LM7905T
LM7905T
    HGSEMI(华冠)
    TO220-3
    LM7905T
LM7905T 数据手册
LM79xx FEATURES     Output current in excess of 1.0A Internal short current circuit limiting Internal thermal overload protection Output voltage offered of 4% tolerance ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM7905T TO220-3L LM7905 TUBE 1000pcs/box LM7906T TO220-3L LM7906 TUBE 1000pcs/box LM7908T TO220-3L LM7908 TUBE 1000pcs/box LM7912T TO220-3L LM7912 TUBE 1000pcs/box LM7915T TO220-3L LM7915 TUBE 1000pcs/box LM7918T TO220-3L LM7918 TUBE 1000pcs/box LM7924T TO220-3L LM7924 TUBE 1000pcs/box LM7905S/TR TO263-3L LM7905 REEL 500 pcs/reel LM7906S/TR TO263-3L LM7906 REEL 500 pcs/reel LM7908S/TR TO263-3L LM7908 REEL 500 pcs/reel LM7912S/TR TO263-3L LM7912 REEL 500 pcs/reel LM7915S/TR TO263-3L LM7915 REEL 500 pcs/reel LM7918S/TR TO263-3L LM7918 REEL 500 pcs/reel LM7924S/TR TO263-3L LM7924 REEL 500 pcs/reel PIN CONFIGURATION Output Output Input Input GND GND TO220-3 http://www.hgsemi.com.cn TO263-3 1/7 2022 JAN LM79xx ABSOLUTE MAXIMUM RATINGS Condition Maximum input voltage at TJ=25°C Maximum operating junction temperature Min Max -35V +125℃ ELECTRICAL CHARACTERISTICS LM7905 (VIN= -10V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO Line Regulation ∆UV Load Regulation ∆UI Quiescent Current IB Quiescent Current Change ∆IB TEST CONDITION -7.0V  VIN  -20V 5.0mA  IO  1.0 A IO = 100mA, -7.0V VIN  -25V IO = 100mA, -8.0V VIN  -12V IO = 500mA, -7.0V VIN  -25V IO = 500mA, -8.0V VIN  -12V 5.0mA IO  1.5 A 250mA IO  750mA NORMS Min Max -4.82 -5.18 47.5 23.5 95 47.5 95 47.5 7.8 1.25 0.48 -7.0V  VIN  -25V 5.0mA  IO  1.5 A UNIT V mV mV mA mA ELECTRICAL CHARACTERISTICS LM7906 (VIN= -11V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -8.0V  VIN  -21V5.0mA IO 1.0 A Line Regulation ∆UV IO = 100mA, -8.0V  VIN  -25V IO = 100mA, -9.0V  VIN  -13V IO = 500mA,-8.0V  VIN  -25V IO = 500mA, -9.0V  VIN  -13V Load Regulation ∆UI 5.0mA IO  1.5 A 250mA IO  750mA Quiescent Current Quiescent Current Change http://www.hgsemi.com.cn IB ∆IB -8.0V  VIN  -25V 5.0mA IO  1.5 A 2/7 NORMS Min Max -5.77 UNIT -6.23 V 57 28.5 114 57 mV 114 57 mV 7.8 mA 1.25 0.48 mA 2022 JAN LM79xx ELECTRICAL CHARACTERISTICS LM7908 (VIN= -14V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -10.5V  VIN  -23V 5.0mA IO  1.0 A Line Regulation ∆UV IO = 100mA, -10.5V  VIN  -25V IO = 100mA, -11V  VIN  -17V IO = 500mA, -10.5V VIN  -25V IO = 500mA, -11V VIN  -17V Load Regulation ∆UI 5.0mA IO  1.5 A 250mA IO  750mA Quiescent Current Quiescent Current Change NORMS Min Max -7.72 IB ∆IB -10.5V  VIN  -25V 5.0mA IO  1.5 A UNIT -8.28 V 76 38 152 76 mV 152 76 mV 7.8 mA 0.98 0.48 mA ELECTRICAL CHARACTERISTICS LM7912 (VIN= -19V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -14.5V  VIN -21V 5.0mA  IO  1.0 A Line Regulation ∆UV IO = 100mA, -14.5V  VIN  -30V IO = 100mA, -16V  VIN  -22V IO = 500mA, -14.5V  VIN  -30V IO = 500mA, -16V  VIN  -22V Load Regulation ∆UI 5.0mA  IO  1.5 A 250mA  IO  750mA Quiescent Current Quiescent Current Change http://www.hgsemi.com.cn IB ∆IB -14.5V  VIN  -30V 5.0mA  IO  1.5 A 3/7 NORMS Min Max -11.52 UNIT -12.48 V 114 58.5 228 114 228 114 mV 7.8 mA 1.25 0.48 mA mV 2022 JAN LM79xx ELECTRICAL CHARACTERISTICS LM7915 (VIN= -23V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -17.5V  VIN  -30V 5.0mA  IO  1.0 A -14.44 Line Regulation ∆UV IO = 100mA, -17.5V  VIN  -30V IO = 100mA, -20V  VIN  -26V IO = 500mA, -17.5V  VIN  -30V IO = 500mA, -20V  VIN  -26V Load Regulation ∆UI 5.0mA  IO  1.5 A 250mA  IO  750mA Quiescent Current Quiescent Current Change NORMS Min Max IB ∆IB -17.5V  VIN  -30V 5.0mA IO  1.5 A UNIT -15.56 V 142 71 285 142 mV 285 142 mV 7.8 mA 0.98 0.48 mA ELECTRICAL CHARACTERISTICS LM7918 (VIN= -27V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -21V  VIN  -33V 5.0mA  IO  1.0 A Line Regulation ∆UV IO = 100mA, -21V  VIN IO = 100mA, -24V  VIN IO = 500mA, -21V  VIN IO = 500mA, -24V  VIN Load Regulation ∆UI 5.0mA IO  1.5 A 250mAIO  750mA Quiescent Current Quiescent Current Change http://www.hgsemi.com.cn IB ∆IB -21V  VIN  -33V 5.0mA  IO  1.5 A 4/7 NORMS Min Max -17.34  -33V  -30V  -33V  -30V UNIT -18.66 V 171 85.5 342 171 mV 342 171 mV 7.8 mA 0.98 0.48 mA 2022 JAN LM79xx ELECTRICAL CHARACTERISTICS LM7924 (VIN= -33V, IO = 500mA, CIN=2.2µF, CO=1.0µF, TJ=25°C, unless otherwise noted) CHARACTERISTIC Output Voltage SYMBOL VO TEST CONDITION -27V  VIN  -38V 5.0mA  IO  1.0 A Line Regulation ∆UV IO = 100mA, -27V  VIN  -38V IO = 100mA, -30V  VIN  -36V IO = 500mA, -27V  VIN  -38V IO = 500mA, -30V  VIN  -36V Load Regulation ∆UI 5.0mA  IO  1.5 A 250mA  IO  750mA Quiescent Current Quiescent Current Change http://www.hgsemi.com.cn IB ∆IB -27V  VIN  -33V 5.0mA  IO  1.5 A 5/7 NORMS Min Max -23.05 UNIT -24.95 V 228 114 446 228 mV 446 228 mV 7.8 mA 0.98 0.48 mA 2022 JAN LM79xx Physical Dimensions TO263-3 a Dimensions In Millimeters(TO263-3) A A1 B C D D1 E F G a Min: 4.45 1.22 10 1.89 13.7 8.38 0 8.332 7.70 0.71 Max: 4.62 1.32 10.4 2.19 14.6 8.89 0.305 8.552 8.10 0.97 Symbol: b 2.54BSC TO220-3 Dimensions In Millimeters(TO220-3) A A1 B D D1 D2 F G a d b Min: 4.45 1.22 10 13.7 22.42 8.50 8.30 12.55 0.71 0.33 2.54BS Max: 4.62 1.32 10.4 14.6 22.62 9.10 8.55 12.75 0.97 0.42 C Symbol: http://www.hgsemi.com.cn 6/7 q 3.80TYP 2022 JAN LM79xx IMPORTANT STATEMENT: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the onsequences of the application of these products in these fields. Huaguan Semiconductor Co,Ltd. the performance of the semiconductor products produced by the company can reach the performance indicators that can be applied at the time of sales. The use of testing and other quality control technologies is limite d to the quality assurance scope of Huaguan semiconductor. Not all parameters of each device need to be tested. The above documents are for reference only, and all are subject to the physical parameters. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 7/7 2022 JAN
LM7905T 价格&库存
很抱歉,暂时无法提供与“LM7905T”相匹配的价格&库存,您可以联系我们找货
LM7905T
  • 5+1.45887
  • 50+1.18671
  • 150+1.07007
  • 500+0.92459
  • 2000+0.85979
  • 5000+0.82091
