 @+20dBm 0.9 @+24dBm Power Range from 0dBm~+25dBm Power Detector Variations Power Detector Output Impedance dB -0.5 0.5 Nominal Load -1.5 1.5 VSWR=3:1 ohm 1K PA Switching Time ns 300 PA Turn-On Time from TX_EN edge ns 350 PA Turn-Off Time from TX_EN edge ns 350 Load Stability VSWR=3:1 dBm Ruggedness 18 VHT80/MCS9, 1.8% DEVM, Preamble only 19 HT40/MCS7, 3% DEVM, Preamble Only 21 HT20/MCS0, Mask Compliance VSWR=10:1 Pin =0dBm, No Permanent Damage Receive Mode - LNA On Gain dB 11 13 15 This product datasheet is a general list of parameters to provide information on the capabilities of this device and is subject to change without notice. Rev A Dec. 29, 2017 KCT8522C PRODUCT DATASHEET Parameters Units Input Power of P1dB Min Typ Max dBm -12 Noise Figure dB 3.0 3.5 Input Return Loss dB 13 15 Output Return Loss dB 9 10 Switching Time ns 200 LNA _EN Control Current μA 35 LNA Turn On Time ns 300 Current Consumption mA 15 dB 3.5 dBm +13 Input Return Loss dB 14 Output Return Loss dB 8 ANT-RX Isolation dB 35 Bypass Current μA 20 Conditions LNA  Bypass Receive Bypass Mode Insertion Loss Input Power of P1dB Transmit Mode; TX_EN=High; Maximum Power CONTROL LOGIC TABLE TX_EN LNA_EN RX_EN Mode of Operation 1 X X Transmit Mode 0 1 1 Receive LNA Mode 0 0 1 Bypass Mode 0 0 0 Shutdown Mode All Others Note: Unsupported (No Damage) “1” denotes high voltage state (> 1.8V) “0” denotes low voltage state (
KCT8522C 价格&库存
很抱歉,暂时无法提供与“KCT8522C”相匹配的价格&库存,您可以联系我们找货
