WS4508S-8/TR
WS4508S-8/TR
    WILLSEMI(韦尔)
    SOP8L_EP
    WS4508S-8/TR
WS4508S-8/TR 数据手册
WS4508S WS4508S 1000mA, Single Li-ion Battery Charger Http//:www.sh-willsemi.com Descriptions The WS4508S is a complete constant-current / constant voltage linear charger for single cell Lithium-Ion batteries. No external sense resistor is needed, and no blocking diode is required due to the internal MOSFET architecture. Thermal feedback regulates the charge current to limit the die temperature during high power operation or high SOP-8L-EP ambient temperature. The charge voltage is fixed at 4.2V, and the charge current can be programmed CE CHGb STDBYb BAT 8 7 6 5 externally with a single resistor. The WS4508S automatically terminates the charge Expose PAD GND cycle when the charge current drops to 1/10 the programmed value after the final float voltage is reached. 1 2 3 4 When the input supply (wall adapter or USB supply) is TEMP PROG GND VCC removed, the WS4508S automatically enters a low Pin configuration (Top view) current state, dropping the battery drain current to less than 0.5uA. The WS4508S can be put into shutdown mode, reducing supply current to 45uA (Typ.). 8 7 6 5 The WS4508S is available in SOP-8L-EP package. WS4508S YYWW Standard product is Pb-Free. Features  Programmable Charge Current Up to 1000mA  Over-Temperature Protection  Under Voltage Lockout Protection  Automatic Recharge Threshold 4.05V(Typ.) YY = Year  Charge Status Output Pin WW = Week  2.9V Trickle Charge Threshold  Soft-Start Limits Inrush Current Applications  Wireless phone  MP3/MP4 Player  Bluetooth device Will Semiconductor Ltd. 1 2 WS4508S 3 4 = Device Code Order information Device Package Shipping WS4508S-8/TR SOP-8L-EP 2500/Reel&Tape 1 May, 2016 - Rev. 1.4 WS4508S Pin descriptions Pin Number Pin Name 1 TEMP Function Battery Temperature Sense Pin. When the battery temperature is too high or too low, the charging current will be terminated. 2 PROG Charge current setting, charge current monitor and shutdown pin. The charging current is given by I BAT = (1/RPROG)*1000. The chip will be shutdown when PROG pin floating 3 GND Ground 4 VCC Power Supply 5 BAT Charge Current Output. Provides charge current to the battery and regulates the final float voltage to 4.2V. 6 Charge Complete Status Output. Low level status for charge finished. In STDBYb addition, STDBYb pin will be in a high impedance state. 7 Open-Drain Charge Status Output. When the battery is charging, the CHGb CHGb pin is pulled low. When the charge cycle is completed or VCC is removed, the CHGb is forced high impedance. 8 CE Chip Enable. Active high. Block Diagram VCC 165°C TDIE 80%Vcc 1X TA 1000X 5uA BAT C4 MA R1 TEMP 45%Vcc CE STDBYb C5 VA CA R2 INV SHDNb REF 1.2V C1 1V R3 R4 0.1V CHGb C2 To BAT 2.9V R5 3uA Vcc C3 PROG GND Will Semiconductor Ltd. 2 May, 2016 - Rev. 1.4 WS4508S Typical applications VCC 10uF LED1 R3 4 VCC 8 CE TEMP R1 1 R2 LED2 WS4508S R4 7 6 BAT CHGb STDBYb PROG 5 Li-Lon 10uF BAT 2 NTC RPROG GND 3 Figure1. Typical Applications W/T LED Indicate Circuit VCC 10uF 4 VCC 8 CE R3 WS4508S R4 7 uP TEMP 6 BAT CHGb STDBYb PROG GND 1 5 Li-Lon 10uF BAT 2 RPROG 3 Figure2. Typical Applications W/T Microprocessor Detect Circuit Will Semiconductor Ltd. 3 May, 2016 - Rev. 1.4 WS4508S o Electronics Characteristics (VCC=5V, Ta=25 C, unless otherwise noted) Symbol Parameter Condition Min. Typ. Max. Unit RPROG=10kΩ 170 240 2000 uA RPROG=1kΩ 900 1000 1100 mA RPROG=10kΩ 80 93 110 mA 0.93 1.00 1.07 V 140 500 uA ISPLYCHRG Charge Mode Supply Current IBATCHRG Charge Mode Battery Current VPROGCHRG PROG Pin Voltage RPROG=10kΩ ISPLYSTBY Standby Mode Supply Current Charge Terminated IBATSTBY Standby Mode Battery Current Charge Terminated 0 -2.5 -6 uA ISPLYASD Shutdown Mode Supply Current VCC
WS4508S-8/TR 价格&库存
很抱歉,暂时无法提供与“WS4508S-8/TR”相匹配的价格&库存,您可以联系我们找货
WS4508S-8/TR
    • 5+0.94900
    • 50+0.82869
    • 150+0.77717
    • 500+0.71291
    • 2500+0.68429
    库存:3357
