PA8SO1-2006-3
PA8SO1-2006-3
    LOGICALSYSTEMS(Logical Systems)
    ADAPTER 8-SOIC TO 8-DIP
PA8SO1-2006-3 数据手册
PAxxSO1-2006-3 or -6 Data Sheet 8-20 Pin SOP socket/8-20 Pin DIP 0.3" or 0.6" plug Supported Device/Footprints Adapter Dimensions Using this adapter, many SOP packaged devices can be programmed on DIP programmers. The SOP socket accepts packages with the dimensions listed below: Body mm (inches) Knee mm (inches) min. typ. max. min. typ. max. 4.9 5.3 5.4 n/a 6.8 7.1 (0.193) (0.209) (0.213) (0.268) (0.279) Tip mm (inches) min. 7.65 (0.301) typ. 7.8 (0.307) Body Length max. n/a n/a PA8SO1-2006-3 Lead Pitch 1.27 (0.50) Adapter Construction The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced easily. PA8SO1-2006-6 When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. The following chart shows the various socket and board part numbers that make us these adapters. Adapter Socket Board PA8SO1-2006-3 8(20H)SD-06 FP8-06-3 PA8SO1-2006-6 8(20H)SD-06 FP8-06-6 PA14SO1-2006-3(6) 14(20H)SD-06 FP20-06-14-3(6) PA16SO1-2006-3(6) 16(20H)SD-06 FP20-06-16-3(6) PA18SO1-2006-3(6) 18(20H)SD-06 FP20-06-18-3(6) PA20SO1-2006-3(6) 20SD-06 FP20-06-3(6) Test Socket LSC # 20SD-06 xx(20H)SD-06 PAxxSO1-2006-3 or -6 Adapter Wiring Style Lidded ZIF Lidded ZIF Mfgr/Pn Enplas FP-20-1.27-06 Enplas FP-xx(20H)-1.27-06 The adapter is wired 1-1. Pin 1 of the device connects to pin 1 of the DIP footprint, pin 2 to pin 2, and so on around the adapter. The 20 pin socket is depopulated for the lower pin counts. It is depopulated at the Pin 1 end. If you remove the socket be sure to replace it with the latch as shown in the picture. Circuit Board The 14 through 20 pin adapters are built using the same circuit board: FP20-06. The board is depopulated at the Pin 1 end. The various part numbers for this board are listed in the part number chart above. Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PAxxSO1-2006-3(6) Data Sheet Doc: 2006.DOC Rev: 10/05/00 Page 1 of 1
PA8SO1-2006-3 价格&库存
很抱歉,暂时无法提供与“PA8SO1-2006-3”相匹配的价格&库存,您可以联系我们找货
